Keyboard and mouse not working after upgrade
Hello everyone,
I was running Manjaro with KDE for sometime. When I did a full upgrade recently, the inbuilt keyboard and mouse stopped working. Can use external keyboard and mouse.
After hours of trying to find a solution, reinstalled v20.0.3 and it worked fine. When I did the full upgrade it stopped working.
It’s an acer laptop. The recommended solution I found is to change the touchpad setting in BIOS from “Advanced” to “Basic”. But I can’t find that setting in BIOS.
Here are the outputs of,
s6@manjaro-acer ~]$ inxi -Fxxxza --no-host
System:    Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=a1608947-5cbd-48ff-b3ee-59ad86d00ac5 rw quiet apparmor=1
           Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Acer product: Aspire E5-511 v: V1.02 serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Acer model: Aspire E5-511 v: V1.02 serial: <filter> UEFI: Acer v: 1.02 date: 04/14/2014
Battery:   ID-1: BAT1 charge: 43.9 Wh condition: 51.5/55.9 Wh (92%) volts: 12.2/11.1 model: SANYO PABAS0241231 type: Li-ion
           serial: <filter> status: Discharging
CPU:       Topology: Quad Core model: Intel Pentium N3530 bits: 64 type: MCP arch: Silvermont family: 6 model-id: 37 (55)
           stepping: 8 microcode: 838 L2 cache: 1024 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17343
           Speed: 555 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 500 2: 500 3: 826 4: 772
           Type: spec_store_bypass status: Not affected
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics:  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display vendor: Acer Incorporated ALI driver: i915
           v: kernel bus ID: 00:02.0 chip ID: 8086:0f31
           Device-2: Chicony type: USB driver: uvcvideo bus ID: 1-1.4:4 chip ID: 04f2:b455
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
           display ID: :0 screens: 1
           Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
           Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
           OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.1.5 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio vendor: Acer Incorporated ALI
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:0f04
           Sound Server: ALSA v: k5.7.15-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
           v: kernel port: 1000 bus ID: 01:00.1 chip ID: 10ec:8168
           IF: enp1s0f1 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel
           port: 1000 bus ID: 02:00.0 chip ID: 168c:0036
Drives:    Local Storage: total: 931.51 GiB used: 40.47 GiB (4.3%)
           ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
Partition: ID-1: / raw size: 60.00 GiB size: 58.81 GiB (98.01%) used: 8.40 GiB (14.3%) fs: ext4 dev: /dev/sda7
           ID-2: /home raw size: 419.78 GiB size: 412.19 GiB (98.19%) used: 32.05 GiB (7.8%) fs: ext4 dev: /dev/sda8
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.00 GiB used: 5.4 MiB (0.1%) priority: -2 dev: /dev/sda6
Sensors:   System Temperatures: cpu: 39.0 C mobo: N/A
Info:      Processes: 186 Uptime: 36m Memory: 3.73 GiB used: 1.61 GiB (43.1%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Packages: pacman: 1185 lib: 318 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
[s6@manjaro-acer ~]$ mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
[s6@manjaro-acer ~]$ cat /etc/X11/xorg.conf.d/*.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "us"
        Option "XkbModel" "pc105"
EndSection
    Identifier "touchpad"
    Driver "libinput"
    MatchIsTouchpad "on"
    Option "Tapping" "on"
EndSection
Any help is appreciated.
Addition to the above,
Tried different kernel and has the same issue.
I also have Win10 as dual boot, and both keyboard/mouse works fine.
When I boot to Manjaro, it works until I select options in grub.
Also works in tty.
Which different kernel did you try?
Do you have this issue on any other versions of Manjaro?
Tried kernel 4.19.
Started with 20.0.3 in this computer. The live usb says - manjaro-kde-20.0.3-200606
Once I install this, it works fine out of the box, but after a full upgrade both keyboard/mouse stops working.
Try this
https://bbs.archlinux.org/viewtopic.php?id=204564
Checked this, it didn’t help with my issue.
Having exact same issue with HP Pavilion 11 x360 and manjaro-lxqt-20.0-minimal-200423-linux56
inxi output:
System:    Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
          parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=3cd69c67-0932-4203-b658-63f06258d855 rw quiet
          cryptdevice=UUID=710a3c05-4cb3-4722-9173-88803727f1b9:luks-710a3c05-4cb3-4722-9173-88803727f1b9
          root=/dev/mapper/luks-710a3c05-4cb3-4722-9173-88803727f1b9 udev.log_priority=3
          Desktop: LXQt 0.15.1 tk: Qt 5.15.0 info: lxqt-panel wm: Openbox 3.6.1 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: Hewlett-Packard product: HP Pavilion 11 x360 PC v: 0976100001405F00010420180 serial: <filter>
          Mobo: Hewlett-Packard model: 2209 v: 57.57 serial: <filter> UEFI: Insyde v: F.30 date: 03/13/2018
Battery:   ID-1: BAT1 charge: 19.2 Wh condition: 19.2/29.0 Wh (66%) volts: 8.6/7.6 model: COMPAL PABAS0241231 type: Li-ion
          serial: <filter> status: Full
          Speed: 500 MHz min/max: 500/2582 MHz Core speeds (MHz): 1: 500 2: 500 3: 959 4: 1029
Graphics:  Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display vendor: Hewlett-Packard driver: i915
          Device-2: Suyin HP Truevision HD type: USB driver: uvcvideo bus ID: 1-3:2 chip ID: 064e:c342 serial: <filter>
          Display: x11 server: X.org 1.20.8 compositor: compton driver: intel unloaded: modesetting alternate: fbdev,vesa
          resolution: <xdpyinfo missing>
Audio:     Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio vendor: Hewlett-Packard
          Sound Server: ALSA v: k5.7.17-2-MANJARO
Network:   Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Hewlett-Packard driver: rt2800pci v: 2.3.0 port: 2000
          bus ID: 02:00.0 chip ID: 1814:3290
          IF: wlp2s0f0 state: down mac: <filter>
          Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel port: 1000
          bus ID: 04:00.0 chip ID: 10ec:8136
          IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 4.49 GiB (1.0%)
          ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB block size: physical: 4096 B
          logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: YAM1 scheme: GPT
Partition: ID-1: / raw size: 399.00 GiB size: 391.74 GiB (98.18%) used: 4.49 GiB (1.1%) fs: ext4 dev: /dev/dm-0
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 43.0 C mobo: 39.0 C
Info:      Processes: 155 Uptime: 2h 23m Memory: 7.67 GiB used: 970.8 MiB (12.4%) Init: systemd v: 246 Compilers: gcc: N/A
          Packages: pacman: 667 lib: 159 Shell: Zsh v: 5.8 running in: qterminal inxi: 3.1.05
