Wifi not working on Framework Laptop
What happened
Wifi does not work. The option to turn wifi on/off has disappeared from my desktop network manager (screenshot below). I’m completely stumped, if anyone could help, I’d very much appreciate it.
The issue first appeared after a suspend-to-disk. No very recent updates, except for Inxi and spectre-meltdown-checker.
What I’ve tried to do
  • sudo systemctl restart NetworkManager
  • sudo systemctl restart network-online.target
  • sudo modprobe iwlwifi
  • Reboot
  • Use Timeshift to roll back to an older version of my filesystem that I know worked.
  • Boot an older kernel (5.15)
  • This
Details
rfkill list all:
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
sudo dmesg | grep iwlwifi:
[    7.298499] iwlwifi 0000:aa:00.0: enabling device (0000 -> 0002)
[    7.337733] iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
[    7.337756] iwlwifi 0000:aa:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.34
[    7.337960] iwlwifi 0000:aa:00.0: loaded firmware version 67.8f59b80b.0 ty-a0-gf-a0-67.ucode op_mode iwlmvm
[    7.566416] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[    7.573283] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[    7.573285] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[    7.573287] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[    8.593537] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x75a9, CPU2 Status: 0xb03
[    8.593558] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f8e0
[    8.593578] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[    8.593581] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[    8.593688] iwlwifi 0000:aa:00.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[    8.593689] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[    8.593690] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[    8.593691] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[    8.593691] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[    8.593692] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[    8.593692] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[    8.593693] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[    8.593693] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[    8.593694] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[    8.593694] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[    8.593695] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[    8.593695] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[    8.593696] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[    8.593696] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[    8.593697] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[    8.593697] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[    8.593698] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[    8.593698] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[    8.593699] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[    8.593699] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[    8.593700] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[    8.593700] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[    8.593701] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[    8.593701] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[    8.593702] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[    8.593702] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[    8.593703] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[    8.593703] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[    8.593704] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[    8.593704] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[    8.593705] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[    8.593705] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[    8.593706] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[    8.593706] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[    8.593781] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[    8.593781] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[    8.593782] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[    8.593783] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[    8.593783] iwlwifi 0000:aa:00.0: 0x8045E20E | umac branchlink2
[    8.593784] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[    8.593785] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[    8.593785] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[    8.593786] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[    8.593786] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[    8.593787] iwlwifi 0000:aa:00.0: 0x00000043 | umac major
[    8.593787] iwlwifi 0000:aa:00.0: 0x8F59B80B | umac minor
[    8.593788] iwlwifi 0000:aa:00.0: 0x00011EF7 | frame pointer
[    8.593788] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[    8.593789] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[    8.593789] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[    8.593839] iwlwifi 0000:aa:00.0: IML/ROM dump:
[    8.593839] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[    8.593849] iwlwifi 0000:aa:00.0: 0x000075A9 | IML/ROM data1
[    8.593860] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[    8.593867] iwlwifi 0000:aa:00.0: Fseq Registers:
[    8.593870] iwlwifi 0000:aa:00.0: 0x60000000 | FSEQ_ERROR_CODE
[    8.593873] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[    8.593876] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[    8.593879] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[    8.593883] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[    8.593886] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[    8.593889] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[    8.593892] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[    8.593896] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[    8.593901] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[    8.593906] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[    8.593912] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[    8.593914] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[    8.593915] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   10.063245] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[   10.076571] iwlwifi 0000:aa:00.0: retry init count 0
[   10.081443] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   10.087288] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[   10.087290] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[   10.087290] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[   11.100272] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x7670, CPU2 Status: 0xb03
[   11.100291] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f8e0
