Hi all, been working through an issue for months now and not sure where to go past what I’ve already done so I thought I’d reach out here for further info and guidance.
So this all starts quite a while back, probably around February or March of this year, when I was still on vanilla Arch. After an update occurred at some point (unsure when exactly) my system would start crashing at random, seemingly without any trace of what was causing it. I would have done a rollback to whatever the older kernel or software package that was causing this was but I hadn’t used the system in a long, long time… I did what seemed like the best course of action and started looking into systemd and kernel logs to see if I could pinpoint anything in there that could help make sense of things, but all the logs seemed to come back with very different and varied leads that went nowhere. So, I was like “alright, maybe it’s some weird hardware issue” and I attempted to do what I could to isolate out hardware to find the issue. I swapped a different CPU into my motherboard, I tried a different GPU (since I suspected Nvidia at some point), I tried spare RAM, I tried different storage drives, and nothing. Maybe the issue is my arch install? So I moved over to a clean install of Manjaro and the exact same problems as on arch…
Eventually I kind of just gave up, and relegated myself to a setup on an older motherboard and slower CPU until I could figure out the issue further. I sent all my parts in under warranty to be looked at and after testing by another few techs they couldn’t replicate the issue within Windows…
The system didn’t crash in windows, OK, good lead… That seems to suggest it’s a linux issue. I’ve since put the motherboard and CPU back in the system and continue to have the same issues with crashing within Manjaro. As a test I installed Ubuntu and have been using it for a few days at this point without any crashes so I’m really starting to suspect it may be something like a kernel patch that either arch or Manjaro uses that’s causing interference with… something on my MOBO. As for how I could test that, I don’t even know where to start. And maybe I’m barking up the wrong tree here, I dunno.
I’m happy to provide any logs and info that is needed to help work out the issue, just let me know what you need and I’ll get it to you.
System Specs:
CPU: Ryzen 5 3600X
MOBO: Gigabyte B450 Aorus M
RAM: Corsair Vengance something @ 3200mhz
GPU: 1070
