Im having trouble getting mpd to work after a recent update.
The output of systemctl status mpd, which is running:
Mar 13 08:09:01 s-pc mpd[3150]: decoder: Decoder plugin 'wildmidi' is unavailable: configuration file does not exis>
Mar 13 08:09:01 s-pc mpd[3150]: config: Found database setting without music_directory - disabling database
Mar 13 08:09:01 s-pc mpd[3150]: output: No 'audio_output' defined in config file
Mar 13 08:09:01 s-pc mpd[3150]: ALSA lib pcm_dmix.c:1032:(snd_pcm_dmix_open) unable to open slave
Mar 13 08:09:01 s-pc mpd[3150]: alsa_output: Error opening default ALSA device: No such file or directory
Mar 13 08:09:01 s-pc mpd[3150]: oss_output: Error opening OSS device "/dev/dsp": No such file or directory
Mar 13 08:09:01 s-pc mpd[3150]: oss_output: Error opening OSS device "/dev/sound/dsp": No such file or directory
Mar 13 08:09:01 s-pc mpd[3150]: output: Successfully detected a jack audio device
Mar 13 08:09:01 s-pc mpd[3150]: zeroconf: No global port, disabling zeroconf
Mar 13 08:09:01 s-pc systemd[1]: Started Music Player Daemon.
And my mpd config:
type or paste code here music_directory "~/Music"
playlist_directory "~/Music/Playlists"
db_file "~/.config/mpd/mpd.db"
pid_file "~/.config/mpd/mpd.pid"
state_file "~/.config/mpd/mpdstate"
sticker_file "~/.config/mpd/sticker.sql"
log_file "syslog"
user "s"
bind_to_address "any"
port "6600"
restore_paused "yes"
metadata_to_use "artist,album,title,track,name,genre,date,composer,performer,disc"
auto_update "yes"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
save_absolute_paths_in_playlists "no"
#replaygain "track"
#replaygain_preamp "0"
volume_normalization "yes"
zeroconf_enabled "yes"
zeroconf_name "Music Player"
audio_output {
type "alsa"
name "ALSA Output"
device "hw:0,0" # optional
#format "44100:16:2" # optional
#mixer_device "default" # optional
#mixer_control "PCM" # optional
#mixer_index "0" # optional
mixer_type "software" # optional
audio_output {
type "pulse"
name "PulseAudio Output"
audio_output {
type "httpd"
name "HTTP Stream"
encoder "vorbis" # optional, vorbis or lame
port "8080"
quality "5.0" # do not define if bitrate is defined
# bitrate "128" # do not define if quality is defined
format "44100:16:1"
max_clients "0" # optional 0=no limit
