Lenovo ThinkPad T14s Low Microphone Volume
Hello,
The volume of my built-in microphone on my ThinkPad T14s (Gen 1, AMD) is really low. I have tried boosting the audio using pulse audio but that did not work. I think it is a driver related issue since it works perfectly fine using Windows 10.
I am using Manjaro 21.1.2 GNOME, with kernel Linux 5.13.13-1-MANJARO.
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=6e12e4bb-bd01-4f80-9111-0639404f8c65 rw quiet splash apparmor=1
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: LENOVO product: 20UHCTO1WW v: ThinkPad T14s Gen 1
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20UHCTO1WW v: SDK0R32862 WIN serial: <filter>
  UEFI: LENOVO v: R1CET66W(1.35 ) date: 07/30/2021
  ID-1: BAT0 charge: 51.4 Wh (88.6%) condition: 58.0/57.0 Wh (101.8%)
  volts: 12.7 min: 11.5 model: SMP 5B10W139 type: Li-poly serial: <filter>
  status: Unknown cycles: 5
  RAM: total: 30.59 GiB used: 5.95 GiB (19.4%)
  Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 4 MiB bogomips: 54316
  Speed: 3042 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
  1: 3042 2: 3240 3: 1409 4: 1399 5: 1442 6: 1399 7: 1513 8: 1717 9: 2825
  10: 2621 11: 1991 12: 4055 13: 1562 14: 1836 15: 1427 16: 1444
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 06:00.0
  chip-ID: 1002:1636 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-2:2
  chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
  Device-3: Jieli USB PHY 2.0 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 6-2.3:8 chip-ID: 1224:2a25 class-ID: 0102
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.13-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 06:00.1
  chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
  driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 06:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Jieli USB PHY 2.0 type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: yes
  vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 3400
  bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci
  port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
  bus-ID: 6-4:4 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 23.85 GiB (5.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo model: UMIS RPIRJ512VME2OWD
  lanes: 4 type: SSD serial: <filter> rev: 1.8Q1908 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 360.44 GiB size: 353.72 GiB (98.13%)
  used: 23.82 GiB (6.7%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  label: N/A uuid: 6e12e4bb-bd01-4f80-9111-0639404f8c65
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 29.3 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: SYSTEM uuid: 3AB6-9A89
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 116.23 GiB fs: ntfs label: Windows
  uuid: 009CBC309CBC21D8
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 2-2:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
  interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6cb
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 6-1:2 info: Realtek BillBoard Device type: Billboard driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 0bda:2169 class-ID: 1100
  serial: <filter>
  Hub-7: 6-2:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 6-2.1:6 info: Logitech G203 LIGHTSYNC Gaming Mouse type: Mouse,HID
  power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
  Device-2: 6-2.2:7 info: Logitech Keyboard K120 type: Keyboard,HID
  power: 90mA chip-ID: 046d:c31c class-ID: 0300
  Device-3: 6-2.3:8 info: Jieli USB PHY 2.0 type: Video,Audio
  power: 500mA chip-ID: 1224:2a25 class-ID: 0102
  Device-4: 6-3:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-5: 6-4:4 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
  interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:4852
  Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): fan-1: 2800
  Processes: 381 Uptime: 1h 15m wakeups: 1 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1245 pacman: 1236 lib: 334
  flatpak: 0 snap: 9 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
What should I do to make this better?
Thank you in advance!
I have the exact same notebook and I can confirm the low mic volume. Nevertheless, I had so far no complaints about it from my meeting partners. My mic volume setting is 100%.
I had complaints from my meeting partners, Zoom even filters out the microphone sound as background noise which makes it look as if I am muted.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
That doesn’t mean anything: Vendors just configure the Microsoft driver settings optimally for their hardware whereas you’re probably stuck with the defaults for the hardware under Linux.
  1. You have both PipeWire and PulseAudio running so let’s start with disabling PipeWire to keep things simple:
    systemctl --user disable --now pipewire.socket && systemctl --user disable --now pipewire.service && systemctl --user mask pipewire.socket
  2. Execute:
    alsamixer
  3. Press F4 to go to the capture settings
  4. Press F6 to select the default:0 and you should see something like this:
  5. Use the ←→ on your keyboard to select the capture modes you have one by one.
  6. Use ↑↓ on your keyboard to crank everything up to 50% if it’s lower than that and 90% if it’s already above 50%.
  7. Go back to 5 and take the next capture mode until done.
  8. Press Esc to leave alsamixer
  9. Whisper during the first zoom meeting to ensure you don’t blast everyone’s ears out!
  10. Use your normal microphone settings in Gnome / Zoom Microphone settings to bring the microphone down to an acceptable level for your meeting partners.
:crossed_fingers:
Thank you for the instructions, I disabled PipeWire with the given command.
I had the following windows in alsamixer:
These are all my displayed devices:
default 0:
default 1:
Performing the Mic boost does not really change anything in my experience. The capture level was already on 100%. The USB device is a crappy webcam Mic which I do not use for anything.
PulseAudio settings:
  1. Please execute:
    alsa-info.sh
  2. Answer Y
  3. post the link you’ve been given to the data you collected or post the full contents of the /tmp/asla-info.txt.RandomNumber file if you feel hesitant to upload your data there.
  4. I will then call in our resident Audio Über-Guru. :grin:
:crossed_fingers:
Thanks for the help, I really appreciate it!
Here is the link:
http://alsa-project.org/db/?f=3916817a21ee24a08945f34caaaf41ff6b3b4cb3
Have I told you to try an LTS kernal already???
If not, please read this:
While I analyze your alsa output.
:bowing_man:
I did not try that yet, but that is something for the weekend since this is my main device to do my work
Okay, I tried out Kernel 5.10.61.1 LTS and that did not solve the issue sadly…
@nikgnomic
Low mic. Boost doesn’t help. I’m out of my league.
:sob:
Did you try this already?
https://wiki.archlinux.org/title/Lenovo_ThinkPad_T14s_(AMD)_Gen_1#Microphone
Microphone
The microphone may not be operational. A possible fix is to blacklist the snd_pci_acp3x module (to allow newer kernels to use snd_rn_pci_acp3x?)
Not that it’s not working, but maybe it makes a difference… :man_shrugging: (I have a similar laptop; never tried the internal mic though)
Yes I tried that again, does not seem to make any difference
It seems that one of the last alsa updates made it a little better, but people still complain that I sound very quiet in calls
