I am not able to get into a terminal, my system simply does not send any graphics information to either of my two monitors, As for your extensive system info inquiry, note that this is from a boot stick, so some data may slightly diverge from my usual setup and i put a sudo in front:
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2304 quiet
systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <filter> UEFI: American Megatrends LLC. v: A.B0 date: 08/25/2022
System RAM: total: 32 GiB available: 31.27 GiB used: 3.3 GiB (10.5%)
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2400 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KHX3200C16D4/8GX serial: <filter>
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
volts: 3.3 bus-ID: 00:01.0
Slot: 1 type: PCIe lanes: 1 status: in use info: J6B1 length: short
volts: 3.3 bus-ID: 00:1c.3
Slot: 2 type: PCIe lanes: 1 status: in use info: J6D1 length: short
volts: 3.3 bus-ID: 00:1c.4
Slot: 3 type: PCIe lanes: 1 status: in use info: J7B1 length: short
volts: 3.3 bus-ID: 00:1c.5
Slot: 4 type: PCIe lanes: 1 status: in use info: J8B4 length: short
volts: 3.3 bus-ID: 00:1c.6
Slot: 5 type: PCIe lanes: 1 status: in use info: J8D1 length: short
volts: 3.3 bus-ID: 00:1c.7
Slot: 6 type: PCI bits: 32 status: in use info: J8B3 length: short
volts: 3.3 bus-ID: 00:1e.0
Slot: 12 type: PCIe lanes: 16 status: in use info: J10 length: short
volts: 3.3 bus-ID: 00:03.1 children: 1: 2b:00.0 class-ID: 0604 type: bridge
children: 1: 2c:00.0 class-ID: 0604 type: bridge children: 1: 2d:00.0
class-ID: 0300 type: display 2: 2d:00.1 class-ID: 0403 type: audio
Slot: 14 type: PCIe lanes: 1 status: in use info: J3700, M.2 length: short
volts: 3.3 bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0108
type: mass-storage
Slot: 128 type: PCIe lanes: 4 status: in use info: J3708 length: short
volts: 3.3 bus-ID: 03:00.0
Slot: 134 type: PCIe lanes: 1 status: available info: J3703 length: short
volts: 3.3 bus-ID: 00:1f.7
Slot: 135 type: PCIe lanes: 1 status: in use info: J3702 length: short
volts: 3.3 bus-ID: 03:07.0
Slot: 132 type: PCIe lanes: 4 status: available info: J3707 length: short
Slot: 137 type: PCIe lanes: 1 status: in use info: J3701, M.2
length: short volts: 3.3 bus-ID: 03:09.0
Info: model: AMD Ryzen 7 5700X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2275 high: 3400 min/max: 2200/4662 boost: enabled
base/boost: 3400/4650 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 108862
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT]
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 2d:00.0 chip-ID: 1002:73df
class-ID: 0300
Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-2 pos: primary,left model: MSI G24C4 serial: <filter>
built: 2022 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2 chroma: red: x: 0.675
y: 0.314 green: x: 0.282 y: 0.651 blue: x: 0.153 y: 0.071 white: x: 0.314
y: 0.329 size: 520x290mm (20.47x11.42") diag: 598mm (23.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1440x576, 1024x768, 1440x480, 800x600, 720x576,
720x480, 640x480, 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: right model: HP All-in-One
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
chroma: red: x: 0.682 y: 0.310 green: x: 0.204 y: 0.694 blue: x: 0.149
y: 0.055 white: x: 0.314 y: 0.329 size: 530x300mm (20.87x11.81")
diag: 604mm (23.8") ratio: 16:9 modes: 1920x1080, 1600x1200, 1680x1050,
1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.5-1-MANJARO) device-ID: 1002:73df memory: 11.72 GiB
unified: no
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair HS80 MAX WIRELESS Gaming Receiver
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 1b1c:0a97 class-ID: 0300
serial: <filter>
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 9.15 TiB used: 972.21 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
scheme: GPT
SMART: yes health: PASSED on: 161d 20h cycles: 321
read-units: 111,063,645 [56.8 TB] written-units: 22,230,295 [11.3 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 39.9 C
scheme: GPT
SMART: yes health: PASSED on: 1y 71d 23h cycles: 1,106
