buzzer
28 September 2023 07:10
1
Hello everyone,
following update to 6.5 series, my dell optiplex 7040 does not power off or reset anymore.
Using 6.4 series everything is working well.
I tried to add kernel parameters acpi=force and apm=power_off and the both, no change.
I will try 6.6 series, but I do not like to user Release Candidate kernel.
Any help will be appreciate.
Have you tried Kernel 6.1 (LTS) with and without those kernel parameters?
Is the system fully updated? Are you dual-booting?
Please post information about your system as outlined here:
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
buzzer
28 September 2023 12:18
3
short explanation why I request help :
6.1 kernel does not contain module I need for my wifi/bluetooth usb dongle
6.4 kernel contain module, but will be shortly EOL
6.5 is failing since first release 6.5.1
6.6 is failing too
I tried “shutdown -h” (with and without additional parameters, result is the same) in multi-user.target for :
6.1 ok
6.4 ok
6.5 poweroff failed
6.6 poweroff failed
System is fully up-to-date
There is dual boot, using rEFInd, with a windows 10 (dedicated drive)
here are my details (for 6.5):
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: root=UUID=5d3d2c20-d929-4c1d-a7ab-cef2d428eb2e
init=/lib/systemd/systemd systemd.unit=graphical.target rw
resume=UUID=81cc9d6a-fc6c-4078-858d-53856b1a32b5 udev.log_priority=3
nvidia-drm.modeset=1 initrd=\boot\initramfs-6.5-x86_64.img
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0HD5W2 v: A01 serial: <superuser required> UEFI: Dell
v: 1.24.0 date: 07/14/2022
Info: model: Intel Core i5-6600 bits: 64 type: MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1562 high: 3851 min/max: 800/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 3851
bogomips: 26411
Type: gather_data_sampling status: Vulnerable: No microcode
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4 ports: active: none
off: DP-1,HDMI-A-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:1d01
class-ID: 0300
Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.2.4:11
chip-ID: 045e:0810 class-ID: 0102
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: DP-1 model: Dell U2419H serial: <filter> built: 2021
res: 1920x1080 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 model: Dell P2217 serial: <filter> built: 2017
res: 1680x1050 dpi: 90 gamma: 1.2 size: 474x296mm (18.66x11.65")
diag: 559mm (22") ratio: 16:10 modes: max: 1680x1050 min: 640x480
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
memory: 1.95 GiB display-ID: :0.0
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce GT 1030 driver: nvidia v: 535.113.01
device-ID: 10de:1d01 surfaces: xcb,xlib,wayland
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
Device-3: Plantronics Blackwire C5220 headset (remote control and 3.5mm
audio adapter) driver: plantronics,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.2.2:7 chip-ID: 047f:c053
class-ID: 0300 serial: <filter>
Device-4: GN Netcom Jabra SPEAK 510 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.2.3:9
chip-ID: 0b0e:0420 class-ID: 0300 serial: <filter>
Device-5: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.80 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: bridge1 state: down mac: <filter>
IF-ID-2: bridge2 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
IF-ID-4: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-5: wlp0s20f0u5i2 state: down mac: <filter>
Device-1: Realtek 802.11ac+Bluetooth 5.0 Adapter driver: btusb,rtw_8822bu
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 0bda:b82c class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 1.38 TiB used: 402.41 GiB (28.6%)
ID-1: /dev/sda maj-min: 8:0 model: P3-512 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 810a scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MK5065GSXF
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 8B scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 40WD
scheme: GPT
ID-1: / raw-size: 460 GiB size: 451.71 GiB (98.20%) used: 276.2 GiB (61.1%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 250 MiB size: 249.7 MiB (99.89%)
used: 57.2 MiB (22.9%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 41.0 C pch: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 242 Uptime: 22m wakeups: 0 Memory: total: 16 GiB
available: 15.42 GiB used: 3.2 GiB (20.8%) Init: systemd v: 254
Packages: 2058 pm: pacman pkgs: 2047 libs: 534
tools: gnome-software,pamac,yay pm: flatpak pkgs: 8 pm: snap pkgs: 3
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.30
Same issue here with similar maschine. No kernel above 6.4 works for me.
buzzer
10 October 2023 07:29
5
Hello,
there is a thread on archlinux and reddit .
it seems issue occurs only on Dell Optiplex …
buzzer
31 October 2023 06:12
6
Perhaps the solution solution
commit 0c1773bf8f386a8e34ce1da6d2c2923aa06299e1
Author: Linus Torvalds torvalds@linux-foundation.org
Date: Sun Oct 15 12:02:02 2023 -0700
https://cdn.kernel.org/pub/linux/kernel/v6.x/ChangeLog-6.5.8
buzzer
31 October 2023 08:32
7
same for kernel 6.6, revertion correct the issue.
subject closed !
system
Closed
2 November 2023 22:33
8
