Booting Manjaro is a very long process, 40 seconds in average.
But windows 10 boot second 5 seconds
My laptop :
Huawei D15 2020 AMD
AMD vega 8 graphic
Ryzen 5 3500u
SSD Samgun (3500r / 3000w) in only manjaro plasma minimal x64/86
How can I make manjaro boot faster?
I want to learn Linux. I want you to help me with the first vexing case. Make me love Linux guys
systemd-analyze blame ξ² β
2.559s NetworkManager-wait-online.service
2.428s ModemManager.service
693ms dev-nvme0n1p2.device
421ms plymouth-quit.service
227ms systemd-udev-trigger.service
218ms boot-efi.mount
216ms user@1000.service
209ms plymouth-quit-wait.service
207ms systemd-user-sessions.service
206ms systemd-remount-fs.service
177ms systemd-modules-load.service
147ms systemd-tmpfiles-setup.service
134ms systemd-tmpfiles-setup-dev.service
118ms lvm2-monitor.service
116ms modprobe@fuse.service
111ms upower.service
103ms systemd-vconsole-setup.service
103ms systemd-rfkill.service
92ms systemd-journald.service
81ms systemd-journal-flush.service
79ms systemd-random-seed.service
76ms modprobe@drm.service
67ms systemd-logind.service
63ms systemd-tmpfiles-clean.service
60ms plymouth-read-write.service
57ms polkit.service
It seems to open fast. but the bios icon appears twice and it takes a long time
Discussed ad nauseam here. Forum search is your friend.
hint: systemctl disable network-manager-wait-online.service
Similarly, you most likely donβt need ModemManager.service on a modern computer unless you have dial-up internet. systemctl disable ModemManager.service
Can you write the necessary codes to disable it? I only use wifi for internet
Yes, there are many questions, but my case is different. The boot screen comes up twice and then opens. Iβm new to Linux.
systemctl disable Network-manager-wait-online.service ξ² 1 β
Failed to disable unit: Unit file Network-manager-wait-online.service does not exist.
you have a typo, that is why the command does not work. In terminal:
systemctl disable NetworkManager-wait-online.service
Please post systemd-analyze output and please read the following:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL3 (Trust Level 3) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you toβ¦
Difficulty: β
ββββ
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links wheneβ¦
thank you sir
inxi -v7azy ξ² β
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0c9ab668-2ba0-4edc-b365-10ae451b3198 rw quiet splash
resume=/dev/nvme0n1p3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: BOHK-WAX9X v: M1010
serial: <superuser required>
Mobo: HUAWEI model: BOHK-WAX9X-PCB v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 1.18 date: 03/30/2022
ID-1: BAT1 charge: 36.4 Wh (100.0%) condition: 36.4/41.6 Wh (87.6%)
volts: 12.8 min: 11.5 model: Sunwoda-H HB4692J5ECW-31 type: Li-ion
serial: <filter> status: full cycles: 260
RAM: total: 6.71 GiB used: 1.75 GiB (26.0%)
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1478 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1397 4: 1397 5: 1332 6: 1400 7: 1400 8: 2100 bogomips: 33550
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Huawei driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 61.0 C
Device-2: IMC Networks ov9734_azurewave_camera type: USB driver: uvcvideo
bus-ID: 1-4.2:5 chip-ID: 13d3:56f9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0872 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Vega 8 Graphics (raven
LLVM 14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: no
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2:2 chip-ID: 1358:c123 class-ID: e001 serial: <filter>
Local Storage: total: 238.47 GiB used: 10.46 GiB (4.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EXH7201Q temp: 40.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%) used: 10.46 GiB (4.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0c9ab668-2ba0-4edc-b365-10ae451b3198
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: F190-E2D0
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 277b87e6-52c3-4c88-a61c-5cf42c8abf58
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Xenta 2.4Ghz wireless optical mouse receiver
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1d57:130f class-ID: 0301
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 2 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-4.1:4 info: Shenzhen Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5110 class-ID: 0a00
serial: <filter>
Device-2: 1-4.2:5 info: IMC Networks ov9734_azurewave_camera type: Video
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-2:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 1358:c123
Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 60.2 C mobo: N/A gpu: amdgpu temp: 60.0 C
Processes: 237 Uptime: 5m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1084 libs: 310 tools: pamac,yay Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Check with Huawei support if there is a BIOS/UEFI update. Also it sounds like you are dual booting with Windows. If that is the case, make sure that Windows is always completely shutdown and hibernation, hybrid sleep and fastboot are disabled in Windows.
Also, if for some reason disabling does not work for NetworkManager-wait-online.service,
then mask the service:
systemctl mask NetworkManager-wait-online.service
SSD only has manjaro. No windows. Bios is up to date. But the bios screen comes up twice at startup. The first screen takes a long time. The second is fast. I turned off the internet service, sir. Boot up pretty fast but my first bios screen takes a long time
