Ok, so with the first command, everything went well and now the
ldconfig
returns nothing.
But, both
mhwd-kernel -i linux515 --force
and
mhwd-kernel -i linux60 --force
return this,
Error: Invalid argument.
Please choose one of the available kernels:
* linux419
* linux510
* linux515
* linux54
* linux60
* linux61
* linux515-rt
* linux60-rt
brahma
28 December 2022 20:10
22
it should work, so try this instead:
mhwd-kernel -f -i linux515
still getting the invalid error?
brahma
28 December 2022 20:12
24
i dont know how to use the mhwd tool for reinstalling, it just doesnt work… so lets use pacman:
pacman -S linux515 linux60
if there are no errors, exit chroot:
exit
reboot
This kind of worked, but returned a bunch of errors…
warning: linux515-5.15.85-1 is up to date -- reinstalling
warning: linux60-6.0.15-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) linux515-5.15.85-1 linux60-6.0.15-1
Total Installed Size: 274.28 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [#####################################################################] 100%
(2/2) checking package integrity [#####################################################################] 100%
(2/2) loading package files [#####################################################################] 100%
(2/2) checking for file conflicts [#####################################################################] 100%
(2/2) checking available disk space [#####################################################################] 100%
(1/3) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/3) Remove upgraded DKMS modules
(3/3) Save Linux kernel modules
(1/2) reinstalling linux515 [#####################################################################] 100%
(2/2) reinstalling linux60 [#####################################################################] 100%
(1/7) Updating module dependencies...
depmod: ERROR: failed to load symbols from /lib/modules/5.15.85-1-MANJARO/extramodules/nvidia-peermem.ko.xz: Invalid argument
depmod: ERROR: failed to load symbols from /lib/modules/5.15.85-1-MANJARO/extramodules/nvidia-drm.ko.xz: Invalid argument
(2/7) Install DKMS modules
==> ERROR: Missing 6.0.15-1-MANJARO kernel headers for module deepin-anything/5.0.18.
==> ERROR: Missing 5.15.85-1-MANJARO kernel headers for module deepin-anything/5.0.18.
(3/7) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.85-1-MANJARO
-> Running build hook: [base]
==> ERROR: Hook /usr/lib/initcpio/install/udev has no build function
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
-> Running build hook: [openswap]
-> Running build hook: [resume]
-> Running build hook: [fsck]
-> Running build hook: [bootsplash-arch]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> Starting build: 6.0.15-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64-fallback.img
error: command failed to execute correctly
(4/7) Updating Kernel initcpios for Nvidia-DRM...
(5/7) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
(6/7) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
(7/7) Restore Linux kernel modules
==> Warning:
-> This computer hasn't been restarted for a while.
-> You are running an old kernel. In order to use a
-> new version of the kernel, please restart your
-> computer as soon as possible.
brahma
28 December 2022 20:19
26
it looks like pacman didnt pull all the dependencies like the mhwd tool would… just to be sure, lets uninstall the kernels, and install them again using the mhwd:
mhwd-kernel -r linux515
mhwd-kernel -r linux60
install them again:
Removing linux515 returned some errors,
checking dependencies...
:: base optionally requires linux: bare metal support
Packages (3) linux515-5.15.85-1 linux515-nvidia-525.60.11-6 linux515-r8168-8.050.03-33
Total Removed Size: 106.89 MiB
:: Do you want to remove these packages? [Y/n] y
(1/2) Removing linux initcpios...
(2/2) Remove DKMS modules
(1/3) removing linux515-r8168 [#####################################################################] 100%
(2/3) removing linux515-nvidia [#####################################################################] 100%
(3/3) removing linux515 [#####################################################################] 100%
(1/4) Updating module dependencies...
(2/4) Updating Kernel initcpios for Nvidia-DRM...
(3/4) Refreshing PackageKit...
