Here’s the full inxi output:
inxi
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ac0d5505-9144-4e35-8e7b-536df9090123 rw quiet splash apparmor=1
security=apparmor resume=UUID=1c32aa94-a24c-490a-b7ee-923401d5f85e
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 21A4 v: ThinkBook 15 G3 ACL
serial: <filter> Chassis: type: 10 v: ThinkBook 15 G3 ACL serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697 WIN serial: <filter>
part-nu: LENOVO_MT_21A4_BU_idea_FM_ThinkBook 15 G3 ACL
uuid: d2ec84eb-d414-11eb-810a-7c8ae188cc46 UEFI: LENOVO v: GQCN45WW(V1.31)
date: 10/22/2024
ID-1: BAT1 charge: 35.4 Wh (90.8%) condition: 39.0/45.0 Wh (86.6%)
power: 10.0 W volts: 12.3 min: 11.5 model: 0x43 0x65 0x6C 0x78 0x70 0x72
0x74 0x00 0x32 0x30 0x31 0x4C 0x31 0x39 0x43 0x33 0x50 0x44 0x41
type: Li-ion serial: <filter> status: discharging cycles: 404
Device-1: hidpp_battery_1 model: Logitech MX Anywhere 3 serial: <filter>
charge: 80% rechargeable: yes status: discharging
System RAM: total: 24 GiB available: 19.35 GiB used: 3.93 GiB (20.3%)
(unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT16G4SFS832A.M8FE serial: <filter>
(unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: N/A
Slot: 1 type: PCIe status: available info: J10 length: short volts: 3.3
bus-ID: 0200:00:01.1
Slot: 2 type: PCIe status: available info: J79 length: short volts: 3.3
bus-ID: 0200:00:01.6
Slot: N/A type: N/A status: available info: M.2, J92 length: short
volts: 3.3 bus-ID: 0200:00:01.2
Slot: N/A type: N/A status: available info: M.2, J90 length: short
volts: 3.3 bus-ID: 0200:00:01.4
Slot: N/A type: N/A status: available info: M.2, J19 length: short
volts: 3.3 bus-ID: 0200:00:01.7
Slot: 6 type: PCIe status: available length: short volts: 3.3
bus-ID: 0200:00:01.5
Info: model: AMD Ryzen 7 5700U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608108
desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1435 min/max: 400/4372 boost: enabled
base/boost: 1800/4350 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1435 2: 1435 3: 1435 4: 1435
5: 1435 6: 1435 7: 1435 8: 1435 9: 1435 10: 1435 11: 1435 12: 1435 13: 1435
14: 1435 15: 1435 16: 1435 bogomips: 57517
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 33.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xe48d built: 2019 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.576 y: 0.345 green: x: 0.345 y: 0.573 blue: x: 0.157 y: 0.118 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:164c
memory: 3.91 GiB unified: no
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4852
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.38 TiB used: 484.51 GiB (34.4%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 24.9 C
scheme: GPT
SMART: yes health: PASSED on: 6d 9h cycles: 658
read-units: 4,380,143 [2.24 TB] written-units: 5,386,791 [2.75 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HBLU-00BL2
lanes: 4 tech: SSD serial: <filter> fw-rev: 7L2QFXM7 temp: 18.9 C
scheme: GPT
SMART: yes health: PASSED on: 38d 7h cycles: 2,011
read-units: 33,677,163 [17.2 TB] written-units: 27,071,785 [13.8 TB]
ID-1: / raw-size: 916.39 GiB size: 900.94 GiB (98.31%)
used: 215.2 GiB (23.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:8 label: N/A uuid: ac0d5505-9144-4e35-8e7b-536df9090123
used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:7 label: N/A uuid: 418E-BDC2
ID-3: /mnt/win raw-size: 293.51 GiB size: 293.51 GiB (100.00%)
used: 269.31 GiB (91.8%) fs: ntfs block-size: 4096 B dev: /dev/nvme1n1p3
maj-min: 259:3 label: Windows-SSD uuid: 8AB660D6B660C473
ID-1: swap-1 type: partition size: 14.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:9 label: swap
uuid: 1c32aa94-a24c-490a-b7ee-923401d5f85e
ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 0060-41D1
ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme1n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs
label: WINRE_DRV uuid: A2AC61FCAC61CAFD
ID-4: /dev/nvme1n1p5 maj-min: 259:5 size: 182.18 GiB fs: ext4 label: N/A
uuid: 62a418f8-da93-4a65-9002-f866a6fca85d
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56ff class-ID: 0e02
Device-1: 3-3:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c4b class-ID: 0000
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1453 libs: 383 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.funami.tech/manjaro/stable/$repo/$arch
2: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
3: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
6: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
7: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
8: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 442
1: cpu: 100% command: ps pid: 7187 mem: 3.74 MiB (0.0%)
