Manjaro freezing upon shutdown and restart
Hello! I’ve been having issues with Manjaro. Both restarting and shutting down just freeze the computer in this state:
/dev/sda1: recovering journal
/dev/sda1: clean, 943535/73236480 files, 30595027/292934978 blocks
I’m using the latest LTS kernel (Linux 5.10.53-1).
As for past solutions I’ve tried adding noefi to kernel options, but sadly it didn’t help.
When I run sudo journalctl -xe this shows up:
kernel: mce: [Hardware Error]: Machine check events logged
kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank: 9: d00002c0000a008f
kernel: mce: [Hardware Error]: TSC 6c2d309b48d4
kernel: mce: [Hardware Error]: PROCESSOR 0: 206f2 TIME 1628519386 SOCKET 0 APIC 0 microcode 3b
I would’ve attached some screenshots, but it would not let me.
Characteristics if needed:
CPU: 4x Xeon E7-4870
GPU: GeForce GTX 670
If any more information is needed to solve this issue, I’ll be happy to provide it.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  4. No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  5. Good! And this is why:grin:
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
Hello! Thank you for the warm welcome, for formatting my question for me and for the link with the information on how to format my answers. I’ve updated my settings with my DE, CPU, GPU and GPU driver.
For your question №2 here’s the output:
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=5f42910c-c213-472c-a57c-f804a67d30f9 rw quiet splash acpi=force
  apm=power_off
  Console: tty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
  base: Arch Linux
  Type: Server System: HP product: ProLiant DL580 G7 v: N/A serial: <filter>
  Chassis: type: 23 serial: <filter>
  Mobo: N/A model: N/A serial: N/A BIOS: HP v: P65 date: 10/01/2013
  RAM: total: 125.88 GiB used: 2.55 GiB (2.0%)
  Array-1: capacity: 512 GiB slots: 16 EC: Single-bit ECC
  Device-1: Board 1, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  actual: 1067 MT/s type: DDR3 detail: synchronous bus-width: 64 bits
  total: 72 bits manufacturer: N/A part-no: Not Specified serial: <filter>
  Device-2: Board 1, DIMM 2C size: No Module Installed
  Device-3: Board 1, DIMM 3B size: No Module Installed
  Device-4: Board 1, DIMM 4D size: No Module Installed
  Device-5: Board 1, DIMM 5D size: No Module Installed
  Device-6: Board 1, DIMM 6B size: No Module Installed
  Device-7: Board 1, DIMM 7C size: No Module Installed
  Device-8: Board 1, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Device-9: Board 2, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-10: Board 2, DIMM 2C size: No Module Installed
  Device-11: Board 2, DIMM 3B size: No Module Installed
  Device-12: Board 2, DIMM 4D size: No Module Installed
  Device-13: Board 2, DIMM 5D size: No Module Installed
  Device-14: Board 2, DIMM 6B size: No Module Installed
  Device-15: Board 2, DIMM 7C size: No Module Installed
  Device-16: Board 2, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Array-2: capacity: 512 GiB slots: 16 EC: Single-bit ECC
  Device-1: Board 3, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-2: Board 3, DIMM 2C size: No Module Installed
  Device-3: Board 3, DIMM 3B size: No Module Installed
  Device-4: Board 3, DIMM 4D size: No Module Installed
  Device-5: Board 3, DIMM 5D size: No Module Installed
  Device-6: Board 3, DIMM 6B size: No Module Installed
  Device-7: Board 3, DIMM 7C size: No Module Installed
  Device-8: Board 3, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Device-9: Board 4, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-10: Board 4, DIMM 2C size: No Module Installed
  Device-11: Board 4, DIMM 3B size: No Module Installed
  Device-12: Board 4, DIMM 4D size: No Module Installed
  Device-13: Board 4, DIMM 5D size: No Module Installed
  Device-14: Board 4, DIMM 6B size: No Module Installed
  Device-15: Board 4, DIMM 7C size: No Module Installed
  Device-16: Board 4, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Array-3: capacity: 512 GiB slots: 16 EC: Single-bit ECC
  Device-1: Board 5, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-2: Board 5, DIMM 2C size: No Module Installed
  Device-3: Board 5, DIMM 3B size: No Module Installed
  Device-4: Board 5, DIMM 4D size: No Module Installed
  Device-5: Board 5, DIMM 5D size: No Module Installed
  Device-6: Board 5, DIMM 6B size: No Module Installed
  Device-7: Board 5, DIMM 7C size: No Module Installed
