Manjaro Boot fails on RIP:0010
I use manjaro linux 21.6 stabile on my ASUs zen book ux331un with nvidia mx150 graphics card . On manjaro I had two DE installed Plasma and Deepin .I use kernel 5.13.19 I recently installed any box including dkms modules and then reboot … but sadly reboot is not happened … so pressing Ctrl+ALT+F2 it gives me following log
But basic initialisation happens … caps lock indication is working …
Quick google gives me idea that I should make bootable stick and then try fix system .
Hi @AlexZas21, and welcome!
I’d just written a guide for something similar:
Take a look as it, try and fix your system from the chroot environment.
If you still have problems, use the ISO you booted into to post a reply to this topic with the info gathered, as described below, from within the chroot environment.
[HowTo] Provide System Information and, if applicable [HowTo] Post screenshots and links
Hope you come right!
[HowTo] Resolve an unbootable Manjaro (black screen, login failed, cant boot, etc)
