Lenovo Legion 7 - NVidia drivers not working properly with external display
Hi,
I’m new to this forum and Manjaro in general. I migrated a few days ago.
I’ve got a problem with a proper configuration of my graphics card.
Also, I use an external monitor (Eizo EV2360). Both of my displays are of 16:10 ratio.
I currently use open source drivers and I see no major problems using my laptop, but the performance sometimes could be better. Also, I’m unable to launch any game using lutris (I get an error message at startup informing that it is impossible to create a window).
My graphics card can be configured in BIOS in two modes: “Dynamic” and “Discrete”. Neither of these however work well with NVidia drivers.
In “Dynamic” mode only the built-in display works. My external screen is detected, but stays off and I can’t switch it on. An attempt to do so causes the screen to blink and return to the previous state immediately.
In “Discrete” mode both of the screens are on, but I can’t select resolution for my built-in display. There’s only one option: 2560x1600, which makes all the items way too small.
I’d like to use NVidia drivers to fully benefit from the power of my graphics card and continue using both of my displays.
As I said, I’m new to this forum. Can you tell me, what pieces of my system configuration I need to provide here?
Regards,
Alojzy
PS: I tried posting a picture of my “Hardware configuration” menu, but looks like I’m not allowed to post pictures here.
Welcome to the forum! :wave:
I suggest using the proprietary NVIDIA drivers, then. See Configure NVIDIA (non-free) settings and load them on Startup - Manjaro
Hi @Yochanan
Thanks for the hints. As it’s getting quite late here, I’ll give it a go tomorrow.
For now I attach the result of running inxi on my machine.
  Kernel: 5.19.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=9efecacd-fae6-4ed8-a120-f610bbc9eb3b rw quiet splash apparmor=1
  Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: LENOVO product: 82N6 v: Legion 7 16ACHg6
    serial: <superuser required> Chassis: type: 10 v: Legion 7 16ACHg6
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> UEFI: LENOVO v: GKCN49WW date: 11/08/2021
  ID-1: BAT0 charge: 77.3 Wh (100.0%) condition: 77.3/80.0 Wh (96.6%)
    volts: 17.3 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
    serial: <filter> status: full cycles: 99
  RAM: total: 27.27 GiB used: 9.21 GiB (33.8%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3 gen: 4 level: v3 built: 2021-22 process: TSMC n7 (7nm)
    family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1479 high: 3200 min/max: 1200/4462 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1276 2: 1397
    3: 1200 4: 1200 5: 1200 6: 3200 7: 1200 8: 1197 9: 1200 10: 1200 11: 1397
    12: 3200 13: 1198 14: 1200 15: 1200 16: 1200 bogomips: 102267
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Lenovo
    driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-08)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: HDMI-A-1 empty: DP-1,DP-2,eDP-1 bus-ID: 01:00.0
    chip-ID: 10de:24dd class-ID: 0300
  Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
    arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-2 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
    class-ID: 0300
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-3:3 chip-ID: 04f2:b67d class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    gpu: amdgpu,nouveau display-ID: 0
  Monitor-1: HDMI-A-1 model: EIZO NANAO EV2360 serial: <filter> built: 2021
    res: 1920x1200 dpi: 100 gamma: 1.2 size: 489x298mm (19.25x11.73")
    diag: 573mm (22.5") ratio: 15:9 modes: max: 1920x1200 min: 720x400
  Monitor-2: eDP-2 model-id: CSO 0x1609 built: 2021 res: 2560x1600 dpi: 188
    gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
    modes: max: 2560x1600 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.7-1-MANJARO) v: 4.6
    Mesa 22.1.7 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: bus-ID: 1-2.1:4 gen: 3 chip-ID: 1038:12aa class-ID: 0300 speed: 8 GT/s
    serial: <filter> lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: SteelSeries ApS Arctis 5 type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.57 running: yes
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
    driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 212.33 GiB (22.3%)
    model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
    rev: 3L1QEXF7 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 195.58 GiB size: 191.45 GiB (97.89%) used: 47.31 GiB
    (24.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: Manjaro
    uuid: 9efecacd-fae6-4ed8-a120-f610bbc9eb3b
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 35.3 MiB
    (13.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: SYSTEM_DRV
    uuid: 9466-7FDD
  ID-3: /home/beko raw-size: N/A size: 191.45 GiB used: 47.31 GiB (24.7%)
    fs: ecryptfs source: ERR-102