[   11.100302] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[   11.100304] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   11.100417] iwlwifi 0000:aa:00.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[   11.100418] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[   11.100419] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[   11.100420] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[   11.100420] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[   11.100421] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[   11.100421] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[   11.100422] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[   11.100422] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[   11.100423] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[   11.100423] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[   11.100424] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[   11.100424] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[   11.100425] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[   11.100425] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[   11.100426] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[   11.100426] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[   11.100427] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[   11.100427] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[   11.100428] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[   11.100428] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[   11.100429] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[   11.100429] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[   11.100430] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[   11.100430] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[   11.100431] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[   11.100431] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[   11.100432] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[   11.100432] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[   11.100433] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[   11.100433] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[   11.100434] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[   11.100434] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[   11.100435] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[   11.100435] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[   11.100514] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[   11.100514] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[   11.100515] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[   11.100516] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[   11.100516] iwlwifi 0000:aa:00.0: 0x8045E20E | umac branchlink2
[   11.100517] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[   11.100517] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[   11.100518] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[   11.100518] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[   11.100519] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[   11.100520] iwlwifi 0000:aa:00.0: 0x00000043 | umac major
[   11.100520] iwlwifi 0000:aa:00.0: 0x8F59B80B | umac minor
[   11.100521] iwlwifi 0000:aa:00.0: 0x0001202E | frame pointer
[   11.100521] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[   11.100522] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[   11.100522] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[   11.100575] iwlwifi 0000:aa:00.0: IML/ROM dump:
[   11.100576] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[   11.100586] iwlwifi 0000:aa:00.0: 0x00007670 | IML/ROM data1
[   11.100597] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[   11.100603] iwlwifi 0000:aa:00.0: Fseq Registers:
[   11.100606] iwlwifi 0000:aa:00.0: 0x60000000 | FSEQ_ERROR_CODE
[   11.100610] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[   11.100613] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[   11.100616] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[   11.100619] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[   11.100623] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[   11.100626] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[   11.100629] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[   11.100632] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[   11.100637] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[   11.100643] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   11.100648] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   11.100651] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[   11.100652] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   12.578384] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[   12.591778] iwlwifi 0000:aa:00.0: retry init count 1
[   12.596792] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[   12.604014] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[   12.604015] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[   12.604016] iwlwifi 0000:aa:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[   13.610200] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x759a, CPU2 Status: 0xb03
[   13.610222] iwlwifi 0000:aa:00.0: UMAC PC: 0x8047f8e0
[   13.610233] iwlwifi 0000:aa:00.0: LMAC PC: 0x0
[   13.610235] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   13.610352] iwlwifi 0000:aa:00.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[   13.610353] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[   13.610354] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[   13.610355] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[   13.610356] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[   13.610356] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[   13.610357] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[   13.610357] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[   13.610358] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[   13.610358] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[   13.610359] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[   13.610359] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[   13.610360] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[   13.610360] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[   13.610361] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[   13.610361] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[   13.610362] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[   13.610362] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[   13.610363] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[   13.610363] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[   13.610364] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[   13.610364] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[   13.610365] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[   13.610365] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[   13.610366] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[   13.610366] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[   13.610367] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[   13.610367] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[   13.610368] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[   13.610368] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[   13.610369] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[   13.610369] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[   13.610370] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[   13.610370] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[   13.610371] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[   13.610445] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[   13.610446] iwlwifi 0000:aa:00.0: Transport status: 0x00000042, valid: 7
