Lower resolution (960x540) on video-hybrid-intel-nvidia-390xx-bumblebee
Lower resolution (960x540) on video-hybrid-intel-nvidia-390xx-bumblebee Can you help me on this?
    ~  xrandr                                                           ✔
Screen 0: minimum 8 x 8, current 1024 x 768, maximum 32767 x 32767
eDP1 connected primary 960x540+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
   960x540       59.82*
   864x486       60.00    59.92    59.57
   640x480       59.94
HDMI1 connected 1024x768+0+0 (normal left inverted right x axis y axis) 410mm x 260mm
   1440x900      59.89 +
   1280x1024     75.02    60.02
   1280x960      60.00
   1152x864      75.00
   1024x768      75.03*   60.00
   832x624       74.55
   800x600       75.00    60.32
   640x480       75.00    59.94
   720x400       70.08
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Any help, please?
    ~  mhwd -l -li                                     ✔
> Installed PCI configs:
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
> 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation:
    video-nvidia-390xx            2021.11.26               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
Can you help me @Mirdarthos)?
This are the correct resolutions for GeForce GT 750M (notebook)
800x600
1024x768
1152x720
1280x600
1280x720
1280x768
1360x768
1366x768
1440x900
@Mirdarthos
why do you have installed only this?
Because only this driver works relatively good on my system.
My card: GeForce GT 750M (notebook).
Can you suggest me another best driver to install corrrectly @brahma ?
uninstall it:
sudo mhwd -r pci video-hybrid-intel-nvidia-390xx-bumblebee
and then install the proper one:
sudo mhwd -a pci nonfree 0300
maybe running only on nvidia would be better?
@brahma Yes, I think! But I’m booting from USB and applying sudo manjaro-chroot -a.
Graphics starts, I see desktop, but taskbar is missed and I can’t do anything.
so you are now in chroot?
post output from:
mhwd -l -li
find /etc/X11/ -name "*.conf"
ls /etc/modprobe.d
The resulto of sudo mhwd -a pci nonfree 0300
was
Successfully installed video-hybrid-intel-nvidia-390xx-bumblebee
[manjaro /]#  sudo mhwd -a pci nonfree 0300
> Using config 'video-hybrid-intel-nvidia-390xx-bumblebee' for device: 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation GK107M [GeForce GT 750M]
> Using config 'video-hybrid-intel-nvidia-390xx-bumblebee' for device: 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation 4th Gen Core Processor Integrated Graphics Controller
> Installing video-hybrid-intel-nvidia-390xx-bumblebee...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-bumblebee/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: primus will be installed before its bumblebee dependency
Packages (12) egl-wayland-2:1.1.11-2  eglexternalplatform-1.1-2  libxnvctrl-390xx-390.154-1  libxvmc-1.0.13-1  primus-20151110-9  bumblebee-3.2.1-22  lib32-nvidia-390xx-utils-390.154-1  lib32-primus-20151110-4  linux515-bbswitch-0.8-89  linux515-nvidia-390xx-390.154-18  nvidia-390xx-utils-390.154-2  xf86-video-intel-1:2.99.917+916+g31486f40-2
Total Installed Size:  213.86 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing primus...
installing eglexternalplatform...
installing egl-wayland...
installing libxnvctrl-390xx...
installing nvidia-390xx-utils...
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-390xx-utils
    xorg-server-devel: nvidia-xconfig
    opencl-nvidia-390xx: OpenCL support
installing bumblebee...
Don't forget to add yourself to the 'bumblebee' group to use Bumblebee
Optional dependencies for bumblebee
    xf86-video-nouveau: nouveau driver
    nouveau-dri: 3D acceleration features fo nouveau
    bbswitch: switch on/off discrete card [pending]
    nvidia: NVIDIA kernel driver [pending]
    virtualgl: alternative back-end for optirun
    lib32-virtualgl: run 32bit applications with optirun
    lib32-primus: faster back-end for optirun [pending]
installing libxvmc...
installing xf86-video-intel...
