Some might notice, especially when you are using testing branch that the plymouth version often jumps back to 22.02.122 version. That is to us the last known version, which also works with broken KMS setup.
Nvidia users and now also some with AMD GPUs might see the black screen issue on newer versions of plymouth.
Seems the thing goes even deeper. We all know that Fedora is the trend giver in new tech on Linux. So dropping legacy stuff which is not maintained anymore might be a good thing, at some point. Changes/ReplaceFbdevDrivers - Fedora Project Wiki
So why I got those issues? Normally you guys test it for me - right? Hmm. Actually all testing is done by the community using Manjaro Linux. We as developers not always have all devices to test on and also it will take a long time to verify all setups before we can do an update.
So why it landed in stable branch? There was another issue with Bluetooth and other things in newer kernel series. So the whole set of kernels got fast tracked to stable. Those who tested the Nvidia change use their Laptops with Nvidia cards in dedicated mode and not in hybrid.
You can check how Nvidia should be set-up for KMS and early KMS: NVIDIA - ArchWiki
But with all that combination and kernel patches setting those flags on hybrids or non Nvidia systems might create issues: which might result in a Black Screen …
