Still no luck, plus the grub ain’t showing up, it just goes directly into booting Manjaro and then it gets stuck in the booting logo which keeps turning and turning, without getting to the log in screen or being able to go into tty.
so you have to chroot again, and post logs from the failed boot:
journalctl -b-1 -p4 --no-pager
you have probably more exists in filesystem
errors…
Ok, here’s what i got,
Dec 19 16:53:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:53:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:06 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bf0d2160) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 16:54:06 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 16:54:06 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 16:54:06 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 19 16:54:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:23 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:54:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:54:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:05 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:55:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:35 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:55:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:55:59 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:56:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:46 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 16:56:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:56:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:16 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:57:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:46 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 16:57:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:57:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:33 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 16:58:39 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:45 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:51 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:58:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:03 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:20 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 16:59:26 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:32 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:38 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:44 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:50 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 16:59:56 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:02 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:00:08 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:14 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:20 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:26 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:32 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:38 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:44 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:50 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:00:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:01 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:01:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:37 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:01:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:01:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:36 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:02:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:02:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:00 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:06 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:18 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:03:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:03:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:00 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:06 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:04:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:27 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571be0838d0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 17:04:27 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 17:04:27 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 17:04:27 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 19 17:04:27 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:37:5: QML TextArea: Binding loop detected for property "implicitHeight"
Dec 19 17:04:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:04:53 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:04:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:17 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:05:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:47 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 21830, resource id: 17890502, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 19 17:05:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:05:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:05 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:06:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:31 ppapadopoulos plasmashell[1220]: QObject::startTimer: Timers cannot have negative intervals
Dec 19 17:06:35 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:06:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:06:54 ppapadopoulos plasmashell[1220]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Dec 19 17:06:56 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 31066, resource id: 17909674, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 19 17:06:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:17 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:07:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:28 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/core/private/DefaultToolTip.qml:69:13: QML Label: Binding loop detected for property "verticalAlignment"
Dec 19 17:07:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:47 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:07:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:07:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:29 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:08:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:08:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:11 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:09:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:40 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:09:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:09:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:16 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:10:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:10:52 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:10:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:11:51 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:11:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:03 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:21 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:27 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:32 ppapadopoulos kscreenlocker_greet[99288]: Qt: Session management error: networkIdsList argument is NULL
Dec 19 17:12:33 ppapadopoulos kscreenlocker_greet[99288]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Dec 19 17:12:33 ppapadopoulos kscreenlocker_greet[99288]: kf.kirigami: Failed to find a Kirigami platform plugin
Dec 19 17:12:33 ppapadopoulos kscreenlocker_greet[99288]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Dec 19 17:12:33 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:39 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:45 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:12:51 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:12:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:03 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:21 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:13:27 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:33 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:39 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:44 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:13:50 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:13:56 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:02 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:08 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:14 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:20 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:22 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571ba511000) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 17:14:22 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 17:14:22 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 17:14:22 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:37:5: QML TextArea: Binding loop detected for property "implicitHeight"
