I’m not sure which package. My system is up to date. The only package related to timeshift was timeshift-autosnap-manjaro and grub-btrfs which comes preinstalled.
Couldn’t test timeshift-autosnap-manjaro out because there are no updates yet
On distrowatch, the release announcement can be read.
https://distrowatch.com/
The revamped KDE theming is awesome (particularly Bamboo wallpaper everywhere)! And the Gnome 40 update is too good
. Thank you Team Manjaro
Running well on my Acer Swift 3 Ryzen 5 edition. Thank your for you and your team hard work!
Can someone remove the test releases here:
https://sourceforge.net/projects/manjarolinux/files/xfce/
The word “any” is a clue.
History
Previously I experienced the
==> WARNING: Possibly missing firmware for module: xhci_pci
issue during kernel installation/update (Xhci_pci Warning while building initramfs).
And “curing process” was via AUR patch as mentioned in the linked thread.
Nowadays state w/ Pahvo pre-release
I installed new ISO build manjaro-kde-21.1-stable-staging-210816-linux513.iso (having stable-staging branch settings), switched to unstable branch and update it.
While re-building the 5.13.11-1 kernel (cause got the [ALPM] upgraded systemd (248.7-1 -> 249.3-1) update at least) and while installing the 5.14.rc6.d0815.g7c60610-1 kernel version (and the version of linux-firmware (20210719.r1990.168452e-1) was always the same (I do not know there the patch is: in every kernel version or just in linux-firmware package)) I never saw the warning again (I do not istalled the patch manually).
Again, it was the fresh ISO installation w/o manually installing the patch.
Thanks for global (for all) fix!
Nice. With the move forward from 5.10 I’ll finally be able to install it to the previously unrecognised SATA drive on my new laptop (leaving the NVME alone). I’ve had to use Kubuntu in the interim.
I assumed that this was only due to my not very high quality monitor (a Dell with 8 bit IPS panel.)
It appears timeshift is involved with the new snapshot support for btrfs. While it is a fine way to peform snapshots, I prefer using snapper and pre/post snapshots. Does this new snapshot support allow for removing timeshift and the installation of snapper? Or am I better off trying to figure out how to configure timeshift to do pre/post snapshots instead, to stay in the Manjaro way?
The following bugs.
1.No auto mount usb / hdd external.
2. alsamixer - you must manually enable front every time. The rest of the settings are saved. “sudo alsactl store” doesn’t fix it.
Thanks.
Nope, It’s because we’ve noticed it too late when the artist already was busy.
OK, thanx
A bit off-topic, but not every 8 bit IPS monitor are same: there are many 6 bit + FRC (Frame rate control - Wikipedia) and there are not many true 8 bit w/o FRC.
10 bit monitors are also not the same: 10 true bits or 10 = 8 true + 2 bit via FRC.
The only website to check it I know is displayspecifications.com but and there there is the note: The information on this website is provided on "as is, as available basis" without warranty of any kind....
So that info couldn’t be 100% guarantee also, but could be a one of start point to check a monitor model on.
So if you have 8 bit via 6 bit + FRC , and only 72% NTSC (or by sRGB sacle it is about 97%) color space usage it is not a very HQ monitor, it is very typical 10 years old IPS display technology.
Even current TFT TN tech much differ from how is was looks like the same TFT TN but 15 years ago, for example in aspect of currently wider color space usage.
@alven : My current (still)monitor will be replaced next year by another one that has 14 bits (8 bit + LUT), so this is nothing new for me - but thanks for the explanation
Too bad that Gnome does not come with Wayland, as in Fedora and although it is well optimized, Gnome-shell has a very high consumption compared to Fedora, but I loved the terminal
I installed new ISO build manjaro-kde-21.1-stable-staging-210816-linux513.iso having stable-staging branch settings.
BTRFS+LUKS was chosen (all operations via GUI installer and auto-partitioning used)).
Switched to unstable branch and updated it.
I found that saved log which I wanted to report: may be it can be helpful for someone developer.
It is very first / initial update after clean ISO installation.
