I have a PC, and I connect my headsets to my monitor since my cable is to short and doesn’t reach my pc. It is a single cable, so it is not splitting input and output. What can I do to make this work? It does work on windows, so there sure must be a way of doing it.
➜ ~ sudo dmesg | egrep -i "(snd|sound|sof|alsa|hda)"
[ 0.019052] software IO TLB: area num 16.
[ 0.381840] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.381841] software IO TLB: mapped [mem 0x0000000061a8a000-0x0000000065a8a000] (64MB)
[ 6.924981] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 6.925058] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 6.925063] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 6.925133] snd_hda_intel 0000:13:00.1: enabling device (0000 -> 0002)
[ 6.925181] snd_hda_intel 0000:13:00.1: Handle vga_switcheroo audio client
[ 6.925232] snd_hda_intel 0000:13:00.6: enabling device (0000 -> 0002)
[ 6.931965] snd_hda_intel 0000:13:00.1: bound 0000:13:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[ 6.944178] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:13:00.1/sound/card1/input18
[ 6.944275] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:13:00.1/sound/card1/input19
[ 6.944314] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input22
[ 6.944389] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:13:00.1/sound/card1/input20
[ 6.944431] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input23
[ 6.944508] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input24
[ 6.944551] input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:13:00.1/sound/card1/input21
[ 6.945340] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input25
[ 6.946145] snd_hda_codec_realtek hdaudioC2D0: autoconfig for ALC897: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 6.946149] snd_hda_codec_realtek hdaudioC2D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 6.946151] snd_hda_codec_realtek hdaudioC2D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 6.946152] snd_hda_codec_realtek hdaudioC2D0: mono: mono_out=0x0
[ 6.946154] snd_hda_codec_realtek hdaudioC2D0: inputs:
[ 6.946155] snd_hda_codec_realtek hdaudioC2D0: Front Mic=0x19
[ 6.946156] snd_hda_codec_realtek hdaudioC2D0: Rear Mic=0x18
[ 6.946157] snd_hda_codec_realtek hdaudioC2D0: Line=0x1a
[ 6.987504] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2/input26
[ 6.987546] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2/input27
[ 6.987582] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2/input28
[ 6.987615] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2/input29
[ 6.987649] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:13:00.6/sound/card2/input30
➜ ~ inxi -Faz
Kernel: 6.10.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
root=UUID=22a23718-f74b-4b64-b9dd-8860d1dc4fd5 rw quiet splash apparmor=1
Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro
base: Arch Linux
Type: Desktop System: Gigabyte product: B650M DS3H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B650M DS3H v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FB
date: 07/10/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 400 min/max: 400/5573 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 143768
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] vendor: Gigabyte
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2783
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 13:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 35.0 C
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: X: loaded: amdgpu,nouveau
unloaded: modesetting,radeon failed: nvidia alternate: fbdev,nv,vesa
dri: radeonsi gpu: nvidia,amdgpu display-ID: :1
note: <missing: xdpyinfo/xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 2560x1440
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070
SUPER/PCIe/SSE2 memory: 11.71 GiB
Device-1: NVIDIA AD104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 13:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 13:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.10.11-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:4
chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 1.35 TiB used: 24 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FPK001T
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFMH0.1 temp: 38.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: K1B3 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 24 GiB (2.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 36.9 C mobo: 34.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :1.0 temp: 33 C fan: 0% device: amdgpu
temp: 34.0 C
Memory: total: 16 GiB note: est. available: 14.78 GiB used: 2.47 GiB (16.7%)
Processes: 351 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.87 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1244 libs: 337 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.36
Thanks!
