I don’t think that it is.
I have looked into my driver related logs, since I suspect that the issue might be graphics driver related.
I will also try to boot into a Manjaro 4.x kernel I have sitting around (I have no clue why though) since that should predate the plymouth issues, if I understood that linked article correctly
journalctl -b -1 | grep -iE 'amdgpu|drm|error'
Journal file /var/log/journal/c604737f890c4412ba6b8a90f448f555/user-1000@00061e029a187773-8523894c6eeddecb.journal~ is truncated, ignoring file.
Jul 25 20:11:01 entropy-ws kernel: ACPI: bus type drm_connector registered
Jul 25 20:11:01 entropy-ws kernel: [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
Jul 25 20:11:01 entropy-ws kernel: simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
Jul 25 20:11:01 entropy-ws kernel: RAS: Correctable Errors collector initialized.
Jul 25 20:11:01 entropy-ws kernel: [drm] amdgpu kernel modesetting enabled.
Jul 25 20:11:01 entropy-ws kernel: amdgpu: CRAT table disabled by module option
Jul 25 20:11:01 entropy-ws kernel: amdgpu: Virtual CRAT table created for CPU
Jul 25 20:11:01 entropy-ws kernel: amdgpu: Topology: Add CPU node
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: enabling device (0006 -> 0007)
Jul 25 20:11:01 entropy-ws kernel: [drm] initializing kernel modesetting (NAVY_FLOUNDER 0x1002:0x73DF 0x1002:0x0E36 0xC1).
Jul 25 20:11:01 entropy-ws kernel: [drm] register mmio base: 0xFCC00000
Jul 25 20:11:01 entropy-ws kernel: [drm] register mmio size: 1048576
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 0 <nv_common>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 1 <gmc_v10_0>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 2 <navi10_ih>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 3 <psp>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 4 <smu>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 5 <dm>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 6 <gfx_v10_0>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 7 <sdma_v5_2>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 8 <vcn_v3_0>
Jul 25 20:11:01 entropy-ws kernel: [drm] add ip block number 9 <jpeg_v3_0>
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Fetched VBIOS from VFCT
Jul 25 20:11:01 entropy-ws kernel: amdgpu: ATOM BIOS: 113-D5121100-101
Jul 25 20:11:01 entropy-ws kernel: [drm] VCN(0) decode is enabled in VM mode
Jul 25 20:11:01 entropy-ws kernel: [drm] VCN(0) encode is enabled in VM mode
Jul 25 20:11:01 entropy-ws kernel: [drm] JPEG decode is enabled in VM mode
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: vgaarb: deactivate vga console
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Jul 25 20:11:01 entropy-ws kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: VRAM: 12272M 0x0000008000000000 - 0x00000082FEFFFFFF (12272M used)
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: AGP: 267894784M 0x0000008400000000 - 0x0000FFFFFFFFFFFF
Jul 25 20:11:01 entropy-ws kernel: [drm] Detected VRAM RAM=12272M, BAR=256M
Jul 25 20:11:01 entropy-ws kernel: [drm] RAM width 192bits GDDR6
Jul 25 20:11:01 entropy-ws kernel: [drm] amdgpu: 12272M of VRAM memory ready
Jul 25 20:11:01 entropy-ws kernel: [drm] amdgpu: 16009M of GTT memory ready.
Jul 25 20:11:01 entropy-ws kernel: [drm] GART: num cpu pages 131072, num gpu pages 131072
Jul 25 20:11:01 entropy-ws kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000800000).
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: STB initialized to 2048 entries
Jul 25 20:11:01 entropy-ws kernel: [drm] Loading DMUB firmware via PSP: version=0x02020020
Jul 25 20:11:01 entropy-ws kernel: [drm] use_doorbell being set to: [true]
Jul 25 20:11:01 entropy-ws kernel: [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 2
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Will use PSP to load VCN firmware
Jul 25 20:11:01 entropy-ws kernel: [drm] reserve 0xa00000 from 0x82fd000000 for PSP TMR
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: RAS: optional ras ta ucode is not available
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: smu driver if version = 0x0000000e, smu fw if version = 0x00000012, smu fw program = 0, version = 0x00413e00 (65.62.0)
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: SMU driver if version not matched
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: use vbios provided pptable
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Attempt to override pcie params failed!
