Laptop battery draining faster
I just installed manjaro today before this i was using pop os in which the battery draining issue was not a problem and it hasn’t occur in there but after using manjaro it has been draining very much eventhough i have already install tlp and its enabled also
please help with this
thank you in advance
It also needs to be configured - it will not magically work and do what you might want it to do - because it does not know what you want it to do
without you telling it …
You could perhaps use the tlp config from the previous system as a guide …
Plus, a little housekeeping…
Hi @0w1z and welcome to the Manjaro community.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
Cheers.
Did you start tlp.service ?
