Manjaro XFCE fails to boot after upgrade (maybe TIFU)
Hello everyone
Manjaro has been my daily driver for a long time. I’m really pleased with it, but I think I killed it by accident!
I upgraded my system using the app in XFCE for that kind of thing. However, it kept complaining about a JDK or JRE that was needed for some old version of Electron.
I nuked the orphan packages using this command (I think - can’t remember)
sudo pacman -R $(pacman -Qtdq)
I then updated the system, and it finished with success notifying me that I had to reboot. It was here the trouble started.
When I reboot, the system keeps taking me into the BIOS settings.
Hitting ESC during boot takes me into the GRUB menu that have two entries:
  1. UEFI Firmware Settings
  2. Memory Tester (memtest86+)
Hitting E for Edit boot options revel this content:
setparams 'UEFI Firmware Settings'
                         fwsetup
When following the normal boot sequence I get send into the BIOS right away without any visible errors.
I have a Debian LiveUSB and can see my system files when I mount the partition.
How can I diagnose the problem, with logs and so on, so that I can get a minimal working system?
Any help greatly appriciated!
In the grub command line:
grub> ls
(hd0) (hd0,gpt3) (hd0,gpt2) (hd0,gpt1)
Ok something is there let’s explore!
grub>ls (hd0)/
error: unknown file system (translated from Danish)
grub> ls (hd0,gpt1)/
efi/
grub>ls (hd0,gpt2)/
lost+found/ boot/ dev/ proc/ run/ (cutting it short - this is the partition for the system)
grub>ls (hd0,gpt3)/
The efi folder in (hd0,gpt1) is organized like this:
efi/boot/bootx64.efi
efi/boot/Manjaro/grubx64.efi
I then tried this out:
set root=(hd0,gpt1)
insmod linux
insmod normal
normal
And the system booted - directly into the BIOS…
Hello @Markowitch :wink:
For some reason, Grub was not updated on your system. Update once in a Manjaro live session: GRUB/Restore the GRUB Bootloader - Manjaro If you only have a Debian live session available, you will need to chroot (switch to the local installation) manually.
Thanks for the reply @megavolt
I’ll start the Debian LiveUSB
(for some reason I can’t download ISO’s from manjaro.org. Transfers grind to a halt after the first 40MB)
> sudo /sbin/fdisk -l
A lot of text
Disk /dev/nvme0n1
Device  ... Type
/dev/nvme0n1p1  EFI system
/dev/nvme0n1p2  Linux filesystem
/dev/nvme0n1p3  Linux Swap
Skipping info about the LiveUSB which is on /dev/sda
So I will ´chroot´ to the local installation. But I’m not sure how to? I got the chroot command on the LiveUSB, but I guess I should mount the EFI system and the linux filesystem?
The ISO from the website is provided using CDN77.
Perhaps try the manjaro-get-iso script (python) which also pulls the official using CDN but provides also release review and developer preview options.
Applications / Manjaro Get Iso · GitLab
[root tip] [recovery] Basic Manjaro Linux Recovery
No, first Linux, then EFI.
sudo mount /dev/nvme0n1p2 /mnt
sudo mount /dev/nvme0n1p1 /mnt/boot/efi
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys /mnt/sys
sudo mount --bind /run /mnt/run
sudo chroot /mnt /usr/bin/bash
In chroot:
mkinitcpio -P
grub-mkconfig -o /boot/grub/grub.cfg
exit
Thanks for the details @megavolt
In the meantime I tried the download from cdn77 on another computer, and it worked. So now I’m burning a manjaro XFCE LiveUSB with Rufus on Win.
Rufus is a bit weird. It will not make a bootable LiveUSB from the Manjaro iso
manjaro-xfce-24.2.1-241216-linux612.iso
So I used Ventoy, which makes the USB bootable and lets you copy ISO files to it, that you can choose in the startup menu on boot time.
