In Manjaro kde,
keyboard and touchpad are not working after suspend(In laptop)
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. -
The output of
journalctl --system --boot=0 --priority=3 | tail --lines=50ASAP after you come back from suspend would be helpful as well.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Out of inxi --admin --verbosity=7 --filter --no-host --width
[prince@Bot ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=06723026-9c87-4ba4-9846-0ca9430e1931 ro quiet udev.log_priority=3
atkbd.reset=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Sony product: SVE1513CYNB v: C10H55HJ serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Sony model: VAIO serial: <filter> UEFI-[Legacy]: Insyde v: R0190E5
date: 07/31/2012
ID-1: BAT1 charge: 0.6 Wh (1.3%) condition: 47.5/47.5 Wh (100.0%) volts: 3.2
min: 10.8 model: SONY Corp. VGP-BPS22 type: Li-ion serial: N/A
status: Charging
RAM: total: 3.74 GiB used: 1.5 GiB (40.0%)
Info: Dual Core model: Intel Core i3-2328M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 3 MiB bogomips: 17567
Speed: 1642 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 1642 2: 1605
3: 1599 4: 1360
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Sony driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Ricoh USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-1.3:4
chip-ID: 05ca:18c3 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.1.4 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Sony
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.31 running: no
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: Foxconn Unex DHXA-225 driver: ath9k v: kernel port: 3040
bus-ID: 01:00.0 chip-ID: 168c:0032 class-ID: 0280
vendor: Sony driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-1: Foxconn / Hon Hai Bluetooth USB Host Controller type: USB
driver: btusb v: 0.8 bus-ID: 1-1.2:5 chip-ID: 0489:e036 class-ID: e001
serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 298.09 GiB used: 47.63 GiB (16.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS543232A7A384
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: A90C scheme: MBR
Optical-1: /dev/sr0 vendor: MATSHITA model: DVD-RAM UJ8C0 rev: 1.20
dev-links: cdrom
ID-1: / raw-size: 138.82 GiB size: 135.64 GiB (97.71%)
used: 47.63 GiB (35.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 06723026-9c87-4ba4-9846-0ca9430e1931
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 352b6f20-757d-449a-b953-330361e3dcb0
ID-1: /dev/sda2 maj-min: 8:2 size: 49.05 GiB fs: <superuser required>
label: My File uuid: d06be3ae-0132-415d-9889-607e2eaea819
ID-2: /dev/sda3 maj-min: 8:3 size: 102.77 GiB fs: <superuser required>
label: Entertainment uuid: 6e6ec9db-cc86-4582-9133-17966c1827b6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:5 info: Foxconn / Hon Hai Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0489:e036 class-ID: e001 serial: <filter>
Device-2: 1-1.3:4 info: Ricoh USB2.0 Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 05ca:18c3
class-ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 198 Uptime: 3m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1231 pacman: 1225 lib: 324
flatpak: 6 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
You have no resume id there, so:
Execute:
sudo nano /etc/default/grub -
find the line starting with
GRUB_CMDLINE_LINUX_DEFAULT -
Add
resume=UUID=352b6f20-757d-449a-b953-330361e3dcb0(with a space at the end) beforero quiet -
Execute:
sudo update-grub sudo mkinitcpio --preset linux510 sudo reboot -
Try again
If that doesn’t work, I need the output of
journalctl
it doesn’t work.
