so you booted with the 5.15?
Yes. 5.15.46-1
you mentioned that this happened after update, but you run still an older kernel?
remove the 5.18 with:
sudo mhwd-kernel -r linux518
then copy the logs here from:
cat /home/test/.local/share/xorg/Xorg.1.log
I Do it.
It’s not After a kernel update but a Big update of lot of pakage in “pamac manager”. I use this computer every day, i allways do my update, but sometime there IS update of100 pakage in one Time.
[ 522.587] (II) This device may have been added with another device file.
[ 522.588] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 522.588] (II) No input driver specified, ignoring this device.
[ 522.588] (II) This device may have been added with another device file.
[ 522.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 522.589] (II) No input driver specified, ignoring this device.
[ 522.589] (II) This device may have been added with another device file.
[ 522.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 522.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 522.590] (II) No input driver specified, ignoring this device.
[ 522.590] (II) This device may have been added with another device file.
[ 522.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
[ 522.592] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 522.592] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 522.592] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 522.592] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 522.592] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 522.592] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 31 paused 0
[ 522.593] (**) dakai PS/2+USB Keyboard: always reports core events
[ 522.593] (**) Option "Device" "/dev/input/event2"
[ 522.595] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 522.595] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 522.595] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 522.595] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 522.595] (**) Option "xkb_layout" "fr"
[ 522.598] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 522.598] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 522.600] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 522.600] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 522.600] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 522.600] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 522.600] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 522.601] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 32 paused 0
[ 522.601] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 522.601] (**) Option "Device" "/dev/input/event3"
[ 522.605] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 522.606] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 522.606] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 522.606] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 522.606] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 522.607] (**) Option "AccelerationScheme" "none"
[ 522.607] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 522.607] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 522.607] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 522.610] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 522.611] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 522.613] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 522.613] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 522.614] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 522.614] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 522.614] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 522.615] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 522.615] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 522.615] (**) Option "Device" "/dev/input/event4"
[ 522.618] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 522.618] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 522.619] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 522.619] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 522.619] (**) Option "xkb_layout" "fr"
[ 522.622] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 522.622] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 522.624] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 522.624] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 522.624] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 522.624] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 522.624] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 522.625] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[ 522.625] (**) dakai PS/2+USB Keyboard: always reports core events
[ 522.625] (**) Option "Device" "/dev/input/event5"
[ 522.627] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 522.627] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 522.628] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 522.628] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 522.628] (**) Option "xkb_layout" "fr"
[ 522.630] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 522.630] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 522.631] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 522.631] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 522.631] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 522.631] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 522.687] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 522.687] (**) USB OPTICAL MOUSE : always reports core events
[ 522.687] (**) Option "Device" "/dev/input/event6"
[ 522.691] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 522.692] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 522.692] (II) event6 - USB OPTICAL MOUSE : device removed
[ 522.692] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 522.693] (**) Option "AccelerationScheme" "none"
[ 522.693] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 522.693] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 522.693] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 522.697] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 522.697] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 522.700] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 522.700] (II) No input driver specified, ignoring this device.
[ 522.700] (II) This device may have been added with another device file.
[ 522.701] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 522.701] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 522.701] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 522.701] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 522.701] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 522.703] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 522.703] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 522.703] (**) Option "Device" "/dev/input/event7"
[ 522.706] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 522.706] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 522.707] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 522.707] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 522.707] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 522.707] (**) Option "AccelerationScheme" "none"
[ 522.707] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 522.707] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 522.707] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 522.710] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 522.710] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 522.713] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event8)
[ 522.713] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 522.713] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 522.713] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "system-keyboard"
[ 522.713] (II) Using input driver 'libinput' for 'C-Media Electronics Inc. USB Audio Device'
[ 522.714] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 37 paused 0
[ 522.714] (**) C-Media Electronics Inc. USB Audio Device: always reports core events
[ 522.714] (**) Option "Device" "/dev/input/event8"
[ 522.716] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 522.717] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 522.717] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 522.717] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0014.0005/input/input11/event8"
[ 522.717] (**) Option "xkb_layout" "fr"
[ 522.720] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 522.720] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 522.721] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event17)
[ 522.721] (II) No input driver specified, ignoring this device.
[ 522.721] (II) This device may have been added with another device file.
[ 522.721] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event18)
[ 522.722] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event19)
[ 522.722] (II) No input driver specified, ignoring this device.
[ 522.722] (II) This device may have been added with another device file.
[ 522.722] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event20)
[ 522.723] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event21)
[ 522.723] (II) No input driver specified, ignoring this device.
[ 522.723] (II) This device may have been added with another device file.
[ 522.724] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 522.724] (II) No input driver specified, ignoring this device.
[ 522.724] (II) This device may have been added with another device file.
[ 522.733] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 522.733] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 522.733] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 522.733] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 522.733] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 522.733] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 522.733] (**) Option "Device" "/dev/input/event3"
[ 522.733] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 522.733] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 522.733] (**) Option "xkb_layout" "fr"
[ 522.733] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 522.733] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 522.733] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 522.733] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 522.733] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 522.733] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 522.733] (**) Option "Device" "/dev/input/event7"
[ 522.733] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 522.733] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 523.734] (**) Option "fd" "27"
[ 523.734] (II) event1 - Power Button: device removed
[ 523.734] (**) Option "fd" "30"
[ 523.734] (II) event0 - Power Button: device removed
[ 523.734] (**) Option "fd" "31"
[ 523.734] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 523.735] (**) Option "fd" "32"
[ 523.735] (**) Option "fd" "33"
[ 523.735] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 523.735] (**) Option "fd" "34"
[ 523.735] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 523.735] (**) Option "fd" "35"
[ 523.735] (II) event6 - USB OPTICAL MOUSE : device removed
[ 523.735] (**) Option "fd" "36"
[ 523.735] (**) Option "fd" "37"
[ 523.735] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 523.735] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 523.736] (**) Option "fd" "36"
[ 523.736] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 523.738] (II) UnloadModule: "libinput"
[ 523.738] (II) systemd-logind: not releasing fd for 13:71, still in use
[ 523.738] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 523.738] (II) systemd-logind: releasing fd for 13:72
[ 523.783] (II) UnloadModule: "libinput"
[ 523.783] (II) systemd-logind: releasing fd for 13:71
[ 523.807] (II) UnloadModule: "libinput"
[ 523.807] (II) systemd-logind: releasing fd for 13:70
[ 523.840] (II) UnloadModule: "libinput"
[ 523.840] (II) systemd-logind: releasing fd for 13:69
[ 523.857] (II) UnloadModule: "libinput"
[ 523.857] (II) systemd-logind: releasing fd for 13:68
[ 523.873] (II) UnloadModule: "libinput"
[ 523.873] (II) systemd-logind: releasing fd for 13:67
[ 523.890] (II) UnloadModule: "libinput"
[ 523.890] (II) systemd-logind: releasing fd for 13:66
[ 523.907] (II) UnloadModule: "libinput"
[ 523.907] (II) systemd-logind: releasing fd for 13:64
[ 523.925] (II) UnloadModule: "libinput"
[ 523.925] (II) systemd-logind: releasing fd for 13:65
[ 523.949] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 523.949] (==) modeset(0): DPMS enabled
[ 523.949] (II) modeset(0): [DRI2] Setup complete
[ 523.949] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 523.949] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 523.949] (II) Initializing extension Generic Event Extension
[ 523.950] (II) Initializing extension SHAPE
[ 523.950] (II) Initializing extension MIT-SHM
[ 523.950] (II) Initializing extension XInputExtension
[ 523.951] (II) Initializing extension XTEST
[ 523.951] (II) Initializing extension BIG-REQUESTS
[ 523.951] (II) Initializing extension SYNC
[ 523.952] (II) Initializing extension XKEYBOARD
[ 523.952] (II) Initializing extension XC-MISC
[ 523.953] (II) Initializing extension SECURITY
[ 523.953] (II) Initializing extension XFIXES
[ 523.953] (II) Initializing extension RENDER
[ 523.953] (II) Initializing extension RANDR
[ 523.954] (II) Initializing extension COMPOSITE
[ 523.954] (II) Initializing extension DAMAGE
[ 523.955] (II) Initializing extension MIT-SCREEN-SAVER
[ 523.955] (II) Initializing extension DOUBLE-BUFFER
[ 523.955] (II) Initializing extension RECORD
[ 523.955] (II) Initializing extension DPMS
[ 523.956] (II) Initializing extension Present
[ 523.956] (II) Initializing extension DRI3
[ 523.956] (II) Initializing extension X-Resource
[ 523.956] (II) Initializing extension XVideo
[ 523.957] (II) Initializing extension XVideo-MotionCompensation
[ 523.957] (II) Initializing extension GLX
[ 523.969] (II) AIGLX: Loaded and initialized nouveau
[ 523.969] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 523.969] (II) Initializing extension XFree86-VidModeExtension
[ 523.969] (II) Initializing extension XFree86-DGA
[ 523.969] (II) Initializing extension XFree86-DRI
[ 523.969] (II) Initializing extension DRI2
[ 523.969] (II) modeset(0): Damage tracking initialized
[ 524.100] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 524.100] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 524.100] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 524.100] (**) Power Button: Applying InputClass "system-keyboard"
[ 524.100] (II) Using input driver 'libinput' for 'Power Button'
[ 524.101] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[ 524.101] (**) Power Button: always reports core events
[ 524.101] (**) Option "Device" "/dev/input/event1"
[ 524.107] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 524.107] (II) event1 - Power Button: device is a keyboard
[ 524.107] (II) event1 - Power Button: device removed
[ 524.107] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 524.107] (**) Option "xkb_layout" "fr"
[ 524.139] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 524.139] (II) event1 - Power Button: device is a keyboard
[ 524.140] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 524.140] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 524.140] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 524.140] (**) Power Button: Applying InputClass "system-keyboard"
[ 524.140] (II) Using input driver 'libinput' for 'Power Button'
[ 524.142] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 30 paused 0
[ 524.142] (**) Power Button: always reports core events
[ 524.142] (**) Option "Device" "/dev/input/event0"
[ 524.143] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 524.143] (II) event0 - Power Button: device is a keyboard
[ 524.143] (II) event0 - Power Button: device removed
[ 524.143] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 524.143] (**) Option "xkb_layout" "fr"
[ 524.144] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 524.144] (II) event0 - Power Button: device is a keyboard
[ 524.145] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 524.145] (II) No input driver specified, ignoring this device.
[ 524.145] (II) This device may have been added with another device file.
[ 524.145] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 524.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 524.146] (II) No input driver specified, ignoring this device.
[ 524.146] (II) This device may have been added with another device file.
[ 524.146] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 524.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 524.147] (II) No input driver specified, ignoring this device.
[ 524.147] (II) This device may have been added with another device file.
