Keyboard not working properly after update
Hi everyone,
I’ve recently experience an issue with my keyboard after updating to 5.11.18-1.
The lower half of the keyboard stopped working. Seldom they work, sometimes in combination with other keys.
It already happened once and somehow it got fixed. i try to roll back to previous kernel version and reinstall the drivers, but it didn’t work.
Any suggestions?
try to upgrade kernel 5.12
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. Try what Olli just said and if that doesn’t work: just the bottom part not working sounds like a hardware error. Have you tried another keyboard already?
:+1:
Thanks,
I tried several times to paste it, but the forum kept saying that I´m not allowed to insert links in my post due to sequential periods. In the meantime I needed to buy an external keyboard and it works fine.
Anyway, I put spaces around the periods and this is the result:
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=d685df21-3d1c-4846-a77a-88fc6ef652d4 rw quiet udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Laptop System: Dell product: Inspiron 5570 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0DRPKR v: X07 serial: <filter> UEFI: Dell v: 1.0.0
  date: 08/07/2017
  ID-1: BAT0 charge: 32.3 Wh (100.0%) condition: 32.3/42.0 Wh (76.8%)
  volts: 12.8 min: 11.4 model: SMP DELL Y3F7Y6B type: Li-ion serial: <filter>
  status: Full
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
  serial: <filter> charge: 10% (should be ignored) rechargeable: yes
  status: Discharging
  RAM: total: 7.54 GiB used: 4.08 GiB (54.1%)
  RAM Report: permissions: Unable to run dmidecode.Root privileges required.
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: EA cache: L2: 6 MiB bogomips: 28808
  Speed: 699 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 699 2: 700 3: 700
  4: 700 5: 700 6: 700 7: 701 8: 700
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:4 chip-ID: 0c45:6a06 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
  loaded: amdgpu,ati,intel unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.5
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: no
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Dell driver: ath10k_pci v: kernel modules: wl port: d000
  bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:6
  chip-ID: 0cf3:e009 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 8 state: up address: <filter>
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 21 class-ID: 0104
  Local Storage: total: 4.78 TiB used: 4.06 TiB (85.0%)
  SMART Message: Required tool smartctl not installed.Check --recommends
  ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 256GB
  size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 0P10 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data model: HD830
  size: 4.55 TiB block-size: physical: 4096 B logical: 4096 B type: N/A
  serial: <filter> rev: 9203 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C2
  dev-links: cdrom
  ID-1: / raw-size: 237.97 GiB size: 233.24 GiB (98.01%)
  used: 143.96 GiB (61.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: d685df21-3d1c-4846-a77a-88fc6ef652d4
  used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 8337-BA51
  ID-3: /run/media/nicolo/0a5b9c57-6300-488a-ad6f-b0128787733f
  raw-size: 4.55 TiB size: 4.51 TiB (99.19%) used: 3.92 TiB (86.9%) fs: ext4
  dev: /dev/sdb1 maj-min: 8:17 label: N/A
  uuid: 0a5b9c57-6300-488a-ad6f-b0128787733f
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-2:8 info: Logitech Optical Wheel Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 046d:c018 class-ID: 0301
  Device-3: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
  Device-4: 1-6:5 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Device-5: 1-7:6 info: Qualcomm Atheros type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-3:61 info: A-DATA HD830 type: Mass Storage driver: usb-storage
  interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA chip-ID: 125f:a84a
  class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 42.0 C mobo: 37.0 C sodimm: SODIMM C gpu: amdgpu
  temp: 43.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 259 Uptime: 1d 10h 42m wakeups: 163 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1544
  lib: 321 flatpak: 0 Shell: Bash v: 5.1.8 running-in: xfce4-terminal
  inxi: 3.3.06
I tried, but didn’t change. In the meantime I bought a new keyboard and it works fine.
Thus, I think it’s a mechanical issue.
  1. That’s why I said:
  2. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  3. No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed. :wink:
  4. Editing/Reading now…
    That’s what I was going to text next so, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