[prince@Bot ~]$ journalctl
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 IST. >
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, date =>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GCC>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID>
Jun 29 23:29:47 Bot kernel: KERNEL supported cpus:
Jun 29 23:29:47 Bot kernel: Intel GenuineIntel
Jun 29 23:29:47 Bot kernel: AMD AuthenticAMD
Jun 29 23:29:47 Bot kernel: Hygon HygonGenuine
Jun 29 23:29:47 Bot kernel: Centaur CentaurHauls
Jun 29 23:29:47 Bot kernel: zhaoxin Shanghai
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating poin>
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 IST.>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, date >
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GC>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUI>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating poi>
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 IST>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, date>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (G>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UU>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating po>
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 I>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, da>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc >
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating >
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 >
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, d>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE register>
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, >
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gc>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 roo>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floatin>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registe>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX regi-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:1>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION)>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 flo>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE reg>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX reg-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_6>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 fl>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE re>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX re-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision >
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGIO>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 f>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE r>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AV-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-2>
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revis>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@L>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9->
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x002: 'S>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004---- -- J--------------- ----- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 08:18:14 IST. --
Jun 29 23:29:47 Bot kernel: microcode: microcode updated early to revision 0x2f, date = 2019-0>
Jun 29 23:29:47 Bot kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.>
Jun 29 23:29:47 Bot kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=067230>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point regis>
Jun 29 23:29:47 Bot kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jun 29 23:29:47 Bot kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Jun 29 23:29:47 Bot kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, u>
Jun 29 23:29:47 Bot kernel: BIOS-provided physical RAM map:
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000020200000-0x000000003fffffff] usable
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000040000000-0x00000000401fffff] reserved
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x0000000040200000-0x00000000aaabefff] usable
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x00000000aaabf000-0x00000000aaebefff] reserved
Jun 29 23:29:47 Bot kernel: BIOS-e820: [mem 0x00000000aaebf000-0x00000000aafbefff] ACPI NVS
lines 1-26
Please note that the output of journalctl is cut off at the 80th column: I need the full output
Also to limit the output, please:
Reboot
Log in
execute
systemctl suspend -
come back from suspend and execute:
journalctl --system --boot=0 --priority=3 | tail --lines=50using the virtual keyboard (as your physical keyboard is not working coming back from suspend)
[prince@Bot ~]$ journalctl --system --boot=0 --priority=3 | tail --lines=50
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 18:40:05 IST. --
Jul 22 18:38:49 Bot kernel: i8042: Can't reactivate AUX port
journalctl --system --boot=0 --priority=4
please using the same system (reboot, login, suspend, journalctl)
[prince@Bot ~]$ journalctl --system --boot=0 --priority=4
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Thu 2021-07-22 21:47:25 IST. --
Jul 22 21:44:49 Bot kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.>
Jul 22 21:44:49 Bot kernel: #2 #3
Jul 22 21:44:49 Bot kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 22 21:44:49 Bot kernel: vboxdrv: loading out-of-tree module taints kernel.
Jul 22 21:44:49 Bot kernel: VBoxNetAdp: Successfully started.
Jul 22 21:44:49 Bot kernel: VBoxNetFlt: Successfully started.
Jul 22 21:45:03 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflict>
Jul 22 21:45:03 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflict>
Jul 22 21:45:03 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflict>
Jul 22 21:45:03 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflict>
Jul 22 21:45:03 Bot kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jul 22 21:45:03 Bot kernel: at24 0-0050: supply vcc not found, using dummy regulator
Jul 22 21:45:03 Bot kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Jul 22 21:45:03 Bot kernel: kauditd_printk_skb: 4 callbacks suppressed
Jul 22 21:45:08 Bot kernel: kauditd_printk_skb: 11 callbacks suppressed
Jul 22 21:45:08 Bot NetworkManager[373]: <warn> [1626970508.6512] keyfile: load: "/etc/NetworkManager/>
Jul 22 21:45:13 Bot sddm-helper[433]: gkr-pam: no password is available for user
Jul 22 21:45:14 Bot NetworkManager[373]: <warn> [1626970514.6441] device (wlp1s0): no secrets: No agen>
Jul 22 21:45:14 Bot NetworkManager[373]: <warn> [1626970514.6448] device (wlp1s0): Activation: failed >
Jul 22 21:45:37 Bot kernel: kauditd_printk_skb: 4 callbacks suppressed
Jul 22 21:46:12 Bot kernel: kauditd_printk_skb: 5 callbacks suppressed
Jul 22 21:47:04 Bot kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Jul 22 21:47:04 Bot rtkit-daemon[642]: The canary thread is apparently starving. Taking action.
Jul 22 21:47:04 Bot upowerd[713]: treating change event as add on /sys/devices/pci0000:00/0000:00:1a.0/>
Jul 22 21:47:14 Bot kernel: i8042: Can't write CTR while closing AUX port
Jul 22 21:47:14 Bot kernel: i8042: Can't reactivate AUX port
Jul 22 21:47:14 Bot kernel: atkbd serio0: Spurious ACK on isa0060/serio0. Some program might be trying >
lines 1-29/29 (END)
- That’s a partial
journalctlcut off at the right again. (When you see a>that’s not good) - Are you running this in a VM because I can’t see half of the information I need…
If not in a VM, let’s try:
journalctl --boot=0 --priority=4
No, I’m using it on my main machine
[prince@Bot ~]$ journalctl --boot=0 --priority=4
-- Journal begins at Tue 2021-06-29 23:29:47 IST, ends at Fri 2021-07-23 10:29:50 IST. --
Jul 23 10:13:07 Bot kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.>
Jul 23 10:13:07 Bot kernel: #2 #3
Jul 23 10:13:07 Bot kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jul 23 10:13:08 Bot kernel: vboxdrv: loading out-of-tree module taints kernel.
Jul 23 10:13:08 Bot kernel: VBoxNetAdp: Successfully started.
Jul 23 10:13:08 Bot kernel: VBoxNetFlt: Successfully started.
Jul 23 10:13:22 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflict>
Jul 23 10:13:22 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflict>
Jul 23 10:13:22 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflict>
Jul 23 10:13:22 Bot kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflict>
Jul 23 10:13:22 Bot kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Jul 23 10:13:22 Bot kernel: at24 0-0050: supply vcc not found, using dummy regulator
Jul 23 10:13:22 Bot kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Jul 23 10:13:22 Bot kernel: kauditd_printk_skb: 6 callbacks suppressed
Jul 23 10:13:24 Bot kernel: kauditd_printk_skb: 4 callbacks suppressed
Jul 23 10:13:29 Bot kernel: kauditd_printk_skb: 7 callbacks suppressed
Jul 23 10:13:28 Bot systemd[1]: pkgfile-update.service: Failed with result 'exit-code'.
Jul 23 10:13:28 Bot systemd[1]: Failed to start pkgfile database update.
Jul 23 10:13:29 Bot NetworkManager[383]: <warn> [1627015409.7336] keyfile: load: "/etc/NetworkManager/>
Jul 23 10:13:38 Bot sddm-helper[492]: gkr-pam: no password is available for user
Jul 23 10:13:38 Bot systemd-xdg-autostart-generator[543]: /home/prince/.config/autostart/org.kde.latte->
Jul 23 10:13:38 Bot systemd-xdg-autostart-generator[543]: Configuration file /etc/xdg/autostart/msm_kde>
Jul 23 10:13:51 Bot systemd-xdg-autostart-generator[719]: /home/prince/.config/autostart/org.kde.latte->
Jul 23 10:13:51 Bot systemd-xdg-autostart-generator[719]: Configuration file /etc/xdg/autostart/msm_kde>
Jul 23 10:13:53 Bot klauncher[727]: Connecting to deprecated signal QDBusConnectionInterface::serviceOw>
Jul 23 10:13:58 Bot kernel: kauditd_printk_skb: 4 callbacks suppressed
Jul 23 10:14:04 Bot kcminit_startup[731]: QDBusConnection: error: could not send signal to service "" p>
Jul 23 10:14:05 Bot ksplashqml[705]: file:///home/prince/.local/share/plasma/look-and-feel/Arch/content>
Jul 23 10:14:08 Bot kwin_x11[752]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "en_IN"
Jul 23 10:14:10 Bot ksmserver[780]: Qt: Session management error: networkIdsList argument is NULL
Jul 23 10:14:10 Bot kglobalaccel5[781]: kf.globalaccel.kglobalacceld: No desktop file found for service>
Jul 23 10:14:18 Bot kwin_x11[752]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 755,>
Jul 23 10:14:21 Bot kwin_x11[752]: kwin_core: XCB error: 10 (BadAccess), sequence: 819, resource id: 31>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 859,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 863,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 871,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 875,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 879,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 890,>
Jul 23 10:14:21 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 902,>
Jul 23 10:14:23 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 906,>
Jul 23 10:14:26 Bot kwin_x11[752]: kwin_core: XCB error: 152 (BadDamage), sequence: 1307, resource id: >
Jul 23 10:14:26 Bot kwin_x11[752]: kwin_core: XCB error: 3 (BadWindow), sequence: 1309, resource id: 41>
Jul 23 10:14:26 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1310>
Jul 23 10:14:26 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1315>
Jul 23 10:14:28 Bot kded5[747]: kf.modemmanagerqt: Failed enumerating MM objects: "org.freedesktop.syst>
"Unit dbus-org.freedesktop.ModemManager1.service is masked."