  ID-4: /nix raw-size: 130.48 GiB size: 127.37 GiB (97.62%) used: 48.26 GiB
    (37.9%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:8 label: nix
    uuid: ece59e86-8f89-4f2b-9778-ab99fce86c50
  ID-5: /vm raw-size: 166.02 GiB size: 162.35 GiB (97.79%) used: 69.41 GiB
    (42.8%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:6 label: VMs
    uuid: 6e0d0eec-a232-40df-a7af-255907d7026e
  ID-1: /dev/nvme0n1p11 maj-min: 259:9 size: 46.77 GiB fs: ext4 label: Backup
    uuid: dec8cfbb-9478-4a15-b49d-27d99b353e6b
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 122.54 GiB fs: ntfs
    label: Windows-SSD uuid: 146C671E6C66F9BE
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 244.14 GiB fs: ntfs
    label: Programy uuid: E078431F7842F436
  ID-5: /dev/nvme0n1p8 maj-min: 259:7 size: 1000 MiB fs: ntfs
    label: WINRE_DRV uuid: C2C86784C8677597
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
  Device-1: 1-2.1:4 info: SteelSeries ApS Arctis 5 type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    speed: 12 Mb/s power: 250mA chip-ID: 1038:12aa class-ID: 0300
    serial: <filter>
  Hub-3: 1-2.3:6 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-2.3.1:7 info: ROCCAT Kone XTD Mouse type: Mouse,Keyboard
    driver: koneplus,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 200mA
    chip-ID: 1e7d:2e22 class-ID: 0300
  Device-2: 1-2.3.2:8 info: ROCCAT Suora FX Keyboard type: Keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 1e7d:3246 class-ID: 0300 serial: <filter>
  Device-3: 1-3:3 info: Chicony Integrated Camera type: Video
  Device-4: 1-4:5 info: Integrated Express ITE Device(8258) type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:c968 class-ID: 0301
  Hub-4: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-5: 2-2:2 info: Genesys Logic GL3523 Hub ports: 3 rev: 3.2
    speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
  Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 44.6 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Processes: 421 Uptime: 2h 49m wakeups: 1 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1407 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr
  pkgs: 72 libs: 13 pm: pacman pkgs: 1335 libs: 351
  tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.21
you dont have installed the nvidia drivers, you are running on open source drivers, so install the proprietary ones via system settings/manjaro settings/hardware configuration and click on ‘auto install proprietary drivers’
or install them via command:
sudo mhwd -a pci nonfree 0300
reboot
you are also using wayland, so if you have still issues after installing the nvidia drivers, switch to xorg/x11
This guy describes installing arch: Lenovo Legion 7 (2021) and Arch Linux
No issues with the graphics, it seems.
Hi,
Thanks for the response.
Regarding nouveau - as I said, I tried using NVidia driver, but my external monitor didn’t work, so I used nouveau instead.
I’ve just switched to xorg, but my external display doesn’t work even with nouveau.
I re-run inxi with NVidia installed (and my external screen being detected, but failing to start):
  RAM: total: 27.27 GiB used: 3.27 GiB (12.0%)
    required.
  Speed (MHz): avg: 1251 high: 1491 min/max: 1200/4462 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1361 2: 1267
    3: 1197 4: 1200 5: 1200 6: 1200 7: 1200 8: 1198 9: 1351 10: 1200 11: 1366
    12: 1200 13: 1200 14: 1200 15: 1200 16: 1491 bogomips: 102254
    driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
    (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24dd class-ID: 0300
    active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1638
    class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa gpu: amdgpu
    display-ID: :1 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
  Monitor-2: eDP pos: primary res: 1920x1200 hz: 165 dpi: 141
    size: 345x215mm (13.58x8.46") diag: 407mm (16") modes: N/A
    pcie: bus-ID: 1-2.1:4 gen: 3 chip-ID: 1038:12aa speed: 8 GT/s class-ID: 0300
    lanes: 8 serial: <filter> link-max: gen: 4 speed: 16 GT/s lanes: 16
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 213.52 GiB (22.4%)
    rev: 3L1QEXF7 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 195.58 GiB size: 191.45 GiB (97.89%) used: 47.91 GiB
    (25.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: Manjaro
    uuid: 9466-7FDD
  ID-3: /home/beko raw-size: N/A size: 191.45 GiB used: 47.91 GiB (25.0%)
    serial: <filter>
  Device-1: 3-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
    class-ID: e001
  System Temperatures: cpu: 38.6 C mobo: N/A gpu: amdgpu temp: 33.0 C
  Processes: 387 Uptime: 3m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1414
  pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 72 libs: 13
  pm: pacman pkgs: 1342 libs: 353 tools: gnome-software,pamac pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.21
Re the article about Arch: that’s what I’ve done.But I’ll double check, thanks for posting.
