Hello Manjarians,
this problem has been apparent since I replaced my Arch install with Manjaro XFCE. I can’t find any clues in the journal or in any settings that I’m aware of. After each boot I’ve to use alsamixer to unmute the mic boost so I’m audible to my conversational partner. Audio on Linux has been an Overfiend for me since the beginning and I’m at a loss on debugging this. To start I posted my (somewhat custom PA) daemon.conf, pactl info and the obligatory inxi output. Some insight will be much appreciated!
cat .config/pulse/daemon.conf
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
resample-method = speex-float-5
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
default-sample-format = s24le
default-sample-rate = 96000
alternate-sample-rate = 48000
default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 33
Server Protocol Version: 33
Is Local: yes
Client Index: 64
Tile Size: 65472
User Name: manjarist
Host Name: manjarum
Server Name: pulseaudio
Server Version: 13.0
Default Sample Specification: s24le 2ch 96000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_07_04.0.iec958-stereo
Default Source: alsa_input.pci-0000_07_04.0.analog-stereo
Cookie: 7c1b:742b
"inxi -Fazy"
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=f7f8a12c-0cdd-4456-88d9-daf2c5643027 rw
resume=UUID=6b16004a-0720-4947-914a-f3feba91ebb2 udev.log_priority=3
Desktop: sway 1.5 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: 990XA-UD3 v: x.x serial: <filter>
UEFI: American Megatrends v: FD date: 02/04/2013
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: Discharging
Topology: 8-Core model: AMD FX-8320E bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: N/A microcode: 6000852
L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 56283
Speed: 1479 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
1: 1422 2: 1493 3: 1626 4: 1677 5: 1465 6: 1441 7: 2920 8: 2632
disabled, RSB filling
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Tul driver: amdgpu v: kernel bus ID: 01:00.0 chip ID: 1002:67df
Display: server: X.Org 1.20.8 compositor: sway v: 1.5 driver: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: XWAYLAND0 res: 1920x1200 hz: 60 dpi: 94
size: 520x330mm (20.5x13.0") diag: 616mm (24.2")
OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.38.0
5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Tul driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aaf0
Device-2: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus ID: 07:04.0 chip ID: 13f6:8788
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Intel 82574L Gigabit Network driver: e1000e v: 3.2.6-k port: d000
bus ID: 02:00.0 chip ID: 8086:10d3
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
vendor: Gigabyte driver: r8169 v: kernel port: c000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 12.00 TiB used: 7.39 TiB (61.6%)
ID-1: /dev/sda vendor: Samsung model: SSD 830 Series size: 119.24 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 3B1Q scheme: GPT
ID-2: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 023 scheme: GPT
ID-3: /dev/sdc vendor: HGST (Hitachi) model: HDN724040ALE640 size: 3.64 TiB
rotation: 7200 rpm serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdd vendor: HGST (Hitachi) model: HDN724040ALE640 size: 3.64 TiB
ID-5: /dev/sde vendor: HGST (Hitachi) model: HDN724040ALE640 size: 3.64 TiB
ID-6: /dev/sdf type: USB vendor: Kingston model: HyperX Savage
size: 58.62 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: PMAP scheme: MBR
Supported md-raid types: raid6 raid5 raid4
Device-1: md0 type: mdraid status: active Components:
online: sdc1~c5 sde1~c3 sdd1~c4
Info: raid: raid-5 blocks: 7813568000 report: 3/3 UUU chunk size: 256k
super blocks: 1.2 algorithm: 2
ID-1: / raw size: 110.15 GiB size: 107.92 GiB (97.98%)
used: 21.68 GiB (20.1%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 40.1 C mobo: N/A gpu: amdgpu temp: 62 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 424
Processes: 265 Uptime: 3h 02m Memory: 15.66 GiB used: 5.25 GiB (33.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1324 lib: 424
Shell: Zsh v: 5.8 running in: alacritty inxi: 3.1.05