2: cpu: 1.1% command: [kworker/u66:0-events_unbound] pid: 6594
mem: 0.00 MiB (0.0%)
3: cpu: 0.6% command: sudo pid: 7165 mem: 9.38 MiB (0.0%)
4: cpu: 0.3% command: zen-bin pid: 1957 mem: 276.7 MiB (1.3%)
5: cpu: 0.3% command: zen-bin pid: 2264 mem: 345.9 MiB (1.7%)
Memory top: 5 of 442
1: mem: 529.4 MiB (2.6%) command: zen-bin pid: 2166 cpu: 0.0%
2: mem: 471.6 MiB (2.3%) command: zen-bin pid: 1889 cpu: 0.1%
3: mem: 345.9 MiB (1.7%) command: zen-bin pid: 2264 cpu: 0.3%
4: mem: 319.2 MiB (1.6%) command: zen-bin pid: 3255 cpu: 0.0%
5: mem: 314.2 MiB (1.5%) command: zen-bin pid: 2318 cpu: 0.0%
Processes: 442 Power: uptime: 10h 13m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 7.72 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
About the journal entries: There’s nothing to suggest any errors or causes of the shutdown. Here’s the output of journalctl --priority=warning..crit --no-pager --boot=-1 for example:
journal
Jan 15 22:43:05 filter-tb kernel: tpm tpm0: tpm_read_log_acpi: Failed to map ACPI memory
Jan 15 22:43:05 filter-tb kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jan 15 22:43:05 filter-tb kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
Jan 15 22:43:05 filter-tb kernel: amdgpu 0000:06:00.0: amdgpu: psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
Jan 15 22:43:05 filter-tb kernel: amdgpu 0000:06:00.0: amdgpu: Secure display: Generic Failure.
Jan 15 22:43:05 filter-tb kernel: amdgpu 0000:06:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Jan 15 22:43:05 filter-tb systemd-journald[460]: File /var/log/journal/dc00cd59ed3d463baa2fd490567b13cb/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jan 15 22:43:06 filter-tb kernel: rtw89_8852ae 0000:05:00.0: MAC has already powered on
Jan 15 22:43:06 filter-tb systemd[1]: nordvpnd.socket: TCP_NODELAY failed: Operation not supported
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support bap plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support bass plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support mcp plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support vcp plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support micp plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support ccp plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support csip plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/plugin.c:init_plugin() System does not support asha plugin
Jan 15 22:43:06 filter-tb bluetoothd[882]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Jan 15 22:43:11 filter-tb dbus-broker-launch[877]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jan 15 22:43:12 filter-tb dbus-broker-launch[877]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 15 22:43:12 filter-tb dbus-broker-launch[1239]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Jan 15 22:43:14 filter-tb lightdm[1270]: gkr-pam: unable to locate daemon control file
Jan 15 22:43:14 filter-tb systemd-xdg-autostart-generator[1297]: Configuration file /home/filter/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Jan 15 22:43:14 filter-tb systemd-journald[460]: File /var/log/journal/dc00cd59ed3d463baa2fd490567b13cb/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Jan 15 22:43:14 filter-tb dbus-broker-launch[1309]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Jan 15 22:43:15 filter-tb wireplumber[1447]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Jan 15 22:43:15 filter-tb tumblerd[1548]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Jan 15 22:43:15 filter-tb nextcloud[1536]: QGuiApplication::setDesktopFileName: the specified desktop file name ends with .desktop. For compatibility reasons, the .desktop suffix will be removed. Please specify a desktop file name without .desktop suffix
Jan 15 22:43:15 filter-tb nextcloud[1536]: nextcloud.gui.application: Failed to move the old config directory to its new location ( "/home/filter/.local/share/Nextcloud" to "/home/filter/.config/Nextcloud" )
Jan 15 22:43:15 filter-tb nextcloud[1536]: nextcloud.gui.application: Fallback move of "filter_Nextcloud_sync.log" also failed
Jan 15 22:43:15 filter-tb nextcloud[1536]: nextcloud.gui.application: Fallback move of "Nextcloud_sync.log" also failed
Jan 15 22:43:18 filter-tb gnome-keyring-daemon[1303]: asked to register item /org/freedesktop/secrets/collection/login/28, but it's already registered
Jan 15 22:43:18 filter-tb gnome-keyring-d[1303]: asked to register item /org/freedesktop/secrets/collection/login/28, but it's already registered
Here’s the output of pacdiff -o. I also recently updated the system (I think the day before this started happening), so that is also a possible culprit.
/etc/profile.pacnew
/etc/pacman.conf.pacnew
/etc/makepkg.conf.d/rust.conf.pacnew