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Failed to setup smc hw!
Jul 25 20:11:01 entropy-ws kernel: [drm:amdgpu_device_init [amdgpu]] *ERROR* hw_init of IP block <smu> failed -5
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: amdgpu_device_ip_init failed
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: Fatal error during GPU init
Jul 25 20:11:01 entropy-ws kernel: amdgpu 0000:2d:00.0: amdgpu: amdgpu: finishing device.
Jul 25 20:11:01 entropy-ws kernel: WARNING: CPU: 14 PID: 258 at drivers/gpu/drm/amd/amdgpu/amdgpu_irq.c:615 amdgpu_irq_put+0x46/0x70 [amdgpu]
Jul 25 20:11:01 entropy-ws kernel: Modules linked in: uas usb_storage usbhid amdgpu(+) btrfs blake2b_generic libcrc32c crc32c_generic i2c_algo_bit xor drm_ttm_helper raid6_pq ttm video drm_suballoc_helper amdxcp drm_buddy gpu_sched nvme drm_display_helper crc32c_intel nvme_core xhci_pci cec xhci_pci_renesas nvme_common wmi
Jul 25 20:11:01 entropy-ws kernel: RIP: 0010:amdgpu_irq_put+0x46/0x70 [amdgpu]
Jul 25 20:11:01 entropy-ws kernel: ? amdgpu_irq_put+0x46/0x70 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_fence_driver_hw_fini+0xfe/0x130 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_device_fini_hw+0xa6/0x340 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_driver_load_kms+0xec/0x190 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_pci_probe+0x150/0x440 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: ? __pfx_amdgpu_init+0x10/0x10 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: gmc_v10_0_hw_fini+0x53/0x80 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_device_fini_hw+0x1ed/0x340 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu: probe of 0000:2d:00.0 failed with error -5
Jul 25 20:11:01 entropy-ws kernel: WARNING: CPU: 14 PID: 258 at drivers/gpu/drm/drm_buddy.c:192 drm_buddy_fini+0x62/0x70 [drm_buddy]
Jul 25 20:11:01 entropy-ws kernel: RIP: 0010:drm_buddy_fini+0x62/0x70 [drm_buddy]
Jul 25 20:11:01 entropy-ws kernel: ? drm_buddy_fini+0x62/0x70 [drm_buddy 7ddeb2b2c4fbea59eda7680d2d0de2751b7a676d]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_vram_mgr_fini+0x176/0x190 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_ttm_fini+0x164/0x220 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_bo_fini+0x2e/0xa0 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: gmc_v10_0_sw_fini+0x2a/0x40 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_device_fini_sw+0xd2/0x430 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: amdgpu_driver_release_kms+0x16/0x30 [amdgpu e6c9c1e9bbc031e36b5507fdf246d83de02c9a81]
Jul 25 20:11:01 entropy-ws kernel: devm_drm_dev_init_release+0x49/0x70
Jul 25 20:11:01 entropy-ws kernel: WARNING: CPU: 14 PID: 258 at drivers/gpu/drm/drm_buddy.c:196 drm_buddy_fini+0x66/0x70 [drm_buddy]
Jul 25 20:11:01 entropy-ws kernel: RIP: 0010:drm_buddy_fini+0x66/0x70 [drm_buddy]
Jul 25 20:11:01 entropy-ws kernel: ? drm_buddy_fini+0x66/0x70 [drm_buddy 7ddeb2b2c4fbea59eda7680d2d0de2751b7a676d]
Jul 25 20:11:01 entropy-ws kernel: ? drm_buddy_fini+0x3f/0x70 [drm_buddy 7ddeb2b2c4fbea59eda7680d2d0de2751b7a676d]
Jul 25 20:11:01 entropy-ws kernel: [drm] amdgpu: ttm finalized
Jul 25 20:11:01 entropy-ws systemd[1]: Starting Load Kernel Module drm...
Jul 25 20:11:01 entropy-ws systemd[1]: modprobe@drm.service: Deactivated successfully.
Jul 25 20:11:01 entropy-ws systemd[1]: Finished Load Kernel Module drm.
Lines that i find interesting are:
*I have tried reading that file via cat, only *
I am not sure if that is intended this way
This might cause some issues, but i have no clue what issues
