Kernels installed in /boot and /boot/efi, grub shows only kernels in /boot/efi
As part of the procedure of converting the root filesystem of my computer to btrfs, I chrooted into it and reinstalled grub. Followed this guide: GRUB/Restore the GRUB Bootloader - Manjaro .
I also removed and installed some kernels, using pacman (mhwd-kernel didn’t work in chroot), and did mkinitcpio -P and grub-mkconfig.
Removed two dkms modules that were causing issues, anbox-ashmem and anbox-binder.
More info about how I got in this situation in my previous forum post.
Now, booted into the actual system, new kernel images are installed into /boot, but grub only shows the kernel images located in /boot/efi/.
I am unable to boot from any kernel images apart from the ones located in /boot/efi/
What should I do to restore regular system functions, i.e. boot from the newest installed kernel?
test -d /sys/firmware/efi && echo efi || echo bios
efi
ls -R /boot
cat /etc/default/grub
GRUB_DEFAULT=0
GRUB_TIMEOUT=1
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR=“Manjaro”
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash loglevel=3 sysrq_always_enabled=1 udev.log_priority=3”
GRUB_CMDLINE_LINUX=“”
If you want to enable the save default function, uncomment the following
line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT=true
Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES=“part_gpt part_msdos”
Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command ‘videoinfo’
GRUB_GFXMODE=auto
Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
Uncomment if you want GRUB to pass to the Linux kernel the old parameter
format “root=/dev/xxx” instead of “root=/dev/disk/by-uuid/xxx”
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
Uncomment this option to enable os-prober execution in the grub-mkconfig command
GRUB_DISABLE_OS_PROBER=false
Uncomment and set to the desired menu colors. Used by normal and wallpaper
modes only. Entries specified as foreground/background.
GRUB_COLOR_NORMAL=“light-gray/black”
GRUB_COLOR_HIGHLIGHT=“green/black”
Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND=“/usr/share/grub/background.png”
GRUB_THEME=“/usr/share/grub/themes/manjaro/theme.txt”
Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE=“480 440 1”
Uncomment to ensure that the root filesystem is mounted read-only so that
systemd-fsck can run the check automatically. We use ‘fsck’ by default, which
needs ‘rw’ as boot parameter, to avoid delay in boot-time. ‘fsck’ needs to be
removed from ‘mkinitcpio.conf’ to make ‘systemd-fsck’ work.
See also Arch-Wiki: fsck - ArchWiki
#GRUB_ROOT_FS_RO=true
inxi -Fazy
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.10-x86_64
root=UUID=ea10f93b-0ef1-4889-80e9-b0ca11f6999f rw rootflags=subvol=root
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Notebook product: P95xER v: N/A serial: N/A
Chassis: No Enclosure type: 10 serial: N/A
Mobo: Notebook model: P95xER serial: N/A UEFI: American Megatrends
v: 1.07.15 date: 11/16/2018
ID-1: BAT0 charge: 45.4 Wh (89.4%) condition: 50.8/53.2 Wh (95.4%)
volts: 16.6 min: 15.2 model: Notebook BAT type: Li-ion serial:
status: Unknown
Info: 6-Core model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: 9A cache: L1: 384 KiB
L2: 9 MiB L3: 9 MiB
bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz base/boost: 2079/8300 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: srbds status: Vulnerable: No microcode
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: CLEVO/KAPOK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: CLEVO/KAPOK
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1ba1 class-ID: 0300
Device-3: Chicony Chicony USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b5a7 class-ID: 0e02
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.6x15.0")
s-diag: 775mm (30.5")
Monitor-1: eDP-1 res: 2560x1440 hz: 60 dpi: 188 size: 345x194mm (13.6x7.6")
diag: 396mm (15.6")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.38 running: no
Device-1: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel port: 4000 bus-ID: 03:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp3s0 state: up mac:
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac:
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.05 TiB used: 260.45 GiB (12.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: rev: 3B7QCXE7 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 169d 19h cycles: 2,095
read-units: 22,961,369 [11.7 TB] written-units: 32,327,264 [16.5 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
family: FireCuda 2.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: rev: SDM1 temp: 37 C
SMART: yes state: enabled health: PASSED on: 275d 5h cycles: 2094
read: 27.35 TiB written: 7.67 TiB Pre-Fail: reallocated sector: 100
threshold: 36 attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-1: / raw-size: 232.59 GiB size: 232.59 GiB (100.00%)
used: 87.77 GiB (37.7%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 63.4 MiB (21.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 172.62 GiB (9.3%) fs: btrfs block-size: 4096 B dev: /dev/sda
maj-min: 8:0
System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 40.0 C
Processes: 331 Uptime: 3h 25m wakeups: 2 Memory: 31.21 GiB
used: 3.63 GiB (11.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1873 pacman: 1863 lib: 453
flatpak: 10 Shell: Bash (su) v: 5.1.8 running-in: yakuake inxi: 3.3.06
efibootmgr -v
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0001,0006,0000
Boot0000* Windows Boot Manager VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)WINDOWS…x…B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}…u…
Boot0001* manjaro HD(1,GPT,dd2eae74-f0b5-a041-a448-763d2bcf8fa8,0x1000,0x96000)/File(\EFI\manjaro\grubx64.efi)
Boot0006* UEFI OS HD(1,GPT,dd2eae74-f0b5-a041-a448-763d2bcf8fa8,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
The system had a sudden, apparently random, hard poweroff today. I’ve read a few forum posts elsewhere stating it’s a regular problem for this laptop model.
