Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK107M [GeForce GT 750M] driver: N/A
Device-3: Realtek Lenovo EasyCamera type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: intel gpu: i915
resolution: 1: 1440x900~60Hz 2: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2) v: 4.6 Mesa
22.1.6
In USB Boot.
as you can see, also in live usb the nvidia drivers are not being loaded, they are not available N/A:
so you were always running on intel gpu, and if you had performance issues, it was because you were on intel gpu, and not actually on nvidia
OK, but, why it works on Windows?
it would also work on linux, but these bumblebee drivers are bad… if you had the normal one, that we installed, there is a 50/50 chance that using envycontrol, which failed to install because fo the systemd issue, would work to switch only to nvidia…
so what i suggesting is to reinstall your system, because its messed up, you have this:
and these:
so backup your data and do a fresh install… then we can try to switch to only nvidia…
OK, but… please…
Tell me how to do a fresh install in order not to erase the home partition, only root.
I have dedicate this: /, uefi, swap, home… Can I start a fresh partition only on /?
do you have separate partition for your home?
post output:
lsblk -f
Yes, the command not in chroot gives me this
~ lsblk -f ✔
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
sda
├─sda1
│ vfat FAT32 NO_LABEL D01E-B912
├─sda2
│ swap 1 0ded34b8-b7db-4e6f-a4da-f2f40762fa61
├─sda3
│ ext4 1.0 a8ccfad4-a58e-4dc0-9fe6-482e02645c75
└─sda4
ext4 1.0 bb8c1ce1-4308-49e1-9999-7772d9af25b5
sdb
├─sdb1
│ ntfs FA74FBB074FB6DAF
├─sdb2
│ ntfs 01D5426B22D05470
├─sdb3
│ ntfs 01D66D0D82378F50
├─sdb4
│ vfat FAT32 0A1A-BFBB
├─sdb5
│ swap 1 55e0a3ad-8923-4eb3-92d4-a9c7152eef39
├─sdb6
│ ext4 1.0 49fd255f-df32-4c41-962a-91c8e715f1d6
└─sdb7
ext4 1.0 1f1ba5b0-a690-4149-8091-bc11c80bf5df
sdc iso966 Jolie MANJARO_KDE_2137
2022-08-16-12-52-10-00 0 100% /run/miso/bootmnt
├─sdc1
│ iso966 Jolie MANJARO_KDE_2137
│ 2022-08-16-12-52-10-00
└─sdc2
vfat FAT12 MISO_EFI C80E-8B3F
sdd
And this on chroot:
[manjaro /]# lsblk -f
loop0
loop1
loop2
loop3
sda
|-sda1 510.7M 0% /boot/efi
|-sda2
|-sda3 40.6G 36% /
`-sda4 302.9G 13% /home
sdb
|-sdb1
|-sdb2
|-sdb3
|-sdb4
|-sdb5
|-sdb6
`-sdb7
sdc
|-sdc1
`-sdc2
sdd
[manjaro /]#
I think is better this way in order to install root as a clean install and not touch home.
Can you guide me on this clean install?
you just select manual partitioning in the install options, then you bound it to your home partition, and DONT FORMAT THE HOME PARTITION… do a backup of your data too…
here is more info:
but i would just back up my data from my current home partition and do a fresh install…
I have one SSD GB dedicated only to Manjaro.
Can’t go with clean installation and mantain home, so, I run a manual partition with same parameters and I’m updating now.
Can you tell me how to go with clean installation without partitioning again?
I tell you when it finish to update.
@brahma OK, now I’m in a clean installation all updated.
Can you guide me in order to check and install propietary nvidia drivers?
in the link above there it is explained that you have to use manual partitioning and not format the home partition… but i never reinstalled system like that so really cant help you out on this, but you can search the forum on guides…
so check again with:
inxi -G && mhwd -li
v: kernel
Device-2: NVIDIA GK107M [GeForce GT 750M] driver: nouveau v: kernel
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
dri: crocus,nouveau gpu: i915 resolution: 1: 1440x900~60Hz 2: 1366x768~60Hz
22.1.7
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
~ mhwd -l ✔
> 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
~ mhwd -li ✔
@brahma Please!!! Help me before Halloween!!!
so now you are on open source drivers, so lets try with the envycontrol, but you will very likely end up with a black screen…
install the non bumblebee drivers:
sudo mhwd -i pci video-nvidia-390xx
install envycontrol:
pamac build envycontrol
then run this:
sudo envycontrol -s nvidia
it will prompt you for reboot so do it, and finger crossed ![]()
Stuck on plasma, can’t enter.
Now in chroot.