Jul 23 10:14:28 Bot org_kde_powerdevil[788]: Warning from helper: Failed to open "/sys/class/power_supp>
Jul 23 10:14:28 Bot org_kde_powerdevil[788]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelp>
Jul 23 10:14:30 Bot kded5[747]: kscreen.kded: PowerDevil SuspendSession action not available!
Jul 23 10:14:33 Bot org_kde_powerdevil[788]: org.kde.powerdevil: Handle button events action could not >
Jul 23 10:14:33 Bot org_kde_powerdevil[788]: Warning from helper: Failed to open "/sys/class/power_supp>
Jul 23 10:14:33 Bot org_kde_powerdevil[788]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelp>
Jul 23 10:14:34 Bot baloo_file[797]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but w>
Jul 23 10:14:35 Bot systemd-coredump[1022]: [🡕] Process 797 (baloo_file) of user 1000 dumped core.
Stack trace of thread 1019:
#0 0x00007f976b848396 n/a (liblmdb.so + 0x4396)
#1 0x00007f976b84aefe n/a (liblmdb.so + 0x6efe)
#2 0x00007f976b84b644 n/a (liblmdb.so + 0x7644)
#3 0x00007f976b84bc50 mdb_get (liblmdb.so + 0x7c50)
#4 0x00007f976cdf5115 _ZN5Baloo12IdFilenameDB3getEy (libKF>
#5 0x00007f976cdedcdc _ZNK5Baloo13DocumentUrlDB3getEy (lib>
#6 0x00007f976ce032d5 _ZNK5Baloo11Transaction11documentUrl>
#7 0x000055979094c444 n/a (baloo_file + 0x22444)
#8 0x00007f976ce0c629 _ZN5Baloo16WriteTransaction17removeR>
#9 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#10 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#11 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#12 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#13 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#14 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#15 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#16 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#17 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#18 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#19 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#20 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#21 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#22 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#23 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#24 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#25 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#26 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#27 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#28 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#29 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#30 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#31 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#32 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#33 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#34 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#35 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#36 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#37 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#38 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#39 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#40 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#41 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#42 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#43 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#44 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#45 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#46 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#47 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#48 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#49 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#50 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#51 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#52 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#53 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#54 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#55 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#56 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#57 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#58 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#59 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#60 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#61 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#62 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
#63 0x00007f976ce0c67c _ZN5Baloo16WriteTransaction17removeR>
Stack trace of thread 797:
#0 0x00007f976c44fb2f __poll (libc.so.6 + 0xf3b2f)