After powering on again, it now runs the newest installed kernel, 5.14 :thinking:
The 5.10 kernel still resides in /boot/efi/, and the 5.14 kernel still resides in /boot/.
I will mark this topic as solved if the issue doesn’t reappear until tomorrow night.
journalctl -b -0 | tail -n 100
okt. 11 19:20:36 jacob-p950er sudo[9457]: jacob : TTY=pts/2 ; PWD=/home/jacob ; USER=root ; COMMAND=/usr/bin/dmesg
okt. 11 19:20:36 jacob-p950er audit[9457]: USER_START pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct=“root
" exe=”/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success’
okt. 11 19:20:36 jacob-p950er sudo[9457]: pam_unix(sudo:session): session opened for user root(uid=0) by jacob(uid=1000)
okt. 11 19:20:36 jacob-p950er kernel: audit: type=1101 audit(1633972836.771:152): pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:accounting grantors=pam_unix,pam_pe
rmit,pam_time acct=“jacob” exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success’
okt. 11 19:20:36 jacob-p950er kernel: audit: type=1110 audit(1633972836.771:153): pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:setcred grantors=pam_faillock,pam_p
ermit,pam_faillock acct=“root” exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success’
okt. 11 19:20:36 jacob-p950er kernel: audit: type=1105 audit(1633972836.771:154): pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:session_open grantors=pam_limits,pa
m_unix,pam_permit acct=“root” exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success’
okt. 11 19:20:36 jacob-p950er sudo[9457]: pam_unix(sudo:session): session closed for user root
okt. 11 19:20:36 jacob-p950er audit[9457]: USER_END pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct=“root”
okt. 11 19:20:36 jacob-p950er audit[9457]: CRED_DISP pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct=“root
okt. 11 19:20:36 jacob-p950er kernel: audit: type=1106 audit(1633972836.784:155): pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:session_close grantors=pam_limits,p
am_unix,pam_permit acct=“root” exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success’
okt. 11 19:20:36 jacob-p950er kernel: audit: type=1104 audit(1633972836.784:156): pid=9457 uid=1000 auid=1000 ses=2 msg=‘op=PAM:setcred grantors=pam_faillock,pam_p
okt. 11 19:20:38 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:39 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:41 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:44 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:51 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:53 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:54 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:56 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:57 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:20:59 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:02 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:03 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:12 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:15 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:17 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:20 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:21 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:30 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:32 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:33 jacob-p950er dbus-daemon[529]: [system] Activating via systemd: service name=‘org.freedesktop.locale1’ unit=‘dbus-org.freedesktop.locale1.service’
requested by ‘:1.192’ (uid=1000 pid=9651 comm=“pamac checkupdates -q --refresh-tmp-files-dbs --us”)
okt. 11 19:21:33 jacob-p950er audit: BPF prog-id=38 op=LOAD
okt. 11 19:21:33 jacob-p950er audit: BPF prog-id=39 op=LOAD
okt. 11 19:21:33 jacob-p950er audit: BPF prog-id=40 op=LOAD
okt. 11 19:21:33 jacob-p950er systemd[1]: Starting Locale Service…
okt. 11 19:21:33 jacob-p950er kernel: audit: type=1334 audit(1633972893.059:157): prog-id=38 op=LOAD
okt. 11 19:21:33 jacob-p950er kernel: audit: type=1334 audit(1633972893.059:158): prog-id=39 op=LOAD
okt. 11 19:21:33 jacob-p950er kernel: audit: type=1334 audit(1633972893.059:159): prog-id=40 op=LOAD
okt. 11 19:21:33 jacob-p950er dbus-daemon[529]: [system] Successfully activated service ‘org.freedesktop.locale1’
okt. 11 19:21:33 jacob-p950er systemd[1]: Started Locale Service.