Pacman's log key excerpt:
E: ERROR: can't list qgroups: quotas not enabled
E: btrfs returned an error: 256
E: Failed to query subvolume quota
Enabled subvolume quota support
Complete log
$ sudo pacman-mirrors -c Netherlands -P https -B unstable -a
::INFO Branch in config is changed
::INFO Protocols in config is changed
::WARNING https://repo.manjaro.org 'Connection: HTTPSConnectionPool(host='repo.manjaro.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9f2f3680d0>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
::WARNING https://wikipedia.org 'Connection: HTTPSConnectionPool(host='wikipedia.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9f2da3b6d0>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
::WARNING https://bitbucket.org 'Connection: HTTPSConnectionPool(host='bitbucket.org', port=443): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f9f2da3b310>: Failed to establish a new connection: [Errno -2] Name or service not known'))'
::INFO Internet connection appears to be down
::INFO Mirror ranking is not available
::INFO Mirror list is generated using random method
::INFO User generated mirror list
::INFO Custom mirror file saved: /var/lib/pacman-mirrors/custom-mirrors.json
::INFO Writing mirror list
::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/$repo/$arch
::Netherlands : https://mirror.koddos.net/manjaro/unstable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
::INFO To reset custom mirrorlist 'sudo pacman-mirrors -id'
::INFO To remove custom config run 'sudo pacman-mirrors -c all'
$ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
From 172.27.235.73 icmp_seq=1 Destination Net Unreachable
From 172.27.235.73 icmp_seq=2 Destination Net Unreachable
From 172.27.235.73 icmp_seq=3 Destination Net Unreachable
^C
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 2020ms
$ ping 8.8.8.8
64 bytes from 8.8.8.8: icmp_seq=1 ttl=103 time=39.1 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=103 time=39.8 ms
^C
2 packets transmitted, 2 received, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 39.133/39.467/39.801/0.334 ms
$ sudo pacman-mirrors -c Netherlands -P https -a -B unstable
::INFO => Mirror status: http://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
1.463 Netherlands : https://mirror.erickochen.nl/manjaro/
3.169 Netherlands : https://manjaro.mirrors.lavatech.top/
1.547 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
0.787 Netherlands : https://mirror.koddos.net/manjaro/
::Netherlands : https://mirror.erickochen.nl/manjaro/unstable/$repo/$arch
::Netherlands : https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
0.482 Netherlands : https://mirror.erickochen.nl/manjaro/
2.444 Netherlands : https://manjaro.mirrors.lavatech.top/
0.630 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
0.688 Netherlands : https://mirror.koddos.net/manjaro/
$ sudo pacman -Syu
:: Synchronising package databases...
core 169.4 KiB 204 KiB/s 00:01 [####################################################################] 100%
extra 1886.4 KiB 927 KiB/s 00:02 [####################################################################] 100%
community 6.6 MiB 1303 KiB/s 00:05 [####################################################################] 100%
multilib 176.2 KiB 177 KiB/s 00:01 [####################################################################] 100%
resolving dependencies...
Package (9) Old Version New Version Net Change Download Size
multilib/lib32-systemd 248.7-1 249.3-1 0.08 MiB 0.78 MiB
extra/libpamac 11.0.1-3 11.1.0beta-2 0.21 MiB 0.83 MiB
extra/libpamac-flatpak-plugin 11.0.1-2 11.1.0beta-2 0.00 MiB 0.04 MiB
extra/libpamac-snap-plugin 11.0.1-2 11.1.0beta-2 0.00 MiB 0.03 MiB
extra/pamac-cli 10.1.3-3 10.2.0beta-1 0.00 MiB 0.08 MiB
extra/pamac-gtk 10.1.3-3 10.2.0beta-1 0.01 MiB 0.22 MiB
core/systemd 248.7-1 249.3-1 0.66 MiB 8.56 MiB
core/systemd-libs 248.7-1 249.3-1 0.10 MiB 0.77 MiB
core/systemd-sysvcompat 248.7-1 249.3-1 0.00 MiB 0.01 MiB
Total Download Size: 11.31 MiB
Total Installed Size: 34.83 MiB
Net Upgrade Size: 1.06 MiB
:: Retrieving packages...
