Hello, I have an Lenovo Yoga 7 and I downloaded Manjaro Gnome- Im new to Arch but even with all the other distros I still was not able to get my sound to work. Can someone help. I can get you the computer info but not sure how to do it.
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3c310667-033d-401a-a250-04294a3e7635 rw quiet splash apparmor=1
Console: pty pts/0 wm: gnome-shell DM: GDM 41.0 Distro: Manjaro Linux
base: Arch Linux
Type: Convertible System: LENOVO product: 82BJ v: Yoga 7 15ITL5
serial: <filter> Chassis: type: 31 v: Yoga 7 15ITL5 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: F5CN38WW date: 10/26/2020
ID-1: BAT0 charge: 45.3 Wh (66.0%) condition: 68.6/71.0 Wh (96.6%)
volts: 16.7 min: 15.4 model: Celxpert L19C4PDC type: Li-poly
serial: <filter> status: Charging cycles: 72
RAM: total: 11.5 GiB used: 1.92 GiB (16.7%)
Array-1: capacity: 16 GiB note: est. slots: 2 EC: None
Device-1: Controller0-ChannelA size: 8 GiB speed: 3200 MT/s type: DDR4
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: N/A
Device-2: Controller1-ChannelA size: 4 GiB speed: 3200 MT/s type: DDR4
part-no: M471A5244CB0-CWE serial: N/A
Info: Quad Core model: 11th Gen Intel Core i7-1165G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1
microcode: 88 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB bogomips: 44864
Speed: 1299 MHz min/max: 400/4700 MHz base/boost: 2800/4700 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1299 2: 1303 3: 1302 4: 1382
5: 1348 6: 1348 7: 1344 8: 1402
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-8:2
chip-ID: 5986:212a class-ID: 0e02
Display: server: X.org 1.21.1.1 compositor: gnome-shell driver: loaded: i915
note: n/a (using device driver) resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 14.51 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
lanes: 4 type: SSD serial: <filter> rev: AL2QFXV7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 14.51 GiB (3.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 3c310667-033d-401a-a250-04294a3e7635
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 5E1F-1E23
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-8:2 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212a
class-ID: 0e02
Device-2: 3-9:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00be
class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C mobo: N/A
Processes: 271 Uptime: 54m wakeups: 2548 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1333
pacman: 1325 lib: 344 flatpak: 8 Shell: Zsh (sudo) v: 5.8 default: Bash
v: 5.1.8 running-in: gnome-terminal inxi: 3.3.09
Hanzel
26 November 2021 17:59
2
You should consider updating system BIOS
Yoga 7 15itl5 - Lenovo Support
Kernel v5.13 has been marked End Of Life in update announcements for some time and will likely be dropped completely from Manjaro soon
Kernel v5.14.21-2 has been marked End Of Life in Testing branch and will be marked similar when it lands in Stable branch
I suggest you install kernel v5.15 using Manjaro Settings Manager GUI
( manjaro-settings-manager -m msm_kernel
OR use these terminal commands to install new kernel and remove old one
sudo mhwd-kernel --install linux515
sudo mhwd-kernel --remove linux513
System data is showing 2 sound servers running
PipeWire cannot support audio unless PulseAudio is removed and replaced, but it can impede PulseAudio functions
To continue using PulseAudio, use this command to stop, disable and mask PipeWire service and socket
systemctl --user disable --now pipewire.socket pipewire.service && systemctl --user mask pipewire.socket
OR
Install metapackage manjaro-pipewire
to remove and replace PulseAudio
pamac install manjaro-pipewire
Swapping the Kernel worked but that is odd that swapping the kernel on other distros did not. But YAY its working with Kernel change. Do i still have two sounds going?
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
base: Arch Linux
ID-1: BAT0 charge: 65.9 Wh (96.1%) condition: 68.6/71.0 Wh (96.6%)
volts: 17.5 min: 15.4 model: Celxpert L19C4PDC type: Li-poly
serial: <filter> status: Charging cycles: 73
RAM: total: 11.49 GiB used: 1.31 GiB (11.4%)
Speed: 1301 MHz min/max: 400/4700 MHz base/boost: 2800/4700 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1900 2: 1327 3: 1308 4: 1301
5: 1620 6: 2242 7: 1785 8: 1319
class-ID: 0300
direct render: Yes
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Local Storage: total: 476.94 GiB used: 14.64 GiB (3.1%)
lanes: 4 type: SSD serial: <filter> rev: AL2QFXV7 temp: 36.9 C scheme: GPT
used: 14.64 GiB (3.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
class-ID: 0e02
class-ID: e001
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 268 Uptime: 1m wakeups: 127 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1333 pacman: 1325 lib: 344
flatpak: 8 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
system
Closed
29 November 2021 09:16
6
