Hey there,
I’m unable to log in to graphical environment. After updating manjaro, login screen freezes after entering password.
Things I tried so far via Terminal (crlt + alt + f3):
- Boot kde
sudo startx
Output:
unable to connect to d-bus: using x11 for dbus-deamon was disabled at compile at compile time, set your DBUS_SESSION_BUS_ADRRESS instead
couldn't exec startkde: no such file or directory
xinit: connection to X server lost
Or
startx
Output:
Xauth: unable to write authority file
Fatal server error: (EE) Cannot open log file "..../Xorg.1.log”
added new usr. Login screen appears again after entering psw.
switch kernel in advanced settings didn’t bring any changes, neither does fallback init
I tried to lounch an application
qt.qpa.xcb: Could not connect to display qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem. Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb. Aborted (core dumped)
Thanks for any ideas or replies. Please excuse any mistakes, as I am a noob. ![]()
