Ok i tried myself on my older laptop:
$ inxi -Fazy
Kernel: 5.9.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=f0ad847f-8932-4873-8ad4-28586960d434 rw quiet udev.log_priority=3
resume=UUID=f0ad847f-8932-4873-8ad4-28586960d434 resume_offset=1273856..
video=eDP1:1366x768@60.02
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 80G0 v: Lenovo G50-30 serial: <filter>
Chassis: type: 10 v: Lenovo G50-30 serial: <filter>
Mobo: LENOVO model: Lancer 5A6 v: SDK0F82993WIN serial: <filter>
UEFI: LENOVO v: A7CN48WW date: 08/03/2015
ID-1: BAT0 charge: 39.1 Wh condition: 71.0/72.0 Wh (99%) volts: 15.5/14.4
model: Lenovo type: Unknown serial: <filter> status: Discharging
Info: Dual Core model: Intel Celeron N2830 bits: 64 type: MCP
arch: Silvermont family: 6 model-id: 37 (55) stepping: 8 microcode: 838
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 8671
Speed: 1406 MHz min/max: 500/2416 MHz Core speeds (MHz): 1: 2023 2: 2062
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0f31
Device-2: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus ID: 1-4.1:3
chip ID: 5986:0652 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 20.2.2
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:0f04
Sound Server: ALSA v: k5.9.10-1-MANJARO
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lenovo Z50-75 driver: rtl8723be v: kernel port: 2000 bus ID: 02:00.0
chip ID: 10ec:b723
vendor: Lenovo driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 298.09 GiB used: 73.60 GiB (24.7%)
ID-1: /dev/sda vendor: Seagate model: ST320LT012-1DG14C size: 298.09 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LVM1 scheme: GPT
ID-1: / raw size: 249.26 GiB size: 244.35 GiB (98.03%)
used: 51.20 GiB (21.0%) fs: ext4 dev: /dev/sda5
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 9.77 GiB used: 8.6 MiB (0.1%) priority: -2
file: /swapfile
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 188 Uptime: 1h 19m Memory: 3.73 GiB used: 2.39 GiB (64.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 10
Xorg.0.log
$ cat /var/log/Xorg.0.log
[ 3183.283]
X.Org X Server 1.20.9
[ 3183.283] Build Operating System: Linux Manjaro Linux
[ 3183.283] Current Operating System: Linux Lenovo-G50-30 5.9.10-1-MANJARO #1 SMP PREEMPT Sun Nov 22 11:25:19 UTC 2020 x86_64
[ 3183.283] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=f0ad847f-8932-4873-8ad4-28586960d434 rw quiet udev.log_priority=3 resume=UUID=f0ad847f-8932-4873-8ad4-28586960d434 resume_offset=1273856.. video=eDP1:1366x768@60.02
[ 3183.283] Build Date: 20 November 2020 09:03:19PM
[ 3183.283]
[ 3183.283] Current version of pixman: 0.40.0
[ 3183.284] Before reporting problems, check http://wiki.x.org
[ 3183.284] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3183.284] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 24 12:37:35 2020
[ 3183.284] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3183.284] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3183.285] (==) No Layout section. Using the first Screen section.
[ 3183.285] (==) No screen section available. Using defaults.
[ 3183.285] (**) |-->Screen "Default Screen Section" (0)
[ 3183.285] (**) | |-->Monitor "<default monitor>"
[ 3183.286] (==) No monitor specified for screen "Default Screen Section".
[ 3183.286] (==) Automatically adding devices
[ 3183.286] (==) Automatically enabling devices
[ 3183.286] (==) Automatically adding GPU devices
[ 3183.286] (==) Automatically binding GPU devices
[ 3183.286] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3183.286] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 3183.286] Entry deleted from font path.
[ 3183.286] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 3183.286] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 3183.286] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 3183.286] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 3183.286] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3183.286] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3183.286] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3183.286] (==) FontPath set to:
[ 3183.287] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3183.287] (II) The server relies on udev to provide the list of input devices.