[ 524.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 524.147] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
[ 524.148] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 524.148] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 524.148] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 524.148] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 524.148] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 524.149] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 31 paused 0
[ 524.149] (**) dakai PS/2+USB Keyboard: always reports core events
[ 524.149] (**) Option "Device" "/dev/input/event2"
[ 524.150] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 524.150] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 524.151] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 524.151] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 524.151] (**) Option "xkb_layout" "fr"
[ 524.152] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 524.152] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 524.154] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 524.154] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 524.154] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 524.154] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 524.154] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 524.154] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 32 paused 0
[ 524.154] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 524.154] (**) Option "Device" "/dev/input/event3"
[ 524.156] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 524.156] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 524.156] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 524.156] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 524.156] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 524.156] (**) Option "AccelerationScheme" "none"
[ 524.156] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 524.156] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 524.156] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 524.158] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 524.158] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 524.159] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 524.159] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 524.159] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 524.159] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 524.159] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 524.160] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 524.160] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 524.160] (**) Option "Device" "/dev/input/event4"
[ 524.161] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 524.161] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 524.161] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 524.161] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 524.161] (**) Option "xkb_layout" "fr"
[ 524.163] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 524.163] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 524.164] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 524.164] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 524.164] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 524.164] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 524.164] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 524.165] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[ 524.165] (**) dakai PS/2+USB Keyboard: always reports core events
[ 524.165] (**) Option "Device" "/dev/input/event5"
[ 524.166] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 524.167] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 524.167] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 524.167] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 524.167] (**) Option "xkb_layout" "fr"
[ 524.168] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 524.169] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 524.170] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 524.170] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 524.170] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 524.170] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 524.227] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 524.227] (**) USB OPTICAL MOUSE : always reports core events
[ 524.227] (**) Option "Device" "/dev/input/event6"
[ 524.228] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 524.229] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 524.229] (II) event6 - USB OPTICAL MOUSE : device removed
[ 524.229] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 524.229] (**) Option "AccelerationScheme" "none"
[ 524.229] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 524.229] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 524.229] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 524.232] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 524.232] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 524.235] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 524.235] (II) No input driver specified, ignoring this device.
[ 524.235] (II) This device may have been added with another device file.
[ 524.237] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 524.237] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 524.237] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 524.237] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 524.237] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 524.238] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 524.238] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 524.239] (**) Option "Device" "/dev/input/event7"
[ 524.242] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 524.242] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 524.243] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 524.243] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 524.243] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 524.243] (**) Option "AccelerationScheme" "none"
[ 524.243] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 524.243] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 524.243] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 524.246] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 524.246] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 524.249] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event8)
[ 524.249] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 524.249] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 524.249] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "system-keyboard"
[ 524.249] (II) Using input driver 'libinput' for 'C-Media Electronics Inc. USB Audio Device'
[ 524.250] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 37 paused 0
[ 524.250] (**) C-Media Electronics Inc. USB Audio Device: always reports core events
[ 524.250] (**) Option "Device" "/dev/input/event8"
[ 524.253] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 524.253] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 524.253] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 524.253] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0014.0005/input/input11/event8"
[ 524.253] (**) Option "xkb_layout" "fr"
[ 524.256] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 524.256] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 524.257] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event17)
[ 524.257] (II) No input driver specified, ignoring this device.
[ 524.257] (II) This device may have been added with another device file.
[ 524.258] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event18)
[ 524.258] (II) No input driver specified, ignoring this device.
[ 524.258] (II) This device may have been added with another device file.
[ 524.258] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event19)
[ 524.259] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event20)
[ 524.259] (II) No input driver specified, ignoring this device.
[ 524.259] (II) This device may have been added with another device file.
[ 524.259] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event21)
[ 524.260] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 524.260] (II) No input driver specified, ignoring this device.
[ 524.260] (II) This device may have been added with another device file.
[ 524.268] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 524.268] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 524.268] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 524.268] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 524.268] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 524.268] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 524.268] (**) Option "Device" "/dev/input/event3"
[ 524.268] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 524.268] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 524.268] (**) Option "xkb_layout" "fr"
[ 524.269] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 524.269] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 524.269] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 524.269] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 524.269] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 524.269] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 524.269] (**) Option "Device" "/dev/input/event7"
[ 524.269] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 524.269] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 524.269] (**) Option "xkb_layout" "fr"
[ 525.270] (**) Option "fd" "27"
[ 525.270] (II) event1 - Power Button: device removed
[ 525.270] (**) Option "fd" "30"
[ 525.270] (II) event0 - Power Button: device removed
[ 525.270] (**) Option "fd" "31"
[ 525.270] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 525.270] (**) Option "fd" "32"
[ 525.270] (**) Option "fd" "33"
[ 525.270] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 525.270] (**) Option "fd" "34"
[ 525.270] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 525.271] (**) Option "fd" "35"
[ 525.271] (II) event6 - USB OPTICAL MOUSE : device removed
[ 525.271] (**) Option "fd" "36"
[ 525.271] (**) Option "fd" "37"
[ 525.271] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 525.271] (**) Option "fd" "32"
[ 525.271] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 525.271] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 525.273] (II) UnloadModule: "libinput"
[ 525.273] (II) systemd-logind: not releasing fd for 13:71, still in use
[ 525.273] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 525.274] (II) UnloadModule: "libinput"
