dmesg | grep -i edac
[ 0.404845] EDAC MC: Ver: 3.0.0
[ 4.685907] EDAC i7core: Device not found: dev 00.0 PCI ID 8086:2c70
CPU i7 980X Extreme
Chipdatz X58
Hat zufällig wer einen Lösungsansatz ? In welche Richtung muss man suchen ? Ist da hardwaremäßig überhaupt was vorhanden ?
inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=9929717f-a7bf-4f29-bc5e-6b7f603d689f rw quiet apparmor=1
security=apparmor mitigations=off intremap=off udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: Rampage III Extreme v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 1601
date: 01/03/2012
RAM: total: 11.68 GiB used: 3.9 GiB (33.4%)
RAM Report:
Info: model: Intel Core i7 X 980 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 0x2C (44) stepping: 2 microcode: 0x1F
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3438 high: 3512 min/max: N/A cores: 1: 3512 2: 3512
3: 3512 4: 3512 5: 3512 6: 3512 7: 3512 8: 3512 9: 3512 10: 3512 11: 2625
12: 3512 bogomips: 84329
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr
pni popcnt pse pse36 rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:2488 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1440 s-dpi: 109 s-size: 597x336mm (23.5x13.2")
s-diag: 685mm (27")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel 82567V-2 Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel port: cc00 bus-ID: 00:19.0 chip-ID: 8086:10ce class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 7-1:2 chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 23.21 TiB used: 6.08 TiB (26.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 2B0QBXX7 temp: 36.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3000NM0033-9ZM178
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN07 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3000NM0033-9ZM178
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST16000NM001G-2KK103
size: 14.55 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN03 scheme: GPT
ID-1: / raw-size: 292.89 GiB size: 287.23 GiB (98.07%)
used: 19.43 GiB (6.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: System uuid: 9929717f-a7bf-4f29-bc5e-6b7f603d689f
ID-2: /media/C raw-size: 183.4 GiB size: 183.4 GiB (100.00%)
used: 48.72 GiB (26.6%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: Windows uuid: 983C244E3C2429A8
ID-3: /media/Downloads raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 44.08 GiB (4.7%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Downloads
uuid: C42E58082E57F1C2
ID-4: /media/FTP raw-size: 14.55 TiB size: 14.44 TiB (99.20%)
used: 5.31 TiB (36.8%) fs: ext4 dev: /dev/sde1 maj-min: 8:65 label: FTP
uuid: 6e2a81e7-bd14-42cc-874f-50de7694e933
ID-5: /media/Games raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 379.12 GiB (20.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: GAMES
uuid: 2c606cec-cfd4-4179-a786-62218237b2aa
ID-6: /media/NTFS raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 296.77 GiB (10.6%) fs: ntfs dev: /dev/sdc2 maj-min: 8:34 label: NTFS
uuid: C624E96724E95B47
ID-7: /media/ext4 raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
used: 28 KiB (0.0%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: ext4
uuid: 4d67db85-2293-4040-bdfa-e6012e151560
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: ntfs label: N/A
uuid: B4FC7F32FC7EEE4C
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 556 MiB fs: ntfs label: N/A
uuid: 01D7AB03709DF290
ID-3: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0
Hub-4: 3-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 4-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 7-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 3 rev: 2.0 speed: 12 Mb/s
Hub-9: 8-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 8-1:2 info: ASUSTek ROG GLADIUS III type: HID,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:197b class-ID: 0300
Device-2: 8-2:3 info: ASUSTek ROG Claymore Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0b05:184d class-ID: 0300
Hub-10: 9-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 10-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-12: 10-1:2 info: Genesys Logic Hub ports: 3 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 21.5 C mobo: 30.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): cpu: 1323 gpu: nvidia fan: 0%
Power: 12v: 12.19 5v: N/A 3.3v: 3.33 vbat: N/A
Processes: 295 Uptime: 5h 19m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1312
lib: 373 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
lspci ✔
00:00.0 Host bridge: Intel Corporation 5520/5500/X58 I/O Hub to ESI Port (rev 13)
00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 13)
00:02.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 2 (rev 13)
00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 13)
00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 13)
00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 13)
00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 13)
00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 13)
00:14.3 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Throttle Registers (rev 13)
00:19.0 Ethernet controller: Intel Corporation 82567V-2 Gigabit Network Connection
00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 5
00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 SATA controller: Intel Corporation 82801JI (ICH10 Family) SATA AHCI Controller
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
02:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 03)
03:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3070 Lite Hash Rate] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 (rev 01)
ff:00.0 Host bridge: Intel Corporation Device 2c71 (rev 02)
ff:00.1 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 0 (rev 02)
ff:02.3 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 1 (rev 02)
ff:03.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Registers (rev 02)
ff:03.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Target Address Decoder (rev 02)
ff:03.4 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Test Registers (rev 02)
ff:04.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Control (rev 02)
ff:04.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Address (rev 02)
ff:04.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Rank (rev 02)
ff:04.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control (rev 02)
ff:05.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Control (rev 02)
ff:05.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Address (rev 02)
ff:05.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Rank (rev 02)
ff:05.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control (rev 02)
ff:06.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Control (rev 02)
ff:06.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Address (rev 02)
ff:06.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Rank (rev 02)
ff:06.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control (rev 02)
EDAC hat mit ECC RAM zu tun. Hast solche RAM Module installiert?
nein
Also kann der gar nicht geladen werden ?
Nope, wenn kein ECC RAM installiert ist, dann kann das auch nicht verwendet werden.
Ich danke euch. Haben wir wieder was gelernt.
Manchmal findet man in den Logs wirklich wichtige Sachen …,
Aber zu oft sollte man nach meiner Erfahrung nicht reinschauen
(Sonst fängt man an Geister zu jagen)
Manche Programmierer vergessen bei der Meldung anzugeben, ob das ein Error, ein Warning oder nur eine Info nebenbei ist
Hätte wohl besser geheißen
Device not present
Das sind die Nachwirkungen von jahrelanger Windowsnutzung.
Aber ich möchte ja auch dazu lernen.
