@scarwire well the logic changed. 39-6 should fix it. Try to delete all preset files including pacsave ones.
If younstill see issues I provide a script with more verbose output
@philm, thanks for the recent patch. However, it seems there is still a function oversight in the patch, causing the package to remain non-functional.
Specifically, the install_kernel
function invokes install_preset
, which requires three arguments. Unfortunately, only two arguments are currently being provided, an issue not addressed in the patch.
Ref:
mkinitcpio
39.1-2 fixes this issue. Thanks!