[ 3183.287] (II) Module ABI versions:
[ 3183.287] X.Org ANSI C Emulation: 0.4
[ 3183.287] X.Org Video Driver: 24.1
[ 3183.287] X.Org XInput driver : 24.1
[ 3183.287] X.Org Server Extension : 10.0
[ 3183.290] (++) using VT number 7
[ 3183.290] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3183.295] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3183.316] (--) PCI:*(0@0:2:0) 8086:0f31:17aa:3905 rev 14, Mem @ 0x90000000/4194304, 0x80000000/268435456, I/O @ 0x00003050/8, BIOS @ 0x????????/131072
[ 3183.316] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3183.316] (II) LoadModule: "glx"
[ 3183.317] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3183.337] (II) Module glx: vendor="X.Org Foundation"
[ 3183.337] compiled for 1.20.9, module version = 1.0.0
[ 3183.337] ABI class: X.Org Server Extension, version 10.0
[ 3183.337] (==) Matched intel as autoconfigured driver 0
[ 3183.337] (==) Matched modesetting as autoconfigured driver 1
[ 3183.337] (==) Matched fbdev as autoconfigured driver 2
[ 3183.337] (==) Matched vesa as autoconfigured driver 3
[ 3183.337] (==) Assigned the driver to the xf86ConfigLayout
[ 3183.337] (II) LoadModule: "intel"
[ 3183.338] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3183.338] (II) Module intel: vendor="X.Org Foundation"
[ 3183.338] compiled for 1.20.9, module version = 2.99.917
[ 3183.339] Module class: X.Org Video Driver
[ 3183.339] ABI class: X.Org Video Driver, version 24.1
[ 3183.339] (II) LoadModule: "modesetting"
[ 3183.339] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3183.364] (II) Module modesetting: vendor="X.Org Foundation"
[ 3183.364] compiled for 1.20.9, module version = 1.20.9
[ 3183.364] Module class: X.Org Video Driver
[ 3183.364] ABI class: X.Org Video Driver, version 24.1
[ 3183.364] (II) LoadModule: "fbdev"
[ 3183.364] (WW) Warning, couldn't open module fbdev
[ 3183.364] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3183.364] (II) LoadModule: "vesa"
[ 3183.365] (WW) Warning, couldn't open module vesa
[ 3183.365] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3183.365] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 3183.366] (II) intel: Driver for Intel(R) HD Graphics
[ 3183.366] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 3183.366] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 3183.366] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3183.385] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200715
[ 3183.385] (II) intel(0): SNA compiled from 2.99.917-912-gad5540f6
[ 3183.402] (WW) Falling back to old probe method for modesetting
[ 3183.402] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[ 3183.402] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2; using a maximum of 2 threads
[ 3183.402] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 3183.403] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 3183.403] (==) intel(0): RGB weight 888
[ 3183.403] (==) intel(0): Default visual is TrueColor
[ 3183.404] (II) intel(0): Output eDP1 has no monitor section
[ 3183.404] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 3183.404] (II) intel(0): Enabled output eDP1
[ 3183.405] (II) intel(0): Output VGA1 has no monitor section
[ 3183.405] (II) intel(0): Enabled output VGA1
[ 3183.405] (II) intel(0): Output DP1 has no monitor section
[ 3183.405] (II) intel(0): Enabled output DP1
[ 3183.406] (II) intel(0): Output HDMI1 has no monitor section
[ 3183.406] (II) intel(0): Enabled output HDMI1
[ 3183.406] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 3183.406] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 3183.406] (II) intel(0): Enabled output VIRTUAL1
[ 3183.406] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 3183.407] (==) intel(0): TearFree disabled
[ 3183.407] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3183.407] (==) intel(0): DPI set to (96, 96)
[ 3183.407] (II) Loading sub module "dri3"
[ 3183.407] (II) LoadModule: "dri3"
[ 3183.407] (II) Module "dri3" already built-in
[ 3183.407] (II) Loading sub module "dri2"
[ 3183.407] (II) LoadModule: "dri2"
[ 3183.407] (II) Module "dri2" already built-in
[ 3183.407] (II) Loading sub module "present"
[ 3183.407] (II) LoadModule: "present"
[ 3183.407] (II) Module "present" already built-in
[ 3183.407] (II) UnloadModule: "modesetting"
[ 3183.407] (II) Unloading modesetting
[ 3183.408] (II) intel(0): SNA initialized with Baytrail (gen7) backend
[ 3183.408] (==) intel(0): Backing store enabled
[ 3183.408] (==) intel(0): Silken mouse disabled
[ 3183.408] (II) intel(0): HW Cursor enabled
[ 3183.409] (==) intel(0): DPMS enabled
[ 3183.409] (==) intel(0): Display hotplug detection enabled
[ 3183.409] (II) intel(0): [DRI2] Setup complete
[ 3183.409] (II) intel(0): [DRI2] DRI driver: i965
[ 3183.409] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 3183.410] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 3183.410] (II) intel(0): hardware support for Present enabled
[ 3183.410] (II) Initializing extension Generic Event Extension
[ 3183.410] (II) Initializing extension SHAPE
[ 3183.410] (II) Initializing extension MIT-SHM
[ 3183.411] (II) Initializing extension XInputExtension
