Loginctl with second seat leads to crash of xorg/lightdm
Yesterday i tried to update manjaro. But after the Update the GUI won´t start any more. see: stable-update-2021-09-24. I do have btrfs and snapper, so i did a rollback. But i kept the defect snapshot, so i can look into it.
Then i tried my USB-stick with manjaro. When i booted from it, it did work flawlessly. Then i made the update to the stick. After that the stick will not boot into GUI any more. I can get into a console, but startx won´t work.
Schreibtisch sudo inxi -Fazy
  Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
  root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@
  bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
  modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
  Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
  UEFI: American Megatrends v: P1.10 date: 06/19/2018
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Info: 8-Core model: AMD Ryzen 7 2700 socket: AM4 bits: 64 type: MT MCP
  arch: Zen+ family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
  L1: 768 KiB L2: 4 MiB L3: 16 MiB
  bogomips: 102227
  Speed: 1377 MHz min/max: 1550/3200 MHz base/boost: 3200/4100 boost: enabled
  volts: 1.0 V ext-clock: 100 MHz Core speeds (MHz): 1: 1377 2: 1377 3: 1547
  4: 1547 5: 1546 6: 1543 7: 1546 8: 1546 9: 1376 10: 1384 11: 1378 12: 1383
  13: 1483 14: 1539 15: 1504 16: 1495
  disabled, RSB filling
  Device-1: NVIDIA GK107 [GeForce GT 740] vendor: eVga.com. driver: nouveau
  v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fc8 class-ID: 0300
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte
  driver: nouveau v: kernel bus-ID: 27:00.0 chip-ID: 10de:1c82 class-ID: 0300
  Device-3: Logitech C922 Pro Stream Webcam type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 1-6.1:5 chip-ID: 046d:085c
  class-ID: 0102 serial: <filter>
  Display: server: X.org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  OpenGL: renderer: NV137 v: 4.3 Mesa 21.1.6 direct render: Yes
  Device-1: NVIDIA GK107 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:0fb9
  class-ID: 0403
  Device-3: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
  v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-4: Logitech C922 Pro Stream Webcam type: USB
  Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  vendor: ASRock driver: r8169 v: kernel port: c000 bus-ID: 25:00.0
  IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  driver: btusb v: 0.8 bus-ID: 1-6.2:6 chip-ID: 0a12:0001 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
  Local Storage: total: 3.37 TiB used: 462.94 GiB (13.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
  size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC temp: 38.9 C scheme: GPT
  SMART: yes health: PASSED on: 113d 12h cycles: 174
  read-units: 2,100,878 [1.07 TB] written-units: 10,013,405 [5.12 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH31000G
  family: Marvell based SSDs size: 931.51 GiB block-size: physical: 512 B
  logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
  rev: 10RL temp: 34 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 268d 5h cycles: 1038
  ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SP610 size: 476.94 GiB
  block-size: physical: 512 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 2C temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 37d 18h cycles: 2735
  read: 360.9 MiB written: 504.1 MiB Old-Age: UDMA CRC errors: 446
  ID-4: /dev/sdc maj-min: 8:32 vendor: A-Data model: SX900 size: 119.24 GiB
  block-size: physical: 512 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 7a temp: 39 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 255d 11h cycles: 2954
  read: 4.2 MiB written: 2.3 MiB
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: A-Data model: USB Flash Drive
  size: 14.73 GiB block-size: physical: 512 B logical: 512 B type: SSD
  serial: <filter> rev: 1.00 scheme: GPT
  ID-1: / raw-size: 900 GiB size: 900 GiB (100.00%) used: 462.94 GiB (51.4%)
  fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 953 MiB size: 951.1 MiB (99.80%)
  used: 4.7 MiB (0.5%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 900 GiB size: 900 GiB (100.00%)
  used: 462.94 GiB (51.4%) fs: btrfs block-size: 4096 B dev: /dev/sda2
  maj-min: 8:2
  System Temperatures: cpu: 37.1 C mobo: N/A
  GPU: device: nouveau temp: 59.0 C fan: 0 device: nouveau temp: 39.0 C
  mV: 975.00
  Processes: 420 Uptime: 18m wakeups: 2 Memory: 47.05 GiB
  used: 9.62 GiB (20.4%) Init: systemd v: 248 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2068 lib: 457 Shell: Zsh (sudo)
  v: 5.8 running-in: xfce4-terminal inxi: 3.3.06
This is from the system while it works (before the update)
Did you check the journal after the GUI gained to load?
No, i did not check the journal. I checked only /var/log/Xorg.0.log
With GUI it is:
cat Xorg.0.log
[     7.972]
X.Org X Server 1.20.13
[     7.972] Build Operating System: Linux Manjaro Linux
[     7.972] Current Operating System: Linux manjaro18 5.10.68-1-MANJARO #1 SMP PREEMPT Wed Sep 22 12:29:47 UTC 2021 x86_64
[     7.972] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64 root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@ bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
[     7.972] Build Date: 29 July 2021  08:07:46PM
[     7.972]
[     7.972] Current version of pixman: 0.40.0
[     7.972] 	Before reporting problems, check http://wiki.x.org
[     7.972] Markers: (--) probed, (**) from config file, (==) default setting,
[     7.972] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 27 19:28:52 2021
[     7.972] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     7.972] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     7.973] (==) No Layout section.  Using the first Screen section.
[     7.973] (==) No screen section available. Using defaults.
[     7.973] (**) |-->Screen "Default Screen Section" (0)
[     7.973] (**) |   |-->Monitor "<default monitor>"
[     7.973] (==) No monitor specified for screen "Default Screen Section".
[     7.973] (==) Automatically adding devices
[     7.973] (==) Automatically enabling devices
[     7.973] (==) Automatically adding GPU devices
[     7.973] (==) Automatically binding GPU devices
[     7.973] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     7.973] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF,
	/usr/share/fonts/Type1,
	/usr/share/fonts/100dpi,
	/usr/share/fonts/75dpi
[     7.973] (==) ModulePath set to "/usr/lib/xorg/modules"
[     7.973] (II) The server relies on udev to provide the list of input devices.
[     7.973] (II) Module ABI versions:
[     7.973] 	X.Org ANSI C Emulation: 0.4
[     7.973] 	X.Org Video Driver: 24.1
[     7.973] 	X.Org XInput driver : 24.1
[     7.973] 	X.Org Server Extension : 10.0
[     7.974] (++) using VT number 7
[     7.974] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     7.975] (II) xfree86: Adding drm device (/dev/dri/card0)
[     7.982] (--) PCI: (1@0:0:0) 10de:0fc8:3842:3744 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     7.982] (--) PCI:*(39@0:0:0) 10de:1c82:1458:3733 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     7.982] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     7.982] (II) LoadModule: "glx"
[     7.982] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     7.984] (II) Module glx: vendor="X.Org Foundation"
[     7.984] 	compiled for 1.20.13, module version = 1.0.0
[     7.984] 	ABI class: X.Org Server Extension, version 10.0
[     7.984] (==) Matched nouveau as autoconfigured driver 0
[     7.984] (==) Matched nv as autoconfigured driver 1
[     7.984] (==) Matched modesetting as autoconfigured driver 2
[     7.984] (==) Matched fbdev as autoconfigured driver 3
[     7.984] (==) Matched vesa as autoconfigured driver 4
[     7.984] (==) Assigned the driver to the xf86ConfigLayout
[     7.984] (II) LoadModule: "nouveau"
[     7.985] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     7.985] (II) Module nouveau: vendor="X.Org Foundation"
[     7.985] 	compiled for 1.20.10, module version = 1.0.17
[     7.985] 	Module class: X.Org Video Driver
[     7.985] 	ABI class: X.Org Video Driver, version 24.1
[     7.985] (II) LoadModule: "nv"
[     7.985] (WW) Warning, couldn't open module nv
[     7.985] (EE) Failed to load module "nv" (module does not exist, 0)
[     7.985] (II) LoadModule: "modesetting"
[     7.985] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     7.986] (II) Module modesetting: vendor="X.Org Foundation"
[     7.986] 	compiled for 1.20.13, module version = 1.20.13
[     7.986] 	Module class: X.Org Video Driver
[     7.986] 	ABI class: X.Org Video Driver, version 24.1
[     7.986] (II) LoadModule: "fbdev"
[     7.987] (WW) Warning, couldn't open module fbdev
[     7.987] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     7.987] (II) LoadModule: "vesa"
[     7.987] (WW) Warning, couldn't open module vesa
[     7.987] (EE) Failed to load module "vesa" (module does not exist, 0)
[     7.987] (II) NOUVEAU driver
[     7.987] (II) NOUVEAU driver for NVIDIA chipset families :
[     7.987] 	RIVA TNT            (NV04)
[     7.987] 	RIVA TNT2           (NV05)
[     7.987] 	GeForce 256         (NV10)
[     7.987] 	GeForce 2           (NV11, NV15)
[     7.987] 	GeForce 4MX         (NV17, NV18)
[     7.987] 	GeForce 3           (NV20)
[     7.987] 	GeForce 4Ti         (NV25, NV28)
[     7.987] 	GeForce FX          (NV3x)
[     7.987] 	GeForce 6           (NV4x)
[     7.987] 	GeForce 7           (G7x)
[     7.987] 	GeForce 8           (G8x)
[     7.987] 	GeForce 9           (G9x)
[     7.988] 	GeForce GTX 2xx/3xx (GT2xx)
[     7.988] 	GeForce GTX 4xx/5xx (GFxxx)
[     7.988] 	GeForce GTX 6xx/7xx (GKxxx)
[     7.988] 	GeForce GTX 9xx     (GMxxx)
[     7.988] 	GeForce GTX 10xx    (GPxxx)
[     7.988] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     7.989] (II) [drm] nouveau interface version: 1.3.1
[     7.989] (WW) Falling back to old probe method for modesetting
[     7.989] (II) Loading sub module "dri2"
[     7.989] (II) LoadModule: "dri2"
[     7.989] (II) Module "dri2" already built-in
[     7.990] (--) NOUVEAU(0): Chipset: "NVIDIA NVE7"
[     7.990] (II) NOUVEAU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     7.990] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[     7.990] (==) NOUVEAU(0): RGB weight 888
[     7.990] (==) NOUVEAU(0): Default visual is TrueColor
[     7.990] (==) NOUVEAU(0): Using HW cursor
[     7.990] (==) NOUVEAU(0): Allowed maximum DRI level 2.
[     7.990] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[     7.990] (==) NOUVEAU(0): Page flipping enabled
[     7.990] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[     7.990] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[     7.990] (II) NOUVEAU(0): Initializing outputs ...
[     8.003] (II) NOUVEAU(0): Output DVI-I-1 has no monitor section
[     8.005] (II) NOUVEAU(0): Output DVI-D-1 has no monitor section
[     8.095] (II) NOUVEAU(0): Output HDMI-1 has no monitor section
[     8.095] (II) NOUVEAU(0): 3 crtcs needed for screen.
[     8.095] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[     8.095] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[     8.095] (II) NOUVEAU(0): Allocated crtc nr. 2 to this screen.
[     8.095] (II) NOUVEAU(0): Allocated crtc nr. 3 to this screen.
[     8.108] (II) NOUVEAU(0): EDID for output DVI-I-1
[     8.110] (II) NOUVEAU(0): EDID for output DVI-D-1
[     8.200] (II) NOUVEAU(0): EDID for output HDMI-1
[     8.200] (II) NOUVEAU(0): Manufacturer: GSM  Model: 7706  Serial#: 204790
[     8.200] (II) NOUVEAU(0): Year: 2020  Week: 12
[     8.200] (II) NOUVEAU(0): EDID Version: 1.3
[     8.200] (II) NOUVEAU(0): Digital Display Input
[     8.200] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[     8.200] (II) NOUVEAU(0): Gamma: 2.20
[     8.200] (II) NOUVEAU(0): DPMS capabilities: StandBy Suspend Off
[     8.200] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.200] (II) NOUVEAU(0): First detailed timing is preferred mode
[     8.200] (II) NOUVEAU(0): redX: 0.680 redY: 0.315   greenX: 0.280 greenY: 0.674
[     8.200] (II) NOUVEAU(0): blueX: 0.152 blueY: 0.050   whiteX: 0.312 whiteY: 0.329
[     8.200] (II) NOUVEAU(0): Supported established timings:
[     8.200] (II) NOUVEAU(0): 640x480@60Hz
[     8.200] (II) NOUVEAU(0): 800x600@60Hz
[     8.200] (II) NOUVEAU(0): 1024x768@60Hz
[     8.200] (II) NOUVEAU(0): Manufacturer's mask: 0
[     8.200] (II) NOUVEAU(0): Supported standard timings:
[     8.200] (II) NOUVEAU(0): #0: hsize: 1152  vsize 864  refresh: 60  vid: 16497
[     8.200] (II) NOUVEAU(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     8.200] (II) NOUVEAU(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[     8.200] (II) NOUVEAU(0): #3: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[     8.200] (II) NOUVEAU(0): #4: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     8.200] (II) NOUVEAU(0): #5: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     8.200] (II) NOUVEAU(0): Supported detailed timing:
[     8.200] (II) NOUVEAU(0): clock: 594.0 MHz   Image Size:  600 x 340 mm
[     8.200] (II) NOUVEAU(0): h_active: 3840  h_sync: 4016  h_sync_end 4104 h_blank_end 4400 h_border: 0
[     8.200] (II) NOUVEAU(0): v_active: 2160  v_sync: 2168  v_sync_end 2178 v_blanking: 2250 v_border: 0
[     8.200] (II) NOUVEAU(0): clock: 297.0 MHz   Image Size:  600 x 340 mm
[     8.200] (II) NOUVEAU(0): Ranges: V min: 56 V max: 61 Hz, H min: 30 H max: 135 kHz, PixClock max 605 MHz
[     8.200] (II) NOUVEAU(0): Monitor name: LG HDR 4K
[     8.200] (II) NOUVEAU(0): clock: 148.5 MHz   Image Size:  600 x 340 mm
[     8.200] (II) NOUVEAU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.200] (II) NOUVEAU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.200] (II) NOUVEAU(0): clock: 241.5 MHz   Image Size:  600 x 340 mm
[     8.200] (II) NOUVEAU(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[     8.200] (II) NOUVEAU(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[     8.200] (II) NOUVEAU(0): Serial No: 012NTSU60790
[     8.200] (II) NOUVEAU(0): Number of EDID sections to follow: 1
[     8.200] (II) NOUVEAU(0): EDID (in hex):
[     8.200] (II) NOUVEAU(0): 	00ffffffffffff001e6d0677f61f0300
[     8.200] (II) NOUVEAU(0): 	0c1e0103803c2278ea3e31ae5047ac27
[     8.200] (II) NOUVEAU(0): 	0c50542108007140818081c0a9c0d1c0
[     8.200] (II) NOUVEAU(0): 	81000101010108e80030f2705a80b058
[     8.201] (II) NOUVEAU(0): 	8a0058542100001e04740030f2705a80
[     8.201] (II) NOUVEAU(0): 	b0588a0058542100001a000000fd0038
[     8.201] (II) NOUVEAU(0): 	3d1e873c000a202020202020000000fc
[     8.201] (II) NOUVEAU(0): 	004c472048445220344b0a20202001bc
[     8.201] (II) NOUVEAU(0): 	02033b714d9022201f1203040161605d
[     8.201] (II) NOUVEAU(0): 	5e5f230907076d030c004000b83c2000
[     8.201] (II) NOUVEAU(0): 	6001020367d85dc401788003e30f0003
[     8.201] (II) NOUVEAU(0): 	e305c000e606050160605a023a801871
[     8.201] (II) NOUVEAU(0): 	382d40582c450058542100001e565e00
[     8.201] (II) NOUVEAU(0): 	a0a0a029503020350058542100001a00
[     8.201] (II) NOUVEAU(0): 	0000ff003031324e5453553630373930
[     8.201] (II) NOUVEAU(0): 	0a0000000000000000000000000000a4
[     8.201] (--) NOUVEAU(0): HDMI max TMDS frequency 300000KHz
[     8.201] (II) NOUVEAU(0): Printing probed modes for output HDMI-1
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync -vsync (67.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.201] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.201] (II) NOUVEAU(0): Output DVI-I-1 disconnected
[     8.201] (II) NOUVEAU(0): Output DVI-D-1 disconnected
[     8.201] (II) NOUVEAU(0): Output HDMI-1 connected
[     8.201] (II) NOUVEAU(0): Using exact sizes for initial modes
[     8.201] (II) NOUVEAU(0): Output HDMI-1 using initial mode 3840x2160 +0+0
[     8.201] (==) NOUVEAU(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.201] (II) NOUVEAU(0): Virtual size is 3840x2160 (pitch 0)
[     8.201] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 30.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 56.2 kHz, 25.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 54.0 kHz, 24.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "3840x2160": 296.7 MHz (scaled from 0.0 MHz), 67.4 kHz, 30.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "3840x2160": 296.7 MHz (scaled from 0.0 MHz), 53.9 kHz, 24.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "2560x1440": 241.5 MHz (scaled from 0.0 MHz), 88.8 kHz, 60.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.5 MHz (scaled from 0.0 MHz), 67.5 kHz, 60.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.5 MHz (scaled from 0.0 MHz), 56.2 kHz, 50.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.4 MHz (scaled from 0.0 MHz), 67.4 kHz, 59.9 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 33.8 kHz, 30.0 Hz
[     8.201] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 27.0 kHz, 24.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 33.7 kHz, 30.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 27.0 kHz, 24.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1600x900": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1280x800": 71.0 MHz (scaled from 0.0 MHz), 49.3 kHz, 59.9 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 45.0 kHz, 59.9 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[     8.202] (II) NOUVEAU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "720x576": 27.0 MHz (scaled from 0.0 MHz), 31.2 kHz, 50.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "720x480": 27.0 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "720x480": 27.0 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[     8.202] (II) NOUVEAU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[     8.202] (II) NOUVEAU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.202] (**) NOUVEAU(0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[     8.202] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.202] (==) NOUVEAU(0): DPI set to (96, 96)
[     8.202] (II) Loading sub module "fb"
[     8.202] (II) LoadModule: "fb"
[     8.202] (II) Loading /usr/lib/xorg/modules/libfb.so
[     8.203] (II) Module fb: vendor="X.Org Foundation"
[     8.203] 	compiled for 1.20.13, module version = 1.0.0
[     8.203] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.203] (II) Loading sub module "shadowfb"
[     8.203] (II) LoadModule: "shadowfb"
[     8.203] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[     8.204] (II) Module shadowfb: vendor="X.Org Foundation"
[     8.204] 	compiled for 1.20.13, module version = 1.0.0
[     8.204] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.204] (II) Loading sub module "dri2"
[     8.204] (II) LoadModule: "dri2"
[     8.204] (II) Module "dri2" already built-in
[     8.204] (EE) NOUVEAU(G0): [drm] failed to set drm interface version.
