Hi,
Lately I’ve been seeing that Battery charging limit setting in KDE plasma does not persist, so I tried the solution present in this link: https://forum.manjaro.org/t/laptop-battery-charging-limit/138704
The basic gist of it was to create a systemd service that manually sets the value in sys/class/power_supply/BAT1/charge_control_end_threshold on boot. This solution had been working fine until I installed tuf-manager from AUR and uninstalled it since it wasn’t able to set the inbuilt keyboard RGB modes.
Currently, the file sys/class/power_supply/BAT1/charge_control_end_threshold is missing and I’m unable to create it even as root. The setting to set charge limit is missing even from plasma settings.
Pls help out
If it’s missing, creating it would be useless. The file should be present if the property is detected in the first place. Check first what you have in /sys/class/power_supply (i.e.: ls /sys/class/power_supply). BAT1 is rather strange, unless your device has 2 batteries as the counting starts from 0.
ls /sys/class/power_supply yields the following output:
ACAD BAT1
It is kinda strange, but that wouldn’t make the charge_control_end_threshold to disappear.
ls /sys/class/power_supply/BAT1 gives this output:
alarm capacity_level charge_full_design current_now device manufacturer power serial_number subsystem type voltage_min_design
capacity charge_full charge_now cycle_count hwmon2 model_name present status technology uevent voltage_now
Welcome to the forum!
Either your laptop manufacturer included battery charging limit support or they didn’t. If it does, then it’s up to the kernel to detect it. Nothing to do with the Desktop Environment.
Please post your system info as outlined here:
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY …
Please also see:
What’s the output of:
ls /sys/class/power_supply/BAT1 | grep charge
If there is support, then you should see output like I see on my System76 Gazelle (gaze17-3060-b) :
charge_control_start_threshold
charge_full
charge_full_design
charge_now
Pulled system information using the inxi -v7azy command. It’s output is as follows:
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=c7a59d06-b0cc-41da-beb5-2288d0a7c2f3 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QM_FA506QM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506QM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: FA506QM.314 date: 01/07/2023
ID-1: BAT1 charge: 86.2 Wh (100.0%) condition: 86.2/90.2 Wh (95.5%)
volts: 17.3 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
System RAM: available: 15.03 GiB used: 13.08 GiB (87.0%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Micron Technology
part-no: 8ATF1G64HZ-3G2R1 serial: <filter>
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1593 high: 3300 min/max: 1200/4679 boost: enabled
base/boost: 3300/4650 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3300 2: 1200 3: 1200 4: 1200
5: 3300 6: 1200 7: 1200 8: 3300 9: 1200 10: 1200 11: 1200 12: 1200 13: 1200
14: 1200 15: 1200 16: 1200 bogomips: 105453
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 54.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 322e:202c
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.70 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3563
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.38 TiB used: 153.74 GiB (10.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B00
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7201Q temp: 31.9 C
scheme: GPT
SMART: yes health: PASSED on: 15d 3h cycles: 1,065
read-units: 8,512,737 [4.35 TB] written-units: 5,728,168 [2.93 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
family: Blue Mobile (SMR) size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 1214
drive-rev: 05.01A05 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 210d 23h cycles: 1673 Old-Age:
UDMA CRC errors: 934 alert: Bad cable/connection?
ID-1: / raw-size: 46.83 GiB size: 45.79 GiB (97.79%) used: 26.36 GiB (57.6%)
fs: ext4 block-size: 4096 B dev: /dev/sda4 maj-min: 8:4 label: man-root
uuid: c7a59d06-b0cc-41da-beb5-2288d0a7c2f3
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 288 KiB (0.0%)
fs: vfat block-size: 512 B dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: B039-A6FC
ID-3: /run/media/darshk/Data raw-size: 244.14 GiB
size: 244.14 GiB (100.00%) used: 127.38 GiB (52.2%) fs: ntfs
block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4 label: Data
uuid: 863608C43608B769
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: 088D-2880
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 209.55 GiB fs: ntfs label: OS
uuid: BC748F21748EDD90
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 800 MiB fs: ntfs label: RECOVERY
uuid: 20AAC624AAC5F5F6
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 22 GiB fs: ntfs label: RESTORE
uuid: 2E86234786230EC1
ID-6: /dev/nvme0n1p7 maj-min: 259:7 size: 200 MiB fs: vfat label: MYASUS
uuid: 3E23-8D8B
ID-7: /dev/sda1 maj-min: 8:1 size: 634.95 GiB fs: ntfs label: Games
uuid: 72C28F7DC28F43F7
ID-8: /dev/sda2 maj-min: 8:2 size: 201.17 GiB fs: ntfs label: Movies
uuid: A8C4BA68C4BA3880
ID-9: /dev/sda3 maj-min: 8:3 size: 46.56 GiB fs: ntfs label: Backups
uuid: 0F040E1766C8BF13
Device-1: 1-1:2 info: JMicron / USA Gen1 SATA 6Gb/s Bridge
type: mass storage driver: uas interfaces: 1 rev: 2.1
chip-ID: 152d:0576 class-ID: 0806 serial: <filter>
Device-2: 1-2:3 info: Logitech G402 Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07e class-ID: 0300
serial: <filter>
Device-3: 1-4:4 info: Sonix USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 322e:202c class-ID: 0e02
Device-1: 3-2:2 info: SINO WEALTH Gaming KB type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-2: 3-3:3 info: IMC Networks Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
System Temperatures: cpu: 59.6 C mobo: N/A gpu: amdgpu temp: 55.0 C
Processes: 360 Uptime: 1h 18m wakeups: 2 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 12
clang: 15.0.7 Packages: pm: pacman pkgs: 1351 libs: 376 tools: pamac
pm: flatpak pkgs: 0 Shell: Bash (sudo) v: 5.1.16 running-in: konsole
inxi: 3.3.27
The output of ls /sys/class/power_supply/BAT1 grep charge is as follows:
charge_full
charge_full_design
charge_now
It’s missing these:
You can try setting the values manually as ASUS laptops seem to support it See: Laptop/ASUS - ArchWiki