Dec 19 17:14:26 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:31 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:14:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:14:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:06 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:15:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:15:53 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:15:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:16:47 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:16:53 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:16:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:23 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:17:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:17:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:11 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:18:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:18:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:05 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:19:06 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 48497, resource id: 14680224, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 19 17:19:08 ppapadopoulos plasmashell[1220]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Dec 19 17:19:11 ppapadopoulos kernel: kauditd_printk_skb: 9 callbacks suppressed
Dec 19 17:19:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:25 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 53180, resource id: 17911594, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 19 17:19:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:52 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/core/private/DefaultToolTip.qml:69:13: QML Label: Binding loop detected for property "verticalAlignment"
Dec 19 17:19:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:19:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:05 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:20:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:40 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:20:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:20:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:28 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:21:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:21:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:04 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:22:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:34 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:22:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:22:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:04 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:23:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:34 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:23:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:23:57 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bd6a8050) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 17:23:57 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 17:23:57 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 17:23:57 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 19 17:23:57 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:37:5: QML TextArea: Binding loop detected for property "implicitHeight"
Dec 19 17:23:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:28 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:24:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:24:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:04 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:25:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:25:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:04 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:26:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:22 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:26:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:26:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:22 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:27:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:27:51 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:27:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:03 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:21 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:27 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:33 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:38 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:28:44 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:50 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:28:56 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:02 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:08 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:13 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:29:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:27 ppapadopoulos ksmserver[1183]: kscreenlocker: Could not establish screen lock
Dec 19 17:29:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:29:49 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:29:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:18 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:30:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:30:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:00 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:06 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:31:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:42 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:31:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:31:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:00 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:32:06 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:24 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:32:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:32:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:00 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:05 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:33:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:33:53 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:33:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:29 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:34:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:42 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571be0eef10) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 17:34:42 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 17:34:42 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 17:34:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:34:53 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:34:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:41 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:35:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:35:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:41 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:36:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:36:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:16 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:37:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:37:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:15 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:38:21 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:27 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:33 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:39 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:45 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:51 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:38:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:03 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:39:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:21 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:27 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:39:33 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:39 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:45 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:51 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:39:57 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:03 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:09 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:15 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:21 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:26 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:40:32 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:38 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:44 