systemd-sysvcompat-249.3-1-x86_64 6.2 KiB 5.94 KiB/s 00:01 [####################################################################] 100%
lib32-systemd-249.3-1-x86_64 798.8 KiB 722 KiB/s 00:01 [####################################################################] 100%
libpamac-flatpak-plugin-11.1.0beta-2-x86_64 39.6 KiB 30.0 KiB/s 00:01 [####################################################################] 100%
libpamac-snap-plugin-11.1.0beta-2-x86_64 35.5 KiB 24.3 KiB/s 00:01 [####################################################################] 100%
libpamac-11.1.0beta-2-x86_64 849.6 KiB 257 KiB/s 00:03 [####################################################################] 100%
systemd-libs-249.3-1-x86_64 785.4 KiB 237 KiB/s 00:03 [####################################################################] 100%
pamac-cli-10.2.0beta-1-x86_64 78.1 KiB 21.1 KiB/s 00:04 [####################################################################] 100%
systemd-249.3-1-x86_64 8.6 MiB 1281 KiB/s 00:07 [####################################################################] 100%
pamac-gtk-10.2.0beta-1-x86_64 221.5 KiB 29.8 KiB/s 00:07 [####################################################################] 100%
Total (9/9) 11.3 MiB 1539 KiB/s 00:08 [####################################################################] 100%
(9/9) checking keys in keyring [####################################################################] 100%
(9/9) checking package integrity [####################################################################] 100%
(9/9) loading package files [####################################################################] 100%
(9/9) checking for file conflicts [####################################################################] 100%
(9/9) checking available disk space [####################################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/dm-0 (nvme0n1p2)' at '/run/timeshift/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/dm-0, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-08-17_15-09-52
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-08-17_15-09-52/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-08-17_15-09-52/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-08-17_15-09-52': ondemand
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-08-17 15:09:52 | timeshift-btrfs/snapshots/2021-08-17_15-09-52/@
Found 1 snapshot(s)
done
(1/9) upgrading systemd-libs [####################################################################] 100%
(2/9) upgrading systemd [####################################################################] 100%
(3/9) upgrading lib32-systemd [####################################################################] 100%
(4/9) upgrading libpamac [####################################################################] 100%
(5/9) upgrading libpamac-flatpak-plugin [####################################################################] 100%
(6/9) upgrading libpamac-snap-plugin [####################################################################] 100%
(7/9) upgrading pamac-cli [####################################################################] 100%
(8/9) upgrading pamac-gtk [####################################################################] 100%
(9/9) upgrading systemd-sysvcompat [####################################################################] 100%
( 1/14) Creating system user accounts...
( 2/14) Updating journal message catalog...
( 3/14) Reloading system manager configuration...
( 4/14) Updating udev hardware database...
( 5/14) Applying kernel sysctl settings...
( 6/14) Creating temporary files...
( 7/14) Reloading device manager configuration...
( 8/14) Arming ConditionNeedsUpdate...
( 9/14) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> Starting build: 5.13.11-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
(10/14) Refreshing PackageKit...
(11/14) Reloading system bus configuration...
(12/14) Updating icon theme caches...
(13/14) Updating the desktop file MIME type cache...
(14/14) Updating the MIME type database...
$ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
After that error during initial update I see no more problems in several further updates.
And in the [Solved] Btrfs error 256 on Setup Assistant - Garuda Installer Images - Garuda Linux Forum topic it mentioned like sort of “normal error”. Does he right or wrong I do not know, but the error survived at least from that Jan 'till Aug: 7 months.
I did a new install of Manjaro Gnome 21.1 Pahvo.
There was one issue I would like to see fixed:
After installation, the touchegg service is not enabled by default, which causes that the gestures are not working in the x11 session.
For the rest, I really like how the team made gnome 40 this polished.
Thanks for the hard work!
There is the issue of dolphin that can not open the terminal by pressing Shift+ F4, because the package kinit is missing.
Here is the solution:
Discussed here [Testing Update] 2021-08-16 - Kernels, KDE Frameworks, KDE Gear, Wine, KDE-git, Python - #12 by flux
Basically kinit is not a dependency anymore of Dolphin, nor an optional dependency.
