I had not used my laptop for about 5 days during the holidays, so today I booted in my main OS (Manjaro KDE). No problem booting and restoring browser pages etc. Then I proceeded checking for any available updates and also doing them. The update process returned some errors for some of them, I then rerun the update process and it managed to complete. However I got a warning/error, saying that it was long ago that I restarted my laptop, that there is a new kernel available and should do so.
I tried to restart, then suddenly everything was clickable but no process was available to start, I tried to start the terminal but it also wouldn’t start. Then the screen went black and there was a message about going into tyy or tty or something with ctrl+alt+f2. Now I knew this alternative workspace as I’ve there before, only problem was that there was only a dash flashing and I could not type the command that the message told me to. So I hard restarted my laptop, after that I am no longer able to boot, as I am stuck all the time at the booting manjaro logo. Grub seems fine as it recognizes manjaro and windows 10 partitions.
I tried booting from live usb and rerun the update, but this action also produced a bunch of warnings about which kernel I am using and such…
I would really appreciate any help and guidance as I really need to work…
EDIT: I should also mention that my partitions are encrypted…
Currently running: 5.13.19-2-MANJARO (linux513)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
* linux513
if there are no errors, rerun update again: pacman-mirrors -f 5 && pacman -Syyu
if there are no errors from the update, and you are up to date, provide output from: mhwd-kernel -li
did you tried booting with different kernels, since you have them installed?
uninstall the 5.19: mhwd-kernel -r linux519
reinstall the other two: mhwd-kernel -i linux515 linux60 --force
if there are no errors, exit chroot: exit
reboot
checking dependencies...
:: base optionally requires linux: bare metal support
Packages (3) linux519-5.19.17-2 linux519-nvidia-525.60.11-1 linux519-r8168-8.050.03-25
Total Removed Size: 234.00 MiB
:: Do you want to remove these packages? [Y/n] y
(1/2) Removing linux initcpios...
(2/2) Remove DKMS modules
(1/3) removing linux519-r8168 [#####################################################################] 100%
(2/3) removing linux519-nvidia [#####################################################################] 100%
(3/3) removing linux519 [#####################################################################] 100%
ldconfig: File /usr/lib/libSM.so.6 is empty, not checked.
ldconfig: File /usr/lib/libgailutil-3.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgthread-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgthread-2.0.so.0.7400.4 is empty, not checked.
ldconfig: File /usr/lib/libSM.so is empty, not checked.
ldconfig: File /usr/lib/libgailutil-3.so is empty, not checked.
ldconfig: File /usr/lib/libgmodule-2.0.so.0.7400.4 is empty, not checked.
ldconfig: File /usr/lib/libgmodule-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgmodule-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgailutil-3.so.0 is empty, not checked.
ldconfig: File /usr/lib/libSM.so.6.0.1 is empty, not checked.
ldconfig: File /usr/lib/libgthread-2.0.so.0 is empty, not checked.
(1/4) Updating module dependencies...
(2/4) Updating Kernel initcpios for Nvidia-DRM...
(3/4) Refreshing PackageKit...
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.0-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.0-x86_64.img
Found initrd fallback image: /boot/initramfs-6.0-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
and this,
returned this,
Error: Invalid argument.
Please choose one of the available kernels:
* linux419
* linux510
* linux515
* linux54
* linux60
* linux61
* linux515-rt
* linux60-rt
Thank you so much for your patience, here is the output,
if there are no errors, check again with: ldconfig
it should return nothing…
reinstall the kernels: mhwd-kernel -i linux515 --force mhwd-kernel -i linux60 --force
reboot
warning: libsm-1.2.4-1 is up to date -- reinstalling
error: target not found: 32lib-libsm
warning: gtk3-1:3.24.36-1 is up to date -- reinstalling
error: target not found: lib32-gkt3
warning: glib2-2.74.4-1 is up to date -- reinstalling
warning: lib32-glib2-2.74.4-1 is up to date -- reinstalling
and the
ldconfig
still returns,