>>> This driver now uses DRI3 as the default Direct Rendering
    Infrastructure. You can try falling back to DRI2 if you run
    into trouble. To do so, save a file with the following
    content as /etc/X11/xorg.conf.d/20-intel.conf :
      Section "Device"
        Identifier  "Intel Graphics"
        Driver      "intel"
        Option      "DRI" "2"             # DRI3 is now default
        #Option      "AccelMethod"  "sna" # default
        #Option      "AccelMethod"  "uxa" # fallback
      EndSection
Optional dependencies for xf86-video-intel
    libxrandr: for intel-virtual-output [installed]
    libxinerama: for intel-virtual-output [installed]
    libxcursor: for intel-virtual-output [installed]
    libxtst: for intel-virtual-output [installed]
    libxss: for intel-virtual-output [installed]
installing lib32-nvidia-390xx-utils...
Optional dependencies for lib32-nvidia-390xx-utils
    lib32-opencl-nvidia
installing lib32-primus...
installing linux515-nvidia-390xx...
installing linux515-bbswitch...
ldconfig: File /usr/lib32/libcurl.so.4.6.0 is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-glib.so.4.0.12 is empty, not checked.
ldconfig: File /usr/lib32/libpipewire-0.3.so is empty, not checked.
ldconfig: File /usr/lib32/libindicator.so.7 is empty, not checked.
ldconfig: File /usr/lib32/libnss3.so is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.2.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.2.0 is empty, not checked.
ldconfig: File /usr/lib32/libindicator.so is empty, not checked.
ldconfig: File /usr/lib32/libidn.so.11 is empty, not checked.
ldconfig: File /usr/lib32/libcaca.so is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-glib.so.4 is empty, not checked.
ldconfig: File /usr/lib32/libvpx.so.1.3 is empty, not checked.
ldconfig: File /usr/lib32/libnsl.so.3.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-gtk.so.4.0.12 is empty, not checked.
ldconfig: File /usr/lib32/libappindicator.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_ttf-2.0.so.0.2000.0 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_image-2.0.so.0.600.1 is empty, not checked.
ldconfig: File /usr/lib32/libjpeg.so.62.2.0 is empty, not checked.
ldconfig: File /usr/lib32/libgtk-x11-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.8.0 is empty, not checked.
ldconfig: File /usr/lib32/libgtk-x11-2.0.so.0.2400.33 is empty, not checked.
ldconfig: File /usr/lib32/libwebpdecoder.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.7.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libcaca.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libSDL-1.2.so.1.2.52 is empty, not checked.
ldconfig: File /usr/lib32/libgailutil.so.18 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.7.0 is empty, not checked.
ldconfig: File /usr/lib32/libgailutil.so is empty, not checked.
ldconfig: File /usr/lib32/libXss.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libfreeblpriv3.so is empty, not checked.
ldconfig: File /usr/lib32/libnsssysinit.so is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-gtk.so is empty, not checked.
ldconfig: File /usr/lib32/libsmpeg-0.4.so.0.1.4 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.1.0 is empty, not checked.
ldconfig: File /usr/lib32/libmodplug.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libtheoraenc.so.1.1.2 is empty, not checked.
ldconfig: File /usr/lib32/libidn.so.11.6.16 is empty, not checked.
ldconfig: File /usr/lib32/libSDL_image-1.2.so.0.8.4 is empty, not checked.
ldconfig: File /usr/lib32/libvpx.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libplds4.so is empty, not checked.
ldconfig: File /usr/lib32/libwebpdemux.so is empty, not checked.
ldconfig: File /usr/lib32/libSDL_mixer.so is empty, not checked.
ldconfig: File /usr/lib32/libSDL_mixer-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libwrap.so.0.7.6 is empty, not checked.
ldconfig: File /usr/lib32/libmikmod.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_image.so is empty, not checked.
ldconfig: File /usr/lib32/libdbus-glib-1.so is empty, not checked.
ldconfig: File /usr/lib32/libSDL_ttf.so is empty, not checked.
ldconfig: File /usr/lib32/libXss.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libGLEW.so.1.10.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebp.so.7.1.5 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_image-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libgdk-x11-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebp.so is empty, not checked.