[     8.204] (EE) NOUVEAU(G0): [drm] error opening the drm
[     8.204] (EE) NOUVEAU(G0): 910:
[     8.204] (II) UnloadModule: "nouveau"
[     8.204] (II) UnloadModule: "modesetting"
[     8.204] (II) Unloading modesetting
[     8.206] (II) NOUVEAU(0): Channel setup complete.
[     8.206] (II) NOUVEAU(0): [COPY] async initialised.
[     8.206] (II) NOUVEAU(0): Hardware support for Present enabled
[     8.206] (II) NOUVEAU(0): [DRI2] Setup complete
[     8.206] (II) NOUVEAU(0): [DRI2]   DRI driver: nouveau
[     8.206] (II) NOUVEAU(0): [DRI2]   VDPAU driver: nouveau
[     8.206] (II) Loading sub module "exa"
[     8.206] (II) LoadModule: "exa"
[     8.206] (II) Loading /usr/lib/xorg/modules/libexa.so
[     8.207] (II) Module exa: vendor="X.Org Foundation"
[     8.207] 	compiled for 1.20.13, module version = 2.6.0
[     8.207] 	ABI class: X.Org Video Driver, version 24.1
[     8.207] (II) EXA(0): Driver allocated offscreen pixmaps
[     8.207] (II) EXA(0): Driver registered support for the following operations:
[     8.207] (II)         Solid
[     8.207] (II)         Copy
[     8.207] (II)         Composite (RENDER acceleration)
[     8.208] (II)         UploadToScreen
[     8.208] (II)         DownloadFromScreen
[     8.208] (==) NOUVEAU(0): Backing store enabled
[     8.208] (==) NOUVEAU(0): Silken mouse disabled
[     8.208] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[     8.208] (II) NOUVEAU(0): [XvMC] Extension initialized.
[     8.208] (==) NOUVEAU(0): DPMS enabled
[     8.208] (II) Initializing extension Generic Event Extension
[     8.208] (II) Initializing extension SHAPE
[     8.209] (II) Initializing extension MIT-SHM
[     8.209] (II) Initializing extension XInputExtension
[     8.209] (II) Initializing extension XTEST
[     8.209] (II) Initializing extension BIG-REQUESTS
[     8.209] (II) Initializing extension SYNC
[     8.209] (II) Initializing extension XKEYBOARD
[     8.210] (II) Initializing extension XC-MISC
[     8.210] (II) Initializing extension SECURITY
[     8.210] (II) Initializing extension XFIXES
[     8.210] (II) Initializing extension RENDER
[     8.210] (II) Initializing extension RANDR
[     8.211] (II) Initializing extension COMPOSITE
[     8.211] (II) Initializing extension DAMAGE
[     8.211] (II) Initializing extension MIT-SCREEN-SAVER
[     8.211] (II) Initializing extension DOUBLE-BUFFER
[     8.211] (II) Initializing extension RECORD
[     8.211] (II) Initializing extension DPMS
[     8.211] (II) Initializing extension Present
[     8.212] (II) Initializing extension DRI3
[     8.212] (II) Initializing extension X-Resource
[     8.212] (II) Initializing extension XVideo
[     8.212] (II) Initializing extension XVideo-MotionCompensation
[     8.212] (II) Initializing extension GLX
[     8.365] (II) AIGLX: Loaded and initialized nouveau
[     8.365] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.365] (II) Initializing extension XFree86-VidModeExtension
[     8.365] (II) Initializing extension XFree86-DGA
[     8.366] (II) Initializing extension XFree86-DRI
[     8.366] (II) Initializing extension DRI2
[     8.375] (II) NOUVEAU(0): NVEnterVT is called.
[     8.423] (II) NOUVEAU(0): Setting screen physical size to 1016 x 571
[     8.423] resize called 3840 2160
[     8.672] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.672] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.672] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.672] (**) Power Button: Applying InputClass "system-keyboard"
[     8.672] (II) LoadModule: "libinput"
[     8.672] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.678] (II) Module libinput: vendor="X.Org Foundation"
[     8.678] 	compiled for 1.20.11, module version = 1.1.0
[     8.678] 	Module class: X.Org XInput Driver
[     8.678] 	ABI class: X.Org XInput driver, version 24.1
[     8.678] (II) Using input driver 'libinput' for 'Power Button'
[     8.678] (**) Power Button: always reports core events
[     8.678] (**) Option "Device" "/dev/input/event1"
[     8.678] (**) Option "_source" "server/udev"
[     8.683] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.683] (II) event1  - Power Button: device is a keyboard
[     8.683] (II) event1  - Power Button: device removed
[     8.703] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     8.703] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.703] (**) Option "xkb_layout" "de"
[     8.745] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.745] (II) event1  - Power Button: device is a keyboard
[     8.746] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     8.746] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.746] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.746] (**) Power Button: Applying InputClass "system-keyboard"
[     8.746] (II) Using input driver 'libinput' for 'Power Button'
[     8.746] (**) Power Button: always reports core events
[     8.746] (**) Option "Device" "/dev/input/event0"
[     8.746] (**) Option "_source" "server/udev"
[     8.747] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.747] (II) event0  - Power Button: device is a keyboard
[     8.747] (II) event0  - Power Button: device removed
[     8.770] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     8.770] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     8.770] (**) Option "xkb_layout" "de"
[     8.771] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.771] (II) event0  - Power Button: device is a keyboard
[     8.772] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
[     8.772] (II) No input driver specified, ignoring this device.
[     8.772] (II) This device may have been added with another device file.
[     8.772] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
[     8.773] (II) No input driver specified, ignoring this device.
[     8.773] (II) This device may have been added with another device file.
[     8.773] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event19)
[     8.774] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event20)
[     8.774] (II) No input driver specified, ignoring this device.
[     8.774] (II) This device may have been added with another device file.
[     8.774] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event25)
[     8.775] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event26)
[     8.775] (II) No input driver specified, ignoring this device.
[     8.775] (II) This device may have been added with another device file.
[     8.775] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver mouse (/dev/input/event258)
[     8.775] (**) X10 Wireless Technology Inc USB Receiver mouse: Applying InputClass "evdev pointer catchall"
[     8.775] (**) X10 Wireless Technology Inc USB Receiver mouse: Applying InputClass "libinput pointer catchall"
[     8.775] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver mouse'
[     8.776] (**) X10 Wireless Technology Inc USB Receiver mouse: always reports core events
[     8.776] (**) Option "Device" "/dev/input/event258"
[     8.776] (**) Option "_source" "server/udev"
[     8.777] (II) event258 - X10 Wireless Technology Inc USB Receiver mouse: is tagged by udev as: Mouse
[     8.777] (II) event258 - X10 Wireless Technology Inc USB Receiver mouse: device is a pointer
[     8.778] (II) event258 - X10 Wireless Technology Inc USB Receiver mouse: device removed
[     8.816] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/input/input36/event258"
[     8.816] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver mouse" (type: MOUSE, id 8)
[     8.816] (**) Option "AccelerationScheme" "none"
[     8.816] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) selected scheme none/0
[     8.816] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) acceleration factor: 2.000
[     8.816] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) acceleration threshold: 4
[     8.818] (II) event258 - X10 Wireless Technology Inc USB Receiver mouse: is tagged by udev as: Mouse
[     8.818] (II) event258 - X10 Wireless Technology Inc USB Receiver mouse: device is a pointer
[     8.819] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver mouse (/dev/input/mouse3)
[     8.819] (II) No input driver specified, ignoring this device.
[     8.819] (II) This device may have been added with another device file.
[     8.820] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver (/dev/input/event257)
[     8.820] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "evdev keyboard catchall"
[     8.820] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "libinput keyboard catchall"
[     8.820] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "system-keyboard"
[     8.820] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver'
[     8.820] (**) X10 Wireless Technology Inc USB Receiver: always reports core events
[     8.820] (**) Option "Device" "/dev/input/event257"
[     8.820] (**) Option "_source" "server/udev"
[     8.822] (II) event257 - X10 Wireless Technology Inc USB Receiver: is tagged by udev as: Keyboard Pointingstick
[     8.823] (II) event257 - X10 Wireless Technology Inc USB Receiver: device is a pointer
[     8.823] (II) event257 - X10 Wireless Technology Inc USB Receiver: device is a keyboard
[     8.823] (II) event257 - X10 Wireless Technology Inc USB Receiver: device removed
[     8.840] (II) libinput: X10 Wireless Technology Inc USB Receiver: needs a virtual subdevice
[     8.840] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/rc/rc0/input35/event257"
[     8.840] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver" (type: MOUSE, id 9)
[     8.840] (**) Option "AccelerationScheme" "none"
[     8.840] (**) X10 Wireless Technology Inc USB Receiver: (accel) selected scheme none/0
[     8.840] (**) X10 Wireless Technology Inc USB Receiver: (accel) acceleration factor: 2.000
[     8.840] (**) X10 Wireless Technology Inc USB Receiver: (accel) acceleration threshold: 4
[     8.842] (II) event257 - X10 Wireless Technology Inc USB Receiver: is tagged by udev as: Keyboard Pointingstick
[     8.842] (II) event257 - X10 Wireless Technology Inc USB Receiver: device is a pointer
[     8.842] (II) event257 - X10 Wireless Technology Inc USB Receiver: device is a keyboard
[     8.843] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event6)
[     8.844] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[     8.844] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput keyboard catchall"
[     8.844] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "system-keyboard"
[     8.844] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.844] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.844] (**) Option "Device" "/dev/input/event6"
[     8.844] (**) Option "_source" "server/udev"
[     8.845] (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.846] (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.846] (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     8.873] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.0/0003:062A:4101.0003/input/input8/event6"
[     8.873] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 10)
[     8.873] (**) Option "xkb_layout" "de"
[     8.875] (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.875] (II) event6  - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.880] (II) config/udev: Adding input device Logitech M310 (/dev/input/event3)
[     8.880] (**) Logitech M310: Applying InputClass "evdev pointer catchall"
[     8.880] (**) Logitech M310: Applying InputClass "libinput pointer catchall"
[     8.880] (II) Using input driver 'libinput' for 'Logitech M310'
[     8.880] (**) Logitech M310: always reports core events
[     8.880] (**) Option "Device" "/dev/input/event3"
[     8.880] (**) Option "_source" "server/udev"
[     8.882] (II) event3  - Logitech M310: is tagged by udev as: Mouse
[     8.882] (II) event3  - Logitech M310: device set to 800 DPI
[     8.882] (II) event3  - Logitech M310: device is a pointer
[     8.882] (II) event3  - Logitech M310: device removed
[     8.913] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:1024.0009/input/input53/event3"
[     8.913] (II) XINPUT: Adding extended input device "Logitech M310" (type: MOUSE, id 11)
[     8.913] (**) Option "AccelerationScheme" "none"
[     8.913] (**) Logitech M310: (accel) selected scheme none/0
[     8.913] (**) Logitech M310: (accel) acceleration factor: 2.000
[     8.913] (**) Logitech M310: (accel) acceleration threshold: 4
[     8.915] (II) event3  - Logitech M310: is tagged by udev as: Mouse
[     8.915] (II) event3  - Logitech M310: device set to 800 DPI
[     8.915] (II) event3  - Logitech M310: device is a pointer
[     8.917] (II) config/udev: Adding input device Logitech M310 (/dev/input/mouse0)
[     8.917] (II) No input driver specified, ignoring this device.
[     8.917] (II) This device may have been added with another device file.
[     8.918] (II) config/udev: Adding input device Logitech K520 (/dev/input/event4)
[     8.918] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     8.918] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     8.918] (**) Logitech K520: Applying InputClass "system-keyboard"
[     8.918] (II) Using input driver 'libinput' for 'Logitech K520'
[     8.918] (**) Logitech K520: always reports core events
[     8.918] (**) Option "Device" "/dev/input/event4"
[     8.918] (**) Option "_source" "server/udev"
[     8.920] (II) event4  - Logitech K520: is tagged by udev as: Keyboard
[     8.920] (II) event4  - Logitech K520: device is a keyboard
[     8.920] (II) event4  - Logitech K520: device removed
[     8.933] (II) libinput: Logitech K520: needs a virtual subdevice
[     8.933] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:2011.000A/input/input54/event4"
[     8.933] (II) XINPUT: Adding extended input device "Logitech K520" (type: MOUSE, id 12)
[     8.933] (**) Option "AccelerationScheme" "none"
[     8.933] (**) Logitech K520: (accel) selected scheme none/0
[     8.933] (**) Logitech K520: (accel) acceleration factor: 2.000
[     8.933] (**) Logitech K520: (accel) acceleration threshold: 4
[     8.935] (II) event4  - Logitech K520: is tagged by udev as: Keyboard
[     8.935] (II) event4  - Logitech K520: device is a keyboard
[     8.937] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event15)
[     8.937] (II) No input driver specified, ignoring this device.
[     8.937] (II) This device may have been added with another device file.
[     8.937] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event16)
[     8.938] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event23)
[     8.938] (II) No input driver specified, ignoring this device.
[     8.938] (II) This device may have been added with another device file.
[     8.938] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event24)
[     8.939] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event29)
[     8.939] (II) No input driver specified, ignoring this device.
[     8.939] (II) This device may have been added with another device file.
[     8.939] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[     8.948] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "evdev keyboard catchall"
[     8.948] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "libinput keyboard catchall"
[     8.948] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "system-keyboard"
[     8.948] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver'
[     8.948] (**) X10 Wireless Technology Inc USB Receiver: always reports core events
[     8.948] (**) Option "Device" "/dev/input/event257"
[     8.948] (**) Option "_source" "_driver/libinput"
[     8.948] (II) libinput: X10 Wireless Technology Inc USB Receiver: is a virtual subdevice
[     8.948] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/rc/rc0/input35/event257"
[     8.948] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver" (type: KEYBOARD, id 13)
[     8.948] (**) Option "xkb_layout" "de"
[     8.948] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     8.948] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     8.948] (**) Logitech K520: Applying InputClass "system-keyboard"
[     8.948] (II) Using input driver 'libinput' for 'Logitech K520'
[     8.948] (**) Logitech K520: always reports core events
[     8.948] (**) Option "Device" "/dev/input/event4"
[     8.948] (II) libinput: Logitech K520: is a virtual subdevice
[     8.948] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:2011.000A/input/input54/event4"
[     8.948] (II) XINPUT: Adding extended input device "Logitech K520" (type: KEYBOARD, id 14)
[     9.054] (II) NOUVEAU(0): EDID vendor "GSM", prod id 30470
[     9.054] (II) NOUVEAU(0): Using EDID range info for horizontal sync
[     9.054] (II) NOUVEAU(0): Using EDID range info for vertical refresh
[     9.054] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[     9.054] (II) NOUVEAU(0): Modeline "3840x2160"x0.0  594.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (135.0 kHz eP)
[     9.054] (II) NOUVEAU(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync -vsync (67.5 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[     9.054] (II) NOUVEAU(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     9.054] (--) NOUVEAU(0): HDMI max TMDS frequency 300000KHz
[     9.057] (II) config/udev: Adding input device Logitech M310 (/dev/input/mouse0)
[     9.057] (II) No input driver specified, ignoring this device.