read-units: 85,886,799 [43.9 TB] written-units: 80,003,541 [40.9 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD2003FZEX-00Z4SA0 family: Black size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A01 temp: 43 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 1y 284d 11h cycles: 2878
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD50NDZW-11BCSS1 family: Elements / My Passport (USB, AF)
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 sata: 3.1 speed: 6.0 Gb/s
tech: HDD rpm: 4800 serial: <filter> fw-rev: 1023 drive-rev: 01.01A01
temp: 41 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 122d 22h cycles: 97
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra USB 3.0
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: /run/media/manjaro/5TBHDD raw-size: 4.55 TiB size: 4.51 TiB (99.19%)
used: 972.21 GiB (21.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: 5TBHDD uuid: 52cbfe54-2b20-4c6e-8dba-c8eae79794e6
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 300 MiB fs: vfat label: N/A
uuid: B2AF-2FA2
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 1.82 TiB fs: btrfs label: N/A
uuid: 8b8ca515-8b79-42b4-bac3-251d6304ee22
ID-3: /dev/nvme1n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: EB04-A5BC
ID-4: /dev/nvme1n1p2 maj-min: 259:2 size: 922.42 GiB fs: btrfs label: N/A
uuid: e12ec2ec-7d83-406e-9f44-a6c450f272d6
ID-5: /dev/nvme1n1p3 maj-min: 259:3 size: 8.8 GiB fs: swap label: swap
uuid: 21587070-a390-403d-8951-4cc9a848e8ba
ID-6: /dev/sda1 maj-min: 8:1 size: 350 MiB fs: ntfs label: System Reserved
uuid: 363826E33826A23B
ID-7: /dev/sda2 maj-min: 8:2 size: 99.66 GiB fs: ntfs label: System
uuid: 204C2A404C2A1158
ID-8: /dev/sda3 maj-min: 8:3 size: 1.72 TiB fs: ntfs label: Data
uuid: 4CAE160BAE15EDE8
ID-9: /dev/sdc1 maj-min: 8:33 size: 3.52 GiB fs: iso9660
ID-10: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: E09C-ECCD
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3:3 info: Corsair HS80 MAX WIRELESS Gaming Receiver
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
chip-ID: 1b1c:0a97 class-ID: 0300 serial: <filter>
Device-2: 1-5:4 info: Turtle Beach Recon Controller
type: <vendor specific> driver: xpad interfaces: 2 rev: 2.0
chip-ID: 10f5:7005 class-ID: ff00 serial: <filter>
Device-3: 1-6:5 info: SteelSeries ApS Apex 7 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:1612 class-ID: 0300
Device-4: 1-8:6 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c91 class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 2-4:2 info: SanDisk Ultra Flair type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: Western Digital Elements 2620 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2620 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 43.2 C mobo: N/A gpu: amdgpu temp: 50.0 C
mem: 46.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1253 libs: 318 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
2: http://kibo.remi.lu/stable/$repo/$arch
3: https://mirror.netzspielplatz.de/manjaro/packages/stable/$repo/$arch
4: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
5: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
6: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
7: http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable/$repo/$arch
8: https://mirrors.zju.edu.cn/manjaro/stable/$repo/$arch
9: http://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
10: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
11: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
12: https://repo.sadjad.ac.ir/manjaro/stable/$repo/$arch
13: https://mirrors.shu.edu.cn/manjaro/stable/$repo/$arch
14: http://mirror.catn.com/pub/manjaro/stable/$repo/$arch
15: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
16: https://mirror.cedia.org.ec/manjaro/stable/$repo/$arch
17: https://mirror.philpot.de/manjaro/stable/$repo/$arch
18: http://mirror.inode.at/manjaro/stable/$repo/$arch
19: http://mirror.dacentec.com/manjaro/stable/$repo/$arch
20: http://mirror.rise.ph/manjaro/stable/$repo/$arch
21: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