I’ve just found this post:
monitor-detected-but-black-screen/32391
(Sorry for formatting, but the forum says I can’t add links in my posts)
It’s a bit old, but it says:
The NVIDIA driver currently cannot be used as an output sink when the output source driver is xf86-video-amdgpu.
which makes sense in my case, as I use amdgpu. Do I need to follow the suggestion and use optimus-manager?
EDIT:
I’ve made some progress:
  • Switched my Graphics card in BIOS to “Discrete” mode.
  • Installed NVidia drivers.
  • After reboot both the built-in and the external displays work.
  • However, the built-in screen operates only in one resolution: 2560x1600, which makes everything too small.
xrandr:
HDMI-0 connected primary 1920x1200+2560+0 (normal left inverted right x axis y axis) 489mm x 298mm
   1920x1200     59.95*+
   1920x1080     59.94    50.00
   1680x1050     59.95
   1600x1200     60.00
   1600x900      60.00
   1280x1024     60.02
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       59.94
   640x480       59.94
DP-4 connected 2560x1600+0+0 (normal left inverted right x axis y axis) 345mm x 215mm
   2560x1600     60.01*+ 165.02
I tried changing the resolution in nvidia-settings and it works, but everything comes back to 2560x1600 after a reboot, despite the fact I saved xorg.conf.
Any idea why does my system show only one resolution for the built-in display?
Can you post the output of:
mhwd -l && mhwd -li
In the post I linked above the bios settings are described as “GPU MUX Switch (Dedicated + Optimus Graphics)”.
This offered choice will need a decision before you install/setup the driver.
  • set to ‘dedicated’
  • run mhwd -l && mhwd -li and
  • install the offered nvidia (only) driver
  • or set to optimus/‘dynamic’
  • install the offered video-hybrid-amd-nvidia-prime optimus driver
In both cases video-nvidia (nouveau) needs to be removed but that seems already have been done. I’m on an intel/nvidia optimus, in a ‘optimus-setup’ my mhwd -l && mhwd -li looks like this:
> 0000:01:00.0 (0302:10de:1392) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
    video-nvidia-390xx            2021.11.26               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
> Installed PCI configs:
you should be able to change the scale from system settings, to 200% and see if it looks better
Thanks for the replay.
Yes, I tried that.
In my case I installed:
  • video-hybrid-amd-nvidia-prime in “dynamic” graphics mode
  • video-nvidia in “discrete” mode
In the first case I can use only one of my displays (either the one built-in or the external one; seems to be random, which one exactly). In the second case I can only use one resolution (2560x1600) on my built-in screen, which is too small to see things.
Here’s output for mhwd -l && mhwd -li executed in “dynamic” mode:
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:24dd) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-prime            2021.11.04               false            PCI
video-hybrid-amd-nvidia-470xx-prime            2021.11.04               false            PCI
> 0000:05:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
If you can’t see anything concerning, no worries. I think I’ll wait for the new major release of the most popular distros to see if they fix the problem with my card by any chance.
Hi, thanks for the hint.
I’ve tried that, but 200% looks even worse :).
I remember that Ubuntu allowed me to use 125% (fractional scaling), but then all the icons on the desktop disappeared.
Hi all,
FYI: I moved my problem to NVidia Dev forum and managed to find answers there.
In case you were interested: Problems with hybrid NVidia RTX 3070 in Linux - #19 by alojzy.leszcz - Linux - NVIDIA Developer Forums
Many thanks for all the hints. These helped me to move in the right direction.