[     9.057] (II) This device may have been added with another device file.
[     9.058] (II) config/udev: removing device Logitech M310
[     9.058] (II) event3  - Logitech M310: device removed
[     9.106] (II) UnloadModule: "libinput"
[     9.107] (II) config/udev: Adding input device Logitech M310 (/dev/input/event3)
[     9.107] (**) Logitech M310: Applying InputClass "evdev pointer catchall"
[     9.107] (**) Logitech M310: Applying InputClass "libinput pointer catchall"
[     9.107] (II) Using input driver 'libinput' for 'Logitech M310'
[     9.107] (**) Logitech M310: always reports core events
[     9.107] (**) Option "Device" "/dev/input/event3"
[     9.107] (**) Option "_source" "server/udev"
[     9.109] (II) event3  - Logitech M310: is tagged by udev as: Mouse
[     9.109] (II) event3  - Logitech M310: device set to 800 DPI
[     9.110] (II) event3  - Logitech M310: device is a pointer
[     9.110] (II) event3  - Logitech M310: device removed
[     9.146] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:1024.0009/input/input53/event3"
[     9.146] (II) XINPUT: Adding extended input device "Logitech M310" (type: MOUSE, id 11)
[     9.147] (**) Option "AccelerationScheme" "none"
[     9.147] (**) Logitech M310: (accel) selected scheme none/0
[     9.147] (**) Logitech M310: (accel) acceleration factor: 2.000
[     9.147] (**) Logitech M310: (accel) acceleration threshold: 4
[     9.149] (II) event3  - Logitech M310: is tagged by udev as: Mouse
[     9.149] (II) event3  - Logitech M310: device set to 800 DPI
[     9.149] (II) event3  - Logitech M310: device is a pointer
[     9.150] (II) config/udev: removing device Logitech K520
[     9.150] (II) UnloadModule: "libinput"
[     9.150] (II) event4  - Logitech K520: device removed
[     9.176] (II) UnloadModule: "libinput"
[     9.177] (II) config/udev: Adding input device Logitech K520 (/dev/input/event4)
[     9.177] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     9.177] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     9.177] (**) Logitech K520: Applying InputClass "system-keyboard"
[     9.177] (II) Using input driver 'libinput' for 'Logitech K520'
[     9.177] (**) Logitech K520: always reports core events
[     9.177] (**) Option "Device" "/dev/input/event4"
[     9.177] (**) Option "_source" "server/udev"
[     9.179] (II) event4  - Logitech K520: is tagged by udev as: Keyboard
[     9.179] (II) event4  - Logitech K520: device is a keyboard
[     9.180] (II) event4  - Logitech K520: device removed
[     9.200] (II) libinput: Logitech K520: needs a virtual subdevice
[     9.200] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:2011.000A/input/input54/event4"
[     9.200] (II) XINPUT: Adding extended input device "Logitech K520" (type: MOUSE, id 12)
[     9.200] (**) Option "AccelerationScheme" "none"
[     9.200] (**) Logitech K520: (accel) selected scheme none/0
[     9.200] (**) Logitech K520: (accel) acceleration factor: 2.000
[     9.200] (**) Logitech K520: (accel) acceleration threshold: 4
[     9.202] (II) event4  - Logitech K520: is tagged by udev as: Keyboard
[     9.202] (II) event4  - Logitech K520: device is a keyboard
[     9.202] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     9.202] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     9.202] (**) Logitech K520: Applying InputClass "system-keyboard"
[     9.202] (II) Using input driver 'libinput' for 'Logitech K520'
[     9.203] (**) Logitech K520: always reports core events
[     9.203] (**) Option "Device" "/dev/input/event4"
[     9.203] (**) Option "_source" "_driver/libinput"
[     9.203] (II) libinput: Logitech K520: is a virtual subdevice
[     9.203] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0004/0003:046D:2011.000A/input/input54/event4"
[     9.203] (II) XINPUT: Adding extended input device "Logitech K520" (type: KEYBOARD, id 14)
[     9.203] (**) Option "xkb_layout" "de"
[     9.203] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:03.1/0000:27:00.0/drm/card1 /dev/dri/card1
[     9.203] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0 /dev/dri/card0
[     9.203] xf86: remove device 0 /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
[     9.203] failed to find screen to remove
[    10.616] (II) config/udev: Adding input device C922 Pro Stream Webcam (/dev/input/event7)
[    10.616] (**) C922 Pro Stream Webcam: Applying InputClass "evdev keyboard catchall"
[    10.616] (**) C922 Pro Stream Webcam: Applying InputClass "libinput keyboard catchall"
[    10.616] (**) C922 Pro Stream Webcam: Applying InputClass "system-keyboard"
[    10.616] (II) Using input driver 'libinput' for 'C922 Pro Stream Webcam'
[    10.616] (**) C922 Pro Stream Webcam: always reports core events
[    10.616] (**) Option "Device" "/dev/input/event7"
[    10.616] (**) Option "_source" "server/udev"
[    10.618] (II) event7  - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[    10.618] (II) event7  - C922 Pro Stream Webcam: device is a keyboard
[    10.618] (II) event7  - C922 Pro Stream Webcam: device removed
[    10.716] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.1/1-6.1:1.0/input/input56/event7"
[    10.716] (II) XINPUT: Adding extended input device "C922 Pro Stream Webcam" (type: KEYBOARD, id 15)
[    10.716] (**) Option "xkb_layout" "de"
[    10.718] (II) event7  - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[    10.718] (II) event7  - C922 Pro Stream Webcam: device is a keyboard
[    14.998] (II) config/udev: Adding input device Logitech Wireless Mouse PID:1020 (/dev/input/mouse2)
[    14.999] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    14.999] (II) No input driver specified, ignoring this device.
[    14.999] (II) This device may have been added with another device file.
[    15.050] (II) config/udev: Adding input device Logitech Wireless Mouse PID:1020 (/dev/input/event10)
[    15.050] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev pointer catchall"
[    15.050] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev keyboard catchall"
[    15.050] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput pointer catchall"
[    15.050] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput keyboard catchall"
[    15.050] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    15.050] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse PID:1020'
[    15.050] (**) Logitech Wireless Mouse PID:1020: always reports core events
[    15.050] (**) Option "Device" "/dev/input/event10"
[    15.050] (**) Option "_source" "server/udev"
[    15.052] (II) event10 - Logitech Wireless Mouse PID:1020: is tagged by udev as: Keyboard Mouse
[    15.053] (II) event10 - Logitech Wireless Mouse PID:1020: device is a pointer
[    15.053] (II) event10 - Logitech Wireless Mouse PID:1020: device is a keyboard
[    15.053] (II) event10 - Logitech Wireless Mouse PID:1020: device removed
[    15.080] (II) libinput: Logitech Wireless Mouse PID:1020: needs a virtual subdevice
[    15.080] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.4/1-6.4:1.1/0003:046D:C52F.000D/0003:046D:1020.000E/input/input57/event10"
[    15.080] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse PID:1020" (type: MOUSE, id 16)
[    15.080] (**) Option "AccelerationScheme" "none"
[    15.080] (**) Logitech Wireless Mouse PID:1020: (accel) selected scheme none/0
[    15.080] (**) Logitech Wireless Mouse PID:1020: (accel) acceleration factor: 2.000
[    15.080] (**) Logitech Wireless Mouse PID:1020: (accel) acceleration threshold: 4
[    15.082] (II) event10 - Logitech Wireless Mouse PID:1020: is tagged by udev as: Keyboard Mouse
[    15.082] (II) event10 - Logitech Wireless Mouse PID:1020: device is a pointer
[    15.082] (II) event10 - Logitech Wireless Mouse PID:1020: device is a keyboard
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev pointer catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev keyboard catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput pointer catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput keyboard catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    15.083] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse PID:1020'
[    15.083] (**) Logitech Wireless Mouse PID:1020: always reports core events
[    15.083] (**) Option "Device" "/dev/input/event10"
[    15.083] (**) Option "_source" "_driver/libinput"
[    15.083] (II) libinput: Logitech Wireless Mouse PID:1020: is a virtual subdevice
[    15.083] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.4/1-6.4:1.1/0003:046D:C52F.000D/0003:046D:1020.000E/input/input57/event10"
[    15.083] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse PID:1020" (type: KEYBOARD, id 17)
[    15.083] (**) Option "xkb_layout" "de"
With the update it was:
cat Xorg.0.log
[     8.634]
[     8.634] Build Operating System: Linux Manjaro Linux
[     8.634] Current Operating System: Linux manjaro18 5.10.68-1-MANJARO #1 SMP PREEMPT Wed Sep 22 12:29:47 UTC 2021 x86_64
[     8.634] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64 root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@ bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
[     8.634] Build Date: 24 August 2021  10:21:29AM
[     8.634]
[     8.635] Current version of pixman: 0.40.0
[     8.635] 	Before reporting problems, check http://wiki.x.org
[     8.635] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.635] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Sep 26 20:34:29 2021
[     8.635] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.635] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.635] (==) No Layout section.  Using the first Screen section.
[     8.635] (==) No screen section available. Using defaults.
[     8.635] (**) |-->Screen "Default Screen Section" (0)
[     8.635] (**) |   |-->Monitor "<default monitor>"
[     8.635] (==) No monitor specified for screen "Default Screen Section".
[     8.635] (==) Automatically adding devices
[     8.635] (==) Automatically enabling devices
[     8.635] (==) Automatically adding GPU devices
[     8.636] (==) Automatically binding GPU devices
[     8.636] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.636] (==) FontPath set to:
[     8.636] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.636] (II) The server relies on udev to provide the list of input devices.
[     8.636] (II) Module ABI versions:
[     8.636] 	X.Org ANSI C Emulation: 0.4
[     8.636] 	X.Org Video Driver: 24.1
[     8.636] 	X.Org XInput driver : 24.1
[     8.636] 	X.Org Server Extension : 10.0
[     8.636] (++) using VT number 7
[     8.636] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.637] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.645] (--) PCI: (1@0:0:0) 10de:0fc8:3842:3744 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     8.645] (--) PCI:*(39@0:0:0) 10de:1c82:1458:3733 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     8.645] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.645] (II) LoadModule: "glx"
[     8.645] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.647] (II) Module glx: vendor="X.Org Foundation"
[     8.647] 	compiled for 1.20.13, module version = 1.0.0
[     8.647] 	ABI class: X.Org Server Extension, version 10.0
[     8.649] (==) Matched modesetting as autoconfigured driver 0
[     8.649] (==) Matched fbdev as autoconfigured driver 1
[     8.649] (==) Matched vesa as autoconfigured driver 2
[     8.649] (==) Assigned the driver to the xf86ConfigLayout
[     8.649] (II) LoadModule: "modesetting"
[     8.649] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.650] (II) Module modesetting: vendor="X.Org Foundation"
[     8.650] 	compiled for 1.20.13, module version = 1.20.13
[     8.650] 	Module class: X.Org Video Driver
[     8.650] 	ABI class: X.Org Video Driver, version 24.1
[     8.650] (II) LoadModule: "fbdev"
[     8.650] (WW) Warning, couldn't open module fbdev
[     8.650] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     8.650] (II) LoadModule: "vesa"
[     8.650] (WW) Warning, couldn't open module vesa
[     8.650] (EE) Failed to load module "vesa" (module does not exist, 0)
[     8.650] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.651] (WW) Falling back to old probe method for modesetting
[     8.651] (II) modeset(1): using default device
[     8.651] (II) modeset(G0): using drv /dev/dri/card0
[     8.651] (EE) Screen 0 deleted because of no matching config section.
[     8.651] (II) UnloadModule: "modesetting"
[     8.651] (EE)
Fatal server error:
[     8.651] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[     8.651] (EE)
[     8.651] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[     8.651] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     8.651] (EE)
[     8.651] (EE) Server terminated with error (1). Closing log file.
With the update (II) LoadModule: “nouveau” is missing in the log. But lsmod did show nouveau
Tomorrow (:de:) i will be able to boot into the USB-Stick again. But i can´t post from within. :man_shrugging: So everything i should post, i have to write into files that i am able to post later then.
Is it possible to access the journal when mounting the USB-Stick in my functioning install ?
Are there any pacnew files after the update?
There are no pacnew files /etc/**/*.pacnew
Now i am on my laptop and the other pc is running with usb-stick and no GUI after update. So i am able to look for the journal. What especially do i search for ? …
:rofl:
While i was waiting for you, i decided to meanwhile change the keyboard-layout from qwerty to qwertz (to german). This did not succeed. The arch wiki said to reboot then. So i did reboot from the same USB-stick.
  • it did take a lot longer then last time
  • while the screen was black i tried ctrl-alt-F3 — nothing happend
  • after a long while lightdm with grafical login apeared
    :face_with_raised_eyebrow:
    I will stay this way. Maybe the journal will give some info now on what happened …
This USB-Stick was created with ALMA. So there seems to be no permanent journal enabled to protect the stick. (journalctl -b -1 says there is no persistent journal found) …
I think my pc is playing games with me :crazy_face:
I will save this journal -b for further use, and reboot. …
Again successfull reboot into GUI. :crazy_face:
But i may be able to look into the journal of the normal installation, because i did leave the readonly snapshot accessible. …
I did reboot my pc. Even without update, i did not reach GUI. :frowning: This has happened before, but only in 1 of 10 boots.
At the moment i am comparing journal -b -0 with journal -b -1. And up to Line 1200 there is only sligth difference in the order of lines.
But then the functioning boot shows the first line with “nouveau” mentioned at line 1217. And in the boot without GUI this line is in 1478.
i did extract all lines with nouveau|login|light
boot with GUI
journalctl -b -0 | egrep -ni 'nouveau|login|light'
1016:Sep 28 11:21:40 manjaro18 systemd[1]: Reached target Login Prompts.
1217:Sep 28 11:21:40 manjaro18 kernel: nouveau 0000:01:00.0: enabling device (0000 -> 0003)
1221:Sep 28 11:21:40 manjaro18 kernel: nouveau 0000:01:00.0: NVIDIA GK107 (0e7080a2)
1279:Sep 28 11:21:40 manjaro18 systemd[1]: Starting User Login Management...
1321:Sep 28 11:21:40 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event1 (Power Button)
1322:Sep 28 11:21:40 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event0 (Power Button)
1323:Sep 28 11:21:40 manjaro18 systemd-logind[632]: New seat seat0.
1324:Sep 28 11:21:40 manjaro18 kernel: nouveau 0000:01:00.0: bios: version 80.07.d9.00.2d
1328:Sep 28 11:21:40 manjaro18 systemd[1]: Started User Login Management.
1358:Sep 28 11:21:40 manjaro18 systemd[1]: Starting Light Display Manager...
1379:Sep 28 11:21:40 manjaro18 systemd[1]: Started Light Display Manager.
1381:Sep 28 11:21:40 manjaro18 dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.11' (uid=0 pid=687 comm="/usr/bin/lightdm ")
1429:Sep 28 11:21:41 manjaro18 kernel: nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
1504:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1505:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1523:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
1524:Sep 28 11:21:41 manjaro18 systemd[1]: Stopped Light Display Manager.
1525:Sep 28 11:21:41 manjaro18 systemd[1]: Starting Light Display Manager...
1526:Sep 28 11:21:41 manjaro18 systemd[1]: Started Light Display Manager.
1536:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1537:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1542:Sep 28 11:21:41 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
1543:Sep 28 11:21:41 manjaro18 systemd[1]: Stopped Light Display Manager.
1544:Sep 28 11:21:41 manjaro18 systemd[1]: Starting Light Display Manager...
1547:Sep 28 11:21:41 manjaro18 systemd[1]: Started Light Display Manager.