ldconfig: File /usr/lib32/libImlib2.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libsmpeg-0.4.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-compat.so.4.8.0 is empty, not checked.
ldconfig: File /usr/lib32/libtheoradec.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libfreebl3.so is empty, not checked.
ldconfig: File /usr/lib32/libSDL_mixer-1.2.so.0.12.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.3.0 is empty, not checked.
ldconfig: File /usr/lib32/libwrap.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libnsl.so is empty, not checked.
ldconfig: File /usr/lib32/libudev.so.0.0.9999 is empty, not checked.
ldconfig: File /usr/lib32/libtiff.so.4 is empty, not checked.
ldconfig: File /usr/lib32/libnm.so is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.6.0 is empty, not checked.
ldconfig: File /usr/lib32/libtiffxx.so.4.3.7 is empty, not checked.
ldconfig: File /usr/lib32/libgailutil.so.18.0.1 is empty, not checked.
ldconfig: File /usr/lib32/libnm.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libtheora.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libImlib2.so is empty, not checked.
ldconfig: File /usr/lib32/libcaca.so.0.99.20 is empty, not checked.
ldconfig: File /usr/lib32/libmikmod.so.3.3.0 is empty, not checked.
ldconfig: File /usr/lib32/libcrypto.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_mixer-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-glib.so is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.3.0 is empty, not checked.
ldconfig: File /usr/lib32/libtheoradec.so.1.1.4 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4 is empty, not checked.
ldconfig: File /usr/lib32/libtiff.so.4.3.7 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libXss.so is empty, not checked.
ldconfig: File /usr/lib32/libjpeg.so.62 is empty, not checked.
ldconfig: File /usr/lib32/libpng.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libpng.so.3.59.0 is empty, not checked.
ldconfig: File /usr/lib32/libmikmod.so is empty, not checked.
ldconfig: File /usr/lib32/libnssutil3.so is empty, not checked.
ldconfig: File /usr/lib32/libgcrypt.so.11 is empty, not checked.
ldconfig: File /usr/lib32/libwebpdecoder.so is empty, not checked.
ldconfig: File /usr/lib32/libcrypt.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libnm.so.0.1.0 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_ttf-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libusb-1.0.so.0.3.0 is empty, not checked.
ldconfig: File /usr/lib32/libindicator.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebp.so.7 is empty, not checked.
ldconfig: File /usr/lib32/libdbusmenu-gtk.so.4 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_mixer.so is empty, not checked.
ldconfig: File /usr/lib32/libssl.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebpmux.so is empty, not checked.
ldconfig: File /usr/lib32/libgdk-x11-2.0.so.0.2400.33 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebpmux.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.4.0 is empty, not checked.
ldconfig: File /usr/lib32/libpng12.so.0.59.0 is empty, not checked.
ldconfig: File /usr/lib32/libgcrypt.so.11.8.5 is empty, not checked.
ldconfig: File /usr/lib32/libSDL_image.so is empty, not checked.
ldconfig: File /usr/lib32/libappindicator.so is empty, not checked.
ldconfig: File /usr/lib32/libudev.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libmodplug.so is empty, not checked.
ldconfig: File /usr/lib32/libusb-1.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libgtk-x11-2.0.so is empty, not checked.
ldconfig: File /usr/lib32/libtiffxx.so.4 is empty, not checked.
ldconfig: File /usr/lib32/libmodplug.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.5.0 is empty, not checked.
ldconfig: File /usr/lib32/libssl3.so is empty, not checked.
ldconfig: File /usr/lib32/libGLEW.so.1.10 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_mixer-2.0.so.0.600.1 is empty, not checked.
ldconfig: File /usr/lib32/libwebpdemux.so.2 is empty, not checked.
ldconfig: File /usr/lib32/libwebpmux.so.3.0.10 is empty, not checked.
ldconfig: File /usr/lib32/libpng12.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.1.0 is empty, not checked.
