After the recent OS Upgrade (Pahvo) my Spotify (Snap) Application Icons have gone missing (Workspace Switcher,Window Cycling,Title bar, Window Menu).
What’s surprising is that the Window Button’s icon is still in place. (although I think it’s also a bit different now)
Having the same issue with Microsoft Teams - but already way before the upgrade.
Thank you so much for any help on this!
Fabby
18 September 2021 08:20
2
Welcome to Manjaro!
I have read this already and left you just a as I don’t use and don’t like snaps (and I’m on KDE)
However, as you haven’t received any responses so far:
Have you tried using a native application instead of a snap already? (E.G From the AUR )
Hey Fabby,
glad to be on board!
So far I tried flatpak and AUR as alternative. both display the same issue.
Fabby
22 September 2021 22:24
4
Then the only thing to do is to read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
Especially the What’s this Upstream / Downstream business section and file a bug upstream…
Please note that a quality bug needs the same kind of information we require here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
I assume it’s an upstream issue (yeah, I learned a new term! Merci )
Same/Similar issue seems to exist on Fedora and KDE. Also this happened after they updated the application. Snap, flatpak and AUR got updated nearly simultaneously and are all based on the same .deb image i guess?
I reported it on the spotify community.
when running spotify via terminal that’s the output (using AUR):
/opt/spotify/spotify: /usr/lib/libcurl-gnutls.so.4: no version information available (required by /opt/spotify/spotify)
/proc/self/exe: /usr/lib/libcurl-gnutls.so.4: no version information available (required by /proc/self/exe)
Even though I guess it cant be fixed here, still here’s my inxi output:
Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=da7cfa18-3d1b-4ba2-874d-965399aeaeec ro quiet apparmor=1
security=apparmor resume=UUID=dac21756-7942-48b3-8aa0-9246f911e961
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
RAM: total: 15.55 GiB used: 2.82 GiB (18.1%)
Info: Quad Core model: Intel Core i7-8809G bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
cache: L2: 8 MiB bogomips: 49618
Speed: 800 MHz min/max: 800/8300 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0380
Device-2: AMD Polaris 22 XT [Radeon RX Vega M GH] vendor: Intel
driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:694c class-ID: 0300
bus-ID: 1-3:2 chip-ID: 045e:0761 class-ID: 0102
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: DisplayPort-2 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-2: DisplayPort-5 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: AMD VEGAM (DRM 3.42.0 5.14.2-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Processes: 258 Uptime: 11h 48m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1195 pacman: 1180 lib: 356
flatpak: 7 snap: 8 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
inxi: 3.3.06
Still any Idea or suggestion how to proceed? Merci
Fabby
24 September 2021 21:19
6
De rien…
Therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
system
Closed
27 September 2021 11:20
7