[ 525.274] (II) systemd-logind: releasing fd for 13:72
[ 525.316] (II) UnloadModule: "libinput"
[ 525.317] (II) systemd-logind: releasing fd for 13:71
[ 525.337] (II) UnloadModule: "libinput"
[ 525.337] (II) systemd-logind: releasing fd for 13:70
[ 525.370] (II) UnloadModule: "libinput"
[ 525.370] (II) systemd-logind: releasing fd for 13:69
[ 525.387] (II) UnloadModule: "libinput"
[ 525.387] (II) systemd-logind: releasing fd for 13:68
[ 525.403] (II) UnloadModule: "libinput"
[ 525.403] (II) systemd-logind: releasing fd for 13:67
[ 525.420] (II) UnloadModule: "libinput"
[ 525.420] (II) systemd-logind: releasing fd for 13:66
[ 525.437] (II) UnloadModule: "libinput"
[ 525.437] (II) systemd-logind: releasing fd for 13:64
[ 525.454] (II) UnloadModule: "libinput"
[ 525.454] (II) systemd-logind: releasing fd for 13:65
[ 525.479] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 525.479] (==) modeset(0): DPMS enabled
[ 525.480] (II) modeset(0): [DRI2] Setup complete
[ 525.480] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 525.480] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 525.480] (II) Initializing extension Generic Event Extension
[ 525.480] (II) Initializing extension SHAPE
[ 525.480] (II) Initializing extension MIT-SHM
[ 525.481] (II) Initializing extension XInputExtension
[ 525.481] (II) Initializing extension XTEST
[ 525.482] (II) Initializing extension BIG-REQUESTS
[ 525.482] (II) Initializing extension SYNC
[ 525.482] (II) Initializing extension XKEYBOARD
[ 525.483] (II) Initializing extension XC-MISC
[ 525.483] (II) Initializing extension SECURITY
[ 525.483] (II) Initializing extension XFIXES
[ 525.484] (II) Initializing extension RENDER
[ 525.484] (II) Initializing extension RANDR
[ 525.484] (II) Initializing extension COMPOSITE
[ 525.485] (II) Initializing extension DAMAGE
[ 525.485] (II) Initializing extension MIT-SCREEN-SAVER
[ 525.485] (II) Initializing extension DOUBLE-BUFFER
[ 525.485] (II) Initializing extension RECORD
[ 525.486] (II) Initializing extension DPMS
[ 525.486] (II) Initializing extension Present
[ 525.486] (II) Initializing extension DRI3
[ 525.487] (II) Initializing extension X-Resource
[ 525.487] (II) Initializing extension XVideo
[ 525.487] (II) Initializing extension XVideo-MotionCompensation
[ 525.487] (II) Initializing extension GLX
[ 525.503] (II) AIGLX: Loaded and initialized nouveau
[ 525.503] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 525.503] (II) Initializing extension XFree86-VidModeExtension
[ 525.503] (II) Initializing extension XFree86-DGA
[ 525.504] (II) Initializing extension XFree86-DRI
[ 525.504] (II) Initializing extension DRI2
[ 525.504] (II) modeset(0): Damage tracking initialized
[ 525.640] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 525.640] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 525.640] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 525.640] (**) Power Button: Applying InputClass "system-keyboard"
[ 525.640] (II) Using input driver 'libinput' for 'Power Button'
[ 525.641] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[ 525.641] (**) Power Button: always reports core events
[ 525.641] (**) Option "Device" "/dev/input/event1"
[ 525.644] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 525.645] (II) event1 - Power Button: device is a keyboard
[ 525.645] (II) event1 - Power Button: device removed
[ 525.645] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 525.645] (**) Option "xkb_layout" "fr"
[ 525.706] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 525.706] (II) event1 - Power Button: device is a keyboard
[ 525.707] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 525.707] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 525.707] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 525.707] (**) Power Button: Applying InputClass "system-keyboard"
[ 525.707] (II) Using input driver 'libinput' for 'Power Button'
[ 525.708] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 30 paused 0
[ 525.708] (**) Power Button: always reports core events
[ 525.708] (**) Option "Device" "/dev/input/event0"
[ 525.709] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 525.709] (II) event0 - Power Button: device is a keyboard
[ 525.710] (II) event0 - Power Button: device removed
[ 525.710] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 525.710] (**) Option "xkb_layout" "fr"
[ 525.711] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 525.711] (II) event0 - Power Button: device is a keyboard
[ 525.713] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 525.713] (II) No input driver specified, ignoring this device.
[ 525.713] (II) This device may have been added with another device file.
[ 525.713] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 525.714] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 525.714] (II) No input driver specified, ignoring this device.
[ 525.714] (II) This device may have been added with another device file.
[ 525.714] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 525.715] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 525.715] (II) No input driver specified, ignoring this device.
[ 525.715] (II) This device may have been added with another device file.
[ 525.716] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 525.716] (II) No input driver specified, ignoring this device.
[ 525.716] (II) This device may have been added with another device file.
[ 525.716] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
[ 525.717] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 525.717] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 525.717] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 525.717] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 525.717] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 525.718] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 31 paused 0
[ 525.718] (**) dakai PS/2+USB Keyboard: always reports core events
[ 525.718] (**) Option "Device" "/dev/input/event2"
[ 525.720] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 525.720] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 525.721] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 525.721] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 525.721] (**) Option "xkb_layout" "fr"
[ 525.722] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 525.722] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 525.724] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 525.724] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 525.724] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 525.724] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 525.724] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 525.725] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 32 paused 0
[ 525.725] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 525.725] (**) Option "Device" "/dev/input/event3"
[ 525.726] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 525.726] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 525.727] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 525.727] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 525.727] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 525.727] (**) Option "AccelerationScheme" "none"
[ 525.727] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 525.727] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 525.727] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 525.729] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 525.729] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 525.730] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 525.730] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 525.730] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 525.730] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 525.730] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 525.730] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 525.730] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 525.730] (**) Option "Device" "/dev/input/event4"
[ 525.732] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 525.732] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 525.733] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 525.733] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 525.733] (**) Option "xkb_layout" "fr"
[ 525.734] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 525.734] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 525.736] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 525.736] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 525.736] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 525.736] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 525.736] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 525.736] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[ 525.736] (**) dakai PS/2+USB Keyboard: always reports core events
[ 525.737] (**) Option "Device" "/dev/input/event5"
[ 525.738] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 525.738] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 525.739] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 525.739] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 525.739] (**) Option "xkb_layout" "fr"
[ 525.740] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 525.741] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 525.742] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 525.742] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 525.742] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 525.742] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 525.797] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 525.797] (**) USB OPTICAL MOUSE : always reports core events
[ 525.797] (**) Option "Device" "/dev/input/event6"
[ 525.801] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 525.802] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 525.802] (II) event6 - USB OPTICAL MOUSE : device removed
[ 525.802] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 525.803] (**) Option "AccelerationScheme" "none"
[ 525.803] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 525.803] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 525.803] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 525.807] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 525.807] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 525.810] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 525.810] (II) No input driver specified, ignoring this device.
[ 525.810] (II) This device may have been added with another device file.