ldconfig: File /usr/lib32/libwebpdecoder.so.3.1.5 is empty, not checked.
ldconfig: File /usr/lib32/librtmp.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libgdk-x11-2.0.so is empty, not checked.
ldconfig: File /usr/lib32/libSDL_ttf-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libpng12.so is empty, not checked.
ldconfig: File /usr/lib32/libtheoradec.so is empty, not checked.
ldconfig: File /usr/lib32/libsmpeg.so is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.4.5.0 is empty, not checked.
ldconfig: File /usr/lib32/libsmime3.so is empty, not checked.
ldconfig: File /usr/lib32/libappindicator.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib32/libnspr4.so is empty, not checked.
ldconfig: File /usr/lib32/libwrap.so is empty, not checked.
ldconfig: File /usr/lib32/libtheora.so is empty, not checked.
ldconfig: File /usr/lib32/libtheoraenc.so.1 is empty, not checked.
ldconfig: File /usr/lib32/libSDL_ttf-2.0.so.0.10.1 is empty, not checked.
ldconfig: File /usr/lib32/libSDL2_ttf.so is empty, not checked.
ldconfig: File /usr/lib32/libImlib2.so.1.9.1 is empty, not checked.
ldconfig: File /usr/lib32/libsoftokn3.so is empty, not checked.
ldconfig: File /usr/lib32/libvpx.so.1.3.0 is empty, not checked.
ldconfig: File /usr/lib32/libtheoraenc.so is empty, not checked.
ldconfig: File /usr/lib32/libnsl.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libSDL_image-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib32/libcurl-gnutls.so.4.4.0 is empty, not checked.
ldconfig: File /usr/lib32/libdbus-glib-1.so.2.3.5 is empty, not checked.
ldconfig: File /usr/lib32/libcrypt.so.1.1.0 is empty, not checked.
ldconfig: File /usr/lib32/libpipewire-0.3.so.0.358.0 is empty, not checked.
ldconfig: File /usr/lib32/libplc4.so is empty, not checked.
ldconfig: File /usr/lib32/libwebpdemux.so.2.0.11 is empty, not checked.
ldconfig: File /usr/lib32/libcurl.so.3 is empty, not checked.
ldconfig: File /usr/lib32/libtheora.so.0.3.10 is empty, not checked.
ldconfig: File /usr/lib32/libSDL-1.2.so.0.old is empty, not checked.
ldconfig: File /usr/lib32/libusb-1.0.so is empty, not checked.
ldconfig: File /usr/lib32/libdbus-glib-1.so.2 is empty, not checked.
ldconfig: File /usr/lib32/libpipewire-0.3.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_and_profiler.so.4 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.6.0 is empty, not checked.
ldconfig: File /usr/lib/libindicator.so.7 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal.so.4 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.2.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.2.0 is empty, not checked.
ldconfig: File /usr/lib/libindicator.so is empty, not checked.
ldconfig: File /usr/lib/libopusurl.so.0.4.5 is empty, not checked.
ldconfig: File /usr/lib/libidn.so.11 is empty, not checked.
ldconfig: File /usr/lib/libprofiler.so.0.5.5 is empty, not checked.
ldconfig: File /usr/lib/libvpx.so.1.3 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-gtk.so.4.0.12 is empty, not checked.
ldconfig: File /usr/lib/libjpeg.so.62.2.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.8.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_debug.so.4.5.10 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.7.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_and_profiler.so is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.7.0 is empty, not checked.
ldconfig: File /usr/lib/libjxl_threads.so.0.7.0 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-gtk.so is empty, not checked.
ldconfig: File /usr/lib/libjxl_jni.so is empty, not checked.
ldconfig: File /usr/lib/libsmpeg-0.4.so.0.1.4 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.1.0 is empty, not checked.
ldconfig: File /usr/lib/libidn.so.11.6.16 is empty, not checked.
ldconfig: File /usr/lib/libSDL_image-1.2.so.0.8.4 is empty, not checked.
ldconfig: File /usr/lib/libvpx.so.1 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_image-2.0.so.0.600.2 is empty, not checked.