1609:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event28 (MOSART Semi. 2.4G Keyboard Mouse)
1613:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1614:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1623:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event29 (MOSART Semi. 2.4G Keyboard Mouse Consumer Control)
1625:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event4 (MOSART Semi. 2.4G Keyboard Mouse System Control)
1626:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
1627:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
1628:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: TMDS table version 2.0
1629:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB version 4.0
1630:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 00: 01000f02 00020030
1631:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 01: 02000f00 00000000
1632:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 02: 08011f82 00020030
1633:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 03: 02022f62 00020010
1634:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
1635:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 01: 00002131
1636:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 02: 00010263
1637:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
1640:Sep 28 11:21:42 manjaro18 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1641:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event7 (X10 Wireless Technology Inc USB Receiver)
1646:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
1647:Sep 28 11:21:42 manjaro18 systemd[1]: Stopped Light Display Manager.
1648:Sep 28 11:21:42 manjaro18 systemd[1]: Starting Light Display Manager...
1649:Sep 28 11:21:42 manjaro18 systemd[1]: Started Light Display Manager.
1650:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: DRM: allocated 3840x2160 fb: 0xa0000, bo 00000000f4d31399
1654:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: [drm] fb1: nouveau frame buffer device
1655:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1656:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1657:Sep 28 11:21:42 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
1661:Sep 28 11:21:42 manjaro18 kernel: fb0: switching to nouveaufb from EFI VGA
1663:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: vgaarb: deactivate vga console
1664:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: NVIDIA GP107 (137000a1)
1669:Sep 28 11:21:42 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
1670:Sep 28 11:21:42 manjaro18 systemd[1]: Stopped Light Display Manager.
1671:Sep 28 11:21:42 manjaro18 systemd[1]: Starting Light Display Manager...
1672:Sep 28 11:21:42 manjaro18 systemd[1]: Started Light Display Manager.
1673:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: bios: version 86.07.39.00.56
1674:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: pmu: firmware unavailable
1675:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: fb: 4096 MiB GDDR5
1678:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
1679:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: VRAM: 4096 MiB
1680:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: GART: 536870912 MiB
1681:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'A' not found
1682:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'L' not found
1683:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: TMDS table version 2.0
1684:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB version 4.1
1685:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 00: 01000f42 04620030
1686:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 01: 02011f62 04620010
1687:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 02: 02822f76 04600020
1688:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 03: 02022f72 04620020
1689:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 04: 04033f82 00020010
1690:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 05: 04044f92 00020020
1691:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 00: 00001031
1692:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 01: 00010161
1693:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 02: 00020246
1694:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 03: 01000361
1695:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 04: 02000461
1696:Sep 28 11:21:42 manjaro18 kernel: nouveau 0000:27:00.0: DRM: MM: using COPY for buffer copies
1697:Sep 28 11:21:42 manjaro18 kernel: snd_hda_intel 0000:27:00.1: bound 0000:27:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1707:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event9 (Logitech K270)
1709:Sep 28 11:21:42 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event8 (Logitech K520)
1710:Sep 28 11:21:43 manjaro18 kernel: nouveau 0000:27:00.0: DRM: allocated 3840x2160 fb: 0x200000, bo 000000001d0870b0
1711:Sep 28 11:21:43 manjaro18 kernel: fbcon: nouveau (fb0) is primary device
1713:Sep 28 11:21:43 manjaro18 kernel: nouveau 0000:27:00.0: [drm] fb0: nouveau frame buffer device
1714:Sep 28 11:21:43 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:27:00.0 on minor 1
1715:Sep 28 11:21:43 manjaro18 systemd-logind[632]: New seat seat1.
1721:Sep 28 11:21:43 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1722:Sep 28 11:21:44 manjaro18 lightdm[1237]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=620) by (uid=0)
1725:Sep 28 11:21:44 manjaro18 systemd-logind[632]: New session c1 of user lightdm.
1731:Sep 28 11:21:44 manjaro18 systemd[1242]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
1732:Sep 28 11:21:44 manjaro18 systemd[1242]: pam_unix(systemd-user:session): session opened for user lightdm(uid=620) by (uid=0)
1755:Sep 28 11:21:44 manjaro18 systemd[1]: Started Session c1 of User lightdm.
1761:Sep 28 11:21:44 manjaro18 dbus-daemon[1266]: [session uid=620 pid=1266] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=620 pid=1255 comm="/usr/bin/lightdm-gtk-greeter ")
1763:Sep 28 11:21:44 manjaro18 lightdm[1263]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=620) by (uid=0)
1765:Sep 28 11:21:44 manjaro18 systemd-logind[632]: New session c2 of user lightdm.
1766:Sep 28 11:21:44 manjaro18 systemd[1]: Started Session c2 of User lightdm.
1769:Sep 28 11:21:44 manjaro18 dbus-daemon[1266]: [session uid=620 pid=1266] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=620 pid=1255 comm="/usr/bin/lightdm-gtk-greeter ")
1780:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1782:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1275 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1784:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1786:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1275 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1788:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1790:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1275 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1792:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1794:Sep 28 11:21:45 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1275 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1795:Sep 28 11:21:45 manjaro18 at-spi-bus-launcher[1276]: dbus-daemon[1276]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=620 pid=1255 comm="/usr/bin/lightdm-gtk-greeter ")
1889:Sep 28 11:21:50 manjaro18 systemd-logind[632]: Watching system buttons on /dev/input/event31 (Logitech Wireless Mouse PID:1020)
1894:Sep 28 11:21:58 manjaro18 lightdm[1318]: gkr-pam: unable to locate daemon control file
1895:Sep 28 11:21:58 manjaro18 lightdm[1318]: gkr-pam: stashed password to try later in open session
1896:Sep 28 11:21:58 manjaro18 dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.49' (uid=0 pid=1318 comm="lightdm --session-child 15 26 ")
1898:Sep 28 11:21:58 manjaro18 lightdm[1318]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
1899:Sep 28 11:21:58 manjaro18 systemd[1]: Stopping Session c2 of User lightdm.
1900:Sep 28 11:21:58 manjaro18 lightdm[1263]: pam_unix(lightdm-greeter:session): session closed for user lightdm
1902:Sep 28 11:21:58 manjaro18 systemd[1]: Stopped Session c2 of User lightdm.
1903:Sep 28 11:21:58 manjaro18 systemd-logind[632]: Removed session c2.
1904:Sep 28 11:21:58 manjaro18 lightdm[1318]: pam_unix(lightdm:session): session opened for user andreas(uid=1000) by (uid=0)
1905:Sep 28 11:21:58 manjaro18 systemd-logind[632]: New session 4 of user andreas.
1907:Sep 28 11:21:58 manjaro18 lightdm[1318]: pam_env(lightdm:session): deprecated reading of user environment enabled
1908:Sep 28 11:21:58 manjaro18 lightdm[1318]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
1909:Sep 28 11:21:58 manjaro18 lightdm[1318]: Error opening audit socket: Protocol not supported
1929:Sep 28 11:21:59 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1937:Sep 28 11:21:59 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1947:Sep 28 11:21:59 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1953:Sep 28 11:21:59 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1960:Sep 28 11:21:59 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1989:Sep 28 11:22:02 manjaro18 dbus-daemon[1499]: [session uid=1000 pid=1499] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.36' (uid=1000 pid=1719 comm="light-locker ")
2060:Sep 28 11:22:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2062:Sep 28 11:22:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2064:Sep 28 11:22:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2066:Sep 28 11:22:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
4456:Sep 28 12:07:05 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
4458:Sep 28 12:07:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
4460:Sep 28 12:07:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
4462:Sep 28 12:07:06 manjaro18 polkitd[626]: <no filename>:4: subject=[Subject pid=1255 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
5595:Sep 28 12:29:06 manjaro18 lightdm[1316]: gkr-pam: unable to locate daemon control file
5596:Sep 28 12:29:06 manjaro18 lightdm[1316]: gkr-pam: stashed password to try later in open session
5597:Sep 28 12:29:06 manjaro18 dbus-daemon[621]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.98' (uid=0 pid=1316 comm="lightdm --session-child 15 24 ")
5599:Sep 28 12:29:06 manjaro18 lightdm[1316]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
5600:Sep 28 12:29:06 manjaro18 systemd[1]: Stopping Session c1 of User lightdm.
5601:Sep 28 12:29:06 manjaro18 lightdm[1237]: pam_unix(lightdm-greeter:session): session closed for user lightdm
5603:Sep 28 12:29:06 manjaro18 systemd[1]: Stopped Session c1 of User lightdm.
5605:Sep 28 12:29:06 manjaro18 systemd-logind[632]: Removed session c1.
5606:Sep 28 12:29:06 manjaro18 lightdm[1316]: pam_unix(lightdm:session): session opened for user andrea(uid=1001) by (uid=0)
5607:Sep 28 12:29:06 manjaro18 systemd-logind[632]: New session 5 of user andrea.
5609:Sep 28 12:29:06 manjaro18 lightdm[1316]: pam_env(lightdm:session): deprecated reading of user environment enabled
5610:Sep 28 12:29:06 manjaro18 lightdm[1316]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
5611:Sep 28 12:29:06 manjaro18 lightdm[1316]: Error opening audit socket: Protocol not supported
5677:Sep 28 12:29:10 manjaro18 dbus-daemon[294908]: [session uid=1001 pid=294908] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.28' (uid=1001 pid=295063 comm="light-locker ")
5750:Sep 28 12:29:16 manjaro18 systemd[1246]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
5761:Sep 28 12:29:18 manjaro18 gnome-keyring-daemon[294899]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
5762:Sep 28 12:29:18 manjaro18 gnome-keyring-daemon[294899]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
7193:Sep 28 12:56:28 manjaro18 gnome-keyring-daemon[1490]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
7194:Sep 28 12:56:28 manjaro18 gnome-keyring-daemon[1490]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
boot no GUI
Schreibtisch journalctl -b -1 | egrep -ni 'nouveau|login|light'
1024:Sep 28 11:18:06 manjaro18 systemd[1]: Reached target Login Prompts.
1253:Sep 28 11:18:06 manjaro18 systemd[1]: Starting User Login Management...
1266:Sep 28 11:18:06 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event1 (Power Button)
1267:Sep 28 11:18:06 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event0 (Power Button)
1268:Sep 28 11:18:06 manjaro18 systemd-logind[660]: New seat seat0.
1278:Sep 28 11:18:06 manjaro18 systemd[1]: Started User Login Management.
1318:Sep 28 11:18:06 manjaro18 systemd[1]: Starting Light Display Manager...
1363:Sep 28 11:18:07 manjaro18 systemd[1]: Started Light Display Manager.
1364:Sep 28 11:18:07 manjaro18 dbus-daemon[652]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.11' (uid=0 pid=711 comm="/usr/bin/lightdm ")
1498:Sep 28 11:18:07 manjaro18 kernel: nouveau 0000:01:00.0: enabling device (0000 -> 0003)
1502:Sep 28 11:18:07 manjaro18 kernel: nouveau 0000:01:00.0: NVIDIA GK107 (0e7080a2)
1520:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1522:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1528:Sep 28 11:18:07 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event4 (MOSART Semi. 2.4G Keyboard Mouse)
1532:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
1533:Sep 28 11:18:07 manjaro18 systemd[1]: Stopped Light Display Manager.
1534:Sep 28 11:18:07 manjaro18 systemd[1]: Starting Light Display Manager...
1536:Sep 28 11:18:07 manjaro18 systemd[1]: Started Light Display Manager.
1541:Sep 28 11:18:07 manjaro18 kernel: nouveau 0000:01:00.0: bios: version 80.07.d9.00.2d
1542:Sep 28 11:18:07 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event14 (MOSART Semi. 2.4G Keyboard Mouse System Control)
1545:Sep 28 11:18:07 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event9 (MOSART Semi. 2.4G Keyboard Mouse Consumer Control)
1551:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1552:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1572:Sep 28 11:18:07 manjaro18 kernel: nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
1575:Sep 28 11:18:07 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
1576:Sep 28 11:18:07 manjaro18 systemd[1]: Stopped Light Display Manager.
1577:Sep 28 11:18:07 manjaro18 systemd[1]: Starting Light Display Manager...
1578:Sep 28 11:18:07 manjaro18 systemd[1]: Started Light Display Manager.
1637:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1638:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1643:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
1644:Sep 28 11:18:08 manjaro18 systemd[1]: Stopped Light Display Manager.
1645:Sep 28 11:18:08 manjaro18 systemd[1]: Starting Light Display Manager...
1646:Sep 28 11:18:08 manjaro18 systemd[1]: Started Light Display Manager.
1649:Sep 28 11:18:08 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event3 (X10 Wireless Technology Inc USB Receiver)
1652:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1653:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1660:Sep 28 11:18:08 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
1661:Sep 28 11:18:08 manjaro18 systemd[1]: Stopped Light Display Manager.
1662:Sep 28 11:18:08 manjaro18 systemd[1]: Starting Light Display Manager...
1663:Sep 28 11:18:08 manjaro18 systemd[1]: Started Light Display Manager.
1664:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
1665:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
1666:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: TMDS table version 2.0
1667:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB version 4.0
1668:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 00: 01000f02 00020030
1669:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 01: 02000f00 00000000
1670:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 02: 08011f82 00020030
1671:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 03: 02022f62 00020010
1672:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
1673:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 01: 00002131
1674:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 02: 00010263
1675:Sep 28 11:18:08 manjaro18 kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
1676:Sep 28 11:18:08 manjaro18 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1677:Sep 28 11:18:09 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event8 (Logitech K520)
1678:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:01:00.0: DRM: allocated 3840x2160 fb: 0xa0000, bo 00000000d3e86191
1680:Sep 28 11:18:09 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event10 (Logitech K270)
1681:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:01:00.0: [drm] fb1: nouveau frame buffer device
1682:Sep 28 11:18:09 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1683:Sep 28 11:18:09 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1684:Sep 28 11:18:09 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
1688:Sep 28 11:18:09 manjaro18 kernel: fb0: switching to nouveaufb from EFI VGA
1690:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: vgaarb: deactivate vga console
1691:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: NVIDIA GP107 (137000a1)
1692:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: bios: version 86.07.39.00.56
1693:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: pmu: firmware unavailable
1694:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: fb: 4096 MiB GDDR5
1695:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: VRAM: 4096 MiB
1696:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: GART: 536870912 MiB
1697:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'A' not found
1698:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'L' not found
1699:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: TMDS table version 2.0
1700:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB version 4.1
1701:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 00: 01000f42 04620030
1702:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 01: 02011f62 04620010
1703:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 02: 02822f76 04600020
1704:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 03: 02022f72 04620020
1705:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 04: 04033f82 00020010
1706:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 05: 04044f92 00020020
1707:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 00: 00001031
1708:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 01: 00010161
1709:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 02: 00020246
1710:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 03: 01000361
1711:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 04: 02000461
1712:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: MM: using COPY for buffer copies
1713:Sep 28 11:18:09 manjaro18 kernel: snd_hda_intel 0000:27:00.1: bound 0000:27:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1714:Sep 28 11:18:09 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
1715:Sep 28 11:18:09 manjaro18 systemd[1]: Stopped Light Display Manager.
1716:Sep 28 11:18:09 manjaro18 systemd[1]: lightdm.service: Start request repeated too quickly.
1717:Sep 28 11:18:09 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1718:Sep 28 11:18:09 manjaro18 systemd[1]: Failed to start Light Display Manager.
1725:Sep 28 11:18:09 manjaro18 kernel: nouveau 0000:27:00.0: DRM: allocated 3840x2160 fb: 0x200000, bo 00000000e6843646
1726:Sep 28 11:18:09 manjaro18 kernel: fbcon: nouveau (fb0) is primary device
1822:Sep 28 11:18:12 manjaro18 kernel: nouveau 0000:27:00.0: [drm] fb0: nouveau frame buffer device
1823:Sep 28 11:18:12 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:27:00.0 on minor 1
1824:Sep 28 11:18:12 manjaro18 systemd-logind[660]: New seat seat1.
1829:Sep 28 11:18:16 manjaro18 systemd-logind[660]: Watching system buttons on /dev/input/event26 (Logitech Wireless Mouse PID:1020)
1913:Sep 28 11:19:39 manjaro18 dbus-daemon[652]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.39' (uid=0 pid=1528 comm="/bin/login -p --         ")
1915:Sep 28 11:19:39 manjaro18 login[1528]: pam_systemd_home(login:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
1916:Sep 28 11:19:39 manjaro18 login[1528]: pam_unix(login:session): session opened for user andreas(uid=1000) by LOGIN(uid=0)
1917:Sep 28 11:19:39 manjaro18 systemd-logind[660]: New session 3 of user andreas.