[ 3183.411] (II) Initializing extension XTEST
[ 3183.419] (II) Initializing extension BIG-REQUESTS
[ 3183.420] (II) Initializing extension SYNC
[ 3183.420] (II) Initializing extension XKEYBOARD
[ 3183.420] (II) Initializing extension XC-MISC
[ 3183.421] (II) Initializing extension SECURITY
[ 3183.421] (II) Initializing extension XFIXES
[ 3183.421] (II) Initializing extension RENDER
[ 3183.422] (II) Initializing extension RANDR
[ 3183.422] (II) Initializing extension COMPOSITE
[ 3183.423] (II) Initializing extension DAMAGE
[ 3183.423] (II) Initializing extension MIT-SCREEN-SAVER
[ 3183.423] (II) Initializing extension DOUBLE-BUFFER
[ 3183.424] (II) Initializing extension RECORD
[ 3183.424] (II) Initializing extension DPMS
[ 3183.428] (II) Initializing extension Present
[ 3183.428] (II) Initializing extension DRI3
[ 3183.429] (II) Initializing extension X-Resource
[ 3183.429] (II) Initializing extension XVideo
[ 3183.430] (II) Initializing extension XVideo-MotionCompensation
[ 3183.430] (II) Initializing extension GLX
[ 3183.482] (II) AIGLX: Loaded and initialized i965
[ 3183.482] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 3183.483] (II) Initializing extension XFree86-VidModeExtension
[ 3183.483] (II) Initializing extension XFree86-DGA
[ 3183.483] (II) Initializing extension XFree86-DRI
[ 3183.483] (II) Initializing extension DRI2
[ 3183.504] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 3183.510] (II) intel(0): Setting screen physical size to 361 x 203
[ 3183.682] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 3183.682] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3183.682] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3183.682] (**) Power Button: Applying InputClass "system-keyboard"
[ 3183.682] (II) LoadModule: "libinput"
[ 3183.682] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3183.688] (II) Module libinput: vendor="X.Org Foundation"
[ 3183.689] compiled for 1.20.8, module version = 0.30.0
[ 3183.689] Module class: X.Org XInput Driver
[ 3183.689] ABI class: X.Org XInput driver, version 24.1
[ 3183.689] (II) Using input driver 'libinput' for 'Power Button'
[ 3183.689] (**) Power Button: always reports core events
[ 3183.689] (**) Option "Device" "/dev/input/event2"
[ 3183.689] (**) Option "_source" "server/udev"
[ 3183.694] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 3183.694] (II) event2 - Power Button: device is a keyboard
[ 3183.695] (II) event2 - Power Button: device removed
[ 3183.715] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 3183.715] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3183.715] (**) Option "xkb_model" "pc105"
[ 3183.715] (**) Option "xkb_layout" "de"
[ 3183.715] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.805] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 3183.805] (II) event2 - Power Button: device is a keyboard
[ 3183.807] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 3183.807] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 3183.807] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 3183.807] (**) Video Bus: Applying InputClass "system-keyboard"
[ 3183.807] (II) Using input driver 'libinput' for 'Video Bus'
[ 3183.807] (**) Video Bus: always reports core events
[ 3183.807] (**) Option "Device" "/dev/input/event3"
[ 3183.807] (**) Option "_source" "server/udev"
[ 3183.810] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 3183.810] (II) event3 - Video Bus: device is a keyboard
[ 3183.811] (II) event3 - Video Bus: device removed
[ 3183.838] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3/event3"
[ 3183.838] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 3183.838] (**) Option "xkb_model" "pc105"
[ 3183.838] (**) Option "xkb_layout" "de"
[ 3183.838] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.842] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 3183.842] (II) event3 - Video Bus: device is a keyboard
[ 3183.844] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3183.844] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3183.844] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3183.844] (**) Power Button: Applying InputClass "system-keyboard"
[ 3183.844] (II) Using input driver 'libinput' for 'Power Button'
[ 3183.844] (**) Power Button: always reports core events
[ 3183.844] (**) Option "Device" "/dev/input/event1"
[ 3183.844] (**) Option "_source" "server/udev"
[ 3183.847] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3183.847] (II) event1 - Power Button: device is a keyboard
[ 3183.847] (II) event1 - Power Button: device removed
[ 3183.858] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 3183.858] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 3183.858] (**) Option "xkb_model" "pc105"
[ 3183.858] (**) Option "xkb_layout" "de"
[ 3183.858] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.861] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3183.862] (II) event1 - Power Button: device is a keyboard
[ 3183.864] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 3183.864] (II) No input driver specified, ignoring this device.
[ 3183.864] (II) This device may have been added with another device file.