[ 525.811] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 525.811] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 525.811] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 525.811] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 525.812] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 525.813] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 525.813] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 525.813] (**) Option "Device" "/dev/input/event7"
[ 525.816] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 525.816] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 525.817] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 525.817] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 525.817] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 525.817] (**) Option "AccelerationScheme" "none"
[ 525.817] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 525.817] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 525.817] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 525.820] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 525.820] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 525.822] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event8)
[ 525.822] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 525.822] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 525.822] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "system-keyboard"
[ 525.822] (II) Using input driver 'libinput' for 'C-Media Electronics Inc. USB Audio Device'
[ 525.823] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 37 paused 0
[ 525.823] (**) C-Media Electronics Inc. USB Audio Device: always reports core events
[ 525.823] (**) Option "Device" "/dev/input/event8"
[ 525.825] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 525.826] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 525.826] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 525.826] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0014.0005/input/input11/event8"
[ 525.826] (**) Option "xkb_layout" "fr"
[ 525.829] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 525.829] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 525.830] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event17)
[ 525.830] (II) No input driver specified, ignoring this device.
[ 525.830] (II) This device may have been added with another device file.
[ 525.830] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event18)
[ 525.831] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event19)
[ 525.831] (II) No input driver specified, ignoring this device.
[ 525.831] (II) This device may have been added with another device file.
[ 525.831] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event20)
[ 525.832] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event21)
[ 525.832] (II) No input driver specified, ignoring this device.
[ 525.832] (II) This device may have been added with another device file.
[ 525.832] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 525.840] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 525.840] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 525.840] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 525.840] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 525.840] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 525.840] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 525.840] (**) Option "Device" "/dev/input/event3"
[ 525.840] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 525.840] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 525.840] (**) Option "xkb_layout" "fr"
[ 525.841] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 525.841] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 525.841] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 525.841] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 525.841] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 525.841] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 525.841] (**) Option "Device" "/dev/input/event7"
[ 525.841] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 525.841] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 525.841] (**) Option "xkb_layout" "fr"
[ 526.842] (**) Option "fd" "27"
[ 526.842] (II) event1 - Power Button: device removed
[ 526.842] (**) Option "fd" "30"
[ 526.842] (II) event0 - Power Button: device removed
[ 526.842] (**) Option "fd" "31"
[ 526.842] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 526.842] (**) Option "fd" "32"
[ 526.842] (**) Option "fd" "33"
[ 526.842] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 526.842] (**) Option "fd" "34"
[ 526.843] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 526.843] (**) Option "fd" "35"
[ 526.843] (II) event6 - USB OPTICAL MOUSE : device removed
[ 526.843] (**) Option "fd" "36"
[ 526.843] (**) Option "fd" "37"
[ 526.843] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 526.843] (**) Option "fd" "32"
[ 526.843] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 526.843] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 526.845] (II) UnloadModule: "libinput"
[ 526.845] (II) systemd-logind: not releasing fd for 13:71, still in use
[ 526.845] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 526.845] (II) systemd-logind: releasing fd for 13:72
[ 526.890] (II) UnloadModule: "libinput"
[ 526.890] (II) systemd-logind: releasing fd for 13:71
[ 526.907] (II) UnloadModule: "libinput"
[ 526.907] (II) systemd-logind: releasing fd for 13:70
[ 526.940] (II) UnloadModule: "libinput"
[ 526.940] (II) systemd-logind: releasing fd for 13:69
[ 526.957] (II) UnloadModule: "libinput"
[ 526.957] (II) systemd-logind: releasing fd for 13:68
[ 526.973] (II) UnloadModule: "libinput"
[ 526.973] (II) systemd-logind: releasing fd for 13:67
[ 526.990] (II) UnloadModule: "libinput"
[ 526.990] (II) systemd-logind: releasing fd for 13:66
[ 527.007] (II) UnloadModule: "libinput"
[ 527.007] (II) systemd-logind: releasing fd for 13:64
[ 527.024] (II) UnloadModule: "libinput"
[ 527.024] (II) systemd-logind: releasing fd for 13:65
[ 527.044] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 527.044] (==) modeset(0): DPMS enabled
[ 527.044] (II) modeset(0): [DRI2] Setup complete
[ 527.044] (II) modeset(0): [DRI2] DRI driver: nouveau
[ 527.044] (II) modeset(0): [DRI2] VDPAU driver: nouveau
[ 527.044] (II) Initializing extension Generic Event Extension
[ 527.044] (II) Initializing extension SHAPE
[ 527.044] (II) Initializing extension MIT-SHM
[ 527.044] (II) Initializing extension XInputExtension
[ 527.044] (II) Initializing extension XTEST
[ 527.045] (II) Initializing extension BIG-REQUESTS
[ 527.045] (II) Initializing extension SYNC
[ 527.045] (II) Initializing extension XKEYBOARD
[ 527.045] (II) Initializing extension XC-MISC
[ 527.045] (II) Initializing extension SECURITY
[ 527.045] (II) Initializing extension XFIXES
[ 527.045] (II) Initializing extension RENDER
[ 527.045] (II) Initializing extension RANDR
[ 527.046] (II) Initializing extension COMPOSITE
[ 527.046] (II) Initializing extension DAMAGE
[ 527.046] (II) Initializing extension MIT-SCREEN-SAVER
[ 527.046] (II) Initializing extension DOUBLE-BUFFER
[ 527.046] (II) Initializing extension RECORD
[ 527.046] (II) Initializing extension DPMS
[ 527.046] (II) Initializing extension Present
[ 527.047] (II) Initializing extension DRI3
[ 527.047] (II) Initializing extension X-Resource
[ 527.047] (II) Initializing extension XVideo
[ 527.047] (II) Initializing extension XVideo-MotionCompensation
[ 527.047] (II) Initializing extension GLX
[ 527.054] (II) AIGLX: Loaded and initialized nouveau
[ 527.054] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 527.054] (II) Initializing extension XFree86-VidModeExtension
[ 527.054] (II) Initializing extension XFree86-DGA
[ 527.054] (II) Initializing extension XFree86-DRI
[ 527.054] (II) Initializing extension DRI2
[ 527.054] (II) modeset(0): Damage tracking initialized
[ 527.164] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 527.164] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 527.164] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 527.164] (**) Power Button: Applying InputClass "system-keyboard"
[ 527.164] (II) Using input driver 'libinput' for 'Power Button'
[ 527.165] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 27 paused 0
[ 527.165] (**) Power Button: always reports core events
[ 527.165] (**) Option "Device" "/dev/input/event1"
[ 527.168] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 527.168] (II) event1 - Power Button: device is a keyboard
[ 527.168] (II) event1 - Power Button: device removed
[ 527.168] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 527.168] (**) Option "xkb_layout" "fr"
[ 527.209] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 527.209] (II) event1 - Power Button: device is a keyboard
[ 527.210] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 527.210] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 527.210] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 527.210] (**) Power Button: Applying InputClass "system-keyboard"
[ 527.210] (II) Using input driver 'libinput' for 'Power Button'
[ 527.211] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 30 paused 0
[ 527.211] (**) Power Button: always reports core events
[ 527.211] (**) Option "Device" "/dev/input/event0"
[ 527.213] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 527.213] (II) event0 - Power Button: device is a keyboard
[ 527.213] (II) event0 - Power Button: device removed
[ 527.213] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 527.213] (**) Option "xkb_layout" "fr"
[ 527.215] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 527.215] (II) event0 - Power Button: device is a keyboard
[ 527.216] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[ 527.216] (II) No input driver specified, ignoring this device.