Yes - the rufus developer(s) is not fond of Manjaro - because the team won’t change the ISO layout just to support Rufus tool.
The ISO files have not been made compatible with ISO/File copy mode - #8 by nikgnomic
When I last checked - years ago - Rufus switch to dd mode when the filesystem contains manjaro’s filesystem
Ventoy is the recommended tool - you may have to check if using grub mode is better than default.
Plain old dd also work.
Ok @megavolt I’m back with another question.
I’ve booted Manjaro from the USB (using Ventoy to select the ISO)
I got the XFCE desktop and opened a terminal.
> manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
root# pacman -Syu grub
// Skipping a lot of output
root# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Intstallation finished. No error reported
Following the how-to I also have to make sure the configuration is up to date
root# grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file ....
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, pleas file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image /boot/memtest86+/memtest.efi
done
I guess it found some strange stuff and bailed. The system still reboots into BIOS.
According to the above how-to the problem could also be resolved by updating GRUB, so that’s what I’ll try.
Boot into the LiveUSB and start a terminal.
> manjaro-chroot -a
 --> mount: [/mnt]
root # pacman -Syu install-grub
// skipping output
Packages (1) install-grub-2:2.12-3
// skipping output
root # install-grub
WARNING: EFI directroy not found! Grub couldn't be installed.
I’m a bit lost… maybe I overlooked something in the how-to…
Interesting… what is output of:
Seems like there are no boot images at /boot to boot from.
Ok, let’s try it (did a chroot prior)
root# mkinitcpio -P
==> ERROR: No presets found in /etc/mkinitcpio.d
@megavolt I assume I have an EFI system and not a BIOS system (the how-to mention those) because this path exists /sys/firmware/efi (while chroot).
root# /etc/mkinitcpio.d/linux65.preset.pacsave
# mkinitcpio preset file for the '6.5-x86_64' package
#ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-6.5-x86_64"
ALL_microcode=(/boot/*-ucode.img)
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-6.5-x86_64.img"
#default_uki="/efi/EFI/Linux/manjaro-6.5-x86_64.efi"
#default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp"
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-6.5-x86_64-fallback.img"
#fallback_uki="/efi/EFI/Linux/manjaro-6.5-x86_64-fallback.efi"
fallback_options="-S autodetect"
I assume there is no kernel installed, Linux 6.5 is long EOL and I suppose it was removed on that upgrade. It was an stable kernel and not a long term support one (LTS). Install linux66 (which is LTS):
mhwd-kernel --install linux66
Take a look here: https://www.kernel.org/
Ok, I kept my system updated frequently.
[manjaro /]# mhwd-kernel --install linux66
 core is up to date
 extra is up to date
 multilib is up to date
error: no targets specified (use -h for help)
Extra info. With manjaro-chroot the content of ls -l /boot is:
drwxr-xr-x 3 root root    4096 Jan  1  1970 efi
drwxr-xr-x 6 root root    4096 Mar  8 13:11 grub
-rw-r--r-- 1 root root 9683968 Feb 11 18:09 intel-ucode.img
drwxr-xr-x 2 root root    4096 Mar  5 17:47 memtest86+
For the record, the command should normally be performed using sudo. :slight_smile:
In a chroot environment, however, commands should be run without sudo.
  • Note that when installing a kernel in a chroot environment, using pacman is usually suggested
Also, in case you missed the previously given link;
On the chance that the update failed in some way the following tutorial might also be useful;
Tried with sudo - same result. I am root after i did manjaro-chroot.
And check with regards to the restore GRUB bootloader link. I am reading it forwards and backwards as we speak. :slightly_smiling_face: :upside_down_face:
pacman -Sy linux66
:question:
Going in…
[manjaro /]# pacman -Sy linux66
 core is up to date
 extra is up to date
resolving dependencies...
Packages (1) linux66-6.6.80-1
Total Download Size:   129.69 MiB
Total Installed Size:  134.81 MiB