[ 3183.867] (II) config/udev: Adding input device Lenovo EasyCamera: Lenovo EasyC (/dev/input/event10)
[ 3183.867] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "evdev keyboard catchall"
[ 3183.868] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "libinput keyboard catchall"
[ 3183.868] (**) Lenovo EasyCamera: Lenovo EasyC: Applying InputClass "system-keyboard"
[ 3183.868] (II) Using input driver 'libinput' for 'Lenovo EasyCamera: Lenovo EasyC'
[ 3183.868] (**) Lenovo EasyCamera: Lenovo EasyC: always reports core events
[ 3183.868] (**) Option "Device" "/dev/input/event10"
[ 3183.868] (**) Option "_source" "server/udev"
[ 3183.879] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[ 3183.879] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[ 3183.880] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device removed
[ 3183.905] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.0/input/input11/event10"
[ 3183.905] (II) XINPUT: Adding extended input device "Lenovo EasyCamera: Lenovo EasyC" (type: KEYBOARD, id 9)
[ 3183.905] (**) Option "xkb_model" "pc105"
[ 3183.905] (**) Option "xkb_layout" "de"
[ 3183.905] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.910] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: is tagged by udev as: Keyboard
[ 3183.910] (II) event10 - Lenovo EasyCamera: Lenovo EasyC: device is a keyboard
[ 3183.911] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event8)
[ 3183.911] (II) No input driver specified, ignoring this device.
[ 3183.911] (II) This device may have been added with another device file.
[ 3183.913] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event6)
[ 3183.913] (II) No input driver specified, ignoring this device.
[ 3183.913] (II) This device may have been added with another device file.
[ 3183.914] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event7)
[ 3183.914] (II) No input driver specified, ignoring this device.
[ 3183.914] (II) This device may have been added with another device file.
[ 3183.919] (II) config/udev: Adding input device Ideapad extra buttons (/dev/input/event5)
[ 3183.919] (**) Ideapad extra buttons: Applying InputClass "evdev keyboard catchall"
[ 3183.919] (**) Ideapad extra buttons: Applying InputClass "libinput keyboard catchall"
[ 3183.919] (**) Ideapad extra buttons: Applying InputClass "system-keyboard"
[ 3183.919] (II) Using input driver 'libinput' for 'Ideapad extra buttons'
[ 3183.919] (**) Ideapad extra buttons: always reports core events
[ 3183.920] (**) Option "Device" "/dev/input/event5"
[ 3183.920] (**) Option "_source" "server/udev"
[ 3183.926] (II) event5 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 3183.926] (II) event5 - Ideapad extra buttons: device is a keyboard
[ 3183.927] (II) event5 - Ideapad extra buttons: device removed
[ 3183.955] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input6/event5"
[ 3183.955] (II) XINPUT: Adding extended input device "Ideapad extra buttons" (type: KEYBOARD, id 10)
[ 3183.955] (**) Option "xkb_model" "pc105"
[ 3183.955] (**) Option "xkb_layout" "de"
[ 3183.955] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.958] (II) event5 - Ideapad extra buttons: is tagged by udev as: Keyboard
[ 3183.958] (II) event5 - Ideapad extra buttons: device is a keyboard
[ 3183.960] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 3183.960] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 3183.960] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 3183.960] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 3183.961] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 3183.961] (**) AT Translated Set 2 keyboard: always reports core events
[ 3183.961] (**) Option "Device" "/dev/input/event4"
[ 3183.961] (**) Option "_source" "server/udev"
[ 3183.968] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3183.968] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 3183.969] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 3183.985] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 3183.985] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[ 3183.985] (**) Option "xkb_model" "pc105"
[ 3183.985] (**) Option "xkb_layout" "de"
[ 3183.985] (**) Option "xkb_variant" "nodeadkeys"
[ 3183.989] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3183.989] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 3183.992] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event9)
[ 3183.992] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 3183.992] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 3183.993] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 3183.993] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 3183.993] (**) Option "Device" "/dev/input/event9"
[ 3183.993] (**) Option "_source" "server/udev"
[ 3184.000] (II) event9 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 3184.010] (II) event9 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 3184.010] (II) event9 - SynPS/2 Synaptics TouchPad: device removed
[ 3184.039] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event9"
[ 3184.039] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
[ 3184.040] (**) Option "AccelerationScheme" "none"
[ 3184.040] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 3184.040] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 3184.040] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 3184.044] (II) event9 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 3184.047] (II) event9 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 3184.053] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 3184.053] (II) No input driver specified, ignoring this device.
[ 3184.053] (II) This device may have been added with another device file.
[ 3185.410] (II) intel(0): EDID vendor "AUO", prod id 16620
[ 3185.410] (II) intel(0): Printing DDC gathered Modelines:
[ 3185.410] (II) intel(0): Modeline "1366x768"x0.0 76.30 1366 1374 1384 1558 768 771 772 816 -hsync -vsync (49.0 kHz eP)
Here it works like it should.