[ 527.216] (II) This device may have been added with another device file.
[ 527.217] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 527.217] (II) No input driver specified, ignoring this device.
[ 527.217] (II) This device may have been added with another device file.
[ 527.218] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[ 527.218] (II) No input driver specified, ignoring this device.
[ 527.218] (II) This device may have been added with another device file.
[ 527.219] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[ 527.219] (II) No input driver specified, ignoring this device.
[ 527.219] (II) This device may have been added with another device file.
[ 527.220] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[ 527.220] (II) No input driver specified, ignoring this device.
[ 527.220] (II) This device may have been added with another device file.
[ 527.222] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[ 527.222] (II) No input driver specified, ignoring this device.
[ 527.222] (II) This device may have been added with another device file.
[ 527.223] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event16)
[ 527.223] (II) No input driver specified, ignoring this device.
[ 527.223] (II) This device may have been added with another device file.
[ 527.224] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event2)
[ 527.224] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 527.224] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 527.224] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 527.224] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 527.226] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 31 paused 0
[ 527.226] (**) dakai PS/2+USB Keyboard: always reports core events
[ 527.226] (**) Option "Device" "/dev/input/event2"
[ 527.229] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 527.229] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 527.230] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 527.230] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/0003:0E6A:02C0.0001/input/input2/event2"
[ 527.230] (**) Option "xkb_layout" "fr"
[ 527.233] (II) event2 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 527.233] (II) event2 - dakai PS/2+USB Keyboard: device is a keyboard
[ 527.235] (II) config/udev: Adding input device dakai PS/2+USB Keyboard Consumer Control (/dev/input/event3)
[ 527.235] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 527.235] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 527.235] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 527.235] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 527.236] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 32 paused 0
[ 527.236] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 527.236] (**) Option "Device" "/dev/input/event3"
[ 527.238] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 527.239] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 527.239] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 527.239] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: needs a virtual subdevice
[ 527.239] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 527.239] (**) Option "AccelerationScheme" "none"
[ 527.239] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) selected scheme none/0
[ 527.239] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 527.239] (**) dakai PS/2+USB Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 527.241] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 527.241] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device is a keyboard
[ 527.243] (II) config/udev: Adding input device dakai PS/2+USB Keyboard System Control (/dev/input/event4)
[ 527.243] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 527.243] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 527.243] (**) dakai PS/2+USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 527.243] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard System Control'
[ 527.244] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 527.244] (**) dakai PS/2+USB Keyboard System Control: always reports core events
[ 527.244] (**) Option "Device" "/dev/input/event4"
[ 527.245] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 527.246] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 527.246] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 527.246] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input4/event4"
[ 527.246] (**) Option "xkb_layout" "fr"
[ 527.248] (II) event4 - dakai PS/2+USB Keyboard System Control: is tagged by udev as: Keyboard
[ 527.248] (II) event4 - dakai PS/2+USB Keyboard System Control: device is a keyboard
[ 527.249] (II) config/udev: Adding input device dakai PS/2+USB Keyboard (/dev/input/event5)
[ 527.249] (**) dakai PS/2+USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 527.249] (**) dakai PS/2+USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 527.249] (**) dakai PS/2+USB Keyboard: Applying InputClass "system-keyboard"
[ 527.249] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard'
[ 527.250] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 34 paused 0
[ 527.250] (**) dakai PS/2+USB Keyboard: always reports core events
[ 527.250] (**) Option "Device" "/dev/input/event5"
[ 527.252] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 527.252] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 527.252] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 527.252] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input6/event5"
[ 527.252] (**) Option "xkb_layout" "fr"
[ 527.254] (II) event5 - dakai PS/2+USB Keyboard: is tagged by udev as: Keyboard
[ 527.254] (II) event5 - dakai PS/2+USB Keyboard: device is a keyboard
[ 527.255] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event6)
[ 527.255] (**) USB OPTICAL MOUSE : Applying InputClass "evdev pointer catchall"
[ 527.255] (**) USB OPTICAL MOUSE : Applying InputClass "libinput pointer catchall"
[ 527.255] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE '
[ 527.310] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
[ 527.310] (**) USB OPTICAL MOUSE : always reports core events
[ 527.310] (**) Option "Device" "/dev/input/event6"
[ 527.312] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 527.312] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 527.312] (II) event6 - USB OPTICAL MOUSE : device removed
[ 527.312] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.0/0003:4E53:5406.0003/input/input7/event6"
[ 527.312] (**) Option "AccelerationScheme" "none"
[ 527.312] (**) USB OPTICAL MOUSE : (accel) selected scheme none/0
[ 527.312] (**) USB OPTICAL MOUSE : (accel) acceleration factor: 2.000
[ 527.312] (**) USB OPTICAL MOUSE : (accel) acceleration threshold: 4
[ 527.315] (II) event6 - USB OPTICAL MOUSE : is tagged by udev as: Mouse
[ 527.316] (II) event6 - USB OPTICAL MOUSE : device is a pointer
[ 527.318] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 527.318] (II) No input driver specified, ignoring this device.