1919:Sep 28 11:19:39 manjaro18 login[1528]: pam_env(login:session): deprecated reading of user environment enabled
1920:Sep 28 11:19:39 manjaro18 login[1528]: LOGIN ON tty2 BY andreas
1930:Sep 28 11:20:08 manjaro18 dbus-daemon[652]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.40' (uid=0 pid=1655 comm="sudo systemctl restart lightdm.service ")
1933:Sep 28 11:20:08 manjaro18 sudo[1655]:  andreas : TTY=tty2 ; PWD=/home/andreas ; USER=root ; COMMAND=/usr/bin/systemctl restart lightdm.service
1935:Sep 28 11:20:08 manjaro18 systemd[1]: Starting Light Display Manager...
1936:Sep 28 11:20:08 manjaro18 systemd[1]: Started Light Display Manager.
1938:Sep 28 11:20:08 manjaro18 kernel: nouveau 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
1939:Sep 28 11:20:08 manjaro18 kernel: nouveau 0000:27:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
1940:Sep 28 11:20:08 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1941:Sep 28 11:20:09 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1942:Sep 28 11:20:09 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1943:Sep 28 11:20:09 manjaro18 systemd[1]: lightdm.service: Consumed 1.060s CPU time.
1944:Sep 28 11:20:09 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
1945:Sep 28 11:20:09 manjaro18 systemd[1]: Stopped Light Display Manager.
1946:Sep 28 11:20:09 manjaro18 systemd[1]: lightdm.service: Consumed 1.060s CPU time.
1947:Sep 28 11:20:09 manjaro18 systemd[1]: Starting Light Display Manager...
1948:Sep 28 11:20:09 manjaro18 systemd[1]: Started Light Display Manager.
1949:Sep 28 11:20:10 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1950:Sep 28 11:20:11 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1951:Sep 28 11:20:11 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1952:Sep 28 11:20:11 manjaro18 systemd[1]: lightdm.service: Consumed 1.019s CPU time.
1953:Sep 28 11:20:11 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
1954:Sep 28 11:20:11 manjaro18 systemd[1]: Stopped Light Display Manager.
1955:Sep 28 11:20:11 manjaro18 systemd[1]: lightdm.service: Consumed 1.019s CPU time.
1956:Sep 28 11:20:11 manjaro18 systemd[1]: Starting Light Display Manager...
1957:Sep 28 11:20:11 manjaro18 systemd[1]: Started Light Display Manager.
1958:Sep 28 11:20:11 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1959:Sep 28 11:20:12 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1960:Sep 28 11:20:12 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1961:Sep 28 11:20:12 manjaro18 systemd[1]: lightdm.service: Consumed 1.016s CPU time.
1962:Sep 28 11:20:12 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
1963:Sep 28 11:20:12 manjaro18 systemd[1]: Stopped Light Display Manager.
1964:Sep 28 11:20:12 manjaro18 systemd[1]: lightdm.service: Consumed 1.016s CPU time.
1965:Sep 28 11:20:12 manjaro18 systemd[1]: Starting Light Display Manager...
1966:Sep 28 11:20:12 manjaro18 systemd[1]: Started Light Display Manager.
1967:Sep 28 11:20:13 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1968:Sep 28 11:20:14 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1969:Sep 28 11:20:14 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1970:Sep 28 11:20:14 manjaro18 systemd[1]: lightdm.service: Consumed 1.014s CPU time.
1971:Sep 28 11:20:14 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
1972:Sep 28 11:20:14 manjaro18 systemd[1]: Stopped Light Display Manager.
1973:Sep 28 11:20:14 manjaro18 systemd[1]: lightdm.service: Consumed 1.014s CPU time.
1974:Sep 28 11:20:14 manjaro18 systemd[1]: Starting Light Display Manager...
1975:Sep 28 11:20:14 manjaro18 systemd[1]: Started Light Display Manager.
1976:Sep 28 11:20:14 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1977:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1978:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1979:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Consumed 1.012s CPU time.
1980:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
1981:Sep 28 11:20:15 manjaro18 systemd[1]: Stopped Light Display Manager.
1982:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Consumed 1.012s CPU time.
1983:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Start request repeated too quickly.
1984:Sep 28 11:20:15 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1985:Sep 28 11:20:15 manjaro18 systemd[1]: Failed to start Light Display Manager.
1988:Sep 28 11:20:39 manjaro18 systemd-logind[660]: System is rebooting.
1996:Sep 28 11:20:40 manjaro18 login[1528]: pam_unix(login:session): session closed for user andreas
2084:Sep 28 11:20:40 manjaro18 systemd-logind[660]: Session 3 logged out. Waiting for processes to exit.
2107:Sep 28 11:20:40 manjaro18 systemd-logind[660]: Removed session 3.
2132:Sep 28 11:20:40 manjaro18 systemd[1]: Stopped target Login Prompts.
2148:Sep 28 11:20:40 manjaro18 systemd[1]: Stopping User Login Management...
2177:Sep 28 11:20:40 manjaro18 systemd[1]: systemd-logind.service: Deactivated successfully.
2178:Sep 28 11:20:40 manjaro18 systemd[1]: Stopped User Login Management.
It seems lightdm ist started before nouveau is ready ?
Does this help?:
  • Edit /etc/lightdm/lightdm.conf
  • Uncomment (remove the # from) the line logind-check-graphical and change its value to true if necessary
logind-check-graphical=true
  • Save and reboot
my existing lightdm.conf
cat lightdm.conf
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# logind-check-graphical = True to on start seats that are marked as graphical by logind
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# sessions-directory = Directory to find sessions
# remote-sessions-directory = Directory to find remote sessions
# greeters-directory = Directory to find greeters
# backup-logs = True to move add a .old suffix to old log files when opening new ones
# dbus-service = True if LightDM provides a D-Bus service to control it
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7 # Setting this to a value < 7 implies security issues, see FS#46799
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#logind-check-graphical=false
#akf 20210828
#logind-check-graphical=true
#log-directory=/var/log/lightdm
run-directory=/run/lightdm
#cache-directory=/var/cache/lightdm
#sessions-directory=/usr/share/lightdm/sessions:/usr/share/xsessions:/usr/share/wayland-sessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#greeters-directory=$XDG_DATA_DIRS/lightdm/greeters:$XDG_DATA_DIRS/xgreeters
#backup-logs=true
#dbus-service=true
# Seat configuration
# Seat configuration is matched against the seat name glob in the section, for example:
# [Seat:*] matches all seats and is applied first.
# [Seat:seat0] matches the seat named "seat0".
# [Seat:seat-thin-client*] matches all seats that have names that start with "seat-thin-client".
# type = Seat type (local, xremote)
# pam-service = PAM service to use for login
# pam-autologin-service = PAM service to use for autologin
# pam-greeter-service = PAM service to use for greeters
# xserver-command = X server command to run (can also contain arguments e.g. X -special-option)
# xmir-command = Xmir server command to run (can also contain arguments e.g. Xmir -special-option)
# xserver-config = Config file to pass to X server
# xserver-layout = Layout to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xserver-share = True if the X server is shared for both greeter and session
# xserver-hostname = Hostname of X server (only for type=xremote)
# xserver-display-number = Display number of X server (only for type=xremote)
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-user-switching = True if allowed to switch users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# greeter-wrapper = Wrapper script to run greeter with
# guest-wrapper = Wrapper script to run guest sessions with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# display-stopped-script = Script to run after stopping the display server (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# autologin-in-background = True if autologin session should not be immediately activated
# exit-on-failure = True if the daemon should exit if this seat fails
[Seat:*]
#type=local
#pam-service=lightdm
#pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
#greeter-session=example-gtk-gnome
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
#user-session=default
#akf
user-session=xfce
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
#autologin-user=
#autologin-user-timeout=0
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
[Seat:seat0]
xserver-layout=seat0
xserver-command=/usr/bin/X :0 vt8 -novtswitch
#xserver-layout=seat1
#xserver-command=/usr/bin/X :1 vt7
#akf 20210828
[Seat:seat1]
#xserver-layout=seat0
#xserver-command=/usr/bin/X :0 vt8
#akf 20210828
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# listen-address = Host/address to listen for XDMCP connections (use all addresses if not present)
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# hostname = Hostname to report to XDMCP clients (defaults to system hostname if unset)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn.  Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#listen-address=
#key=
#hostname=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# listen-address = Host/address to listen for VNC connections (use all addresses if not present)
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#listen-address=
#width=1024
#height=768
#depth=8
cat lightdm.conf|egrep -n graph        [130]
11:# logind-check-graphical = True to on start seats that are marked as graphical by logind
29:#logind-check-graphical=false
32:#logind-check-graphical=true
137:logind-check-graphical=true
145:logind-check-graphical=true
Is it in the wrong section ? (maybe)
In what section should this be ?
But i will test and report.
At first the log seems better, because there are not so much failed attempts of lightdm. And the GUI did show.
But the fault-rate before may have been 1:10. So 1 succesfull boot is no proof :frowning:
only 1 fault
Schreibtisch journalctl -b -0 | egrep -ni 'nouveau|login|light'
1021:Sep 29 13:33:38 manjaro18 systemd[1]: Reached target Login Prompts.
1263:Sep 29 13:33:39 manjaro18 kernel: nouveau 0000:01:00.0: enabling device (0000 -> 0003)
1267:Sep 29 13:33:39 manjaro18 kernel: nouveau 0000:01:00.0: NVIDIA GK107 (0e7080a2)
1294:Sep 29 13:33:39 manjaro18 kernel: nouveau 0000:01:00.0: bios: version 80.07.d9.00.2d
1338:Sep 29 13:33:39 manjaro18 systemd[1]: Starting User Login Management...
1372:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event1 (Power Button)
1373:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event0 (Power Button)
1375:Sep 29 13:33:39 manjaro18 systemd-logind[742]: New seat seat0.
1377:Sep 29 13:33:39 manjaro18 systemd[1]: Started User Login Management.
1406:Sep 29 13:33:39 manjaro18 systemd[1]: Starting Light Display Manager...
1417:Sep 29 13:33:39 manjaro18 dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.11' (uid=0 pid=806 comm="/usr/bin/lightdm ")
1420:Sep 29 13:33:39 manjaro18 systemd[1]: Started Light Display Manager.
1491:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event30 (MOSART Semi. 2.4G Keyboard Mouse)
1495:Sep 29 13:33:39 manjaro18 kernel: nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
1497:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event257 (MOSART Semi. 2.4G Keyboard Mouse System Control)
1501:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event24 (X10 Wireless Technology Inc USB Receiver)
1567:Sep 29 13:33:39 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event256 (MOSART Semi. 2.4G Keyboard Mouse Consumer Control)
1635:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
1636:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
1637:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: TMDS table version 2.0
1638:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB version 4.0
1639:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 00: 01000f02 00020030
1640:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 01: 02000f00 00000000
1641:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 02: 08011f82 00020030
1642:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB outp 03: 02022f62 00020010
1643:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
1644:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 01: 00002131
1645:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: DCB conn 02: 00010263
1646:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
1647:Sep 29 13:33:40 manjaro18 kernel: snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1650:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: DRM: allocated 3840x2160 fb: 0xa0000, bo 0000000016ba674f
1658:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:01:00.0: [drm] fb1: nouveau frame buffer device
1659:Sep 29 13:33:40 manjaro18 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
1660:Sep 29 13:33:40 manjaro18 systemd[1]: lightdm.service: Failed with result 'exit-code'.
1661:Sep 29 13:33:40 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
1665:Sep 29 13:33:40 manjaro18 kernel: fb0: switching to nouveaufb from EFI VGA
1667:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:27:00.0: vgaarb: deactivate vga console
1668:Sep 29 13:33:40 manjaro18 kernel: nouveau 0000:27:00.0: NVIDIA GP107 (137000a1)
1671:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: bios: version 86.07.39.00.56
1672:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: pmu: firmware unavailable
1673:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: fb: 4096 MiB GDDR5
1674:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: VRAM: 4096 MiB
1675:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: GART: 536870912 MiB
1676:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'A' not found
1677:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: BIT table 'L' not found
1678:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: TMDS table version 2.0
1679:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB version 4.1
1680:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 00: 01000f42 04620030
1681:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 01: 02011f62 04620010
1682:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 02: 02822f76 04600020
1683:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 03: 02022f72 04620020
1684:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 04: 04033f82 00020010
1685:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB outp 05: 04044f92 00020020
1686:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 00: 00001031
1687:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 01: 00010161
1688:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 02: 00020246
1689:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 03: 01000361
1690:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: DCB conn 04: 02000461
1691:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: MM: using COPY for buffer copies
1692:Sep 29 13:33:41 manjaro18 kernel: snd_hda_intel 0000:27:00.1: bound 0000:27:00.0 (ops nv50_audio_component_bind_ops [nouveau])
1693:Sep 29 13:33:41 manjaro18 systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
1694:Sep 29 13:33:41 manjaro18 systemd[1]: Stopped Light Display Manager.
1695:Sep 29 13:33:41 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event21 (Logitech K520)
1696:Sep 29 13:33:41 manjaro18 systemd[1]: Starting Light Display Manager...
1697:Sep 29 13:33:41 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event22 (Logitech K270)
1698:Sep 29 13:33:41 manjaro18 systemd[1]: Started Light Display Manager.
1699:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
1700:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
1705:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: DRM: allocated 3840x2160 fb: 0x200000, bo 00000000bab573c6
1706:Sep 29 13:33:41 manjaro18 kernel: fbcon: nouveau (fb0) is primary device
1708:Sep 29 13:33:41 manjaro18 kernel: nouveau 0000:27:00.0: [drm] fb0: nouveau frame buffer device
1709:Sep 29 13:33:41 manjaro18 kernel: [drm] Initialized nouveau 1.3.1 20120801 for 0000:27:00.0 on minor 1
1710:Sep 29 13:33:41 manjaro18 systemd-logind[742]: New seat seat1.
1716:Sep 29 13:33:42 manjaro18 kernel: nouveau 0000:27:00.0: gr: intr 00000040
1718:Sep 29 13:33:42 manjaro18 lightdm[1221]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=620) by (uid=0)
1721:Sep 29 13:33:42 manjaro18 systemd-logind[742]: New session c1 of user lightdm.
1727:Sep 29 13:33:42 manjaro18 systemd[1227]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
1728:Sep 29 13:33:42 manjaro18 systemd[1227]: pam_unix(systemd-user:session): session opened for user lightdm(uid=620) by (uid=0)
1777:Sep 29 13:33:42 manjaro18 systemd[1]: Started Session c1 of User lightdm.
1785:Sep 29 13:33:42 manjaro18 lightdm[1242]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=620) by (uid=0)
1786:Sep 29 13:33:42 manjaro18 systemd-logind[742]: New session c2 of user lightdm.
1787:Sep 29 13:33:42 manjaro18 systemd[1]: Started Session c2 of User lightdm.
1794:Sep 29 13:33:43 manjaro18 dbus-daemon[1259]: [session uid=620 pid=1259] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=620 pid=1248 comm="/usr/bin/lightdm-gtk-greeter ")
1799:Sep 29 13:33:43 manjaro18 dbus-daemon[1259]: [session uid=620 pid=1259] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.4' (uid=620 pid=1240 comm="/usr/bin/lightdm-gtk-greeter ")
1836:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1838:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1248 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1840:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1842:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1248 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1844:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1846:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1248 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1848:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1850:Sep 29 13:33:43 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1248 user='lightdm' groups=lightdm seat='seat1' session='c2' local=true active=true]
1851:Sep 29 13:33:43 manjaro18 at-spi-bus-launcher[1275]: dbus-daemon[1275]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=620 pid=1240 comm="/usr/bin/lightdm-gtk-greeter ")
1879:Sep 29 13:33:48 manjaro18 systemd-logind[742]: Watching system buttons on /dev/input/event26 (Logitech Wireless Mouse PID:1020)
1882:Sep 29 13:33:51 manjaro18 lightdm[1376]: gkr-pam: unable to locate daemon control file
1883:Sep 29 13:33:51 manjaro18 lightdm[1376]: gkr-pam: stashed password to try later in open session
1884:Sep 29 13:33:51 manjaro18 dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.41' (uid=0 pid=1376 comm="lightdm --session-child 15 26 ")
1886:Sep 29 13:33:51 manjaro18 lightdm[1376]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
1887:Sep 29 13:33:51 manjaro18 systemd[1]: Stopping Session c2 of User lightdm.
1888:Sep 29 13:33:51 manjaro18 lightdm[1242]: pam_unix(lightdm-greeter:session): session closed for user lightdm
1890:Sep 29 13:33:51 manjaro18 systemd[1]: Stopped Session c2 of User lightdm.
1891:Sep 29 13:33:51 manjaro18 systemd-logind[742]: Removed session c2.
