Learning how to set up ax210 wifi in manjaro
Hi everyone, I am new to linux and need help setting up the new ax210 intel pcie on my manajro desktop.
This is the following I need to do. let me know if I am missing any steps
  1. check my manjaro kernel.
  2. check to see if the network card was detected.
  3. check if ilwifi was installed.
Anything tip would help. Thank you.
So … what have you done and what have you found?
1-3 are easily answered by inxi, which is generally a good first stop for support.
inxi -Fazy
Thank you. From the command inxi -Fazy.
If there is an intel pcie card wifi6 that is compatible I can return and buy it.
Please advise thank you.
 Kernel: 5.4.242-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
   root=UUID=61f6f811-507c-4d95-af9c-af30e293ee02 rw quiet apparmor=1
 Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
 Type: Desktop Mobo: ASRock model: B450M Steel Legend
   serial: <superuser required> UEFI: American Megatrends v: P2.50
   date: 07/18/2019
 Info: model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ gen: 2
   level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
   model-id: 8 stepping: 2 microcode: 0x800820D
 Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
   L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
   desc: 2x8 MiB
 Speed (MHz): avg: 1593 high: 3673 min/max: 1550/3200 boost: enabled
   scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1374 2: 1286
   3: 1285 4: 1291 5: 3673 6: 1334 7: 1292 8: 1400 9: 2375 10: 1334 11: 1271
   12: 1298 13: 2383 14: 1269 15: 1305 16: 1331 bogomips: 102229
 Type: retbleed status: Vulnerable
   prctl and seccomp
 Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
   disabled, RSB filling, PBRSB-eIBRS: Not affected
 Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
   driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
   status: current (as of 2023-05) arch: Pascal code: GP10x process: TSMC 16nm
   built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 07:00.0
   chip-ID: 10de:1c82 class-ID: 0300
 Device-2: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
   rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 046d:081b
   class-ID: 0102 serial: <filter>
 Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
   loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
 Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
   s-diag: 692mm (27.24")
 Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 163
   size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
 API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX 1050
   Ti/PCIe/SSE2 direct-render: Yes
 Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
   bus-ID: 07:00.1 chip-ID: 10de:0fb9 class-ID: 0403
 Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
   v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
   chip-ID: 1022:1457 class-ID: 0403
 Device-3: Logitech Webcam C310 driver: snd-usb-audio,uvcvideo type: USB
 API: ALSA v: k5.4.242-1-MANJARO status: kernel-api with: aoss
 Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
   status: active tools: pw-cli
 Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
   type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
 Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: N/A modules: iwlwifi
   pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
   class-ID: 0280
   vendor: ASRock driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
   speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
   class-ID: 0200
 IF: enp5s0 state: down mac: <filter>
 Local Storage: total: 465.76 GiB used: 120.56 GiB (25.9%)
   model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
   fw-rev: 1B2QEXM7 scheme: GPT
 ID-1: / raw-size: 396.67 GiB size: 389.37 GiB (98.16%)
   used: 120.56 GiB (31.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
   used: 464 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
 System Temperatures: cpu: 37.1 C mobo: N/A
 Processes: 305 Uptime: 7m wakeups: 0 Memory: available: 31.29 GiB
 used: 1.76 GiB (5.6%) Init: systemd v: 252 default: graphical tool: systemctl
 Compilers: gcc: 12.2.1 alt: 10/11 clang: 15.0.7 Packages: 1641 pm: pacman
 pkgs: 1628 libs: 472 tools: pamac pm: flatpak pkgs: 5 pm: snap pkgs: 8
 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27```
It looks like the card is detected.
But you are on a very old kernel.
Is this a recent install?
I might suggest you use a current image, as I dont think any recent ones would ship a kernel that old.
In whatever case I also suggest you use a newer kernel. (5.15, 6.1, etc)
And also do your BIOS update.
If you have search the forum you have had found many topics about that chip. In one of them is noted that kernel support was introduced in 5.10.
Thank so much, I will follow your instructions. Thank you so much. I have searched the forum but though 5.4 kernel was a newer version than 5.15. Now I know the number schemes are different.
Thank you so much. I will follow your instructions. Unlike MS Manjaro has been running smoothly for the last five years, that is why my kernel is that old.
Thank you so much.
Updated to 6.1 kernel, ax210 worked like a champ, my old wifi was getting 15 mbps, ax210 getting 680mbps download speed.