[ 527.318] (II) This device may have been added with another device file.
[ 527.320] (II) config/udev: Adding input device USB OPTICAL MOUSE Keyboard (/dev/input/event7)
[ 527.320] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 527.320] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 527.320] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 527.320] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 527.322] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 36 paused 0
[ 527.322] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 527.322] (**) Option "Device" "/dev/input/event7"
[ 527.325] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 527.325] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 527.326] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 527.326] (II) libinput: USB OPTICAL MOUSE Keyboard: needs a virtual subdevice
[ 527.326] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 527.327] (**) Option "AccelerationScheme" "none"
[ 527.327] (**) USB OPTICAL MOUSE Keyboard: (accel) selected scheme none/0
[ 527.327] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration factor: 2.000
[ 527.327] (**) USB OPTICAL MOUSE Keyboard: (accel) acceleration threshold: 4
[ 527.330] (II) event7 - USB OPTICAL MOUSE Keyboard: is tagged by udev as: Keyboard
[ 527.330] (II) event7 - USB OPTICAL MOUSE Keyboard: device is a keyboard
[ 527.332] (II) config/udev: Adding input device C-Media Electronics Inc. USB Audio Device (/dev/input/event8)
[ 527.332] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 527.332] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 527.332] (**) C-Media Electronics Inc. USB Audio Device: Applying InputClass "system-keyboard"
[ 527.332] (II) Using input driver 'libinput' for 'C-Media Electronics Inc. USB Audio Device'
[ 527.333] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 37 paused 0
[ 527.334] (**) C-Media Electronics Inc. USB Audio Device: always reports core events
[ 527.334] (**) Option "Device" "/dev/input/event8"
[ 527.336] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 527.336] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 527.337] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 527.337] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.4/1-2.4:1.3/0003:0D8C:0014.0005/input/input11/event8"
[ 527.337] (**) Option "xkb_layout" "fr"
[ 527.339] (II) event8 - C-Media Electronics Inc. USB Audio Device: is tagged by udev as: Keyboard
[ 527.339] (II) event8 - C-Media Electronics Inc. USB Audio Device: device is a keyboard
[ 527.340] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event17)
[ 527.340] (II) No input driver specified, ignoring this device.
[ 527.340] (II) This device may have been added with another device file.
[ 527.341] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event18)
[ 527.341] (II) No input driver specified, ignoring this device.
[ 527.341] (II) This device may have been added with another device file.
[ 527.341] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event19)
[ 527.342] (II) config/udev: Adding input device HDA ATI SB Line Out (/dev/input/event20)
[ 527.342] (II) No input driver specified, ignoring this device.
[ 527.342] (II) This device may have been added with another device file.
[ 527.343] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event21)
[ 527.343] (II) No input driver specified, ignoring this device.
[ 527.343] (II) This device may have been added with another device file.
[ 527.343] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 527.352] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 527.352] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 527.352] (**) dakai PS/2+USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 527.352] (II) Using input driver 'libinput' for 'dakai PS/2+USB Keyboard Consumer Control'
[ 527.352] (II) systemd-logind: returning pre-existing fd for /dev/input/event3 13:67
[ 527.352] (**) dakai PS/2+USB Keyboard Consumer Control: always reports core events
[ 527.352] (**) Option "Device" "/dev/input/event3"
[ 527.352] (II) libinput: dakai PS/2+USB Keyboard Consumer Control: is a virtual subdevice
[ 527.352] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/0003:0E6A:02C0.0002/input/input3/event3"
[ 527.352] (**) Option "xkb_layout" "fr"
[ 527.352] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "evdev keyboard catchall"
[ 527.352] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "libinput keyboard catchall"
[ 527.352] (**) USB OPTICAL MOUSE Keyboard: Applying InputClass "system-keyboard"
[ 527.352] (II) Using input driver 'libinput' for 'USB OPTICAL MOUSE Keyboard'
[ 527.352] (II) systemd-logind: returning pre-existing fd for /dev/input/event7 13:71
[ 527.352] (**) USB OPTICAL MOUSE Keyboard: always reports core events
[ 527.352] (**) Option "Device" "/dev/input/event7"
[ 527.352] (II) libinput: USB OPTICAL MOUSE Keyboard: is a virtual subdevice
[ 527.352] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:12.0/usb3/3-3/3-3:1.1/0003:4E53:5406.0004/input/input8/event7"
[ 528.352] (**) Option "fd" "27"
[ 528.352] (II) event1 - Power Button: device removed
[ 528.352] (**) Option "fd" "30"
[ 528.352] (II) event0 - Power Button: device removed
[ 528.353] (**) Option "fd" "31"
[ 528.353] (II) event2 - dakai PS/2+USB Keyboard: device removed
[ 528.353] (**) Option "fd" "32"
[ 528.353] (**) Option "fd" "33"
[ 528.353] (II) event4 - dakai PS/2+USB Keyboard System Control: device removed
[ 528.353] (**) Option "fd" "34"
[ 528.353] (II) event5 - dakai PS/2+USB Keyboard: device removed
[ 528.353] (**) Option "fd" "35"
[ 528.353] (II) event6 - USB OPTICAL MOUSE : device removed
[ 528.353] (**) Option "fd" "36"
[ 528.353] (**) Option "fd" "37"
[ 528.354] (II) event8 - C-Media Electronics Inc. USB Audio Device: device removed
[ 528.354] (**) Option "fd" "32"
[ 528.354] (II) event3 - dakai PS/2+USB Keyboard Consumer Control: device removed
[ 528.354] (**) Option "fd" "36"
[ 528.354] (II) event7 - USB OPTICAL MOUSE Keyboard: device removed
[ 528.356] (II) UnloadModule: "libinput"
[ 528.356] (II) systemd-logind: not releasing fd for 13:71, still in use
[ 528.356] (II) systemd-logind: not releasing fd for 13:67, still in use
[ 528.356] (II) systemd-logind: releasing fd for 13:72
[ 528.393] (II) UnloadModule: "libinput"
[ 528.393] (II) systemd-logind: releasing fd for 13:71
[ 528.410] (II) UnloadModule: "libinput"
[ 528.410] (II) systemd-logind: releasing fd for 13:70
[ 528.443] (II) UnloadModule: "libinput"
[ 528.443] (II) systemd-logind: releasing fd for 13:69
[ 528.460] (II) UnloadModule: "libinput"
[ 528.460] (II) systemd-logind: releasing fd for 13:68
[ 528.476] (II) UnloadModule: "libinput"
[ 528.477] (II) systemd-logind: releasing fd for 13:67
[ 528.493] (II) UnloadModule: "libinput"
[ 528.493] (II) systemd-logind: releasing fd for 13:66
[ 528.513] (II) UnloadModule: "libinput"
[ 528.513] (II) systemd-logind: releasing fd for 13:64
[ 528.531] (II) UnloadModule: "libinput"
[ 528.532] (II) systemd-logind: releasing fd for 13:65
[ 528.571] (II) Server terminated successfully (0). Closing log file.
