Manjaro boots into tty1, graphics disabled
When I tried to boot my computer today, it launched into tty1 instead of gnome.
    ~  journalctl --boot=-1 --priority=3 --catalog --no-pager           ✔
Apr 02 18:33:58 laslo-quietiam kernel:
Apr 02 18:33:58 laslo-quietiam kernel: nvidia-gpu 0000:26:00.3: i2c timeout error e0000000
Apr 02 18:33:58 laslo-quietiam kernel: ucsi_ccg 3-0008: i2c_transfer failed -110
Apr 02 18:33:58 laslo-quietiam kernel: ucsi_ccg 3-0008: ucsi_ccg_init failed - -110
Apr 02 18:33:59 laslo-quietiam bluetoothd[727]: src/plugin.c:plugin_init() Failed to init vcp plugin
Apr 02 18:33:59 laslo-quietiam bluetoothd[727]: src/plugin.c:plugin_init() Failed to init mcp plugin
Apr 02 18:33:59 laslo-quietiam bluetoothd[727]: src/plugin.c:plugin_init() Failed to init bap plugin
Apr 02 18:40:28 laslo-quietiam systemd-coredump[3239]: Failed to connect to coredump service: Connection refused
Apr 02 18:40:32 laslo-quietiam kernel: watchdog: watchdog0: watchdog did not stop!
I got gnome to launch with
startx
but this is obviously not a great solution for the long term.
I really have no idea whats going on but three weird things I’ve noticed:
  1. After launching gnome I got a notification about some kind of display lock being disabled, but the notification immediately disappeared.
  2. Both 1Password and Jetbrains Toolbox asked to create a vault to store passwords in which they have never asked before, so thats weird
  3. When I tried to use some of my custom shortcuts is spammed them for a bit and it didn’t appear to be working, then in the next five minutes the shortcut was run like every 30 seconds so it appears there is something slowing the cpu, but the pc itself seems fast as usual.
Here is some general information about my system:
  Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=9861382d-79e6-4388-8165-9412e047ed10 rw quiet splash apparmor=1
  Desktop: GNOME v: 43.4 tk: GTK v: 3.24.37 wm: gnome-shell dm: startx
  Type: Desktop System: Micro-Star product: MS-7B85 v: 1.0 serial: N/A
  Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85) v: 1.0
    serial: <filter> UEFI: American Megatrends v: 1.71 date: 05/16/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless All-in-One Keyboard TK820
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
    status: discharging
  RAM: total: 15.57 GiB used: 3.69 GiB (23.7%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 type: no module installed
  Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: spec: 3200 MT/s actual: 1600 MT/s volts: curr: 1.2
    min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: BLS8G4D32AESCK.M8FE serial: <filter>
  Device-3: DIMM 0 type: no module installed
  Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
    gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 1550 min/max: 1550/3400 boost: enabled
    base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 1550 2: 1550 3: 1550 4: 1550
    5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
    bogomips: 81618
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 26:00.0 chip-ID: 10de:2182
    class-ID: 0300
  Device-2: Logitech HD Pro Webcam C920 type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 046d:082d
    class-ID: 0102 serial: <filter>
  Display: server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.0
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
  Monitor-1: DP-3 pos: left res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: HDMI-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1660
    Ti/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel bus-ID: 5-1:2 v: kernel pcie: chip-ID: 046d:082d
    class-ID: 0102 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16
    bus-ID: 26:00.1 chip-ID: 10de:1aeb class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Logitech HD Pro Webcam C920 type: USB
  API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-3: PipeWire v: 0.3.67 status: n/a (root, process) tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active (root, process)
    tools: pacat,pactl
  Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 5-4:4 chip-ID: 8087:0025 class-ID: e001
  Local Storage: total: 465.76 GiB used: 133.35 GiB (28.6%)
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    rev: 2B2QEXM7 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 133.32 GiB (29.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 9861382d-79e6-4388-8165-9412e047ed10
    used: 25.6 MiB (8.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 742C-F260
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-5:3 info: NZXT Smart Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 1e71:1714 class-ID: 0300 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech HD Pro Webcam C920 type: Video,Audio
    power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
  Device-2: 5-3:3 info: Micro Star PRO CARBON type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
    chip-ID: 1462:7b85 class-ID: 0300 serial: <filter>
  Device-3: 5-4:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0025 class-ID: e001
  Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 28.6 C mobo: N/A
  Processes: 324 Uptime: 14m wakeups: 4 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1711
  pm: pacman pkgs: 1685 libs: 479 tools: gnome-software,pamac pm: flatpak
  pkgs: 13 pm: snap pkgs: 13 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.26
    ~  lsb_release -sirc         ✔
ManjaroLinux 22.1.0 Talos
I know all of this sounds kinda random but maybe some of you detectives know more than me :slight_smile:
Thanks in advance
Did you happen to remove orphan packages after updating? If so, you may have accidentally removed gdm (GNOME Display Manager). If so, you can install it and restart the service from a TTY:
sudo pacman -S gdm
systemctl restart gdm
I would do “sudo mkinitcpio -P” and “sudo update-grub”
Yes, I did, thanks! How’d you know that was the issue?
You’re not the only one who did it, that’s why. :wink:
