Macbook Wifi not working
Hi all!
Very very new to using Manjaro, please send help > <
Just installed Manjaro on my Macbook and the Wifi is not showing up as a option to connect. Have read many posts and tried to install the broadcom drivers but hasn’t worked. Please send help as to what to do next?
inxi --admin --verbosity=7 --filter --width         ✔
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=df76bf87-c617-4036-beff-227dd820a99c rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Apple product: MacBookPro9,2 v: 1.0
    serial: <superuser required> Chassis: type: 10 v: Mac-6F01561E16C75D06
  Mobo: Apple model: Mac-6F01561E16C75D06 v: MacBookPro9,2
    serial: <superuser required> UEFI: Apple v: 226.0.0.0.0 date: 04/16/2019
  ID-1: BAT0 charge: 60.0 Wh (96.0%) condition: 62.5/63.2 Wh (98.8%)
    volts: 12.6 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
    status: charging cycles: 4
  RAM: total: 15.53 GiB used: 2.82 GiB (18.2%)
  Info: model: Intel Core i7-3520M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1799 high: 3600 min/max: 1200/3600 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3600 2: 1200 3: 1197
    4: 1200 bogomips: 23156
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept
    erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
    bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
    s-diag: 398mm (15.69") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: Apple Color LCD built: 2009 res: 1280x800 dpi: 114
    gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3") ratio: 16:10
    modes: 1280x800
  API: OpenGL v: 4.2 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) direct-render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp1s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
    driver: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 14e4:4331 class-ID: 0280
  Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
    bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
  Local Storage: total: 465.76 GiB used: 9.48 GiB (2.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 1B6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-R UJ-8A8 rev: HB14
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 9.48 GiB (2.1%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: df76bf87-c617-4036-beff-227dd820a99c
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: FD38-44D9
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Apple FaceTime HD Camera type: Video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 0424:2513 class-ID: 0900
  Hub-6: 2-1.8.1:4 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
    Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500
  Device-1: 2-1.8.1.3:9 info: Apple Bluetooth USB Host Controller
    type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
  Device-2: 2-1.8.2:5 info: Apple Built-in IR Receiver type: HID
    driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
    chip-ID: 05ac:8242 class-ID: 0300
  Device-3: 2-1.8.3:6 info: Apple Internal Keyboard/Trackpad (ANSI)
    type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 40mA chip-ID: 05ac:0252 class-ID: 0301
  Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 68.0 C mobo: N/A
  Processes: 192 Uptime: 1h 8m wakeups: 2 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1178 libs: 354 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.26
Many many thanks! <33
MacBookPro9,x - ArchWiki . I’d go with the solution of the b43-firmware package, the broadcom-wl solution is a bit shaky at the moment. Also try the 5.15LTS kernel, at least as a fall-back.
Hi thanks for the reply!! <333
Sorry to trouble you for more instructions! but can you please tell me what to do exactly? like the commands i need to type in?
Open the Add/remove software (the gui of the pamac package manager), search for ‘b43-firmware’, install it and reboot .
It’s an AUR (Arch User Repository) package, so if it doesn’t show in the Add/remove software you have to enable support for Third Party AUR repository:
Open Add/remove software >> click on the 3 vertical dots >> pick ‘Preferences’ >> type in your password >> pick ‘Third Party’ tab >> Enable AUR support and search again for ‘b43-firmware’.
Hi I have installed this firmware successfully and rebooted. However, the Wi-Fi is still not showing in the networks :persevere:
This is how it looks right now:
  Device-2: Broadcom BCM4331 802.11a/b/g/n driver: N/A modules: bcma pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4331
    class-ID: 0280
Also I see there is option for adding connection in the system settings. Do I need to add it manually?
Again, thanks so much for the replies!!
Hello @Lalo,
this N/A says that no driver is loaded for your wifi device.
Perhaps the right driver isnt installed or blacklisted. Can post the output from this command:
grep blacklist /etc/modprobe.d/*
Hi @kisun !
Thanks for the reply!
I have typed in the command and this is the output:
grep blacklist /etc/modprobe.d/*         1 ✘
zsh: no matches found: /etc/modprobe.d/*
Can you run the following commands one after the other.
sudo modprobe -r wl
sudo modprobe b43 allhwsupport=1
That should switch wifi on. To make it permanent open /etc/modules-load.d/modules.conf and add b43 underneath:
# List of modules to load at boot
b43
Now open /etc/modprobe.d folder and create empty document and name it b43.conf, open it and make it look like this:
options b43 allhwsupport=1
Reboot and it should work.
Yes it worked!
Thank you!! <333
You’ll have to execute the 2 steps to make it permanent but well done.
Hi again! Sorry went out and just saw the edits!
I tried to type in the command:
But the output was:
zsh: permission denied: /etc/modules-load.d/modules.conf
Thank you for the updated edits!
Can you use your file browser for this? Sorry, I’m on xfce, I don’t know if this works in kde.
Step 1: Go to /etc/modules-load.d folder, right-click on it and ‘Open as administrator’? That should allow you to edit the modules.conf file and add ‘b43’ at the bottom.
Step 2: Open /etc/modprobe.d folder, right-click >> ‘create new document’, name it ‘b43.conf’, open it and add ‘options b43 allhwsupport=1’.
If the above doesn’t work you can do all this in a terminal, use:
Step 1: use
sudo nano /etc/modules-load.d/modules.conf
to open the modules.conf file, edit it and add ‘b43’ at the bottom.
Step 2 : To create the b43.conf file inside the /etc/modprobe.d folder use:
sudo touch /etc/modprobe.d/b43.conf
Then open the new file with:
sudo nano /etc/modprobe.d/b43.conf
and edit it to make it look like this:
Hi again! And thanks for all the continued and updated replies!
I have followed all the steps and I have checked the files are already in where they are and with the new edits. However, the Wi-Fi still doesn’t show automatically upon booting.
The manual turning it on still works.
Check again, what’s the output of
cat /etc/modules-load.d/modules.conf
cat /etc/modules-load.d/modules.conf         ✔
b43
And
cat /etc/modprobe.d/b43.conf
rebooted and checked again:
cat /etc/modprobe.d/b43.conf         ✔
b43
That’s as it should be, maybe b43 is blacklisted. Show the output of
cat /etc/modprobe.d/blacklist.conf
cat /etc/modprobe.d/blacklist.conf         ✔
cat: /etc/modprobe.d/blacklist.conf: No such file or directory
ls /etc/modprobe.d