yes i know, there was a big update like 2 days ago, i meant if after this update you started to have this issue? …
Yes, i Do nothing spécial exept launch overwatch.
post also output from:
inxi -Fazy
maybe i’v deleted an old kernel with “not supported” written on it. but in my head I did that a few days before
Kernel: 5.15.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b9d21b41-78e8-4497-96b7-544d629ccbe7 rw quiet apparmor=1
security=apparmor udev.log_priority=3 ibt=off
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: M5A78L-M LX3 v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 1201
date: 04/19/2013
Info: model: AMD FX-4300 bits: 64 type: MT MCP arch: Piledriver
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1405 high: 1408 min/max: 1400/3800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1406 2: 1408
3: 1405 4: 1403 bogomips: 30550
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: NVIDIA GM206 [GeForce GTX 750 v2] driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-06) arch: Maxwell
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: HDMI-A-1,VGA-1
empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1407 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 791x506mm (31.14x19.92")
s-diag: 939mm (36.97")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,bottom-r model: SKP_E5-24
serial: <filter> built: 2019 res: 1920x1080 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: VGA-1 pos: primary,top-left model: Idek Iiyama PL2483H
serial: <filter> built: 2018 res: 1080x1920 dpi: 92 gamma: 1.2
size: 299x531mm (11.77x20.91") diag: 609mm (24") ratio: 16:9 modes:
OpenGL: renderer: NV126 v: 4.3 Mesa 22.1.1 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK M5A78L LE driver: snd_hda_intel
v: kernel bus-ID: 1-2.4:5 chip-ID: 0d8c:0014 bus-ID: 00:14.2
chip-ID: 1002:4383 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
Device-3: C-Media Audio Adapter (Unitek Y-247A) type: USB
driver: cmedia_hs100b,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.46-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: ec00
bus-ID: 02:00.0 chip-ID: 1969:10a1 class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 4-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 465.76 GiB used: 231.64 GiB (49.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 231.64 GiB (50.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 35.0 C mobo: 34.0 C gpu: nouveau temp: 36.0 C
Fan Speeds (RPM): cpu: 1115 case-1: 1569 gpu: nouveau fan: 660
Power: 12v: 12.02 5v: N/A 3.3v: 3.32 vbat: N/A gpu: nouveau watts: 10.63
mV: 981.00
Processes: 207 Uptime: 13m wakeups: 0 Memory: 7.75 GiB used: 2 GiB (25.8%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1442 apt: 0 pacman: 1416 lib: 379
flatpak: 22 snap: 4 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.17
ok post output from this command:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
~ sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu ✔
[sudo] Mot de passe de test :
::INFO Téléchargement des miroirs depuis Manjaro
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Utilisation de la liste des miroirs par défaut
::INFO Interrogation des miroirs - Cela peut prendre un certain temps
0.782 Ukraine : https://manjaro.astra.in.ua/
0.455 Germany : https://mirror.netcologne.de/manjaro/
0.801 Bulgaria : https://manjaro.ipacct.com/manjaro/
..... Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
0.997 United_States : https://mnvoip.mm.fcix.net/manjaro/
::INFO Écriture de la liste des miroirs
::Germany : https://mirror.netcologne.de/manjaro/stable
::Ukraine : https://manjaro.astra.in.ua/stable
::Bulgaria : https://manjaro.ipacct.com/manjaro/stable
::United_States : https://mnvoip.mm.fcix.net/manjaro/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::INFO Liste de miroirs générée et sauvegardée dans: /etc/pacman.d/mirrorlist
:: Synchronisation des bases de données de paquets…
core 166,6 KiB 416 KiB/s 00:00 [#######################################################################################] 100%
extra 1860,5 KiB 1352 KiB/s 00:01 [#######################################################################################] 100%
community 7,0 MiB 1712 KiB/s 00:04 [#######################################################################################] 100%
multilib 174,5 KiB 1051 KiB/s 00:00 [#######################################################################################] 100%
:: Début de la mise à jour complète du système…
il n’y a rien à faire
what if I loaded the timeshift snapshot before the bug? if it works maybe we can find the difference between the 2 version ?
first remove the grub parameter, since you dont have intel cpus…
go to /etc/default/grub open the grub config file and edit this following line:
GRUB_CMDLINE_LINUX_DEFAULT
and inside the “” remove this parameter:
ibt=off
then save the file, and run this:
sudo update-grub
ok, I put it back as before. Another idea or I test timeshift?
what do you mean you put it back as before? did you remove the ibt off parameter and then run the update grub command?
I feel like I’m doing something stupid ?
go to /etc/default/grub open the grub config file and copy this following line here:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1"
is that the whole line?