okt. 11 19:21:33 jacob-p950er audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-localed comm=“systemd” exe="/usr/lib/systemd/sys
temd" hostname=? addr=? terminal=? res=success’
okt. 11 19:21:33 jacob-p950er kernel: audit: type=1130 audit(1633972893.102:160): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-localed comm=“system
d” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
okt. 11 19:21:35 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:41 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:42 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:44 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:48 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:50 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:54 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:56 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:57 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:21:59 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:00 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:02 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:03 jacob-p950er systemd[1]: systemd-localed.service: Deactivated successfully.
okt. 11 19:22:03 jacob-p950er audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-localed comm=“systemd” exe="/usr/lib/systemd/syst
okt. 11 19:22:03 jacob-p950er kernel: audit: type=1131 audit(1633972923.138:161): pid=1 uid=0 auid=4294967295 ses=4294967295 msg=‘unit=systemd-localed comm=“system
okt. 11 19:22:03 jacob-p950er audit: BPF prog-id=40 op=UNLOAD
okt. 11 19:22:03 jacob-p950er audit: BPF prog-id=39 op=UNLOAD
okt. 11 19:22:03 jacob-p950er audit: BPF prog-id=38 op=UNLOAD
okt. 11 19:22:03 jacob-p950er kernel: audit: type=1334 audit(1633972923.238:162): prog-id=40 op=UNLOAD
okt. 11 19:22:03 jacob-p950er kernel: audit: type=1334 audit(1633972923.238:163): prog-id=39 op=UNLOAD
okt. 11 19:22:03 jacob-p950er kernel: audit: type=1334 audit(1633972923.238:164): prog-id=38 op=UNLOAD
okt. 11 19:22:03 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:05 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:12 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:14 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:15 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:17 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:18 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:21 jacob-p950er plasmashell[864]: qml: temp unit: 0
okt. 11 19:22:23 jacob-p950er plasmashell[864]: qml: temp unit: 0
inxi -Fazy
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/root/boot/vmlinuz-5.14-x86_64
Mobo: Notebook model: P95xER serial: UEFI: American Megatrends
ID-1: BAT0 charge: 45.8 Wh (89.6%) condition: 51.1/53.2 Wh (96.1%)
status: Unknown
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: EA cache: L2: 9 MiB
bogomips: 52815
Speed: 893 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 893 2: 900 3: 868
4: 890 5: 894 6: 864 7: 898 8: 891 9: 887 10: 866 11: 883 12: 886
Type: l1tf
bus-ID: 1-8:2 chip-ID: 04f2:b5a7 class-ID: 0e02
diag: 396mm (15.6")
direct render: Yes
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.05 TiB used: 262.27 GiB (12.5%)
lanes: 4 type: SSD serial: rev: 3B7QCXE7 temp: 35.9 C scheme: GPT
type: HDD rpm: 5400 serial: rev: SDM1
used: 88.41 GiB (38.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 63.4 MiB (21.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 173.8 GiB (9.3%) fs: btrfs dev: /dev/sda maj-min: 8:0
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Processes: 355 Uptime: 2h 58m wakeups: 2 Memory: 31.21 GiB
used: 5.28 GiB (16.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1876 pacman: 1866 lib: 454
flatpak: 10 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
A possibly related issue has shown itself, so I’ll keep this post open. sudo iotop no longer displays swap or IO for any processes. I tried both yakuake and konsole.
This error message is displayed:
CONFIG_TASK_DELAY_ACCT not enabled in kernel, cannot determine SWAPIN and IO % 20 be/4 root 0.00 B/s 0.00 B/s ?unavailable? [cpuhp/1]
The process names(?) in [square brackets] change sporadically.
screenshot of yakuake:
Please do not post screenshots of text:
I posted a screenshot of the application as well as a the error message in question to better illustrate what was going on.
Will refrain from doing so in the future.