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:40:50 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:40:56 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:02 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:08 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:14 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:20 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:26 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:32 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:38 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:43 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:41:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:41:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:19 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:42:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:42:49 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:42:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:13 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:43:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:43:55 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:44:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:07 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:24 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:44:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:39 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571baa66750) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 17:44:39 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 17:44:39 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 17:44:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:44:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:00 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:05 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:45:11 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:47 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:45:53 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:45:59 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:05 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:11 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:46:17 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:23 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:29 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:35 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:41 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:47 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:46:52 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 17:46:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:40 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:47:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:47:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:28 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:34 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:48:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:48:58 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:16 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:22 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:28 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:49:34 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:40 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:46 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:52 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:49:58 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:50:04 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:50:10 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 19 17:50:16 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 19 17:50:19 ppapadopoulos kded5[1185]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Dec 19 17:50:19 ppapadopoulos ksmserver[1183]: kscreenlocker: Could not establish screen lock
Dec 19 17:50:22 ppapadopoulos kernel: kauditd_printk_skb: 108 callbacks suppressed
Dec 19 17:50:23 ppapadopoulos ksmserver[1183]: kscreenlocker: Could not establish screen lock
Dec 20 18:31:45 ppapadopoulos kernel: xhci_hcd 0000:00:14.0: xHC error in resume, USBSTS 0x411, Reinit
Dec 20 18:31:45 ppapadopoulos rtkit-daemon[1176]: The canary thread is apparently starving. Taking action.
Dec 20 18:31:45 ppapadopoulos systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Dec 20 18:31:45 ppapadopoulos systemd[1]: Failed to start pkgfile database update.
Dec 20 18:31:45 ppapadopoulos tlp[101121]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 18:31:45 ppapadopoulos tlp[101121]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 18:31:45 ppapadopoulos tlp[101121]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 18:31:45 ppapadopoulos tlp[101121]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 18:31:45 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 20 18:31:46 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Dec 20 18:31:49 ppapadopoulos plasmashell[1220]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 18:31:49 ppapadopoulos kdeconnectd[54149]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 18:31:49 ppapadopoulos wpa_supplicant[838]: bgscan simple: Failed to enable signal strength monitoring
Dec 20 18:31:50 ppapadopoulos kernel: kauditd_printk_skb: 158 callbacks suppressed
Dec 20 18:31:56 ppapadopoulos kernel: kauditd_printk_skb: 55 callbacks suppressed
Dec 20 18:31:58 ppapadopoulos tlp[101379]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101379]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 18:31:58 ppapadopoulos tlp[101381]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101379]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101381]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 18:31:58 ppapadopoulos tlp[101379]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 18:31:58 ppapadopoulos tlp[101381]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101381]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 18:31:58 ppapadopoulos tlp[101448]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101448]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 18:31:58 ppapadopoulos tlp[101448]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 18:31:58 ppapadopoulos tlp[101448]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 18:31:59 ppapadopoulos tlp[101545]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 18:31:59 ppapadopoulos tlp[101545]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 18:31:59 ppapadopoulos tlp[101545]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 18:31:59 ppapadopoulos tlp[101545]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 18:31:59 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bf29f1a0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 18:31:59 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 18:31:59 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 18:32:01 ppapadopoulos kernel: kauditd_printk_skb: 35 callbacks suppressed
Dec 20 18:32:04 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 10859, resource id: 17913626, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 18:32:04 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bd07cba0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 18:32:04 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 18:32:04 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 18:32:07 ppapadopoulos kernel: kauditd_printk_skb: 6 callbacks suppressed
Dec 20 18:32:09 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 14245, resource id: 17913926, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 18:32:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:17 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 20 18:32:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:30 ppapadopoulos plasmashell[1220]: qrc:/kdeconnect/qml/PluginChecker.qml:20:47: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 20 18:32:30 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.kdeconnect/contents/ui/FullRepresentation.qml:37:23: QML DeviceDelegate: Binding loop detected for property "height"