[   13.610447] iwlwifi 0000:aa:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[   13.610447] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[   13.610448] iwlwifi 0000:aa:00.0: 0x8045E20E | umac branchlink2
[   13.610449] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[   13.610449] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[   13.610450] iwlwifi 0000:aa:00.0: 0x0000000C | umac data1
[   13.610450] iwlwifi 0000:aa:00.0: 0x00040000 | umac data2
[   13.610451] iwlwifi 0000:aa:00.0: 0xDEADBEEF | umac data3
[   13.610451] iwlwifi 0000:aa:00.0: 0x00000043 | umac major
[   13.610452] iwlwifi 0000:aa:00.0: 0x8F59B80B | umac minor
[   13.610452] iwlwifi 0000:aa:00.0: 0x00011E41 | frame pointer
[   13.610453] iwlwifi 0000:aa:00.0: 0xC0887F34 | stack pointer
[   13.610454] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[   13.610454] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[   13.610503] iwlwifi 0000:aa:00.0: IML/ROM dump:
[   13.610504] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[   13.610514] iwlwifi 0000:aa:00.0: 0x0000759A | IML/ROM data1
[   13.610525] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[   13.610531] iwlwifi 0000:aa:00.0: Fseq Registers:
[   13.610534] iwlwifi 0000:aa:00.0: 0x60000100 | FSEQ_ERROR_CODE
[   13.610538] iwlwifi 0000:aa:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[   13.610541] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[   13.610544] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[   13.610547] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[   13.610551] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[   13.610554] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[   13.610557] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[   13.610560] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[   13.610566] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[   13.610571] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   13.610576] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   13.610579] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[   13.610580] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[   15.089583] iwlwifi 0000:aa:00.0: Failed to run INIT ucode: -110
[   15.102947] iwlwifi 0000:aa:00.0: retry init count 2
inxi --admin --verbosity=7 --filter --width:
  Kernel: 5.16.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64
    root=UUID=3a9a4f36-4033-4948-b346-c3cb42fde75e rw rootflags=subvol=@ quiet
    cryptdevice=UUID=72ef17b1-25f1-4c2e-bd27-78aee9795757:luks-72ef17b1-25f1-4c2e-bd27-78aee9795757
    root=/dev/mapper/luks-72ef17b1-25f1-4c2e-bd27-78aee9795757 apparmor=1
    security=apparmor resume=UUID=c953467d-c553-47be-a8f3-bf4f0182de20
    udev.log_priority=3 mem_sleep_default=deep
  Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Framework product: Laptop v: AA
    serial: <superuser required>
  Mobo: Framework model: FRANBMCP0A v: AA serial: <superuser required>
    UEFI: INSYDE v: 03.06 date: 10/18/2021
  ID-1: BAT1 charge: 49.5 Wh (91.7%) condition: 54.0/55.0 Wh (98.2%)
    volts: 16.7 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
    status: Discharging
  RAM: total: 15.41 GiB used: 3.03 GiB (19.7%)
  RAM Report:
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x86
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 832 high: 1148 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 683 2: 621 3: 731 4: 849
    5: 1051 6: 538 7: 1148 8: 1042 bogomips: 38720
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Realtek Laptop Camera type: USB driver: uvcvideo bus-ID: 3-7:3
    chip-ID: 0bda:5634 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2256x1504 s-dpi: 144 s-size: 397x265mm (15.6x10.4")
    s-diag: 477mm (18.8")
  Monitor-1: eDP-1 model: BOE Display built: 2019 res: 2256x1504 hz: 60
    dpi: 201 gamma: 1.2 size: 285x190mm (11.2x7.5") diag: 343mm (13.5")
    ratio: 3:2 modes: 2256x1504
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.3.7
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0 chip-ID: 8086:2725
    class-ID: 0280
  IF-ID-1: enp0s20f0u6 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 3-10:5 chip-ID: 8087:0032 class-ID: e001
  Device-2: Google Nexus/Pixel Device (tether) type: USB driver: rndis_host
    v: kernel bus-ID: 3-6:7 chip-ID: 18d1:4ee3 class-ID: 0a00 serial: <filter>
  Device-1: luks-72ef17b1-25f1-4c2e-bd27-78aee9795757 maj-min: 254:0
    type: LUKS dm: dm-0 size: 48.83 GiB
  Components:
  p-1: nvme0n1p1 maj-min: 259:1 size: 48.83 GiB
  Device-2: luks-4bfa54d1-7d82-4234-b305-814874f551ff maj-min: 254:1
    type: LUKS dm: dm-1 size: 390.62 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 390.62 GiB
  Local Storage: total: 465.76 GiB used: 90.68 GiB (19.5%)
    model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
    rev: 111130WD temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
    used: 38.21 GiB (78.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-72ef17b1-25f1-4c2e-bd27-78aee9795757 label: root
    uuid: 3a9a4f36-4033-4948-b346-c3cb42fde75e
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 712 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: BOOT
    uuid: 1966-1ABC
  ID-3: /home raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
    used: 52.47 GiB (13.4%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-4bfa54d1-7d82-4234-b305-814874f551ff label: home
    uuid: 0389a3cf-cd43-470c-a782-7c36ad229440
  ID-4: /run/timeshift/backup raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-5: /var/cache raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-6: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: c953467d-c553-47be-a8f3-bf4f0182de20
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Framework HDMI Expansion Card type: Billboard,HID
    power: 100mA chip-ID: 32ac:0002 class-ID: 0300 serial: <filter>
  Device-2: 3-6:7 info: Google Nexus/Pixel Device (tether)
    type: Bluetooth,CDC-Data driver: rndis_host interfaces: 2 rev: 2.0
    speed: 480 Mb/s chip-ID: 18d1:4ee3 class-ID: 0a00 serial: <filter>
  Device-3: 3-7:3 info: Realtek Laptop Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 300mA chip-ID: 0bda:5634
  Device-4: 3-9:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
  Device-5: 3-10:5 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 39.8 C mobo: N/A
  Processes: 331 Uptime: 18m wakeups: 1 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1412 pacman: 1399 lib: 378
  flatpak: 0 snap: 13 Shell: Zsh v: 5.8.1 running-in: tmux: inxi: 3.3.13
can you connect the Internet without the wifi? such as real line
Thanks for the reply!
I can. USB tethering to my phone works just fine. Bluetooth network sharing does not work, but I’ve had issues with that before and thus cannot say if it’s related to this issue.
Bluetooth, more generally, works, I was able to connect and use Bluetooth headphones.
Have you consulted this https://wiki.archlinux.org/title/Framework_Laptop#Intel_Wi-Fi_6E_AX210_reset/low_throughput/_%22Microcode_SW_error%22
That fixed it, thank you so much!
