~ sudo pacman -S nvidia-390xx-utils lib32-nvidia-390xx-utils --overwrite '*' ✔
[sudo] password for pergamin:
resolving dependencies...
Packages (3) libxnvctrl-390xx-390.154-1 lib32-nvidia-390xx-utils-390.154-1 nvidia-390xx-utils-390.154-2
Total Installed Size: 194,78 MiB
:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring [####################################] 100%
(3/3) checking package integrity [####################################] 100%
(3/3) loading package files [####################################] 100%
(3/3) checking for file conflicts [####################################] 100%
(3/3) checking available disk space [####################################] 100%
(1/3) installing libxnvctrl-390xx [####################################] 100%
(2/3) installing nvidia-390xx-utils [####################################] 100%
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-390xx-utils
xorg-server-devel: nvidia-xconfig
opencl-nvidia-390xx: OpenCL support
(3/3) installing lib32-nvidia-390xx-utils [####################################] 100%
Optional dependencies for lib32-nvidia-390xx-utils
lib32-opencl-nvidia
(1/6) Creating system user accounts...
(2/6) Reloading system manager configuration...
(3/6) Reloading device manager configuration...
(4/6) Arming ConditionNeedsUpdate...
(5/6) Refreshing PackageKit...
(6/6) Updating the desktop file MIME type cache...
~ sudo mhwd -i pci video-nvidia-390xx --force` ✔ 8s
bquote>
bquote>
~ sudo mhwd -i pci video-nvidia-390xx --force INT ✘
> Installing video-nvidia-390xx...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
community downloading...
multilib downloading...
warning: nvidia-390xx-utils-390.154-2 is up to date -- skipping
warning: lib32-nvidia-390xx-utils-390.154-1 is up to date -- skipping
Packages (2) linux510-nvidia-390xx-390.154-15 linux515-nvidia-390xx-390.154-18
Total Installed Size: 30,21 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux510-nvidia-390xx...
installing linux515-nvidia-390xx...
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Refreshing PackageKit...
nvidia-390xx-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
linux510-nvidia-390xx: install reason has been set to 'explicitly installed'
linux515-nvidia-390xx: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia-390xx
Rebooting now…
Again with back screen, USB boot with chroot.
[manjaro /]# mhwd -l
> 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-390xx-bumblebee 2021.11.26 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
[manjaro /]# mhwd -li
> Installed PCI configs:
[manjaro /]#
So, nothing to do? Only bumblebee works, but, without control by nvidia settings?
brahma
28 October 2022 17:06
104
so lets do this, install this in chroot:
pamac build envycontrol
then run this:
envycontrol -s nvidia
exit chroot and reboot and see if you can boot
brahma
28 October 2022 17:07
106
i dont think it works, at least it didnt worked when we tried it before, the nvidia was not loaded…
[manjaro /]# pamac build envycontrol
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Checking envycontrol dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
envycontrol 2.1.1-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning envycontrol build files...
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
Error: Failed to build envycontrol
[manjaro /]#
brahma
28 October 2022 17:09
108
what is with your system? you dont run on systemd?
brahma
28 October 2022 17:13
110
im talking about this… do you have a normal manjaro installation?
Hmmmmm I have a normal Manjaro installation until all this problems with NVIDIA.
brahma
28 October 2022 17:17
112
i googled that log, and it looks that it may be related to WSL - Windows Subsystem for Linux … so i dont know…
at this point i would just reinstall, its too messed up
does your bios have a setting to switch between gpus?
I think that My bios can switch the GPUs. But, in order to be honest, I’ve installed Wine and Lutris in order to play MTGA and with bumblebee works… So…Wine and Lutris installation can impact on
Or not?
What’s yur recommendation?
brahma
28 October 2022 17:26
114
i dont use wine, or lutris, but no, they cant impact it…
so boot into bios, and switch to nvidia, you have installed already the drivers for it
In the setup appears this options:
Primary Display: SG
Options: Auto, IGFX, PEG, PCI, SG
I never touch this…
Which option I have to set?
I assume that SG is Second Graphic… Always have been like that.
brahma
28 October 2022 17:36
117
set it too PEG and see if you can boot into your installation
Black screen again… chroot again.
brahma
28 October 2022 17:46
119
do you still have the peg setting in bios?
if yes post output from:
inxi -G
[manjaro /]# inxi -G
12Graphics:
12Device-1 Intel 4th Gen Core Processor Integrated Graphics 12driver i915 12v kernel
12Device-2 NVIDIA GK107M [GeForce GT 750M] 12driver N/A
12Device-3 Realtek Lenovo EasyCamera 12type USB 12driver uvcvideo
12Display 12server X.org 12v 1.21.1.4 12with Xwayland 12v 22.1.3 12driver 12X 12loaded nvidia 12gpu i915
12resolution 121 1440x900 122 1366x768
12Message GL data unavailable for root.
[manjaro /]#
