uninstall the bumblebee drivers:
mhwd -r pci video-hybrid-intel-nvidia-390xx-bumblebee
then provide output from:
pacman -Qs 'bbswitch|bumblebee|optimus|gpu'
pamac list -qm
mhwd-kernel -li
[manjaro /]# pacman -Qs 'bbswitch|bumblebee|optimus|gpu'
local/libplacebo 4.208.0-1
Reusable library for GPU-accelerated video/image rendering primitives
local/mhwd-amdgpu 19.1.0-1
MHWD module-ids for amdgpu
[manjaro /]#
[manjaro /]# pamac list -qm
google-chrome
jamesdsp-pulse
manjaro-documentation-en
manjaro-firmware
ncurses5-compat-libs
yay-bin
[manjaro /]#
[manjaro /]# mhwd-kernel -li
Currently running: 5.15.60-1-MANJARO (linux515)
* linux515
* linux515-rt
[manjaro /]#
remove these:
pamac remove manjaro-documentation-en manjaro-firmware
these packages are dropped, you dont need them…
also remove the linux515-rt kernel if you are not needing it:
pamac remove linux515-rt
now post output again from this, to remove the leftover configs:
find /etc/X11/ -name "*.conf"
ls /etc/modprobe.d
and no need to create new post for every output, put them all in one
[manjaro /]# pamac remove manjaro-documentation-en manjaro-firmware
Preparing...
Checking dependencies...
To remove (2):
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
Total removed size: 12.6 MB
Apply transaction ? [y/N] y
Removing manjaro-documentation-en (20181009-1)... [1/2]
Removing manjaro-firmware (20160419-1)... [2/2]
Arming ConditionNeedsUpdate... [1/3]
Refreshing PackageKit... [2/3]
Error connecting: Could not connect: No such file or directory
Error: command failed to execute correctly
Updating the desktop file MIME type cache... [3/3]
[manjaro /]# pamac remove linux515-rt
Preparing...
Warning: base optionally requires linux: bare metal support
To remove (1):
linux515-rt 5.15.71_rt51-1 community
Total removed size: 105.6 MB
Running pre-transaction hooks...
Removing linux initcpios... [1/2]
Remove DKMS modules [2/2]
Removing linux515-rt (5.15.71_rt51-1)... [1/1]
Arming ConditionNeedsUpdate... [1/4]
Updating module dependencies... [2/4]
Refreshing PackageKit... [3/4]
Updating Grub-Bootmenu [4/4]
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
fgrep: warning: fgrep is obsolescent; using grep -F
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
Found Linux Mint 19.3 Tricia (19.3) on /dev/sdb6
done
[manjaro /]# find /etc/X11/ -name "*.conf"
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/99-nvidia.conf
/etc/X11/xorg.conf
[manjaro /]# ls /etc/modprobe.d
99-nvidia.conf mhwd-gpu.conf vmware-fuse.conf
remove the configs:
rm /etc/X11/xorg.conf.d/99-nvidia.conf
rm /etc/modprobe.d/99-nvidia.conf
and post output from:
cat /etc/modprobe.d/mhwd-gpu.conf
[manjaro /]# cat /etc/modprobe.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
[manjaro /]#
ok, so install linux510 as a backup kernel:
pamac install linux510
and install video drivers, for now without nvidia:
mhwd -i pci video-linux
mhwd -i pci video-modesetting
exit chroot:
exit
reboot and see if the resolution is correct and you have no issues you mentioned above
Not correct resolution… and Plasma not working, I cannot see Plasma taskbar.
Again with chroot.
Any comments?
and was it working normally before?
Since tuesday… yes…I had bumblebee running ok, and I installed prime switch, since that, became the disaster.
do you still have it installed?
pacman -Qs 'prime|switch'
[manjaro /]# pacman -Qs 'prime|switch'
local/usb_modeswitch 2.6.1-3
Activating switchable USB devices on Linux.
[manjaro /]#
Also, in normal mode, I have autologin. I create another user, but, without path, it was on the konsole.
May be desktop will fix entering with another user?
so its no longer there…
thats a good idea, to create a new user… can you open system settings when you boot back into your installation?
No. I haven’t taskbar or quick access or anything.
Neither access to konsole.
and the mouse cursor is working? right click on deskop shows the menu?
Yes, mouse is working. Righ click don’t work.