Dec 20 18:32:30 ppapadopoulos plasmashell[1220]: qrc:/kdeconnect/qml/RemoteKeyboard.qml:27:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 20 18:32:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:43 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 20 18:32:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:32:55 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 25909, resource id: 92274716, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 18:32:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:07 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 20 18:33:13 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:19 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:25 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:31 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:37 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:43 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:49 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:33:55 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:01 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:06 ppapadopoulos kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 20 18:34:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:42 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:34:54 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:00 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 20 18:35:06 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:12 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:18 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:24 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:30 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:36 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:35:42 ppapadopoulos kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 20 18:35:48 ppapadopoulos kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 20 18:37:09 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bf075d60) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 18:37:09 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 18:37:09 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 18:37:09 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 20 18:37:13 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 53851, resource id: 17917397, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 18:37:50 ppapadopoulos kernel: kauditd_printk_skb: 5 callbacks suppressed
Dec 20 18:39:06 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 20 18:52:50 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 40221, resource id: 92274754, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 19:00:08 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bdc00e80) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 19:00:08 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 19:00:08 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 19:00:08 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 20 19:03:33 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bee18ff0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 19:03:33 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 19:03:33 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 19:13:19 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 42426, resource id: 92274760, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 19:17:56 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 14968, resource id: 92274764, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 19:26:57 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bcfc5ba0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 19:26:57 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 19:26:57 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 19:26:57 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 20 19:28:18 ppapadopoulos kscreenlocker_greet[104581]: Qt: Session management error: networkIdsList argument is NULL
Dec 20 19:28:19 ppapadopoulos kscreenlocker_greet[104581]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Dec 20 19:28:19 ppapadopoulos kscreenlocker_greet[104581]: kf.kirigami: Failed to find a Kirigami platform plugin
Dec 20 19:28:19 ppapadopoulos kscreenlocker_greet[104581]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Dec 20 19:31:50 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 3310, resource id: 92274768, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 19:33:02 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 18068, resource id: 17918844, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 19:33:07 ppapadopoulos plasmashell[1220]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Dec 20 19:33:08 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 21045, resource id: 17946686, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 19:33:29 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:325:17: QML Label: Binding loop detected for property "width"
Dec 20 19:33:32 ppapadopoulos plasmashell[1220]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Dec 20 19:39:30 ppapadopoulos soffice.bin[104913]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/ppapadopoulos/Desktop/Adobe Reader XI.lnk")
Dec 20 19:39:37 ppapadopoulos plasmashell[1220]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("desktop:/.~lock.ΜΕΛΗ ΠΡΩΪΜΗΣ.odt%23")
Dec 20 19:39:38 ppapadopoulos plasmashell[1220]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("desktop:/.~lock.ΜΕΛΗ ΠΡΩΪΜΗΣ.docx%23")
Dec 20 19:39:46 ppapadopoulos plasmashell[1220]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("desktop:/.~lock.ΜΕΛΗ ΠΡΩΙΜΗΣ.xlsx%23")
Dec 20 19:40:22 ppapadopoulos kded5[1185]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Dec 20 19:40:22 ppapadopoulos kscreenlocker_greet[105264]: Qt: Session management error: networkIdsList argument is NULL
Dec 20 19:40:22 ppapadopoulos kscreenlocker_greet[105264]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze/actions/24/edit-copy.svg: Unsupported image format
Dec 20 19:40:22 ppapadopoulos kscreenlocker_greet[105264]: kf.kirigami: Failed to find a Kirigami platform plugin
Dec 20 19:40:23 ppapadopoulos kscreenlocker_greet[105264]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Dec 20 21:09:13 ppapadopoulos kernel: xhci_hcd 0000:00:14.0: xHC error in resume, USBSTS 0x411, Reinit
Dec 20 21:09:13 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 20 21:09:13 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Dec 20 21:09:14 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Dec 20 21:09:17 ppapadopoulos plasmashell[1220]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:09:17 ppapadopoulos kdeconnectd[54149]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:09:17 ppapadopoulos wpa_supplicant[838]: bgscan simple: Failed to enable signal strength monitoring
Dec 20 21:09:19 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bdefbae0) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 21:09:19 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 21:09:19 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 21:09:24 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 41443, resource id: 17952852, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 21:12:37 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 43050, resource id: 14680238, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:16:15 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 18247, resource id: 92274778, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:19:24 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 54832, resource id: 92274788, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:19:49 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 58068, resource id: 92274789, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:20:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 61056, resource id: 92274790, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:21:25 ppapadopoulos xdg-desktop-portal-kde[1274]: kf.kio.widgets.kdirmodel: No node found for item that was just removed: QUrl("file:///home/ppapadopoulos/OneDrive/ΠΑΠΑΔΟΠΟΥΛΟΣ/Ανέλιξη/ΑΠΟΔΕΙΞΕΙΣ/ΙΚΕ/ΜΟΣΧΟΠΟΥΛΟΣ ΕΚΤΟΡΑΣ/10.11-09.12/Συνεδρίες204.docx")
Dec 20 21:21:43 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 20 21:21:49 ppapadopoulos plasmashell[1220]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5571bbb8b310) QQmlContext(0x5571b9eab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 20 21:21:49 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 20 21:21:49 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 20 21:21:49 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Dec 20 21:21:49 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:37:5: QML TextArea: Binding loop detected for property "implicitHeight"
Dec 20 21:22:29 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 152 (BadDamage), sequence: 26408, resource id: 17963983, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 20 21:22:31 ppapadopoulos plasmashell[1220]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Dec 20 21:22:41 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 20 21:22:52 ppapadopoulos kdeconnectd[54149]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:22:52 ppapadopoulos plasmashell[1220]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:22:52 ppapadopoulos steam[107177]: g_main_context_push_thread_default: assertion 'acquired_context' failed
Dec 20 21:22:52 ppapadopoulos steam[107177]: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
Dec 20 21:22:53 ppapadopoulos steam[107177]: g_main_context_push_thread_default: assertion 'acquired_context' failed