#1 0x00007f976b001b29 n/a (libglib-2.0.so.0 + 0xa7b29)
#2 0x00007f976afab871 g_main_context_iteration (libglib-2.>
#3 0x00007f976cb93fd6 _ZN20QEventDispatcherGlib13processEv>
#4 0x00007f976cb39d1c _ZN10QEventLoop4execE6QFlagsINS_17Pr>
#5 0x00007f976cb42284 _ZN16QCoreApplication4execEv (libQt5>
#6 0x0000559790937315 n/a (baloo_file + 0xd315)
#7 0x00007f976c383b25 __libc_start_main (libc.so.6 + 0x27b>
#8 0x000055979093751e n/a (baloo_file + 0xd51e)
Stack trace of thread 828:
#0 0x00007f976c452323 pselect (libc.so.6 + 0xf6323)
#1 0x00007f976a9d3524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007f976a9d48a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007f976b8ba259 start_thread (libpthread.so.0 + 0x92>
#4 0x00007f976c45a5e3 __clone (libc.so.6 + 0xfe5e3)
Stack trace of thread 812:
#5 0x00007f976c94ee12 _ZN7QThread4execEv (libQt5Core.so.5 >
#6 0x00007f976ce30ae8 n/a (libQt5DBus.so.5 + 0x15ae8)
#7 0x00007f976c94ffef n/a (libQt5Core.so.5 + 0xcdfef)
#8 0x00007f976b8ba259 start_thread (libpthread.so.0 + 0x92>
#9 0x00007f976c45a5e3 __clone (libc.so.6 + 0xfe5e3)
Jul 23 10:14:39 Bot kernel: kauditd_printk_skb: 5 callbacks suppressed
Jul 23 10:14:41 Bot plasmashell[792]: file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/c>
Jul 23 10:14:43 Bot plasmashell[792]: file:///home/prince/.local/share/plasma/plasmoids/com.pajuelo.pla>
Jul 23 10:14:48 Bot plasmashell[792]: trying to show an empty dialog
Jul 23 10:14:48 Bot plasmashell[792]: file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.horizon>
Jul 23 10:14:48 Bot plasmashell[792]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/v>
Jul 23 10:14:48 Bot plasmashell[792]: kf.quickcharts.deprecated: LegendDelegate::colorVisible is deprec>
Jul 23 10:14:48 Bot plasmashell[792]: kf.quickcharts.deprecated: LegendDelegate::layoutWidth is depreca>
Jul 23 10:14:48 Bot plasmashell[792]: kf.quickcharts.deprecated: LegendDelegate::valueWidth is deprecat>
Jul 23 10:14:49 Bot kdeconnectd[833]: kdeconnect.core: Could not query capabilities from notifications >
Jul 23 10:14:52 Bot plasmashell[792]: kf.kio.widgets: Invalid url ""
Jul 23 10:14:52 Bot plasmashell[792]: kf.solid.frontend.devicemanager: Couldn't get StorageAccess for ">
Jul 23 10:14:52 Bot kdeinit5[1070]: Qt: Session management error: networkIdsList argument is NULL
Jul 23 10:15:33 Bot msm_kde_notifier[848]: QProcess: Destroyed while process ("pacman") is still runnin>
Jul 23 10:18:23 Bot kded5[747]: plasma-nm: Unhandled active connection state change: 1
Jul 23 10:19:22 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3074>
Jul 23 10:23:41 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3732>
Jul 23 10:23:42 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3742>
Jul 23 10:27:03 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1788>
Jul 23 10:27:11 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 21>
Jul 23 10:27:19 Bot kwin_x11[752]: Module 'org.kde.kwin.decoration' does not contain a module identifie>
Jul 23 10:27:20 Bot kwin_x11[752]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot >
Jul 23 10:27:22 Bot konsole[2033]: qt.xkb.compose: failed to create compose table
Jul 23 10:28:47 Bot kwin_x11[752]: kwin_core: XCB error: 3 (BadWindow), sequence: 48151, resource id: 1>
Jul 23 10:28:52 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4944>
Jul 23 10:28:56 Bot kded5[747]: plasma-nm: Unhandled active connection state change: 3
Jul 23 10:29:13 Bot kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Jul 23 10:29:12 Bot upowerd[959]: treating change event as add on /sys/devices/pci0000:00/0000:00:1a.0/>
Jul 23 10:29:20 Bot upowerd[959]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/>
Jul 23 10:29:21 Bot kded5[747]: plasma-nm: Unhandled active connection state change: 1
Jul 23 10:29:24 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5345>
Jul 23 10:29:25 Bot kernel: i8042: Can't write CTR while closing AUX port
Jul 23 10:29:25 Bot kernel: i8042: Can't reactivate AUX port
Jul 23 10:29:25 Bot kernel: atkbd serio0: Spurious ACK on isa0060/serio0. Some program might be trying >
Jul 23 10:29:25 Bot kded5[747]: Touchpad detached
Jul 23 10:29:28 Bot kded5[747]: Touchpad reset
Jul 23 10:29:29 Bot kwin_x11[752]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5524>
lines 195-223/223 (END)
My apologies: I can’t see anything wrong (nor anything right neither) with your system, so I won’t be of any further help to you.
Maybe this is useful to you to:
Should I reinstall Manjaro?
I can’t make that decision for you, but if you do, please read this:
and this:
first!
