Hi, I’m running the unstable branch with two kernels installed, linux68 and linux66. Recently I noticed that only one of the two shows up in GRUB. When I run mkinitcpio -P, I notice that the files generated for both kernels have the same name:
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz- -g /boot/initramfs-.img
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz- -g /boot/initramfs--fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'default'
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'fallback'
So basically the 6.6 ramdisk is being generated and then being written over by the 6.8 ramdisk. Usually these files have a version number attached to the end of their names, but for some reason now they don’t and they’re conflicting. I haven’t touched the preset files in /etc/mkinitcipio.d/. Any ideas about what might be causing this?
> cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(usbhid xhci_hcd)
MODULES=(crc32c-intel)
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=(/crypto_keyfile.bin)
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No RAID, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect modconf block filesystems fsck)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev modconf block filesystems fsck)
## This setup assembles a mdadm array with an encrypted root file system.
## Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
# HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
## This setup loads an lvm2 volume group.
# HOOKS=(base udev modconf block lvm2 filesystems fsck)
## This will create a systemd based initramfs which loads an encrypted root filesystem.
# HOOKS=(base systemd autodetect modconf kms keyboard sd-vconsole sd-encrypt block filesystems fsck)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr and fsck hooks.
HOOKS=(base udev autodetect kms modconf block keyboard keymap consolefont plymouth encrypt openswap resume filesystems)
# COMPRESSION
# Use this to compress the initramfs image. By default, zstd compression
# is used for Linux ≥ 5.9 and gzip compression is used for Linux < 5.9.
# Use 'cat' to create an uncompressed image.
#COMPRESSION="zstd"
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress loadable kernel modules and their firmware during initramfs
# creation. Switch (yes/no).
# Enable to allow further decreasing image size when using high compression
# (e.g. xz -9e or zstd --long --ultra -22) at the expense of increased RAM usage
# at early boot.
# Note that any compressed files will be placed in the uncompressed early CPIO
# to avoid double compression.
#MODULES_DECOMPRESS="no"
linux66.preset is similar, without version numbers in the .img and .efi file names. What do these files look like normally? If I understand correctly, these files are automatically generated by mkinitcpio, so even if I edit them, the next time I run mkinitcpio or the kernel gets upgraded by pacman, they’ll be overwritten.
I actually edited my reply to remove the obvious statement you ended up quoting.
How do you come to that conclusion? You did notice I can’t reproduce it using the same Manjaro branch, right? I also have no issues on Arch (which apparently you’re using).