22: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
23: https://mirrors.shuosc.org/manjaro/stable/$repo/$arch
24: http://manjaro.barata.pt/stable/$repo/$arch
25: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
26: http://ftp.belnet.be/mirrors/manjaro/stable/$repo/$arch
27: http://repo.manjaro.org.uk/stable/$repo/$arch
28: http://manjaro.mirror.ac.za/stable/$repo/$arch
29: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
30: http://ftp.caliu.cat/manjaro/stable/$repo/$arch
31: https://download.nus.edu.sg/mirror/manjaro/stable/$repo/$arch
32: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
33: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
34: https://manjaro.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
35: https://mirror.clarkson.edu/manjaro/stable/$repo/$arch
36: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
37: http://mirror.ventraip.net.au/Manjaro/stable/$repo/$arch
38: http://pet.inf.ufsc.br/mirrors/manjarolinux/stable/$repo/$arch
39: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
40: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
41: http://mirrors.serverhost.ro/manjaro/packages/stable/$repo/$arch
42: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
43: http://mirror.ragenetwork.de/manjaro/stable/$repo/$arch
44: http://distro.ibiblio.org/manjaro/stable/$repo/$arch
45: http://manjaro.melbourneitmirror.net/stable/$repo/$arch
46: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
47: http://mirror.infotronik.hu/mirrors/pub/manjaro/stable/$repo/$arch
48: https://manjaro.cu.be/stable/$repo/$arch
49: https://repo.rhindon.net/manjaro/stable/$repo/$arch
50: https://mirror.koddos.net/manjaro/stable/$repo/$arch
51: http://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
52: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
53: http://ftp.linux.org.tr/manjaro/stable/$repo/$arch
54: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
55: http://linorg.usp.br/manjaro/stable/$repo/$arch
56: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
57: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
58: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
59: http://kambing.ui.ac.id/manjaro/stable/$repo/$arch
60: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
61: http://manjaro.telecoms.bg/stable/$repo/$arch
62: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
63: https://osmirror.org/manjaro/stable/$repo/$arch
64: https://www.uex.dk/public/manjaro/stable/$repo/$arch
65: http://mirror.chmuri.net/manjaro/stable/$repo/$arch
66: http://mirror.upb.edu.co/manjarostable/$repo/$arch
67: https://mirror.zetup.net/manjaro/stable/$repo/$arch
68: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
69: https://mirror.tuchola-dc.pl/manjaro/stable/$repo/$arch
70: https://mirrors.netix.net/manjaro/stable/$repo/$arch
71: http://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
72: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
73: https://mirror.espoch.edu.ec/manjaro/stable/$repo/$arch
74: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
75: http://manjaro.dcc.uchile.cl/stable/$repo/$arch
76: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
77: https://manjaro.moson.eu/stable/$repo/$arch
78: https://mirrors.sjtug.sjtu.edu.cn/manjarostable/$repo/$arch
Processes:
CPU top: 5 of 389
1: cpu: 14.6% command: firefox pid: 2535 mem: 575.2 MiB (1.7%)
2: cpu: 5.5% command: gnome-shell pid: 1500 mem: 320.8 MiB (1.0%)
3: cpu: 4.7% command: firefox pid: 2902 mem: 234.3 MiB (0.7%)
4: cpu: 2.5% command: firefox pid: 2717 mem: 161.8 MiB (0.5%)
5: cpu: 1.7% command: xwayland pid: 1963 mem: 135.6 MiB (0.4%)
Memory top: 5 of 389
1: mem: 575.2 MiB (1.7%) command: firefox pid: 2535 cpu: 14.6%
2: mem: 320.8 MiB (1.0%) command: gnome-shell pid: 1500 cpu: 5.5%
3: mem: 234.3 MiB (0.7%) command: firefox pid: 2902 cpu: 4.7%
4: mem: 161.8 MiB (0.5%) command: firefox pid: 2717 cpu: 2.5%
5: mem: 135.6 MiB (0.4%) command: xwayland pid: 1963 cpu: 1.7%
Processes: 389 Uptime: 3m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Shell: Sudo (sudo)
v: 1.9.14p3 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.30