1892:Sep 29 13:33:51 manjaro18 lightdm[1376]: pam_unix(lightdm:session): session opened for user andreas(uid=1000) by (uid=0)
1893:Sep 29 13:33:51 manjaro18 systemd-logind[742]: New session 4 of user andreas.
1895:Sep 29 13:33:51 manjaro18 lightdm[1376]: pam_env(lightdm:session): deprecated reading of user environment enabled
1896:Sep 29 13:33:51 manjaro18 lightdm[1376]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
1897:Sep 29 13:33:51 manjaro18 lightdm[1376]: Error opening audit socket: Protocol not supported
1917:Sep 29 13:33:52 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1919:Sep 29 13:33:52 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1925:Sep 29 13:33:52 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1929:Sep 29 13:33:52 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1939:Sep 29 13:33:52 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
1976:Sep 29 13:33:55 manjaro18 dbus-daemon[1465]: [session uid=1000 pid=1465] Activating via systemd: service name='ca.desrt.dconf' unit='dconf.service' requested by ':1.36' (uid=1000 pid=1687 comm="light-locker ")
2047:Sep 29 13:33:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2049:Sep 29 13:33:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2051:Sep 29 13:33:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2053:Sep 29 13:33:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2186:Sep 29 14:18:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2188:Sep 29 14:18:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2190:Sep 29 14:18:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2192:Sep 29 14:18:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2281:Sep 29 15:03:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2283:Sep 29 15:03:59 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2285:Sep 29 15:04:00 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2287:Sep 29 15:04:00 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2356:Sep 29 15:49:00 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2358:Sep 29 15:49:00 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2360:Sep 29 15:49:00 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2362:Sep 29 15:49:01 manjaro18 polkitd[739]: <no filename>:4: subject=[Subject pid=1240 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
2383:Sep 29 15:59:02 manjaro18 gnome-keyring-daemon[1456]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
2384:Sep 29 15:59:02 manjaro18 gnome-keyring-daemon[1456]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
2427:Sep 29 16:03:44 manjaro18 dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.116' (uid=0 pid=621424 comm="sudo mcedit lightdm.conf ")
2430:Sep 29 16:03:44 manjaro18 sudo[621424]:  andreas : TTY=pts/1 ; PWD=/home/andreas/Schreibtisch ; USER=root ; COMMAND=/usr/bin/mcedit lightdm.conf
2455:Sep 29 16:04:02 manjaro18 dbus-daemon[734]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.117' (uid=0 pid=621586 comm="sudo mcedit /etc/lightdm/lightdm.conf ")
2458:Sep 29 16:04:02 manjaro18 sudo[621586]:  andreas : TTY=pts/1 ; PWD=/home/andreas/Schreibtisch ; USER=root ; COMMAND=/usr/bin/mcedit /etc/lightdm/lightdm.conf
And if you look at line 1660, there is a failed attempt of lightdm, where it should not be
I will keep reporting after more boots.
But i think the problem may lay deeper then at lightdm. Why ?
  • Because when there was a black screen, the logs of Xorg did show that even Xorg failed because it could not access nouveau.
  • When i got no GUI i could not start it manually with startx
only for reference and to later compare: Xorg.0.log
cat /var/log/Xorg.0.log
[     8.028]
X.Org X Server 1.20.13
[     8.028] Build Operating System: Linux Manjaro Linux
[     8.028] Current Operating System: Linux manjaro18 5.14.7-2-MANJARO #1 SMP PREEMPT Wed Sep 22 12:22:56 UTC 2021 x86_64
[     8.028] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64 root=UUID=3487ba3d-1cba-4cdc-a043-c420ebca2aca rw rootflags=subvol=@ bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash modprobe.blacklist=ccp udev.log_priority=3 audit=0 sysrq_always_enabled=1
[     8.028] Build Date: 29 July 2021  08:07:46PM
[     8.028]
[     8.028] Current version of pixman: 0.40.0
[     8.028] 	Before reporting problems, check http://wiki.x.org
[     8.028] Markers: (--) probed, (**) from config file, (==) default setting,
[     8.028] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 29 13:33:41 2021
[     8.028] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     8.028] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     8.028] (==) No Layout section.  Using the first Screen section.
[     8.028] (==) No screen section available. Using defaults.
[     8.028] (**) |-->Screen "Default Screen Section" (0)
[     8.028] (**) |   |-->Monitor "<default monitor>"
[     8.029] (==) No monitor specified for screen "Default Screen Section".
[     8.029] (==) Automatically adding devices
[     8.029] (==) Automatically enabling devices
[     8.029] (==) Automatically adding GPU devices
[     8.029] (==) Automatically binding GPU devices
[     8.029] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     8.029] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF,
	/usr/share/fonts/Type1,
	/usr/share/fonts/100dpi,
	/usr/share/fonts/75dpi
[     8.029] (==) ModulePath set to "/usr/lib/xorg/modules"
[     8.029] (II) The server relies on udev to provide the list of input devices.
[     8.029] (II) Module ABI versions:
[     8.029] 	X.Org ANSI C Emulation: 0.4
[     8.029] 	X.Org Video Driver: 24.1
[     8.029] 	X.Org XInput driver : 24.1
[     8.029] 	X.Org Server Extension : 10.0
[     8.030] (++) using VT number 7
[     8.030] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     8.031] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.038] (--) PCI: (1@0:0:0) 10de:0fc8:3842:3744 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[     8.038] (--) PCI:*(39@0:0:0) 10de:1c82:1458:3733 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     8.038] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.038] (II) LoadModule: "glx"
[     8.038] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.040] (II) Module glx: vendor="X.Org Foundation"
[     8.040] 	compiled for 1.20.13, module version = 1.0.0
[     8.040] 	ABI class: X.Org Server Extension, version 10.0
[     8.040] (==) Matched nouveau as autoconfigured driver 0
[     8.040] (==) Matched nv as autoconfigured driver 1
[     8.040] (==) Matched modesetting as autoconfigured driver 2
[     8.040] (==) Matched fbdev as autoconfigured driver 3
[     8.040] (==) Matched vesa as autoconfigured driver 4
[     8.040] (==) Assigned the driver to the xf86ConfigLayout
[     8.040] (II) LoadModule: "nouveau"
[     8.040] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[     8.040] (II) Module nouveau: vendor="X.Org Foundation"
[     8.041] 	compiled for 1.20.10, module version = 1.0.17
[     8.041] 	Module class: X.Org Video Driver
[     8.041] 	ABI class: X.Org Video Driver, version 24.1
[     8.041] (II) LoadModule: "nv"
[     8.041] (WW) Warning, couldn't open module nv
[     8.041] (EE) Failed to load module "nv" (module does not exist, 0)
[     8.041] (II) LoadModule: "modesetting"
[     8.041] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     8.042] (II) Module modesetting: vendor="X.Org Foundation"
[     8.042] 	compiled for 1.20.13, module version = 1.20.13
[     8.042] 	Module class: X.Org Video Driver
[     8.042] 	ABI class: X.Org Video Driver, version 24.1
[     8.042] (II) LoadModule: "fbdev"
[     8.042] (WW) Warning, couldn't open module fbdev
[     8.042] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     8.042] (II) LoadModule: "vesa"
[     8.042] (WW) Warning, couldn't open module vesa
[     8.042] (EE) Failed to load module "vesa" (module does not exist, 0)
[     8.042] (II) NOUVEAU driver
[     8.042] (II) NOUVEAU driver for NVIDIA chipset families :
[     8.042] 	RIVA TNT            (NV04)
[     8.042] 	RIVA TNT2           (NV05)
[     8.042] 	GeForce 256         (NV10)
[     8.042] 	GeForce 2           (NV11, NV15)
[     8.042] 	GeForce 4MX         (NV17, NV18)
[     8.042] 	GeForce 3           (NV20)
[     8.042] 	GeForce 4Ti         (NV25, NV28)
[     8.042] 	GeForce FX          (NV3x)
[     8.043] 	GeForce 6           (NV4x)
[     8.043] 	GeForce 7           (G7x)
[     8.043] 	GeForce 8           (G8x)
[     8.043] 	GeForce 9           (G9x)
[     8.043] 	GeForce GTX 2xx/3xx (GT2xx)
[     8.043] 	GeForce GTX 4xx/5xx (GFxxx)
[     8.043] 	GeForce GTX 6xx/7xx (GKxxx)
[     8.043] 	GeForce GTX 9xx     (GMxxx)
[     8.043] 	GeForce GTX 10xx    (GPxxx)
[     8.043] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     8.044] (II) [drm] nouveau interface version: 1.3.1
[     8.044] (WW) Falling back to old probe method for modesetting
[     8.045] (II) Loading sub module "dri2"
[     8.045] (II) LoadModule: "dri2"
[     8.045] (II) Module "dri2" already built-in
[     8.045] (--) NOUVEAU(0): Chipset: "NVIDIA NVE7"
[     8.045] (II) NOUVEAU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     8.045] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[     8.045] (==) NOUVEAU(0): RGB weight 888
[     8.045] (==) NOUVEAU(0): Default visual is TrueColor
[     8.045] (==) NOUVEAU(0): Using HW cursor
[     8.045] (==) NOUVEAU(0): Allowed maximum DRI level 2.
[     8.045] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[     8.045] (==) NOUVEAU(0): Page flipping enabled
[     8.045] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[     8.045] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[     8.046] (II) NOUVEAU(0): Initializing outputs ...
[     8.058] (II) NOUVEAU(0): Output DVI-I-1 has no monitor section
[     8.060] (II) NOUVEAU(0): Output DVI-D-1 has no monitor section
[     8.150] (II) NOUVEAU(0): Output HDMI-1 has no monitor section
[     8.150] (II) NOUVEAU(0): 3 crtcs needed for screen.
[     8.151] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[     8.151] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[     8.151] (II) NOUVEAU(0): Allocated crtc nr. 2 to this screen.
[     8.151] (II) NOUVEAU(0): Allocated crtc nr. 3 to this screen.
[     8.164] (II) NOUVEAU(0): EDID for output DVI-I-1
[     8.166] (II) NOUVEAU(0): EDID for output DVI-D-1
[     8.255] (II) NOUVEAU(0): EDID for output HDMI-1
[     8.255] (II) NOUVEAU(0): Manufacturer: GSM  Model: 7706  Serial#: 204790
[     8.255] (II) NOUVEAU(0): Year: 2020  Week: 12
[     8.255] (II) NOUVEAU(0): EDID Version: 1.3
[     8.256] (II) NOUVEAU(0): Digital Display Input
[     8.256] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[     8.256] (II) NOUVEAU(0): Gamma: 2.20
[     8.256] (II) NOUVEAU(0): DPMS capabilities: StandBy Suspend Off
[     8.256] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[     8.256] (II) NOUVEAU(0): First detailed timing is preferred mode
[     8.256] (II) NOUVEAU(0): redX: 0.680 redY: 0.315   greenX: 0.280 greenY: 0.674
[     8.256] (II) NOUVEAU(0): blueX: 0.152 blueY: 0.050   whiteX: 0.312 whiteY: 0.329
[     8.256] (II) NOUVEAU(0): Supported established timings:
[     8.256] (II) NOUVEAU(0): 640x480@60Hz
[     8.256] (II) NOUVEAU(0): 800x600@60Hz
[     8.256] (II) NOUVEAU(0): 1024x768@60Hz
[     8.256] (II) NOUVEAU(0): Manufacturer's mask: 0
[     8.256] (II) NOUVEAU(0): Supported standard timings:
[     8.256] (II) NOUVEAU(0): #0: hsize: 1152  vsize 864  refresh: 60  vid: 16497
[     8.256] (II) NOUVEAU(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     8.256] (II) NOUVEAU(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[     8.256] (II) NOUVEAU(0): #3: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[     8.256] (II) NOUVEAU(0): #4: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[     8.256] (II) NOUVEAU(0): #5: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     8.256] (II) NOUVEAU(0): Supported detailed timing:
[     8.256] (II) NOUVEAU(0): clock: 594.0 MHz   Image Size:  600 x 340 mm
[     8.256] (II) NOUVEAU(0): h_active: 3840  h_sync: 4016  h_sync_end 4104 h_blank_end 4400 h_border: 0
[     8.256] (II) NOUVEAU(0): v_active: 2160  v_sync: 2168  v_sync_end 2178 v_blanking: 2250 v_border: 0
[     8.256] (II) NOUVEAU(0): clock: 297.0 MHz   Image Size:  600 x 340 mm
[     8.256] (II) NOUVEAU(0): Ranges: V min: 56 V max: 61 Hz, H min: 30 H max: 135 kHz, PixClock max 605 MHz
[     8.256] (II) NOUVEAU(0): Monitor name: LG HDR 4K
[     8.256] (II) NOUVEAU(0): clock: 148.5 MHz   Image Size:  600 x 340 mm
[     8.256] (II) NOUVEAU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     8.256] (II) NOUVEAU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     8.256] (II) NOUVEAU(0): clock: 241.5 MHz   Image Size:  600 x 340 mm
[     8.256] (II) NOUVEAU(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[     8.256] (II) NOUVEAU(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[     8.256] (II) NOUVEAU(0): Serial No: 012NTSU60790
[     8.256] (II) NOUVEAU(0): Number of EDID sections to follow: 1
[     8.256] (II) NOUVEAU(0): EDID (in hex):
[     8.256] (II) NOUVEAU(0): 	00ffffffffffff001e6d0677f61f0300
[     8.256] (II) NOUVEAU(0): 	0c1e0103803c2278ea3e31ae5047ac27
[     8.256] (II) NOUVEAU(0): 	0c50542108007140818081c0a9c0d1c0
[     8.256] (II) NOUVEAU(0): 	81000101010108e80030f2705a80b058
[     8.256] (II) NOUVEAU(0): 	8a0058542100001e04740030f2705a80
[     8.256] (II) NOUVEAU(0): 	b0588a0058542100001a000000fd0038
[     8.256] (II) NOUVEAU(0): 	3d1e873c000a202020202020000000fc
[     8.256] (II) NOUVEAU(0): 	004c472048445220344b0a20202001bc
[     8.256] (II) NOUVEAU(0): 	02033b714d9022201f1203040161605d
[     8.256] (II) NOUVEAU(0): 	5e5f230907076d030c004000b83c2000
[     8.256] (II) NOUVEAU(0): 	6001020367d85dc401788003e30f0003
[     8.256] (II) NOUVEAU(0): 	e305c000e606050160605a023a801871
[     8.256] (II) NOUVEAU(0): 	382d40582c450058542100001e565e00
[     8.256] (II) NOUVEAU(0): 	a0a0a029503020350058542100001a00
[     8.256] (II) NOUVEAU(0): 	0000ff003031324e5453553630373930
[     8.256] (II) NOUVEAU(0): 	0a0000000000000000000000000000a4
[     8.256] (--) NOUVEAU(0): HDMI max TMDS frequency 300000KHz
[     8.256] (II) NOUVEAU(0): Printing probed modes for output HDMI-1
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync -vsync (67.5 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     8.256] (II) NOUVEAU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x30.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x30.0   74.18  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.257] (II) NOUVEAU(0): Output DVI-I-1 disconnected
[     8.257] (II) NOUVEAU(0): Output DVI-D-1 disconnected
[     8.257] (II) NOUVEAU(0): Output HDMI-1 connected
[     8.257] (II) NOUVEAU(0): Using exact sizes for initial modes
[     8.257] (II) NOUVEAU(0): Output HDMI-1 using initial mode 3840x2160 +0+0
[     8.257] (==) NOUVEAU(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.257] (II) NOUVEAU(0): Virtual size is 3840x2160 (pitch 0)
[     8.257] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 30.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync -vsync (67.5 kHz e)
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 56.2 kHz, 25.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x25.0  297.00  3840 4896 4984 5280  2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "3840x2160": 297.0 MHz (scaled from 0.0 MHz), 54.0 kHz, 24.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  297.00  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "3840x2160": 296.7 MHz (scaled from 0.0 MHz), 67.4 kHz, 30.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x30.0  296.70  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "3840x2160": 296.7 MHz (scaled from 0.0 MHz), 53.9 kHz, 24.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "3840x2160"x24.0  296.70  3840 5116 5204 5500  2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "2560x1440": 241.5 MHz (scaled from 0.0 MHz), 88.8 kHz, 60.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.5 MHz (scaled from 0.0 MHz), 67.5 kHz, 60.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.5 MHz (scaled from 0.0 MHz), 56.2 kHz, 50.0 Hz
[     8.257] (II) NOUVEAU(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 148.4 MHz (scaled from 0.0 MHz), 67.4 kHz, 59.9 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 33.8 kHz, 30.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 27.0 kHz, 24.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1920x1080": 74.2 MHz (scaled from 0.0 MHz), 33.7 kHz, 30.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1600x900": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1280x800": 71.0 MHz (scaled from 0.0 MHz), 49.3 kHz, 59.9 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1280x720": 74.2 MHz (scaled from 0.0 MHz), 45.0 kHz, 59.9 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "720x576": 27.0 MHz (scaled from 0.0 MHz), 31.2 kHz, 50.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "720x480": 27.0 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "720x480": 27.0 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[     8.257] (**) NOUVEAU(0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[     8.258] (**) NOUVEAU(0):  Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[     8.258] (II) NOUVEAU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     8.258] (==) NOUVEAU(0): DPI set to (96, 96)
[     8.258] (II) Loading sub module "fb"
[     8.258] (II) LoadModule: "fb"
[     8.258] (II) Loading /usr/lib/xorg/modules/libfb.so
[     8.259] (II) Module fb: vendor="X.Org Foundation"
[     8.259] 	compiled for 1.20.13, module version = 1.0.0
[     8.259] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     8.259] (II) Loading sub module "shadowfb"
[     8.259] (II) LoadModule: "shadowfb"
[     8.259] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[     8.259] (II) Module shadowfb: vendor="X.Org Foundation"
[     8.259] (II) Loading sub module "dri2"
[     8.259] (II) LoadModule: "dri2"
[     8.260] (II) Module "dri2" already built-in
[     8.260] (EE) NOUVEAU(G0): [drm] failed to set drm interface version.
