Lightdm failed to start again
So every time i dont use my computer to 7 or so days this happens:
Any idea what to do? I tried to reinstall lightdm but nothing.
I would like to use light dm cause i use xfce’s login manager (but only i3 as wm, no de). But i may be considering a switch to ssdm.
If you disable the lightdm.service (for the time being)
and reboot
you could boot normally, to a TTY prompt.
Log in there (not as root - you’ll be prompted for the password) and start lightdm.service
perhaps the output will tell you something.
systemctl disable lightdm.service
reboot
systemctl start lightdm.service
once rebooted and logged in
Same…
Why use sudo?
You will get prompted.
There must be a log about why it fails somewhere - but I can’t tell you where off the top of my head.
There is a chance that you are in a partial update state.
Run a system update.
… you’ll need sudo here :nerd_face:
sudo pacman -Syyu
Without sudo i have to authenticate myself that does the same.
But the same happens
I did that too earlier
Then perhaps someone else can help you - I currently cannot. :man_shrugging:
Thank you for your help!
there are log files in /var/log/lightdm/
sudo ls -l /var/log/lightdm/
look through them:
sudo less /var/log/lightdm/lightdm.log
sudo less /var/log/lightdm/seat0-greeter.log
sudo less /var/log/lightdm/x-0.log
It should also trace in the system journal:
journalctl --boot=0 --unit=lightdm
It appears that the error is gtk greeter related. have you tried removing the gtk greeter and install the lightdm-slick-greeter?
i3hunor@HunorT480 ~]$ journalctl --boot=0 --unit=lightdm
Jan 22 09:52:39 HunorT480 systemd[1]: Starting Light Display Manager...
Jan 22 09:52:39 HunorT480 lightdm[290272]: Failed to use bus name org.freedesktop.DisplayMan>
Jan 22 09:52:39 HunorT480 systemd[1]: lightdm.service: Main process exited, code=exited, sta>
Jan 22 09:52:39 HunorT480 systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 22 09:52:39 HunorT480 systemd[1]: Failed to start Light Display Manager.
Jan 22 09:52:39 HunorT480 systemd[1]: lightdm.service: Scheduled restart job, restart counte>
Jan 22 09:52:39 HunorT480 systemd[1]: Stopped Light Display Manager.
Jan 22 09:52:40 HunorT480 lightdm[290289]: Failed to use bus name org.freedesktop.DisplayMan>
Jan 22 09:52:40 HunorT480 systemd[1]: lightdm.service: Main process exited, code=exited, sta>
Jan 22 09:52:40 HunorT480 systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jan 22 09:52:40 HunorT480 systemd[1]: Failed to start Light Display Manager.
Jan 22 09:52:40 HunorT480 systemd[1]: lightdm.service: Scheduled restart job, restart counte>
Jan 22 09:52:40 HunorT480 systemd[1]: Stopped Light Display Manager.
Jan 22 09:52:40 HunorT480 systemd[1]: Starting Light Display Manager...
Jan 22 09:52:40 HunorT480 lightdm[290299]: Failed to use bus name org.freedesktop.DisplayMan>
Jan 22 09:52:40 HunorT480 lightdm[290310]: Failed to use bus name org.freedesktop.DisplayMan>
Jan 22 09:52:40 HunorT480 lightdm[290326]: Failed to use bus name org.freedesktop.DisplayMan>
Jan 22 09:52:40 HunorT480 systemd[1]: lightdm.service: Start request repeated too quickly.
I cant remove gtk-greeter, but i installed lightdm-slick-greeter.
 yay -R lightdm-gtk-greeter
[sudo] password for i3hunor:
checking dependencies...
:: removing lightdm-gtk-greeter breaks dependency 'lightdm-gtk-greeter' required by lightdm-gtk-greeter-settings
 -> exit status 1
Just removing the gtk-greeter will not magically lead to the other one being used.
You can keep it - no need to remove it.
You need to adapt the configuration file /etc/lightdm/lightdm.conf
swap one entry for the other - in this example here, the slick greeter is active (no # at the start of the line)
grep -E 'greeter-session=' /etc/lightdm/lightdm.conf
#greeter-session=lightdm-webkit2-greeter
greeter-session=lightdm-slick-greeter
You’ll have to put that in yourself.
it is in /etc/lightdm/lightdm.conf
around line nr. 103
just add another line and comment what was there, that will make it easy to switch back should you want to
ps:
The lines of the log you posted are truncated (cut short)
… important things might be missing due to that
what looks relevant is this line here:
something informative has likely been cut off
another ps:
did you find anything when looking through these?
Okay, i dont really understand, but now everything was fine.
I dont know what happened, but it works now altough i just changed to ssdm back to lightdm and thats all.
Anyway, thank you all!