ldconfig: File /usr/lib/libSDL_mixer.so is empty, not checked.
ldconfig: File /usr/lib/libjxl.so.0.7 is empty, not checked.
ldconfig: File /usr/lib/libSDL_mixer-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libwrap.so.0.7.6 is empty, not checked.
ldconfig: File /usr/lib/libmikmod.so.3 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_image.so is empty, not checked.
ldconfig: File /usr/lib/libhwy_contrib.so.1 is empty, not checked.
ldconfig: File /usr/lib/libSDL_ttf.so is empty, not checked.
ldconfig: File /usr/lib/libhwy_test.so.1 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.1.10.0 is empty, not checked.
ldconfig: File /usr/lib/libjxl_threads.so is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal_debug.so.4 is empty, not checked.
ldconfig: File /usr/lib/libjxl.so is empty, not checked.
ldconfig: File /usr/lib/libopusfile.so.0.4.5 is empty, not checked.
ldconfig: File /usr/lib/libopusfile.so.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_image-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc.so is empty, not checked.
ldconfig: File /usr/lib/libsmpeg-0.4.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-compat.so.4.8.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL_mixer-1.2.so.0.12.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.3.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_mixer-2.0.so.0.600.2 is empty, not checked.
ldconfig: File /usr/lib/libhwy_test.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libwrap.so.0 is empty, not checked.
ldconfig: File /usr/lib/libudev.so.0.0.9999 is empty, not checked.
ldconfig: File /usr/lib/libtiff.so.4 is empty, not checked.
ldconfig: File /usr/lib/libopusurl.so is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.6.0 is empty, not checked.
ldconfig: File /usr/lib/libtiffxx.so.4.3.7 is empty, not checked.
ldconfig: File /usr/lib/libhwy_contrib.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_and_profiler.so.4.6.5 is empty, not checked.
ldconfig: File /usr/lib/libmikmod.so.3.3.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal.so.4.5.10 is empty, not checked.
ldconfig: File /usr/lib/libcrypto.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_mixer-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.3.0 is empty, not checked.
ldconfig: File /usr/lib/libprofiler.so is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4 is empty, not checked.
ldconfig: File /usr/lib/libjxl.so.0.7.0 is empty, not checked.
ldconfig: File /usr/lib/libtiff.so.4.3.7 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.3 is empty, not checked.
ldconfig: File /usr/lib/libjpeg.so.62 is empty, not checked.
ldconfig: File /usr/lib/libpng.so.3 is empty, not checked.
ldconfig: File /usr/lib/libpng.so.3.59.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_debug.so is empty, not checked.
ldconfig: File /usr/lib/libmikmod.so is empty, not checked.
ldconfig: File /usr/lib/libhwy_contrib.so is empty, not checked.
ldconfig: File /usr/lib/libjxl_threads.so.0.7 is empty, not checked.
ldconfig: File /usr/lib/libgcrypt.so.11 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal_debug.so.4.5.10 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal_debug.so is empty, not checked.
ldconfig: File /usr/lib/libcrypt.so.1 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_ttf-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_ttf-2.0.so.0.2000.1 is empty, not checked.
ldconfig: File /usr/lib/libindicator.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-gtk.so.4 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_mixer.so is empty, not checked.
ldconfig: File /usr/lib/libssl.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libopusurl.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.0.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_minimal.so is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.4.0 is empty, not checked.
ldconfig: File /usr/lib/libpng12.so.0.59.0 is empty, not checked.
ldconfig: File /usr/lib/libgcrypt.so.11.8.5 is empty, not checked.
ldconfig: File /usr/lib/libSDL_image.so is empty, not checked.
ldconfig: File /usr/lib/libudev.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtiffxx.so.4 is empty, not checked.
ldconfig: File /usr/lib/libhwy.so.1 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.5.0 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.1.10 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc.so.4.5.10 is empty, not checked.
ldconfig: File /usr/lib/libhwy_test.so is empty, not checked.
ldconfig: File /usr/lib/libprofiler.so.0 is empty, not checked.
