Linux Noob: No Sound on 2016 Macbook Pro
Hello and thank you for your time and help. Trying out Manjaro on my 2016 Macbook Pro and I’m getting no sound. Here is my inxi:
  ~  inxi --admin --verbosity=7 --filter --width                                                    ✔
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2121 quiet systemd.show_status=1
    apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Apple product: MacBookPro13,1 v: 1.0
    serial: <superuser required> Chassis: type: 9 v: Mac-473D31EABEB93F9B
  Mobo: Apple model: Mac-473D31EABEB93F9B v: MacBookPro13,1
    serial: <superuser required> UEFI: Apple v: 447.40.12.0.0 date: 09/25/2021
  ID-1: BAT0 charge: 33.9 Wh (115.3%) condition: 29.4/54.6 Wh (53.9%)
    volts: 12.7 min: 11.4 model: DSY bq20z451 type: Li-ion serial: N/A
    status: Full cycles: 786
  RAM: total: 7.63 GiB used: 2.81 GiB (36.9%)
  RAM Report:
  Info: model: Intel Core i5-6360U bits: 64 type: MT MCP arch: Skylake
    family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 500 min/max: 400/3100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 16006
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
    lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
    pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel Iris Graphics 540 vendor: Apple driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:1926 class-ID: 0300
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  Device-2: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 03:00.0
    chip-ID: 14e4:1570 class-ID: 0480
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.42 running: yes
  Device-1: Broadcom BCM4350 802.11ac Wireless Network Adapter vendor: Apple
    driver: brcmfmac v: kernel bus-ID: 02:00.0 chip-ID: 14e4:43a3 class-ID: 0280
  Local Storage: total: 353.27 GiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD AP0256J
    size: 233.76 GiB block-size: physical: 4096 B logical: 4096 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 12.93.01
    temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme0n2 maj-min: 259:3 vendor: Apple model: SSD AP0256J
    size: 8 KiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 12.93.01 temp: 38.9 C
  ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Type-C
    size: 119.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 1100 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: EFI
    uuid: 5F66-17ED
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 233.47 GiB fs: apfs label: N/A
    uuid: 0016c1bc-6371-4867-9ff5-d6db473e912e
  ID-3: /dev/sda1 maj-min: 8:1 size: 3.58 GiB fs: iso9660
  ID-4: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 8078-6038
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-1:2
    info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1
    speed: 5 Gb/s power: 304mA chip-ID: 090c:1000 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 30.0 C mobo: N/A
  Processes: 199 Uptime: 7h 42m wakeups: 2 Init: systemd v: 250
  tool: systemctl Compilers: gcc: N/A Packages: pacman: 1228 lib: 331
  flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole
  inxi: 3.3.11
How should I proceed?
Thank you so much.
Hello,
See if this are helpful:
