yes, this:
pacman -Sy linux66
instead of mhwd-kernel -i ...
which for reasons I do not know doesn’t work in chroot.
yes, this:
pacman -Sy linux66
Ok done - here is the whole output
:: Retrieving packages...
linux66-6.6.80-1-x86_64 129.7 MiB 17.5 MiB/s 00:07 [######################################################] 100%
(1/1) checking keys in keyring [######################################################] 100%
(1/1) checking package integrity [######################################################] 100%
(1/1) loading package files [######################################################] 100%
(1/1) checking for file conflicts [######################################################] 100%
(1/1) checking available disk space [######################################################] 100%
(1/1) installing linux66 [######################################################] 100%
Optional dependencies for linux66
wireless-regdb: to set the correct wireless channels of your country [installed]
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.80-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64-fallback.img'
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
Ohh my, it left something for me in the /boot folder.
[manjaro /]# ls -l /boot
total 118360
drwxr-xr-x 3 root root 4096 Jan 1 1970 efi
drwxr-xr-x 6 root root 4096 Mar 8 14:45 grub
-rw------- 1 root root 78069561 Mar 8 14:45 initramfs-6.6-x86_64-fallback.img
-rw------- 1 root root 20389392 Mar 8 14:45 initramfs-6.6-x86_64.img
-rw-r--r-- 1 root root 9683968 Feb 11 18:09 intel-ucode.img
-rw-r--r-- 1 root root 21 Feb 27 14:05 linux66-x86_64.kver
drwxr-xr-x 2 root root 4096 Mar 5 17:47 memtest86+
-rw-r--r-- 1 root root 13029888 Mar 8 14:45 vmlinuz-6.6-x86_64
Those warnings are typically nothing to be concerned with.
If you can now boot then ![]()
Let the boot commence. Se you guys on the other side! ![]()
Not so fast!
Reboot first, and then;
It’s usually required that you mark the post that helped you the most as the solution.
(I note @megavolt has put some effort into this topic.)
After that, you can sail off into the sunset. ![]()
I’m back! Now on a perfectly running system. Thank you guys - you saved my day
I’ve marked @megavolt reply as the solution, but thank you all for the swift replies!
Ok - recap for others that might end up here
1: After update the system would not boot
2: Made a LiveUSB by downloading a Manjaro ISO
3: Used Ventoy instead of Rufus to transfer ISO to bootable USB
4: Installed a new kernel using pacman -Sy linux66
5: This fixed everything - even the grumpy Grub
Thanks a million, sailing off into the sunset ![]()
See you again at some fine sunrise.
