Manjaro cannot give mic. input (that means i cannot speak)
And i tried so many things in this forum and Arch Linux forum
Please post system information
inxi -Faz
and ALSA information
sudo alsa-info.sh --upload
Sorry for latency. Here:
[huso@LenovoIP320 ~]$ inxi -Faz
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=6a44b7ec-e1fa-4a86-af21-cad77fd33bc6 rw quiet apparmor=1
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.27 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 81BG v: Lenovo ideapad 320-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 320-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40679 WIN serial: <filter>
UEFI: LENOVO v: 6JCN14WW date: 09/28/2017
ID-1: BAT0 charge: 15.4 Wh (100.0%) condition: 15.4/30.0 Wh (51.5%)
volts: 8.3 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
status: Full
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 6 MiB
bogomips: 28808
Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 700
3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:7
chip-ID: 174f:241a class-ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 8086:3166 class-ID: 0280
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-7:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 1.82 TiB used: 216.91 GiB (11.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B rotation: 5400 rpm serial: <filter> rev: 1.14 scheme: GPT
ID-1: / raw-size: 110.35 GiB size: 108.06 GiB (97.92%)
used: 9.95 GiB (9.2%) fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 28.7 MiB (11.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 44.5 C mobo: N/A
Processes: 262 Uptime: 21m wakeups: 1 Memory: 7.56 GiB
used: 2.49 GiB (33.0%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1167 lib: 298 flatpak: 0 Shell: Bash
v: 5.1.0 running-in: gnome-terminal inxi: 3.3.03
And
[huso@LenovoIP320 ~]$ sudo alsa-info.sh --upload
[sudo] password for huso:
Uploading information to www.alsa-project.org ... Done!
Your ALSA information is located at http://alsa-project.org/db/?f=96501dbfb90a0159dc4ee0c9d3029c56cc99d6dc
Please inform the person helping you.
Problem solved itself. That’s akward. Another issue now is when i plug off my headphone (has got deatachable mic), discord cannot transmit my voice but zoom can transmit my voice without my headphone. So… i must make a new topic thanks