Dec 20 21:22:53 ppapadopoulos steam[107177]: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
Dec 20 21:22:53 ppapadopoulos plasmashell[1220]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:22:53 ppapadopoulos kdeconnectd[54149]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:22:54 ppapadopoulos steam[107177]: gtk_disable_setlocale() must be called before gtk_init()
Dec 20 21:22:54 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:22:55 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:22:56 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:22:58 ppapadopoulos plasmashell[1220]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 20 21:22:58 ppapadopoulos plasmashell[1220]: libpng warning: iCCP: known incorrect sRGB profile
Dec 20 21:22:58 ppapadopoulos plasmashell[1220]: libpng warning: known incorrect sRGB profile
Dec 20 21:22:58 ppapadopoulos plasmashell[1220]: libpng warning: profile matches sRGB but writing iCCP instead
Dec 20 21:23:02 ppapadopoulos steam[107177]: g_main_context_push_thread_default: assertion 'acquired_context' failed
Dec 20 21:23:02 ppapadopoulos steam[107177]: g_main_context_pop_thread_default: assertion 'g_queue_peek_head (stack) == context' failed
Dec 20 21:23:02 ppapadopoulos kdeconnectd[54149]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:23:02 ppapadopoulos plasmashell[1220]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/8”"
Dec 20 21:23:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 35399, resource id: 17964850, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 20 21:23:03 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:23:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 35408, resource id: 17964851, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 20 21:23:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 35417, resource id: 17964852, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 20 21:23:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 35427, resource id: 17964853, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 20 21:23:03 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 35436, resource id: 17964854, major code: 134 (SYNC), minor code: 17 (DestroyFence)
Dec 20 21:23:30 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:23:36 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:23:44 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:23:51 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:03 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:07 ppapadopoulos kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Dec 20 21:24:11 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:15 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:17 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 3 (BadWindow), sequence: 38943, resource id: 27269054, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 20 21:24:20 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:26 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:35 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:36 ppapadopoulos plasmashell[1220]: file:///usr/lib/qt/qml/org/kde/plasma/core/private/DefaultToolTip.qml:69:13: QML Label: Binding loop detected for property "verticalAlignment"
Dec 20 21:24:40 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:24:47 ppapadopoulos kstart5[109023]: Omitting both --window and --windowclass arguments is not recommended
Dec 20 21:25:21 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:22 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:25 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:39 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:43 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:48 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:25:59 ppapadopoulos kernel: [drm:nv_drm_fence_context_create_ioctl [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to allocate fence signaling event
Dec 20 21:26:01 ppapadopoulos kstart5[109807]: Omitting both --window and --windowclass arguments is not recommended
Dec 20 21:26:55 ppapadopoulos tlp[109891]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:26:55 ppapadopoulos tlp[109891]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:26:55 ppapadopoulos tlp[109890]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:26:55 ppapadopoulos tlp[109890]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:26:55 ppapadopoulos tlp[109891]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:26:55 ppapadopoulos tlp[109891]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:26:55 ppapadopoulos tlp[109890]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:26:55 ppapadopoulos tlp[109890]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:26:56 ppapadopoulos tlp[109947]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:26:56 ppapadopoulos tlp[109946]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:26:56 ppapadopoulos tlp[109947]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:26:56 ppapadopoulos tlp[109946]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:26:56 ppapadopoulos tlp[109947]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:26:56 ppapadopoulos tlp[109947]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:26:56 ppapadopoulos tlp[109946]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:26:56 ppapadopoulos tlp[109946]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:29:14 ppapadopoulos tlp[110018]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:29:14 ppapadopoulos tlp[110018]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:29:14 ppapadopoulos tlp[110019]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Dec 20 21:29:14 ppapadopoulos tlp[110019]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Dec 20 21:29:14 ppapadopoulos tlp[110018]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:29:14 ppapadopoulos tlp[110018]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:29:14 ppapadopoulos tlp[110019]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Dec 20 21:29:14 ppapadopoulos tlp[110019]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Dec 20 21:29:50 ppapadopoulos kstart5[110079]: Omitting both --window and --windowclass arguments is not recommended
Dec 20 21:32:08 ppapadopoulos plasmashell[1220]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
Dec 20 21:34:06 ppapadopoulos plasmashell[1220]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Dec 20 21:34:12 ppapadopoulos ksystemstats[110787]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Voltage %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Dec 20 21:34:12 ppapadopoulos ksystemstats[110787]: kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "Temperature %1" msgid_plural: "" msgctxt: "@title %1 is a number"
Dec 20 21:34:13 ppapadopoulos ksystemstats[110787]: Could not retrieve information for NVidia GPU 1
Dec 20 21:34:13 ppapadopoulos plasma-systemmonitor[110774]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:22:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
Dec 20 21:34:13 ppapadopoulos plasma-systemmonitor[110774]: file:///usr/lib/qt/qml/org/kde/ksysguard/page/EditablePage.qml?page=overview.page:256:5: QML Loader: Binding loop detected for property "height"
Dec 20 21:34:13 ppapadopoulos kwin_x11[1186]: kwin_core: XCB error: 136 (Unknown), sequence: 31349, resource id: 17968352, major code: 134 (SYNC), minor code: 17 (DestroyFence)
ok, there are som nvidia related logs… lets try to reinstall it:
mhwd -r pci video-hybrid-intel-nvidia-prime
install it again:
mhwd -a pci nonfree 0300
errors post here
Ok so it successfully uninstalled and here is the log of the installation afterwards,
Using config 'video-hybrid-intel-nvidia-prime' for device: 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation 4th Gen Core Processor Integrated Graphics Controller
> Installing video-hybrid-intel-nvidia-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
core downloading...
extra downloading...
community downloading...
multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-utils dependency
Packages (7) egl-wayland-2:1.1.11-2 eglexternalplatform-1.1-2 libxnvctrl-525.60.11-4 lib32-nvidia-utils-525.60.11-1 linux515-nvidia-525.60.11-6 nvidia-prime-1.0-4 nvidia-utils-525.60.11-2
Total Installed Size: 868.24 MiB
:: Retrieving packages...
eglexternalplatform-1.1-2-any downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing eglexternalplatform...
installing egl-wayland...
installing libxnvctrl...
installing nvidia-utils...
If you run into trouble with CUDA not being available, run nvidia-modprobe first.
If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
Optional dependencies for nvidia-utils
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
installing nvidia-prime...
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
installing linux515-nvidia...
(1/5) Updating module dependencies...