ldconfig: File /usr/lib/libpng12.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.1.0 is empty, not checked.
ldconfig: File /usr/lib/librtmp.so.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL_ttf-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libpng12.so is empty, not checked.
ldconfig: File /usr/lib/libSDL.so is empty, not checked.
ldconfig: File /usr/lib/libsmpeg.so is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.4.5.0 is empty, not checked.
ldconfig: File /usr/lib/libhwy.so is empty, not checked.
ldconfig: File /usr/lib/libhwy.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libSDL-1.2.so is empty, not checked.
ldconfig: File /usr/lib/libwrap.so is empty, not checked.
ldconfig: File /usr/lib/libSDL-1.2.so.1.2.56 is empty, not checked.
ldconfig: File /usr/lib/libSDL_ttf-2.0.so.0.10.1 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_ttf.so is empty, not checked.
ldconfig: File /usr/lib/libvpx.so.1.3.0 is empty, not checked.
ldconfig: File /usr/lib/libopusfile.so is empty, not checked.
ldconfig: File /usr/lib/libSDL_image-1.2.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl-gnutls.so.4.4.0 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc.so.4 is empty, not checked.
ldconfig: File /usr/lib/libtcmalloc_debug.so.4 is empty, not checked.
ldconfig: File /usr/lib/libcrypt.so.1.1.0 is empty, not checked.
ldconfig: File /usr/lib/libcurl.so.3 is empty, not checked.
(1/7) Creating system user accounts...
(2/7) Reloading system manager configuration...
  Skipped: Running in chroot.
(3/7) Reloading device manager configuration...
(4/7) Arming ConditionNeedsUpdate...
(5/7) Updating module dependencies...
(6/7) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(7/7) Updating the desktop file MIME type cache...
bumblebee: install reason has been set to 'explicitly installed'
nvidia-390xx-utils: install reason has been set to 'explicitly installed'
xf86-video-intel: install reason has been set to 'explicitly installed'
lib32-primus: install reason has been set to 'explicitly installed'
lib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
linux515-nvidia-390xx: install reason has been set to 'explicitly installed'
linux515-bbswitch: install reason has been set to 'explicitly installed'
modprobe: FATAL: Module bbswitch not found in directory /lib/modules/5.15.60-1-MANJARO
xorg configuration file: '/etc/X11/mhwd.d/intel.conf'
Created symlink /etc/systemd/system/multi-user.target.wants/bumblebeed.service -> /usr/lib/systemd/system/bumblebeed.service.
Running in chroot, ignoring command 'start'
[manjaro /]# mhwd -l -li
[manjaro /]# find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/99-nvidia.conf
/etc/X11/xorg.conf
[manjaro /]#
[manjaro /]#  ls /etc/modprobe.d
99-nvidia.conf  mhwd-bbswitch.conf  mhwd-gpu.conf  mhwd-nvidia.conf  vmware-fuse.conf
[manjaro /]#
first, you have these:
your system is messed up!
so rerun update:
pacman-mirrors --fasttrack 5 && pacman -Syyu
any errors from this?
[manjaro /]#  pacman-mirrors --fasttrack 5 && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
  0.091 Chile          : https://mirror1.cl.netactuate.com/manjaro/
::INFO Writing mirror list
::Chile           : https://mirror1.cl.netactuate.com/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                                  163.0 KiB  1630 KiB/s 00:00 [####################################] 100%
 extra                                1834.2 KiB  4.03 MiB/s 00:00 [####################################] 100%
 community                               7.4 MiB  14.1 MiB/s 00:01 [####################################] 100%
 multilib                              174.6 KiB  13.1 MiB/s 00:00 [####################################] 100%
 there is nothing to do
[manjaro /]#
post output from:
ldconfig
rm all this?
[manjaro /]# ldconfig
[manjaro /]#
these are broken libraries that you have, they should be repaired… they are probably the reason, why you have issues… so run this:
pacman -Qqn | pacman --overwrite=* -S -
this will reinstall everything…
after its done, check again with:
ldconfig
What now? reboot? @brahma?
[manjaro /]#