[     8.260] (EE) NOUVEAU(G0): [drm] error opening the drm
[     8.260] (EE) NOUVEAU(G0): 910:
[     8.260] (II) UnloadModule: "nouveau"
[     8.260] (II) UnloadModule: "modesetting"
[     8.260] (II) Unloading modesetting
[     8.261] (II) NOUVEAU(0): Channel setup complete.
[     8.262] (II) NOUVEAU(0): [COPY] async initialised.
[     8.262] (II) NOUVEAU(0): Hardware support for Present enabled
[     8.262] (II) NOUVEAU(0): [DRI2] Setup complete
[     8.262] (II) NOUVEAU(0): [DRI2]   DRI driver: nouveau
[     8.262] (II) NOUVEAU(0): [DRI2]   VDPAU driver: nouveau
[     8.262] (II) Loading sub module "exa"
[     8.262] (II) LoadModule: "exa"
[     8.262] (II) Loading /usr/lib/xorg/modules/libexa.so
[     8.263] (II) Module exa: vendor="X.Org Foundation"
[     8.263] 	compiled for 1.20.13, module version = 2.6.0
[     8.263] 	ABI class: X.Org Video Driver, version 24.1
[     8.263] (II) EXA(0): Driver allocated offscreen pixmaps
[     8.263] (II) EXA(0): Driver registered support for the following operations:
[     8.263] (II)         Solid
[     8.263] (II)         Copy
[     8.263] (II)         Composite (RENDER acceleration)
[     8.263] (II)         UploadToScreen
[     8.263] (II)         DownloadFromScreen
[     8.263] (==) NOUVEAU(0): Backing store enabled
[     8.263] (==) NOUVEAU(0): Silken mouse disabled
[     8.263] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[     8.263] (II) NOUVEAU(0): [XvMC] Extension initialized.
[     8.263] (==) NOUVEAU(0): DPMS enabled
[     8.264] (II) Initializing extension Generic Event Extension
[     8.264] (II) Initializing extension SHAPE
[     8.264] (II) Initializing extension MIT-SHM
[     8.264] (II) Initializing extension XInputExtension
[     8.265] (II) Initializing extension XTEST
[     8.265] (II) Initializing extension BIG-REQUESTS
[     8.265] (II) Initializing extension SYNC
[     8.265] (II) Initializing extension XKEYBOARD
[     8.265] (II) Initializing extension XC-MISC
[     8.266] (II) Initializing extension SECURITY
[     8.266] (II) Initializing extension XFIXES
[     8.266] (II) Initializing extension RENDER
[     8.266] (II) Initializing extension RANDR
[     8.266] (II) Initializing extension COMPOSITE
[     8.267] (II) Initializing extension DAMAGE
[     8.267] (II) Initializing extension MIT-SCREEN-SAVER
[     8.267] (II) Initializing extension DOUBLE-BUFFER
[     8.267] (II) Initializing extension RECORD
[     8.267] (II) Initializing extension DPMS
[     8.267] (II) Initializing extension Present
[     8.268] (II) Initializing extension DRI3
[     8.268] (II) Initializing extension X-Resource
[     8.268] (II) Initializing extension XVideo
[     8.268] (II) Initializing extension XVideo-MotionCompensation
[     8.268] (II) Initializing extension GLX
[     8.425] (II) AIGLX: Loaded and initialized nouveau
[     8.426] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.426] (II) Initializing extension XFree86-VidModeExtension
[     8.426] (II) Initializing extension XFree86-DGA
[     8.426] (II) Initializing extension XFree86-DRI
[     8.426] (II) Initializing extension DRI2
[     8.435] (II) NOUVEAU(0): NVEnterVT is called.
[     8.500] (II) NOUVEAU(0): Setting screen physical size to 1016 x 571
[     8.500] resize called 3840 2160
[     8.757] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.757] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.757] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.757] (**) Power Button: Applying InputClass "system-keyboard"
[     8.757] (II) LoadModule: "libinput"
[     8.757] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.763] (II) Module libinput: vendor="X.Org Foundation"
[     8.764] 	compiled for 1.20.11, module version = 1.1.0
[     8.764] 	Module class: X.Org XInput Driver
[     8.764] 	ABI class: X.Org XInput driver, version 24.1
[     8.764] (II) Using input driver 'libinput' for 'Power Button'
[     8.764] (**) Power Button: always reports core events
[     8.764] (**) Option "Device" "/dev/input/event1"
[     8.764] (**) Option "_source" "server/udev"
[     8.769] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.769] (II) event1  - Power Button: device is a keyboard
[     8.769] (II) event1  - Power Button: device removed
[     8.800] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     8.800] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.800] (**) Option "xkb_layout" "de"
[     8.842] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.842] (II) event1  - Power Button: device is a keyboard
[     8.843] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     8.843] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.843] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.843] (**) Power Button: Applying InputClass "system-keyboard"
[     8.843] (II) Using input driver 'libinput' for 'Power Button'
[     8.843] (**) Power Button: always reports core events
[     8.843] (**) Option "Device" "/dev/input/event0"
[     8.843] (**) Option "_source" "server/udev"
[     8.844] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.844] (II) event0  - Power Button: device is a keyboard
[     8.845] (II) event0  - Power Button: device removed
[     8.890] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     8.890] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     8.890] (**) Option "xkb_layout" "de"
[     8.891] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     8.891] (II) event0  - Power Button: device is a keyboard
[     8.892] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[     8.892] (II) No input driver specified, ignoring this device.
[     8.892] (II) This device may have been added with another device file.
[     8.893] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[     8.893] (II) No input driver specified, ignoring this device.
[     8.893] (II) This device may have been added with another device file.
[     8.893] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[     8.894] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event13)
[     8.894] (II) No input driver specified, ignoring this device.
[     8.894] (II) This device may have been added with another device file.
[     8.894] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event14)
[     8.895] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[     8.895] (II) No input driver specified, ignoring this device.
[     8.895] (II) This device may have been added with another device file.
[     8.896] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver mouse (/dev/input/event25)
[     8.896] (**) X10 Wireless Technology Inc USB Receiver mouse: Applying InputClass "evdev pointer catchall"
[     8.896] (**) X10 Wireless Technology Inc USB Receiver mouse: Applying InputClass "libinput pointer catchall"
[     8.896] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver mouse'
[     8.896] (**) X10 Wireless Technology Inc USB Receiver mouse: always reports core events
[     8.896] (**) Option "Device" "/dev/input/event25"
[     8.896] (**) Option "_source" "server/udev"
[     8.897] (II) event25 - X10 Wireless Technology Inc USB Receiver mouse: is tagged by udev as: Mouse
[     8.898] (II) event25 - X10 Wireless Technology Inc USB Receiver mouse: device is a pointer
[     8.898] (II) event25 - X10 Wireless Technology Inc USB Receiver mouse: device removed
[     8.946] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/input/input26/event25"
[     8.946] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver mouse" (type: MOUSE, id 8)
[     8.947] (**) Option "AccelerationScheme" "none"
[     8.947] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) selected scheme none/0
[     8.947] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) acceleration factor: 2.000
[     8.947] (**) X10 Wireless Technology Inc USB Receiver mouse: (accel) acceleration threshold: 4
[     8.948] (II) event25 - X10 Wireless Technology Inc USB Receiver mouse: is tagged by udev as: Mouse
[     8.949] (II) event25 - X10 Wireless Technology Inc USB Receiver mouse: device is a pointer
[     8.950] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver mouse (/dev/input/mouse1)
[     8.950] (II) No input driver specified, ignoring this device.
[     8.950] (II) This device may have been added with another device file.
[     8.951] (II) config/udev: Adding input device X10 Wireless Technology Inc USB Receiver (/dev/input/event24)
[     8.951] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "evdev keyboard catchall"
[     8.951] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "libinput keyboard catchall"
[     8.951] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "system-keyboard"
[     8.951] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver'
[     8.951] (**) X10 Wireless Technology Inc USB Receiver: always reports core events
[     8.951] (**) Option "Device" "/dev/input/event24"
[     8.951] (**) Option "_source" "server/udev"
[     8.953] (II) event24 - X10 Wireless Technology Inc USB Receiver: is tagged by udev as: Keyboard Pointingstick
[     8.953] (II) event24 - X10 Wireless Technology Inc USB Receiver: device is a pointer
[     8.953] (II) event24 - X10 Wireless Technology Inc USB Receiver: device is a keyboard
[     8.953] (II) event24 - X10 Wireless Technology Inc USB Receiver: device removed
[     8.983] (II) libinput: X10 Wireless Technology Inc USB Receiver: needs a virtual subdevice
[     8.983] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/rc/rc0/input25/event24"
[     8.983] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver" (type: MOUSE, id 9)
[     8.983] (**) Option "AccelerationScheme" "none"
[     8.983] (**) X10 Wireless Technology Inc USB Receiver: (accel) selected scheme none/0
[     8.983] (**) X10 Wireless Technology Inc USB Receiver: (accel) acceleration factor: 2.000
[     8.983] (**) X10 Wireless Technology Inc USB Receiver: (accel) acceleration threshold: 4
[     8.985] (II) event24 - X10 Wireless Technology Inc USB Receiver: is tagged by udev as: Keyboard Pointingstick
[     8.986] (II) event24 - X10 Wireless Technology Inc USB Receiver: device is a pointer
[     8.986] (II) event24 - X10 Wireless Technology Inc USB Receiver: device is a keyboard
[     8.987] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event30)
[     8.987] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[     8.987] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "libinput keyboard catchall"
[     8.987] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "system-keyboard"
[     8.987] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Keyboard Mouse'
[     8.987] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[     8.987] (**) Option "Device" "/dev/input/event30"
[     8.987] (**) Option "_source" "server/udev"
[     8.989] (II) event30 - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     8.989] (II) event30 - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     8.990] (II) event30 - MOSART Semi. 2.4G Keyboard Mouse: device removed
[     9.023] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7:1.0/0003:062A:4101.0007/input/input32/event30"
[     9.023] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 10)
[     9.023] (**) Option "xkb_layout" "de"
[     9.025] (II) event30 - MOSART Semi. 2.4G Keyboard Mouse: is tagged by udev as: Keyboard
[     9.025] (II) event30 - MOSART Semi. 2.4G Keyboard Mouse: device is a keyboard
[     9.030] (II) config/udev: Adding input device Logitech M310 (/dev/input/event15)
[     9.030] (**) Logitech M310: Applying InputClass "evdev pointer catchall"
[     9.030] (**) Logitech M310: Applying InputClass "libinput pointer catchall"
[     9.030] (II) Using input driver 'libinput' for 'Logitech M310'
[     9.030] (**) Logitech M310: always reports core events
[     9.030] (**) Option "Device" "/dev/input/event15"
[     9.030] (**) Option "_source" "server/udev"
[     9.032] (II) event15 - Logitech M310: is tagged by udev as: Mouse
[     9.032] (II) event15 - Logitech M310: device set to 800 DPI
[     9.032] (II) event15 - Logitech M310: device is a pointer
[     9.033] (II) event15 - Logitech M310: device removed
[     9.090] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/0003:046D:1024.0009/input/input49/event15"
[     9.090] (II) XINPUT: Adding extended input device "Logitech M310" (type: MOUSE, id 11)
[     9.090] (**) Option "AccelerationScheme" "none"
[     9.090] (**) Logitech M310: (accel) selected scheme none/0
[     9.090] (**) Logitech M310: (accel) acceleration factor: 2.000
[     9.090] (**) Logitech M310: (accel) acceleration threshold: 4
[     9.092] (II) event15 - Logitech M310: is tagged by udev as: Mouse
[     9.092] (II) event15 - Logitech M310: device set to 800 DPI
[     9.092] (II) event15 - Logitech M310: device is a pointer
[     9.093] (II) config/udev: Adding input device Logitech M310 (/dev/input/mouse0)
[     9.094] (II) No input driver specified, ignoring this device.
[     9.094] (II) This device may have been added with another device file.
[     9.095] (II) config/udev: Adding input device Logitech K520 (/dev/input/event21)
[     9.095] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     9.095] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     9.095] (**) Logitech K520: Applying InputClass "system-keyboard"
[     9.095] (II) Using input driver 'libinput' for 'Logitech K520'
[     9.095] (**) Logitech K520: always reports core events
[     9.095] (**) Option "Device" "/dev/input/event21"
[     9.095] (**) Option "_source" "server/udev"
[     9.097] (II) event21 - Logitech K520: is tagged by udev as: Keyboard
[     9.097] (II) event21 - Logitech K520: device is a keyboard
[     9.097] (II) event21 - Logitech K520: device removed
[     9.116] (II) libinput: Logitech K520: needs a virtual subdevice
[     9.116] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/0003:046D:2011.000A/input/input50/event21"
[     9.116] (II) XINPUT: Adding extended input device "Logitech K520" (type: MOUSE, id 12)
[     9.117] (**) Option "AccelerationScheme" "none"
[     9.117] (**) Logitech K520: (accel) selected scheme none/0
[     9.117] (**) Logitech K520: (accel) acceleration factor: 2.000
[     9.117] (**) Logitech K520: (accel) acceleration threshold: 4
[     9.119] (II) event21 - Logitech K520: is tagged by udev as: Keyboard
[     9.119] (II) event21 - Logitech K520: device is a keyboard
[     9.120] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event16)
[     9.120] (II) No input driver specified, ignoring this device.
[     9.120] (II) This device may have been added with another device file.
[     9.121] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event17)
[     9.121] (II) No input driver specified, ignoring this device.
[     9.121] (II) This device may have been added with another device file.
[     9.121] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event18)
[     9.122] (II) config/udev: Adding input device HD-Audio Generic Line Out (/dev/input/event19)
[     9.122] (II) No input driver specified, ignoring this device.
[     9.122] (II) This device may have been added with another device file.
[     9.122] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event20)
[     9.123] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[     9.123] (II) No input driver specified, ignoring this device.
[     9.123] (II) This device may have been added with another device file.