(2/5) Updating Kernel initcpios for Nvidia-DRM...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.85-1-MANJARO
-> Running build hook: [base]
==> ERROR: Hook /usr/lib/initcpio/install/udev has no build function
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
-> Running build hook: [openswap]
-> Running build hook: [resume]
-> Running build hook: [fsck]
-> Running build hook: [bootsplash-arch]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'default'
-> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.19-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'fallback'
-> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-6.0-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
error: command failed to execute correctly
(3/5) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
(4/5) Reloading system bus configuration...
call to execv failed (Exec format error)
(5/5) Updating the desktop file MIME type cache...
nvidia-utils: install reason has been set to 'explicitly installed'
nvidia-prime: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux515-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-hybrid-intel-nvidia-prime
there is something wrong with your mkinitcpio/initframs…
lets reinstall it + its dependencies:
pacman -S mkinitcpio awk mkinitcpio-busybox kmod util-linux libarchive coreutils bash binutils diffutils findutils grep filesystem gzip systemd
So I got this,
warning: mkinitcpio-34-1 is up to date -- reinstalling
warning: gawk-5.2.1-1 is up to date -- reinstalling
warning: mkinitcpio-busybox-1.35.0-1 is up to date -- reinstalling
warning: kmod-30-3 is up to date -- reinstalling
warning: util-linux-2.38.1-1 is up to date -- reinstalling
warning: libarchive-3.6.2-2 is up to date -- reinstalling
warning: coreutils-9.1-3 is up to date -- reinstalling
warning: bash-5.1.016-2 is up to date -- reinstalling
warning: binutils-2.39-4 is up to date -- reinstalling
warning: diffutils-3.8-1 is up to date -- reinstalling
warning: findutils-4.9.0-1 is up to date -- reinstalling
warning: grep-3.8-2 is up to date -- reinstalling
warning: filesystem-2022.10.18-1 is up to date -- reinstalling
warning: gzip-1.12-1 is up to date -- reinstalling
warning: systemd-252.4-2 is up to date -- reinstalling
Packages (17) openssl-3.0.7-4 systemd-libs-252.4-2 bash-5.1.016-2 binutils-2.39-4 coreutils-9.1-3 diffutils-3.8-1 filesystem-2022.10.18-1 findutils-4.9.0-1 gawk-5.2.1-1 grep-3.8-2 gzip-1.12-1 kmod-30-3 libarchive-3.6.2-2
mkinitcpio-34-1 mkinitcpio-busybox-1.35.0-1 systemd-252.4-2 util-linux-2.38.1-1
Total Installed Size: 121.71 MiB
Net Upgrade Size: 40.78 MiB
:: Proceed with installation? [Y/n] y
mkinitcpio-busybox-1.35.0-1-x86_64 is up to date
(17/17) checking keys in keyring [#######################################################################################] 100%
(17/17) checking package integrity [#######################################################################################] 100%
(17/17) loading package files [#######################################################################################] 100%
(17/17) checking for file conflicts [#######################################################################################] 100%
error: failed to commit transaction (conflicting files)
systemd-libs: /usr/lib/libnss_myhostname.so.2 exists in filesystem
systemd-libs: /usr/lib/libnss_mymachines.so.2 exists in filesystem
systemd-libs: /usr/lib/libnss_resolve.so.2 exists in filesystem
systemd-libs: /usr/lib/libnss_systemd.so.2 exists in filesystem
systemd-libs: /usr/lib/libsystemd.so exists in filesystem
systemd-libs: /usr/lib/libsystemd.so.0 exists in filesystem
systemd-libs: /usr/lib/libsystemd.so.0.35.0 exists in filesystem
systemd-libs: /usr/lib/libudev.so exists in filesystem
systemd-libs: /usr/lib/libudev.so.1 exists in filesystem
systemd-libs: /usr/lib/libudev.so.1.7.5 exists in filesystem
as expected, you have more exists in filesystem
errors… unfortunately im not aware of a method on how to check which packages have these issues…
again use overwrite:
pacman -S mkinitcpio awk mkinitcpio-busybox kmod util-linux libarchive coreutils bash binutils diffutils findutils grep filesystem gzip systemd --overwrite '*'
This definitely did something,
(17/17) checking available disk space [#######################################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
( 1/17) reinstalling filesystem [#######################################################################################] 100%
( 2/17) reinstalling bash [#######################################################################################] 100%
( 3/17) reinstalling gawk [#######################################################################################] 100%
( 4/17) reinstalling mkinitcpio-busybox [#######################################################################################] 100%
( 5/17) reinstalling openssl [#######################################################################################] 100%
( 6/17) reinstalling kmod [#######################################################################################] 100%
( 7/17) reinstalling coreutils [#######################################################################################] 100%
( 8/17) reinstalling systemd-libs [#######################################################################################] 100%
( 9/17) reinstalling util-linux [#######################################################################################] 100%
(10/17) reinstalling libarchive [#######################################################################################] 100%
(11/17) reinstalling binutils [#######################################################################################] 100%
(12/17) reinstalling diffutils [#######################################################################################] 100%
(13/17) reinstalling findutils [#######################################################################################] 100%
(14/17) reinstalling grep [#######################################################################################] 100%
(15/17) reinstalling gzip [#######################################################################################] 100%
(16/17) reinstalling systemd [#######################################################################################] 100%
(17/17) reinstalling mkinitcpio [#######################################################################################] 100%
( 1/12) Creating system user accounts...
