I am a fairly new user of linux. I have installed manjaro with xfce on a mac mini and have been successfully running it for a couple of months. I do regular (once a month) updates. I recently installed tigervnc and set it up using the instructions on the arch linux wiki. The installation was successful: I can use tigerviewer to access the machine. I can also use ssh to access the machine.
But I broke something else: if I have a display connected to the machine, I get the expected login screen, enter my password, the screen goes black for two or three seconds and comes back to the login screen. Re-entering the password repeats the cycle. The display manager is xfce, I checked in the bottom right hand corner of the display
there is a .xsessions-errors file in my home directory:
gpg-agent: a gpg-agent is already running - not starting a new one
(xfwm4:1499): Gtk-WARNING **: 19:29:11.273: cannot open display: :0
i have output from inxi, too, but whenever I try to paste it into the topic, i get an error message about posting links. thatâs a bit confusing because there are no links in my post! anywayâŚ
Can someone suggest a debugging strategy or what logs to dig into? Iâve set up tigervnc on other manjaro linux boxes but havenât run into this problem before.
Thanks,
wh
Thanks Andreas. I missed the markdown info before. Appreciate the help.
sudo inxi --verbosity=8 --filter --width
[sudo] password for worsthorse:
Kernel: 6.6.54-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1062a0e8-551f-4c4c-a020-10ce22d4067c rw quiet
udev.log_priority=3
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: Apple product: Macmini7,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-35C5E08120C7EEAF serial: <filter>
Mobo: Apple model: Mac-35C5E08120C7EEAF v: Macmini7,1 serial: <filter>
uuid: 35291ed3-6c7b-a855-88f6-c7fd423f1945 UEFI: Apple v: 431.0.0.0.0
date: 02/22/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M325
status: N/A
System RAM: total: 16 GiB available: 15.5 GiB used: 1.73 GiB (11.1%)
igpu: 96 MiB
Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: N/A
volts: N/A width: N/A manufacturer: 0x02FE
part-no: 0x4544464232333241314D412D47442D460000 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed: N/A
Slot: 0 type: PCIe status: available length: short volts: 3.3 bus-ID: N/A
Slot: 2 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
Slot: 3 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
Slot: 4 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
Slot: 5 type: PCI status: available length: long volts: 3.3 bus-ID: N/A
Info: model: Intel Core i7-4578U socket: BGA1168 (U3E1) note: check bits: 64
type: MT MCP arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x45 (69) stepping: 1
microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3000 min/max: 800/3500 base/boost: 3000/3000 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.1 V ext-clock: 25 MHz
cores: 1: 3000 2: 3000 3: 3000 4: 3000 bogomips: 24008
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: DP-2
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a2e
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915 tty: 130x65
Monitor-1: DP-2 model: Dell S2721QS serial: <filter> built: 2023
res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green:
x: 0.306 y: 0.647 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 3840x2160, 2560x1440, 2048x1280, 1920x1080, 1920x1080i, 1600x1200,
1600x900, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
unhandled CEA mode 95
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.6.54-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.5 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
vendor: Apple driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 14e4:1686 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-1: Apple Bluetooth Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3:7 chip-ID: 05ac:8289
class-ID: fe01
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: yes pairing: yes class-ID: 6c010c
Local Storage: total: 233.76 GiB used: 154.28 GiB (66.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256F
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: JA1Q scheme: GPT
ID-1: / raw-size: 233.46 GiB size: 228.74 GiB (97.98%)
used: 154.28 GiB (67.4%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 1062a0e8-551f-4c4c-a020-10ce22d4067c
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: NO_LABEL uuid: ACCB-BB6F
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-3.3:7 info: Apple Bluetooth Host Controller type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 05ac:8289 class-ID: fe01
Device-2: 1-4:3 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Device-3: 1-8:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1136 libs: 354 tools: pamac
1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