  Device-8: Board 5, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Device-9: Board 6, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-10: Board 6, DIMM 2C size: No Module Installed
  Device-11: Board 6, DIMM 3B size: No Module Installed
  Device-12: Board 6, DIMM 4D size: No Module Installed
  Device-13: Board 6, DIMM 5D size: No Module Installed
  Device-14: Board 6, DIMM 6B size: No Module Installed
  Device-15: Board 6, DIMM 7C size: No Module Installed
  Device-16: Board 6, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Array-4: capacity: 512 GiB slots: 16 EC: Single-bit ECC
  Device-1: Board 7, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-2: Board 7, DIMM 2C size: No Module Installed
  Device-3: Board 7, DIMM 3B size: No Module Installed
  Device-4: Board 7, DIMM 4D size: No Module Installed
  Device-5: Board 7, DIMM 5D size: No Module Installed
  Device-6: Board 7, DIMM 6B size: No Module Installed
  Device-7: Board 7, DIMM 7C size: No Module Installed
  Device-8: Board 7, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Device-9: Board 8, DIMM 1A size: 8 GiB speed: spec: 1600 MT/s
  Device-10: Board 8, DIMM 2C size: No Module Installed
  Device-11: Board 8, DIMM 3B size: No Module Installed
  Device-12: Board 8, DIMM 4D size: No Module Installed
  Device-13: Board 8, DIMM 5D size: No Module Installed
  Device-14: Board 8, DIMM 6B size: No Module Installed
  Device-15: Board 8, DIMM 7C size: No Module Installed
  Device-16: Board 8, DIMM 8A size: 8 GiB speed: spec: 1600 MT/s
  Info: 4x 10-Core model: Intel Xeon E7- 4870 socket: LGA1567 (Proc 4)
  note: check bits: 64 type: MT MCP SMP arch: Nehalem family: 6
  model-id: 2F (47) stepping: 2 microcode: 3B cache: L1: 5 MiB L2: 120 MiB
  L3: 480 MiB bogomips: 383798
  Speed: 1066 MHz min/max: 1064/2400 MHz base/boost: 2400/4800 volts: 1.4 V
  ext-clock: 133 MHz Core speeds (MHz): 1: 1066 2: 1066 3: 1066 4: 1066
  5: 1066 6: 1066 7: 1066 8: 1066 9: 1066 10: 1066 11: 1066 12: 1067 13: 1066
  14: 1066 15: 1066 16: 1066 17: 1066 18: 1066 19: 1066 20: 1066 21: 1066
  22: 1066 23: 1066 24: 1066 25: 2398 26: 2398 27: 2398 28: 2398 29: 2398
  30: 2398 31: 2398 32: 2399 33: 2398 34: 2398 35: 1066 36: 1066 37: 1065
  38: 1066 39: 1066 40: 1066 41: 1066 42: 1065 43: 1065 44: 1065 45: 1065
  46: 1066 47: 1065 48: 1066 49: 1066 50: 1066 51: 1065 52: 1065 53: 1066
  54: 1066 55: 1065 56: 1066 57: 1066 58: 1066 59: 1066 60: 1066 61: 1066
  62: 1066 63: 1065 64: 1065 65: 1066 66: 1066 67: 1065 68: 1066 69: 2398
  70: 2398 71: 2398 72: 2397 73: 2398 74: 2398 75: 2397 76: 2397 77: 2398
  78: 2397 79: 1066 80: 1066
  Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
  constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
  monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep smx ss ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid
  x2apic xtopology xtpr
  Type: l1tf
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: eVga.com. driver: nouveau
  v: kernel bus-ID: 0b:00.0 chip-ID: 10de:11c0 class-ID: 0300
  Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3")
  diag: 584mm (23")
  OpenGL: renderer: NVE6 v: 4.3 Mesa 21.1.6 direct render: Yes
  Device-1: NVIDIA GK106 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
  v: kernel bus-ID: 0b:00.1 chip-ID: 10de:0e0b class-ID: 0403
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server
  Adapter
  vendor: Hewlett-Packard NC375i Quad Port driver: netxen_nic v: 4.0.82
  port: 4000 bus-ID: 04:00.0 chip-ID: 4040:0100 class-ID: 0200
  IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server
  Adapter
  port: 4000 bus-ID: 04:00.1 chip-ID: 4040:0100 class-ID: 0200
  IF: enp4s0f1 state: down mac: <filter>
  Device-3: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server
  Adapter
  port: 4000 bus-ID: 04:00.2 chip-ID: 4040:0100 class-ID: 0200
  IF: enp4s0f2 state: down mac: <filter>
  Device-4: NetXen Incorporated NX3031 Multifunction 1/10-Gigabit Server
  Adapter
  port: 4000 bus-ID: 04:00.3 chip-ID: 4040:0100 class-ID: 0200
  IF: enp4s0f3 state: down mac: <filter>
  Hardware-1: Hewlett-Packard Smart Array G6 controllers driver: hpsa
  v: 3.4.20-200 port: 4000 bus-ID: 03:00.0 chip-ID: 103c.323a rev: 01
  class-ID: 0104
  Local Storage: total: 1.21 TiB used: 98.17 GiB (7.9%)
  ID-1: /dev/sda maj-min: 8:0 model: LOGICAL VOLUME size: 1.09 TiB block-size:
  physical: 512 B logical: 512 B type: N/A serial: N/A rev: 6.40 scheme: MBR
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Corsair
  model: Corsair Voyager GTX family: Driven SSDs size: 119.24 GiB block-size:
  physical: 512 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD
  serial: <filter> rev: SBFM61.3 temp: 33 C
  SMART: yes state: enabled health: PASSED on: 203d 0h cycles: 1065
  read: 4048 GiB written: 5690 GiB
  ID-1: / raw-size: 1.09 TiB size: 1.07 TiB (98.33%) used: 98.17 GiB (8.9%)
  fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 5f42910c-c213-472c-a57c-f804a67d30f9
  ID-1: swap-1 type: partition size: 119.24 GiB used: 0 KiB (0.0%)
  priority: -2 dev: /dev/sdb maj-min: 8:16 label: N/A
  uuid: 7ed43abe-d7b8-4ae2-af5a-d8c992208eba
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
  Device-1: 1-6:2 info: Corsair Voyager GTX type: Mass Storage driver: uas
  interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 1b1c:1a0e
  class-ID: 0806 serial: <filter>
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  chip-ID: 1d6b:0001 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  Device-1: 5-1:2 info: Pixart Imaging Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 100mA chip-ID: 093a:2510 class-ID: 0301
  Device-2: 5-2:3 info: Primax HP PR1101U / Primax PMX-KPR1101U Keyboard
  type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 100mA chip-ID: 0461:0010 class-ID: 0300
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 38.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 990
  Processes: 887 Uptime: 33m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1210 lib: 396 Shell: Bash (su)
  v: 5.1.8 running-in: konsole inxi: 3.3.06```
That’s really old: Please update from your manufacturer’s website…
Is there a compelling reason to run on nouveau instead of the 470 series? If not, install the proprietary drivers.
This is unrelated to your issue but it’s strongly advised to have at least 2 partitions: / and /home I’m therefore concluding you’re new to Linux, therefore, please read this:
Start there and test and then we’ll see.
:crossed_fingers:
I have thought about BIOS being the problem before and thought I’d update it, but gave up when I saw on the HP website that there are ~2000 BIOS versions for my server, many of them with matching release dates and I know that for BIOS you have to upgrade to the newest version in order, going through the older versions up to the newest. I know that updating BIOS is a process which can completely destroy your device if not done correctly and that’s I I’d postponed it to a later time and hoped that the problems weren’t BIOS related.
If you or anymore with more experience than me could help me understand which BIOS versions I need to download, I’d be greatly appreciated.
If you send me a machine like that, I’d be very happy to do it for you and then write detailed instructions here on the site that you can follow from your side as unfortunately, I don’t have the same hardware as you. :grin:
Alternatively, post a topic on HPs forum, because I don’t think you’ll find anyone here on the site that can afford an HP Proliant with a Xeon E7- 4870 CPU and 128 GB of RAM!
:man_shrugging:
I think I managed to find the page with BIOS for it and have sorted them in a chronological order. Now is it true that I need to install them 1 version after the other, or can I just install the newest version directly?
Better safe than sorry, install them one by one.
Some BIOS do not like big version steps.
But as @Fabby said, an HP forum would be more helpful on this topic.
I tried posting on the HP forums just now and after posting my question in the Linux subsection it automatically got deleted for «spam» and my account got muted for 2 weeks. :neutral_face:
Worse than Arch forums :dizzy_face:
There seem to be 2 types of BIOS available for download:
Online ROM Flash Component for Linux - HP ProLiant DL580 G7 (P65) Servers (.exe)
and
System ROMPaq Firmware Upgrade for HP ProLiant DL580 G7 (P65) Servers (For USB Key-Media) (.rpm)
What’s the difference, but more importantly, which one do I currently have, so I can then know which one to continue updating?
.exe as you probably know is a Microsoft Windows executable.
.rpm is for Red Hat/Fedora systems.
Depends from which system you update.
From Manjaro, but I’ve looked a bit online and I see that for updating BIOS everybody used .exe files.
I plan on following this tutorial: https://youtu.be/vkLbUkAArs4?t=431
I’m getting this message when trying to update my BIOS by USB:
ROMPAQ or DIAG disk found, Attempting Boot From Drive
Invalid system disk
Replace the disk, and then press any key
How do I fix this?
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