( 2/12) Updating journal message catalog...
( 3/12) Reloading system manager configuration...
Skipped: Running in chroot.
( 4/12) Updating udev hardware database...
( 5/12) Applying kernel sysctl settings...
( 6/12) Creating temporary files...
Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
( 7/12) Reloading device manager configuration...
( 8/12) Arming ConditionNeedsUpdate...
( 9/12) Updating linux initcpios...
-> Running build hook: [udev]
(10/12) Refreshing PackageKit...
(11/12) Reloading system bus configuration...
(12/12) Updating the info directory file...
ok, it looks like there is no longer the udev error… but there are still leftovers of the kernels that we already removed, post output from:
ls /etc/mkinitcpio.d/*.preset
ls /boot/initramfs-*
ls /boot/vmlinuz-*
ls /usr/lib/modules/*
Ok, so here’s everything,
sh-5.1# ls /etc/mkinitcpio.d/*.preset
/etc/mkinitcpio.d/linux515.preset /etc/mkinitcpio.d/linux519.preset /etc/mkinitcpio.d/linux60.preset
sh-5.1# ls /boot/initramfs-*
/boot/initramfs-5.15-x86_64-fallback.img /boot/initramfs-5.15-x86_64.img
sh-5.1# ls /usr/lib/modules/*
/usr/lib/modules/5.15.85-1-MANJARO:
extramodules kernelbase modules.alias.bin modules.builtin.alias.bin modules.builtin.modinfo modules.dep.bin modules.order modules.symbols pkgbase
kernel modules.alias modules.builtin modules.builtin.bin modules.dep modules.devname modules.softdep modules.symbols.bin vmlinuz
/usr/lib/modules/6.0.11-1-MANJARO:
/usr/lib/modules/extramodules-5.15-MANJARO:
nvidia-drm.ko.xz nvidia-modeset.ko.xz nvidia-peermem.ko.xz nvidia-uvm.ko.xz nvidia.ko.xz version
remove them:
rm /etc/mkinitcpio.d/linux519.preset
rm /etc/mkinitcpio.d/linux60.preset
rm -r /usr/lib/modules/6.0.11-1-MANJARO
run this:
mkinitcpio -P && update-grub
and post also output from it
Ok, here you go!
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
looks ok, so now you have 2 options, you can reboot and now you will very likely boot normally, but if you have more ‘exists in filesystem’ errors, you can have problems properly running your system, at least you will not be able to update your system next time when there will be one available…
or you can reinstall all your packages… first refresh your mirrors:
pacman-mirrors -f 5 && pacman -Syyu
then run this:
pacman -Qqn | pacman --overwrite=* -S -
so i leave it up to you how you decide
So if I choose to reinstall my packages, I do it directly from my current environment, meaning chroot? And the only thing is that it will probably take some time, right? I am kind of scare on getting more errors but I do like the idea of being able to update/upgrade without concerns
yes do it from chroot … reinstalling is probably the best option in this case… the only thing that will take time, is to download the packages, but if you have good internet speed, it shouldnt take much time…
first refresh your mirrors, and then run the second command, it will show you how much giga it will download before you confirm it…
I’ll go for it. I’ll check back when everything is done. I want to thank you once again for all your support! I really am grateful.
dont forget to refresh the mirrors first… when its done, exit chroot, reboot
Ok so all done. I’ve rebooted, first time stuck att booting logo but managed to go into tty2 and run a command that told me to do manually. Then restarted and after booting logo got to picture 1
Went again into tty2 and loged in like this
Does this mean I have no graphical interface?
you have optimus manager?
post from tty output:
pacman -Qs 'optimus|bbswitch|prim'