[     9.132] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "evdev keyboard catchall"
[     9.132] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "libinput keyboard catchall"
[     9.132] (**) X10 Wireless Technology Inc USB Receiver: Applying InputClass "system-keyboard"
[     9.132] (II) Using input driver 'libinput' for 'X10 Wireless Technology Inc USB Receiver'
[     9.132] (**) X10 Wireless Technology Inc USB Receiver: always reports core events
[     9.132] (**) Option "Device" "/dev/input/event24"
[     9.132] (**) Option "_source" "_driver/libinput"
[     9.132] (II) libinput: X10 Wireless Technology Inc USB Receiver: is a virtual subdevice
[     9.132] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-5/1-5:1.0/rc/rc0/input25/event24"
[     9.132] (II) XINPUT: Adding extended input device "X10 Wireless Technology Inc USB Receiver" (type: KEYBOARD, id 13)
[     9.132] (**) Option "xkb_layout" "de"
[     9.132] (**) Logitech K520: Applying InputClass "evdev keyboard catchall"
[     9.132] (**) Logitech K520: Applying InputClass "libinput keyboard catchall"
[     9.132] (**) Logitech K520: Applying InputClass "system-keyboard"
[     9.132] (II) Using input driver 'libinput' for 'Logitech K520'
[     9.132] (**) Logitech K520: always reports core events
[     9.132] (**) Option "Device" "/dev/input/event21"
[     9.133] (II) libinput: Logitech K520: is a virtual subdevice
[     9.133] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:07.1/0000:28:00.3/usb3/3-2/3-2:1.2/0003:046D:C52B.0003/0003:046D:2011.000A/input/input50/event21"
[     9.133] (II) XINPUT: Adding extended input device "Logitech K520" (type: KEYBOARD, id 14)
[     9.133] (**) Option "xkb_layout" "de"
[     9.238] (II) NOUVEAU(0): EDID vendor "GSM", prod id 30470
[     9.238] (II) NOUVEAU(0): Using EDID range info for horizontal sync
[     9.238] (II) NOUVEAU(0): Using EDID range info for vertical refresh
[     9.238] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[     9.238] (II) NOUVEAU(0): Modeline "3840x2160"x0.0  594.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (135.0 kHz eP)
[     9.238] (II) NOUVEAU(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync -vsync (67.5 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1920x1080"x0.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[     9.238] (II) NOUVEAU(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[     9.239] (--) NOUVEAU(0): HDMI max TMDS frequency 300000KHz
[     9.239] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0 /dev/dri/card0
[     9.239] xf86: remove device 0 /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
[     9.239] failed to find screen to remove
[     9.239] (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:03.1/0000:27:00.0/drm/card1 /dev/dri/card1
[    10.604] (II) config/udev: Adding input device C922 Pro Stream Webcam (/dev/input/event23)
[    10.604] (**) C922 Pro Stream Webcam: Applying InputClass "evdev keyboard catchall"
[    10.604] (**) C922 Pro Stream Webcam: Applying InputClass "libinput keyboard catchall"
[    10.604] (**) C922 Pro Stream Webcam: Applying InputClass "system-keyboard"
[    10.604] (II) Using input driver 'libinput' for 'C922 Pro Stream Webcam'
[    10.604] (**) C922 Pro Stream Webcam: always reports core events
[    10.604] (**) Option "Device" "/dev/input/event23"
[    10.604] (**) Option "_source" "server/udev"
[    10.606] (II) event23 - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[    10.606] (II) event23 - C922 Pro Stream Webcam: device is a keyboard
[    10.606] (II) event23 - C922 Pro Stream Webcam: device removed
[    10.690] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.1/1-6.1:1.0/input/input52/event23"
[    10.690] (II) XINPUT: Adding extended input device "C922 Pro Stream Webcam" (type: KEYBOARD, id 15)
[    10.690] (**) Option "xkb_layout" "de"
[    10.692] (II) event23 - C922 Pro Stream Webcam: is tagged by udev as: Keyboard
[    10.692] (II) event23 - C922 Pro Stream Webcam: device is a keyboard
[    14.998] (II) config/udev: Adding input device Logitech Wireless Mouse PID:1020 (/dev/input/mouse2)
[    14.998] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    14.998] (II) No input driver specified, ignoring this device.
[    14.998] (II) This device may have been added with another device file.
[    15.083] (II) config/udev: Adding input device Logitech Wireless Mouse PID:1020 (/dev/input/event26)
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev pointer catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev keyboard catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput pointer catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput keyboard catchall"
[    15.083] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    15.083] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse PID:1020'
[    15.083] (**) Logitech Wireless Mouse PID:1020: always reports core events
[    15.083] (**) Option "Device" "/dev/input/event26"
[    15.083] (**) Option "_source" "server/udev"
[    15.086] (II) event26 - Logitech Wireless Mouse PID:1020: is tagged by udev as: Keyboard Mouse
[    15.086] (II) event26 - Logitech Wireless Mouse PID:1020: device is a pointer
[    15.086] (II) event26 - Logitech Wireless Mouse PID:1020: device is a keyboard
[    15.086] (II) event26 - Logitech Wireless Mouse PID:1020: device removed
[    15.130] (II) libinput: Logitech Wireless Mouse PID:1020: needs a virtual subdevice
[    15.130] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.4/1-6.4:1.1/0003:046D:C52F.000D/0003:046D:1020.000E/input/input53/event26"
[    15.130] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse PID:1020" (type: MOUSE, id 16)
[    15.130] (**) Option "AccelerationScheme" "none"
[    15.130] (**) Logitech Wireless Mouse PID:1020: (accel) selected scheme none/0
[    15.130] (**) Logitech Wireless Mouse PID:1020: (accel) acceleration factor: 2.000
[    15.130] (**) Logitech Wireless Mouse PID:1020: (accel) acceleration threshold: 4
[    15.132] (II) event26 - Logitech Wireless Mouse PID:1020: is tagged by udev as: Keyboard Mouse
[    15.132] (II) event26 - Logitech Wireless Mouse PID:1020: device is a pointer
[    15.132] (II) event26 - Logitech Wireless Mouse PID:1020: device is a keyboard
[    15.133] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev pointer catchall"
[    15.133] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "evdev keyboard catchall"
[    15.133] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput pointer catchall"
[    15.133] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "libinput keyboard catchall"
[    15.133] (**) Logitech Wireless Mouse PID:1020: Applying InputClass "system-keyboard"
[    15.133] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse PID:1020'
[    15.133] (**) Logitech Wireless Mouse PID:1020: always reports core events
[    15.133] (**) Option "Device" "/dev/input/event26"
[    15.133] (**) Option "_source" "_driver/libinput"
[    15.133] (II) libinput: Logitech Wireless Mouse PID:1020: is a virtual subdevice
[    15.133] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-6/1-6.4/1-6.4:1.1/0003:046D:C52F.000D/0003:046D:1020.000E/input/input53/event26"
[    15.133] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse PID:1020" (type: KEYBOARD, id 17)
[    15.133] (**) Option "xkb_layout" "de"
I tried again to update my manjaro because i don´t want to be left back :sob:
When i boot after the update manjaro does not go into gui via lightdm. Bevore the update all was good.
I did install manjaro on a USB-Stick. This one does boot into GUI. (I am writing from this USB-Install now) But i am in a loss how to find the problem.
Right now i am trying to compare configs in /etc. But the biggest difference i know is, the USB works only singleseat. The PC was multiseat.
Differences i found:
/var/log/xorg.log shows:
failed (on SSD)
[    83.470] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    83.472] (II) xfree86: Adding drm device (/dev/dri/card0)
[    83.480] (--) PCI: (1@0:0:0) 10de:0fc8:3842:3744 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[    83.480] (--) PCI:*(39@0:0:0) 10de:1c82:1458:3733 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    83.480] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    83.480] (II) LoadModule: "glx"
[    83.480] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    83.482] (II) Module glx: vendor="X.Org Foundation"
[    83.482] 	compiled for 1.20.13, module version = 1.0.0
[    83.482] 	ABI class: X.Org Server Extension, version 10.0
[    83.485] (==) Matched modesetting as autoconfigured driver 0
[    83.485] (==) Matched fbdev as autoconfigured driver 1
[    83.485] (==) Matched vesa as autoconfigured driver 2
[    83.485] (==) Assigned the driver to the xf86ConfigLayout
[    83.485] (II) LoadModule: "modesetting"
[    83.485] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    83.485] (II) Module modesetting: vendor="X.Org Foundation"
[    83.485] 	compiled for 1.20.13, module version = 1.20.13
[    83.486] 	Module class: X.Org Video Driver
[    83.486] 	ABI class: X.Org Video Driver, version 24.1
[    83.486] (II) LoadModule: "fbdev"
[    83.486] (WW) Warning, couldn't open module fbdev
[    83.486] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    83.486] (II) LoadModule: "vesa"
[    83.486] (WW) Warning, couldn't open module vesa
[    83.486] (EE) Failed to load module "vesa" (module does not exist, 0)
[    83.486] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    83.486] (WW) Falling back to old probe method for modesetting
[    83.487] (II) modeset(1): using default device
[    83.487] (II) modeset(G0): using drv /dev/dri/card0
[    83.487] (EE) Screen 0 deleted because of no matching config section.
[    83.487] (II) UnloadModule: "modesetting"
[    83.487] (EE)
Fatal server error:
[    83.487] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[    83.487] (EE)
[    83.487] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    83.487] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    83.487] (EE)
[    83.490] (EE) Server terminated with error (1). Closing log file.
good (on USB)
[  1285.034] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[  1285.036] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1285.036] (II) xfree86: Adding drm device (/dev/dri/card1)
[  1285.044] (--) PCI: (1@0:0:0) 10de:0fc8:3842:3744 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[  1285.044] (--) PCI:*(39@0:0:0) 10de:1c82:1458:3733 rev 161, Mem @ 0xf4000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[  1285.044] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[  1285.044] (II) LoadModule: "glx"
[  1285.044] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1285.046] (II) Module glx: vendor="X.Org Foundation"
[  1285.046] 	compiled for 1.20.13, module version = 1.0.0
[  1285.046] 	ABI class: X.Org Server Extension, version 10.0
[  1285.048] (==) Matched modesetting as autoconfigured driver 0
[  1285.048] (==) Matched fbdev as autoconfigured driver 1
[  1285.048] (==) Matched vesa as autoconfigured driver 2
[  1285.048] (==) Assigned the driver to the xf86ConfigLayout
[  1285.049] (II) LoadModule: "modesetting"
[  1285.049] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  1285.049] (II) Module modesetting: vendor="X.Org Foundation"
[  1285.049] 	compiled for 1.20.13, module version = 1.20.13
[  1285.049] 	Module class: X.Org Video Driver
[  1285.049] 	ABI class: X.Org Video Driver, version 24.1
[  1285.049] (II) LoadModule: "fbdev"
[  1285.049] (WW) Warning, couldn't open module fbdev
[  1285.049] (EE) Failed to load module "fbdev" (module does not exist, 0)
[  1285.050] (II) LoadModule: "vesa"
[  1285.050] (WW) Warning, couldn't open module vesa
[  1285.050] (EE) Failed to load module "vesa" (module does not exist, 0)
[  1285.050] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  1285.050] (II) modeset(0): using drv /dev/dri/card1
[  1285.050] (II) modeset(G0): using drv /dev/dri/card0
[  1285.050] (II) modeset(0): Creating default Display subsection in Screen section
[  1285.051] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[  1285.051] (==) modeset(0): RGB weight 888
[  1285.051] (==) modeset(0): Default visual is TrueColor
[  1285.051] (II) Loading sub module "glamoregl"
[  1285.051] (II) LoadModule: "glamoregl"
[  1285.051] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[  1285.056] (II) Module glamoregl: vendor="X.Org Foundation"
[  1285.056] 	compiled for 1.20.13, module version = 1.0.1
[  1285.056] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1285.086] (II) modeset(0): glamor X acceleration enabled on NV137
[  1285.086] (II) modeset(0): glamor initialized
[  1285.087] (II) modeset(0): Output DVI-D-2 has no monitor section
[  1285.089] (II) modeset(0): Output HDMI-2 has no monitor section
[  1285.159] (II) modeset(0): Output DP-1 has no monitor section
[  1285.161] (II) modeset(0): Output HDMI-3 has no monitor section
[  1285.235] (II) modeset(0): Output HDMI-4 has no monitor section
[  1285.237] (II) modeset(0): EDID for output DVI-D-2
[  1285.238] (II) modeset(0): EDID for output HDMI-2
[  1285.309] (II) modeset(0): EDID for output DP-1
[  1285.311] (II) modeset(0): EDID for output HDMI-3
[  1285.385] (II) modeset(0): EDID for output HDMI-4
[  1285.385] (II) modeset(0): Manufacturer: GSM  Model: 5b08  Serial#: 110118
[  1285.385] (II) modeset(0): Year: 2018  Week: 1
[  1285.385] (II) modeset(0): EDID Version: 1.3
[  1285.385] (II) modeset(0): Digital Display Input
[  1285.385] (II) modeset(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[  1285.385] (II) modeset(0): Gamma: 2.20
[  1285.385] (II) modeset(0): DPMS capabilities: StandBy Suspend Off
[  1285.385] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[  1285.385] (II) modeset(0): First detailed timing is preferred mode
[  1285.385] (II) modeset(0): redX: 0.652 redY: 0.335   greenX: 0.305 greenY: 0.637
[  1285.385] (II) modeset(0): blueX: 0.148 blueY: 0.062   whiteX: 0.313 whiteY: 0.329
[  1285.385] (II) modeset(0): Supported established timings:
[  1285.385] (II) modeset(0): 640x480@60Hz
in short: the failed one (xorg fails to start)
only with card0
versus the good one (xorg and lightdm start with one seat)
with card 0 and card1
card1 seems to be not recognized :cry:
But what does that mean ?:
Now i will try to restart from ssd
The problem of crashing xorg has gone, when i did:
  • loginctl flush-devices
Now i am able to boot into GUI :smiling_face_with_three_hearts:
But in this process i lost my second seat :sob:
Other changes i made while analyzing to find the problem:
  • /etc/mkinitcpio.conf
    • added nouveau to MODULES
    • added udev to HOOKS
    • sudo mkinitcpio -p linux514
cat /etc/mkinitcpio.conf|egrep -v '#'
MODULES=(btrfs nouveau)
BINARIES=()
FILES=()
HOOKS=(base udev systemd autodetect modconf block keyboard sd-vconsole filesystems bootsplash-manjaro)
COMPRESSION="zstd"
Can anyone help me to get back to functioning loginctl for my second seat?
I did solve it (but don´t ask how long it took)
I changed /etc/lightdm/lightdm.conf
cat /etc/lightdm/lightdm.conf | egrep -v '#'
[LightDM]
logind-check-graphical = True
run-directory=/run/lightdm
[Seat:*]
greeter-session=lightdm-gtk-greeter
session-wrapper=/etc/lightdm/Xsession
[Seat:seat0]
xserver-command=/usr/bin/X :0 vt7
xserver-layout=seat0
[Seat:seat1]
xserver-command=/usr/bin/X :1 vt8
xserver-layout=seat1
[XDMCPServer]
[VNCServer]
I reconfigured loginctl
loginctl seat-status seat1
seat1
        Sessions: *4
         Devices:
                  ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
                  │ [MASTER] drm:card0
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0/card0-DVI-D-1
                  │ │ [MASTER] drm:card0-DVI-D-1
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0/card0-DVI-I-1
                  │ │ [MASTER] drm:card0-DVI-I-1
                  │ └─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0/card0-HDMI-A-1
                  │   [MASTER] drm:card0-HDMI-A-1
                  ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/graphics/fb1
                  │ graphics:fb1 "nouveau"
                  ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0
                  │ sound:card0 "NVidia_1"
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input20
                  │ │ input:input20 "HDA NVidia HDMI/DP,pcm=3"
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input21
                  │ │ input:input21 "HDA NVidia HDMI/DP,pcm=7"
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input22
                  │ │ input:input22 "HDA NVidia HDMI/DP,pcm=8"
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input23
                  │ │ input:input23 "HDA NVidia HDMI/DP,pcm=9"
                  │ ├─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input24
                  │ │ input:input24 "HDA NVidia HDMI/DP,pcm=10"
                  │ └─/sys/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input25
                  │   input:input25 "HDA NVidia HDMI/DP,pcm=11"
                  └─/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7.1
                    usb:1-7.1
                    ├─/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7.1/1-7.1:1.2/0003:046D:C52B.0003/0003:046D:1024.0005/input/input17
                    │ input:input17 "Logitech M310"
                    └─/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7.1/1-7.1:1.2/0003:046D:C52B.0003/0003:046D:2011.0006/input/input16
                      input:input16 "Logitech K520"
                      ├─/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7.1/1-7.1:1.2/0003:046D:C52B.0003/0003:046D:2011.0006/input/input16/inp>
                      │ leds:input16::capslock
                      │ leds:input16::compose
                      │ leds:input16::kana
                      │ leds:input16::numlock
                      └─/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-7/1-7.1/1-7.1:1.2/0003:046D:C52B.0003/0003:046D:2011.0006/input/input16/inp>
                        leds:input16::scrolllock
Now i do have multiseat again
In the last few years i did work without any xorg.conf. This leads to xorg using internal defaults. This worked very good. (mostly :wink: )
I had thought it would now be necessary to create again a xorg.conf because of my problems. But it does work without :slight_smile:
One problem remains
  • When the computer boots, the monitor at seat0 shows lightdm login and works flawless.
  • The monitor at seat1 stays dark. loginctl list-sessions says there is a lightdm at seat1 waiting for login :thinking: but the screen stays dark.
  • When the password for the user of seat1 is typed blindly into its keyboard (as if lightdm would have been visible), after the Enter key is pressed, the monitor of seat1 will suddenly show the desktop as if nothing has been wrong at all. :innocent:
:rofl:
