Hello,
yesterday I installed manjaro-gnome-24.0-240513-linux69 via usb stick on my old MacBook Pro (2010, 2,4 GHZ Intel core i5, 8GB DDR, Intel hd graphics 288 MB). This has worked so far Aires, but the mouse pointer (touchpad) keeps hanging up and the whole computer freezes.
1st mouse connected with usb cable, unfortunately the same effect
2. old kernel 5.4 installed, unfortunately no change
Itâs the graphics, your Intel hd graphics arenât up to such a sophisticated desktop as Gnome. Try Xfce, it will run fine. Best start with the minimal edition and add what you need.
To make sure you donât run into similar issues there check Control Centre >> Window Manager Tweaks >> Compositor. Remove as many eye candy features as possible (maybe leave the top 1 or 2 on) and set transparency sliders to âopaqueâ and all should be well.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; itâs always best to check those announcements.