2: https://muug.ca/mirror/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 189
1: cpu: 0.6% command: sdrplay_apiService pid: 694 mem: 3.88 MiB (0.0%)
2: cpu: 0.4% command: /newerversion started-by: dropbox pid: 1394
mem: 468.7 MiB (2.9%)
3: cpu: 0.1% command: blueman-tray started-by: python pid: 1357
mem: 46.1 MiB (0.2%)
4: cpu: 0.0% command: init pid: 1 mem: 12.7 MiB (0.0%)
5: cpu: 0.0% command: [kthreadd] pid: 2 mem: 0.00 MiB (0.0%)
Memory top: 5 of 189
1: mem: 468.7 MiB (2.9%) command: /newerversion started-by: dropbox
pid: 1394 cpu: 0.4%
2: mem: 134.5 MiB (0.8%) command: lightdm-gtk-greeter pid: 1578 cpu: 0.0%
3: mem: 129.5 MiB (0.8%) command: Xorg pid: 1537 cpu: 0.0%
4: mem: 86.6 MiB (0.5%) command: Xvnc pid: 774 cpu: 0.0%
5: mem: 68.8 MiB (0.4%) command: xfwm4 pid: 997 cpu: 0.0%
Processes: 189 Power: uptime: 13h 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16
default: Bash v: 5.2.37 running-in: pty pts/1 (SSH) inxi: 3.3.36
last bit of info⌠i spent about four hours yesterday searching the web, reading the archi and manjaro wikis, and checking this forum. lots of black screens but nothing like this problem. i am just not sure where to startâŚ
thanks,
wh
ceres
19 November 2024 17:48
5
Hi,
I donât know if it is relevant but it seems you donât have a swap partition or a swapfile, right? Maybe you need some?
Hi Ceres, I donât think that matters for this problem⌠Iâve been running the system successfully for months.
I am guessing there is just something I donât understand about how the display manager works in conjunction with the vncserver. Off to do more reading/searching and see if anyone can point me in the right direction here.
wh
brahma
19 November 2024 18:59
7
so how do you access your desktop?
uninstall the tigervnc, remove/backup its configs, reboot and see if it helpsâŚ
BG405
19 November 2024 19:30
8
A wild guess here, but is TigerVNC trying to use the same TTY as youâd normally use for your graphical login? Have you tried starting a graphical session from another TTY?
I mentioned something along these lines here, for a different (but maybe related) issue, albeit thatâs for Plasma:
Iâve found a workaround. Itâs using different TTYs as you probably know, will update later when I get home if I think of anything else.
It appears that the primary userâs DE gets switched to TTY1 when a second user logs into a GUI environment (this doesnât happen with regular TTY logins as far as I know). Iâve usually found it on one of the others (2 or 3?). Maybe this is a clue.
Basically, if I log in as another user, I can switch between them with CTRL + ALT + F⌠to switch between the loggedâŚ
Thanks BG405. Doesnât seem to be the problem you described.
More details. I restarted the machine and was able to log in through the attached display. I logged back out. Now my tigerviewer connection gets refused when I tried to connect to the vncserver.
It looks like I have to reboot the machine to switch back and forth between the vncserver display :1 and the normal display :0 which is definitely not the behavior I expect.
I am seriously confused now. I guess I could roll back the tigervnc install and start over again but Iâd prefer to figure out whatâs broken and fix it.
I could also create another user account and see if the behavior is different but I still donât know where to look for mis-set config.
worsthorse:
You might want to have a browse through this thread from 2 years ago:
Iâve followed the steps in the Initial setup and Accessing vncserver via SSH tunnels from the TigerVNC arch wiki and now when I try to login a black screen flashes and it takes me to the login page again. So I canât access the computer. Now I can only access from another computer by ssh or graphically by using the TigerVNC Viewer.
I would like to still be able to login normally to the computer without having to login from another computer.
The last answer in that topic:
eriefisher beat me to it, but yes I agree the way to go is either x11vnc or TigerVNCâs x0vncserver . It wonât work exactly like Windows RD though, since the remote and local displays will be shared. It will be similar to how TeamViewer works. This might be annoying if you want the remote session to have a different resolution or number of monitors than the ones physically connected to your machine.
Iâm not aware of anything available if you want to easily (read: without manually ensuring the othâŚ
x11vnc
is available from Manjaroâs official (Extra) repo.
Does sound like you are trying to use the same login simultanously - this is unsupported by tigervnc.
Please see the following topics for instructions
â [root tip] [How To] TigerVNC Quick Setup
â [root tip] [How To] TigerVNC over SSH
display:0 is the console - the root display so to speak.
You specifically state you are using xfce - which in turn comes with lightdm - which defaults to open a session at display:7 (at least that is how I remember it)