(4/4) Updating Grub-Bootmenu
done
Should I ignore them and proceed with the rest?
brahma
28 December 2022 20:38
28
yes proceed, then post output from:
pacman -Qs 'nvidia|dkms'
mhwd -l -li
Running,
returned this,
: Synchronizing package databases...
core 160.3 KiB 255 KiB/s 00:01 [#####################################################################] 100%
extra 1829.0 KiB 2.12 MiB/s 00:01 [#####################################################################] 100%
community 7.5 MiB 4.10 MiB/s 00:02 [#####################################################################] 100%
multilib 166.4 KiB 1513 KiB/s 00:00 [#####################################################################] 100%
error: no targets specified (use -h for help)
Did you mean to skip theese,
and run theese directly?
mhwd -l -li
brahma
28 December 2022 20:42
30
and installing linux60 went without any issues?
brahma
28 December 2022 20:45
32
manjaro should do something with their mhwd tool, this is not the first time im seeing these issues using mhwd-kernel in chroot…
install only the 5.15:
pacman -S linux515 linux515-nvidia
then post output from the 2 commands
I really have to thank you though for trying… I really appreciate it.
The command returned this,
core 160.3 KiB 270 KiB/s 00:01 [#####################################################################] 100%
extra 1829.0 KiB 2.14 MiB/s 00:01 [#####################################################################] 100%
community 7.5 MiB 4.20 MiB/s 00:02 [#####################################################################] 100%
multilib 166.4 KiB 1555 KiB/s 00:00 [#####################################################################] 100%
sh-5.1# pacman -S linux515 linux515-nvidia
Packages (2) linux515-5.15.85-1 linux515-nvidia-525.60.11-6
Total Installed Size: 155.89 MiB
error: failed to commit transaction (conflicting files)
linux515-nvidia: /usr/lib/modules/extramodules-5.15-MANJARO/nvidia-drm.ko.xz exists in filesystem
linux515-nvidia: /usr/lib/modules/extramodules-5.15-MANJARO/nvidia-modeset.ko.xz exists in filesystem
linux515-nvidia: /usr/lib/modules/extramodules-5.15-MANJARO/nvidia-peermem.ko.xz exists in filesystem
linux515-nvidia: /usr/lib/modules/extramodules-5.15-MANJARO/nvidia-uvm.ko.xz exists in filesystem
linux515-nvidia: /usr/lib/modules/extramodules-5.15-MANJARO/nvidia.ko.xz exists in filesystem
linux515-nvidia: /usr/share/licenses/linux515-nvidia/LICENSE exists in filesystem
brahma
28 December 2022 20:50
34
you have also these errors: exists in filesystem
- use overwrite:
pacman -S linux515 linux515-nvidia --overwrite '*'
maybe the exist in file system errors are causing the mhwd not working properly
So now things seem to have moved a bit forward, but still a couple of errors,
(1/2) installing linux515 [#####################################################################] 100%
Optional dependencies for linux515
wireless-regdb: to set the correct wireless channels of your country [installed]
(2/2) installing linux515-nvidia [#####################################################################] 100%
(1/6) Updating module dependencies...
(2/6) Install DKMS modules
(3/6) Updating linux initcpios...
(4/6) Updating Kernel initcpios for Nvidia-DRM...
(5/6) Refreshing PackageKit...
(6/6) Updating Grub-Bootmenu
done
brahma
28 December 2022 20:55
36
post the outputs from the 2 commands + output from this:
cat /etc/mkinitcpio.conf
You mean these two?
it’s the above mentioned output.
This,
returned this,
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=""
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES="/crypto_keyfile.bin"
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont encrypt openswap resume filesystems fsck bootsplash-arch"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
The first one returned this,
local/deepin-anything-dkms 5.0.18-1
Deepin Anything file search tool
local/dkms 3.0.9-1
Dynamic Kernel Modules System
local/egl-wayland 2:1.1.11-2
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-nvidia-utils 525.60.11-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl 525.60.11-4
NVIDIA NV-CONTROL X extension
local/linux515-nvidia 525.60.11-6 (linux515-extramodules)
NVIDIA drivers for linux
local/mhwd-nvidia 525.60.11-2
MHWD module-ids for nvidia 525.60.11
local/mhwd-nvidia-390xx 390.157-1
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.161.03-1
MHWD module-ids for nvidia 470.161.03
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 525.60.11-2
and the second one,
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
network-r8168 2016.04.20 true PCI
video-modesetting 2020.01.13 true PCI
> 0000:04:00.1 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
> 0000:01:00.0 (0302:10de:139a) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
video-vesa 2017.03.12 true PCI
brahma
28 December 2022 21:00
40
looks ok to me, so exit chroot, reboot and see if you can boot normally
