libva error: /usr/lib/dri/i965_drv_video.so init failed
When attempting to run SteamVR from ALVR, I get this error and then ALVR seg faults.
When I run the command vainfo it displays the following:
Trying display: wayland
Trying display: x11
libva error: vaGetDriverNames() failed with unknown libva error
vaInitialize failed with error code -1 (unknown libva error),exit
My graphics card is an RTX 4090. My NVidia driver is 535.104.05-1
Upon searching, I came across this issue https://github.com/intel/libva/issues/375 which said to contact the distribution team.
You’re in an unsupported, partial upgrade state. The current driver is 550.67-1.
Please post your system info as outlined here:
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY …
