Kwin and window tilling shortcuts stopped working after bluetooth headphones connected. I was using monjaro with headphones daily for few month and now it just stopped working. I tried reinstalling Bluetooth it doesnt help.
Kernel: 6.5.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=2d31c364-dbae-44b2-a4d5-96e4374ca7af rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Micro-Star product: GL65 Leopard 10SER v: REV:1.0
Mobo: Micro-Star model: MS-16U7 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U7IMS.10A date: 07/17/2020
ID-1: BAT1 charge: 39.8 Wh (99.0%) condition: 40.2/51.6 Wh (78.1%)
volts: 12.0 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: charging
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 70421
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 535.129.03 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:4 chip-ID: 04f2:b695
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x80ed built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6 vendor: intel mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
es-v: 3.2 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 15.08 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.129.03
device-ID: 10de:1f15 surfaces: xcb,xlib
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.5.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.85 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 72.58 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.8 temp: 45.9 C
scheme: GPT
ID-1: / raw-size: 99.12 GiB size: 97.26 GiB (98.12%) used: 72.55 GiB (74.6%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 25.7 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 61.0 C pch: 56.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 324 Uptime: 20m wakeups: 0 Memory: total: 16 GiB
available: 15.44 GiB used: 3.66 GiB (23.7%) Init: systemd v: 254
Packages: 1425 pm: pacman pkgs: 1401 libs: 398 tools: pamac pm: flatpak
pkgs: 9 pm: snap pkgs: 15 Shell: Zsh v: 5.9 default: Bash v: 5.2.15
running-in: konsole inxi: 3.3.31
kglobalshortcutsrc config file
[$Version]
update_info=bismuth_shortcuts_category.upd:bismuth-shortcuts-category,bismuth_shortcuts_from_kwin.upd:bismuth-shortcuts-from-kwin
[ActivityManager]
_k_friendly_name=Activity Manager
switch-to-activity-608101c3-482f-4495-a9c2-da0aca7ca58c=none,none,Switch to activity "Default"
[KDE Keyboard Layout Switcher]
Switch keyboard layout to Chinese=none,none,Switch keyboard layout to Chinese
Switch keyboard layout to English (UK)=none,none,Switch keyboard layout to English (UK)
Switch keyboard layout to English (US)=none,none,Switch keyboard layout to English (US)
Switch keyboard layout to Hanyu Pinyin Letters (with AltGr dead keys)=none,none,Switch keyboard layout to Hanyu Pinyin Letters (with AltGr dead keys)
Switch keyboard layout to Russian=none,none,Switch keyboard layout to Russian
Switch to Next Keyboard Layout=none,none,Switch to Next Keyboard Layout
_k_friendly_name=Keyboard Layout Switcher
[bismuth]
_k_friendly_name=Window Tiling
decrease_master_size=none,none,Decrease Master Area Size
decrease_master_win_count=Meta+[,Meta+[,Decrease Master Area Window Count
decrease_window_height=Meta+Ctrl+K,Meta+Ctrl+K,Decrease Window Height
decrease_window_width=Meta+Ctrl+H,Meta+Ctrl+H,Decrease Window Width
focus_bottom_window=Meta+J,Meta+J,Focus Bottom Window
focus_left_window=Meta+H,Meta+H,Focus Left Window
focus_next_window=Alt+D,none,Focus Next Window
focus_prev_window=Alt+A,none,Focus Previous Window
focus_right_window=none,Meta+L,Focus Right Window
focus_upper_window=Meta+K,Meta+K,Focus Upper Window
increase_master_size=none,none,Increase Master Area Size
increase_master_win_count=Meta+],Meta+],Increase Master Area Window Count
increase_window_height=Meta+Ctrl+J,Meta+Ctrl+J,Increase Window Height
increase_window_width=Meta+Ctrl+L,Meta+Ctrl+L,Increase Window Width
move_window_to_bottom_pos=Meta+Shift+J,Meta+Shift+J,Move Window Down
move_window_to_left_pos=Meta+Shift+H,Meta+Shift+H,Move Window Left
move_window_to_next_pos=none,none,Move Window to the Next Position
move_window_to_prev_pos=none,none,Move Window to the Previous Position
move_window_to_right_pos=Meta+Shift+L,Meta+Shift+L,Move Window Right
move_window_to_upper_pos=Meta+Shift+K\tAlt+3,Meta+Shift+K,Move Window Up
next_layout=Meta+\\\\,Meta+\\\\,Switch to the Next Layout
prev_layout=Meta+|,Meta+|,Switch to the Previous Layout
push_window_to_master=Meta+Return\tAlt+E,Meta+Return,Push Active Window to Master Area
rotate=Meta+R,Meta+R,Rotate
rotate_part=Meta+Shift+R,Meta+Shift+R,Rotate Part
rotate_reverse=none,none,Rotate (Reverse)
toggle_float_layout=Meta+Shift+F,Meta+Shift+F,Toggle Floating Layout
toggle_monocle_layout=none,Meta+M,Toggle Monocle Layout
toggle_quarter_layout=none,none,Toggle Quarter Layout
toggle_spiral_layout=none,none,Toggle Spiral Layout
toggle_spread_layout=none,none,Toggle Spread Layout
toggle_stair_layout=none,none,Toggle Stair Layout
toggle_three_column_layout=none,none,Toggle Three Column Layout
toggle_tile_layout=none,Meta+T,Toggle Tile Layout
toggle_window_floating=Meta+F,Meta+F,Toggle Active Window Floating
[kaccess]
Toggle Screen Reader On and Off=Meta+Alt+S,Meta+Alt+S,Toggle Screen Reader On and Off
_k_friendly_name=Accessibility
[kcm_touchpad]
Disable Touchpad=Touchpad Off,Touchpad Off,Disable Touchpad
Enable Touchpad=Touchpad On,Touchpad On,Enable Touchpad
Toggle Touchpad=Touchpad Toggle,Touchpad Toggle,Toggle Touchpad
_k_friendly_name=Touchpad
[kded5]
Show System Activity=Ctrl+Esc,Ctrl+Esc,Show System Activity
_k_friendly_name=KDE Daemon
display=Display\tMeta+P,Display\tMeta+P,Switch Display
[khotkeys]
_k_friendly_name=Custom Shortcuts Service
{d03619b6-9b3c-48cc-9d9c-a2aadb485550}=none,none,Search
[kmix]
_k_friendly_name=Audio Volume
decrease_microphone_volume=Microphone Volume Down,Microphone Volume Down,Decrease Microphone Volume
decrease_volume=Volume Down,Volume Down,Decrease Volume
increase_microphone_volume=Microphone Volume Up,Microphone Volume Up,Increase Microphone Volume
increase_volume=Volume Up,Volume Up,Increase Volume
mic_mute=Microphone Mute\tMeta+Volume Mute,Microphone Mute\tMeta+Volume Mute,Mute Microphone
mute=Volume Mute,Volume Mute,Mute
[ksmserver]
Halt Without Confirmation=none,none,Halt Without Confirmation
Lock Session=Meta+L\tScreensaver,Meta+L\tScreensaver,Lock Session
Log Out=Ctrl+Alt+Del,Ctrl+Alt+Del,Log Out
Log Out Without Confirmation=none,none,Log Out Without Confirmation
Reboot Without Confirmation=none,none,Reboot Without Confirmation
_k_friendly_name=ksmserver
[kwin]
Activate Window Demanding Attention=Meta+Ctrl+A,Meta+Ctrl+A,Activate Window Demanding Attention
Better Quick Tiles Center=none,none,Better Quick Tiles Center
Better Quick Tiles Down Center=none,none,Better Quick Tiles Down Center
Better Quick Tiles Down Left=none,none,Better Quick Tiles Down Left
Better Quick Tiles Down Right=none,none,Better Quick Tiles Down Right
Better Quick Tiles Left=none,none,Better Quick Tiles Left
Better Quick Tiles Right=none,none,Better Quick Tiles Right
Better Quick Tiles Up Center=none,none,Better Quick Tiles Up Center
Better Quick Tiles Up Left=none,none,Better Quick Tiles Up Left
Better Quick Tiles Up Right=none,none,Better Quick Tiles Up Right
Decrease Opacity=none,none,Decrease Opacity of Active Window by 5%
Edit Tiles=Meta+T,Meta+T,Toggle Tiles Editor
Expose=Ctrl+F9,Ctrl+F9,Toggle Present Windows (Current desktop)
ExposeAll=Ctrl+F10\tLaunch (C),Ctrl+F10\tLaunch (C),Toggle Present Windows (All desktops)
ExposeClass=Ctrl+F7,Ctrl+F7,Toggle Present Windows (Window class)
ExposeClassCurrentDesktop=none,none,Toggle Present Windows (Window class on current desktop)
Exquisite=none,none,Exquisite
Increase Opacity=none,none,Increase Opacity of Active Window by 5%
Invert=Meta+Ctrl+I,Meta+Ctrl+I,Toggle Invert Effect
Invert Screen Colors=none,none,Invert Screen Colors
InvertWindow=Meta+Ctrl+U,Meta+Ctrl+U,Toggle Invert Effect on Window
Kill Window=Meta+Ctrl+Del,Meta+Ctrl+Esc,Kill Window
Krohnkite: Cycle Layout=none,none,
Krohnkite: Decrease=none,none,
Krohnkite: Down/Next=none,none,
Krohnkite: Float=none,none,
Krohnkite: Float All=none,none,
Krohnkite: Floating Layout=none,none,
Krohnkite: Grow Height=none,none,
Krohnkite: Grow Width=none,none,
Krohnkite: Increase=none,none,
Krohnkite: Left=none,none,
Krohnkite: Monocle Layout=none,none,
Krohnkite: Move Down/Next=none,none,
Krohnkite: Move Left=none,none,
Krohnkite: Move Right=none,none,
Krohnkite: Move Up/Prev=none,none,
Krohnkite: Next Layout=none,none,
Krohnkite: Previous Layout=none,none,
Krohnkite: Quarter Layout=none,none,
Krohnkite: Right=none,none,
Krohnkite: Rotate=none,none,
Krohnkite: Rotate Part=none,none,
Krohnkite: Set master=none,none,
Krohnkite: Shrink Height=none,none,
Krohnkite: Shrink Width=none,none,
Krohnkite: Spread Layout=none,none,
Krohnkite: Stair Layout=none,none,
Krohnkite: Three Column Layout=none,none,
Krohnkite: Tile Layout=none,none,
Krohnkite: Up/Prev=none,none,
MoveMouseToCenter=Meta+F6,Meta+F6,Move Mouse to Center
MoveMouseToFocus=Meta+F5,Meta+F5,Move Mouse to Focus
MoveZoomDown=none,none,Move Zoomed Area Downwards
MoveZoomLeft=none,none,Move Zoomed Area to Left
MoveZoomRight=none,none,Move Zoomed Area to Right
MoveZoomUp=none,none,Move Zoomed Area Upwards
Overview=Meta+W,Meta+W,Toggle Overview
Setup Window Shortcut=none,none,Setup Window Shortcut
Show Desktop=Alt+S\tMeta+D,Meta+D,Peek at Desktop
ShowDesktopGrid=Meta+F8,Meta+F8,Show Desktop Grid
Suspend Compositing=Alt+Shift+F12,Alt+Shift+F12,Suspend Compositing
Switch One Desktop Down=none,Meta+Ctrl+Down,Switch One Desktop Down
Switch One Desktop Up=none,Meta+Ctrl+Up,Switch One Desktop Up
Switch One Desktop to the Left=none,Meta+Ctrl+Left,Switch One Desktop to the Left
Switch One Desktop to the Right=none,Meta+Ctrl+Right,Switch One Desktop to the Right
Switch Window Down=Meta+Alt+Down,Meta+Alt+Down,Switch to Window Below
Switch Window Left=Meta+Alt+Left,Meta+Alt+Left,Switch to Window to the Left
Switch Window Right=Meta+Alt+Right,Meta+Alt+Right,Switch to Window to the Right
Switch Window Up=Meta+Alt+Up,Meta+Alt+Up,Switch to Window Above
Switch to Desktop 1=Meta+F1,Ctrl+F1,Switch to Desktop 1
Switch to Desktop 10=Meta+F10,none,Switch to Desktop 10
Switch to Desktop 11=none,none,Switch to Desktop 11
Switch to Desktop 12=none,none,Switch to Desktop 12
Switch to Desktop 13=none,none,Switch to Desktop 13
Switch to Desktop 14=none,none,Switch to Desktop 14
Switch to Desktop 15=none,none,Switch to Desktop 15
Switch to Desktop 16=none,none,Switch to Desktop 16
Switch to Desktop 17=none,none,Switch to Desktop 17
Switch to Desktop 18=none,none,Switch to Desktop 18
Switch to Desktop 19=none,none,Switch to Desktop 19
Switch to Desktop 2=Meta+F2,Ctrl+F2,Switch to Desktop 2
Switch to Desktop 20=none,none,Switch to Desktop 20
Switch to Desktop 3=Meta+F3,Ctrl+F3,Switch to Desktop 3
Switch to Desktop 4=Meta+F4,Ctrl+F4,Switch to Desktop 4
Switch to Desktop 5=none,none,Switch to Desktop 5
Switch to Desktop 6=none,none,Switch to Desktop 6
Switch to Desktop 7=Meta+F7,none,Switch to Desktop 7
Switch to Desktop 8=none,none,Switch to Desktop 8
Switch to Desktop 9=Meta+F9,none,Switch to Desktop 9
Switch to Next Desktop=none,none,Switch to Next Desktop
Switch to Next Screen=none,none,Switch to Next Screen
Switch to Previous Desktop=none,none,Switch to Previous Desktop
Switch to Previous Screen=none,none,Switch to Previous Screen
Switch to Screen 0=none,none,Switch to Screen 0
Switch to Screen 1=none,none,Switch to Screen 1
Switch to Screen 2=none,none,Switch to Screen 2
Switch to Screen 3=none,none,Switch to Screen 3
Switch to Screen 4=none,none,Switch to Screen 4
Switch to Screen 5=none,none,Switch to Screen 5
Switch to Screen 6=none,none,Switch to Screen 6
Switch to Screen 7=none,none,Switch to Screen 7
Switch to Screen Above=none,none,Switch to Screen Above
Switch to Screen Below=none,none,Switch to Screen Below
Switch to Screen to the Left=none,none,Switch to Screen to the Left
Switch to Screen to the Right=none,none,Switch to Screen to the Right
Toggle Night Color=none,none,Toggle Night Color
Toggle Window Raise/Lower=none,none,Toggle Window Raise/Lower
Walk Through Desktop List=none,none,Walk Through Desktop List
Walk Through Desktop List (Reverse)=none,none,Walk Through Desktop List (Reverse)
Walk Through Desktops=none,none,Walk Through Desktops
Walk Through Desktops (Reverse)=none,none,Walk Through Desktops (Reverse)
Walk Through Windows=Alt+Tab,Alt+Tab,Walk Through Windows
Walk Through Windows (Reverse)=Alt+Shift+Tab,Alt+Shift+Backtab,Walk Through Windows (Reverse)
Walk Through Windows Alternative=none,none,Walk Through Windows Alternative
Walk Through Windows Alternative (Reverse)=none,none,Walk Through Windows Alternative (Reverse)
Walk Through Windows of Current Application=Alt+`,Alt+`,Walk Through Windows of Current Application
Walk Through Windows of Current Application (Reverse)=Alt+~,Alt+~,Walk Through Windows of Current Application (Reverse)
Walk Through Windows of Current Application Alternative=none,none,Walk Through Windows of Current Application Alternative
Walk Through Windows of Current Application Alternative (Reverse)=none,none,Walk Through Windows of Current Application Alternative (Reverse)
Window Above Other Windows=none,none,Keep Window Above Others
Window Below Other Windows=none,none,Keep Window Below Others
Window Close=Alt+Esc,Alt+F4,Close Window
Window Fullscreen=Alt+R,none,Make Window Fullscreen
Window Grow Horizontal=none,none,Expand Window Horizontally
Window Grow Vertical=Alt+W,none,Expand Window Vertically
Window Lower=none,none,Lower Window
Window Maximize=Alt+F,Meta+PgUp,Maximize Window
Window Maximize Horizontal=Meta+=,none,Maximize Window Horizontally
Window Maximize Vertical=none,none,Maximize Window Vertically
Window Minimize=Alt+C,Meta+PgDown,Minimize Window
Window Move=none,none,Move Window
Window Move Center=none,none,Move Window to the Center
Window No Border=none,none,Toggle Window Titlebar and Frame
Window On All Desktops=none,none,Keep Window on All Desktops
Window One Desktop Down=Meta+Ctrl+Shift+Down,Meta+Ctrl+Shift+Down,Window One Desktop Down
Window One Desktop Up=Meta+Ctrl+Shift+Up,Meta+Ctrl+Shift+Up,Window One Desktop Up
Window One Desktop to the Left=Meta+Ctrl+Shift+Left,Meta+Ctrl+Shift+Left,Window One Desktop to the Left
Window One Desktop to the Right=Meta+Ctrl+Shift+Right,Meta+Ctrl+Shift+Right,Window One Desktop to the Right
Window One Screen Down=none,none,Window One Screen Down
Window One Screen Up=none,none,Window One Screen Up
Window One Screen to the Left=none,none,Window One Screen to the Left
Window One Screen to the Right=none,none,Window One Screen to the Right
Window Operations Menu=Alt+Menu,Alt+F3,Window Operations Menu
Window Pack Down=none,none,Move Window Down
Window Pack Left=none,none,Move Window Left
Window Pack Right=none,none,Move Window Right
Window Pack Up=none,none,Move Window Up
Window Quick Tile Bottom=Meta+Down,Meta+Down,Quick Tile Window to the Bottom
Window Quick Tile Bottom Left=none,none,Quick Tile Window to the Bottom Left
Window Quick Tile Bottom Right=none,none,Quick Tile Window to the Bottom Right
Window Quick Tile Left=Meta+Left,Meta+Left,Quick Tile Window to the Left
Window Quick Tile Right=Meta+Right,Meta+Right,Quick Tile Window to the Right
Window Quick Tile Top=Meta+Up,Meta+Up,Quick Tile Window to the Top
Window Quick Tile Top Left=none,none,Quick Tile Window to the Top Left
Window Quick Tile Top Right=none,none,Quick Tile Window to the Top Right
Window Raise=none,none,Raise Window
Window Resize=none,none,Resize Window
Window Shade=Meta+_,none,Shade Window
Window Shrink Horizontal=none,none,Shrink Window Horizontally
Window Shrink Vertical=none,none,Shrink Window Vertically
Window to Desktop 1=Meta+Alt+F1,none,Window to Desktop 1
Window to Desktop 10=Meta+Alt+F10,none,Window to Desktop 10
Window to Desktop 11=none,none,Window to Desktop 11
Window to Desktop 12=none,none,Window to Desktop 12
Window to Desktop 13=none,none,Window to Desktop 13
Window to Desktop 14=none,none,Window to Desktop 14
Window to Desktop 15=none,none,Window to Desktop 15
Window to Desktop 16=none,none,Window to Desktop 16
Window to Desktop 17=none,none,Window to Desktop 17
Window to Desktop 18=none,none,Window to Desktop 18
Window to Desktop 19=none,none,Window to Desktop 19
Window to Desktop 2=Meta+Alt+F2,none,Window to Desktop 2
Window to Desktop 20=none,none,Window to Desktop 20
Window to Desktop 3=Meta+Alt+F3,none,Window to Desktop 3
Window to Desktop 4=Meta+Alt+F4,none,Window to Desktop 4
Window to Desktop 5=Meta+Alt+F5,none,Window to Desktop 5
Window to Desktop 6=Meta+Alt+F6,none,Window to Desktop 6
Window to Desktop 7=Meta+Alt+F7,none,Window to Desktop 7
Window to Desktop 8=Meta+Alt+F8,none,Window to Desktop 8
Window to Desktop 9=Meta+Alt+F9,none,Window to Desktop 9
Window to Next Desktop=none,none,Window to Next Desktop
Window to Next Screen=Meta+Shift+Right,Meta+Shift+Right,Window to Next Screen
Window to Previous Desktop=none,none,Window to Previous Desktop
Window to Previous Screen=Meta+Shift+Left,Meta+Shift+Left,Window to Previous Screen
Window to Screen 0=none,none,Window to Screen 0
Window to Screen 1=none,none,Window to Screen 1
Window to Screen 2=none,none,Window to Screen 2
Window to Screen 3=none,none,Window to Screen 3
Window to Screen 4=none,none,Window to Screen 4
Window to Screen 5=none,none,Window to Screen 5
Window to Screen 6=none,none,Window to Screen 6
Window to Screen 7=none,none,Window to Screen 7
_k_friendly_name=KWin
view_actual_size=Meta+0,Meta+0,Zoom to Actual Size
view_zoom_in=Meta++,Meta++,Zoom In
view_zoom_out=Meta+-,Meta+-,Zoom Out
[mediacontrol]
_k_friendly_name=Media Controller
mediavolumedown=none,none,Media volume down
mediavolumeup=none,none,Media volume up
nextmedia=Media Next,Media Next,Media playback next
pausemedia=Media Pause,Media Pause,Pause media playback
playmedia=none,none,Play media playback
playpausemedia=Media Play,Media Play,Play/Pause media playback
previousmedia=Media Previous,Media Previous,Media playback previous
stopmedia=Media Stop,Media Stop,Stop media playback
[org.kde.dolphin.desktop]
_k_friendly_name=Dolphin
_launch=Meta+E,Meta+E,Dolphin
[org.kde.kcalc.desktop]
_k_friendly_name=KCalc
_launch=Launch (1),Launch (1),KCalc
[org.kde.konsole.desktop]
NewTab=none,none,Open a New Tab
NewWindow=none,none,Open a New Window
_k_friendly_name=Konsole
_launch=Ctrl+Alt+T,Ctrl+Alt+T,Konsole
[org.kde.krunner.desktop]
RunClipboard=Alt+Shift+F2,Alt+Shift+F2,Run command on clipboard contents
_k_friendly_name=KRunner
_launch=Alt+Space\tAlt+F2\tSearch,Alt+Space\tAlt+F2\tSearch,KRunner
[org.kde.plasma.emojier.desktop]
_k_friendly_name=Emoji Selector
_launch=Meta+.\tMeta+Ctrl+Alt+Shift+Space,Meta+.\tMeta+Ctrl+Alt+Shift+Space,Emoji Selector
[org.kde.spectacle.desktop]
ActiveWindowScreenShot=Meta+Print,Meta+Print,Capture Active Window
CurrentMonitorScreenShot=none,none,Capture Current Monitor
FullScreenScreenShot=Shift+Print,Shift+Print,Capture Entire Desktop
OpenWithoutScreenshot=none,none,Launch Spectacle without capturing
RectangularRegionScreenShot=Meta+Shift+Print,Meta+Shift+Print,Capture Rectangular Region
WindowUnderCursorScreenShot=Meta+Ctrl+Print,Meta+Ctrl+Print,Capture Window Under Cursor
_k_friendly_name=Spectacle
_launch=Print,Print,Launch Spectacle
[org_kde_powerdevil]
Decrease Keyboard Brightness=Keyboard Brightness Down,Keyboard Brightness Down,Decrease Keyboard Brightness
Decrease Screen Brightness=Monitor Brightness Down,Monitor Brightness Down,Decrease Screen Brightness
Hibernate=Hibernate,Hibernate,Hibernate
Increase Keyboard Brightness=Keyboard Brightness Up,Keyboard Brightness Up,Increase Keyboard Brightness
Increase Screen Brightness=Monitor Brightness Up,Monitor Brightness Up,Increase Screen Brightness
PowerDown=Power Down,Power Down,Power Down
PowerOff=Power Off,Power Off,Power Off
Sleep=Sleep,Sleep,Suspend
Toggle Keyboard Backlight=Keyboard Light On/Off,Keyboard Light On/Off,Toggle Keyboard Backlight
Turn Off Screen=none,none,Turn Off Screen
_k_friendly_name=Power Management
[plasmashell]
_k_friendly_name=Plasma
activate task manager entry 1=Meta+1,Meta+1,Activate Task Manager Entry 1
activate task manager entry 10=none,Meta+0,Activate Task Manager Entry 10
activate task manager entry 2=Meta+2,Meta+2,Activate Task Manager Entry 2
activate task manager entry 3=Meta+3,Meta+3,Activate Task Manager Entry 3
activate task manager entry 4=Meta+4,Meta+4,Activate Task Manager Entry 4
activate task manager entry 5=Meta+5,Meta+5,Activate Task Manager Entry 5
activate task manager entry 6=Meta+6,Meta+6,Activate Task Manager Entry 6
activate task manager entry 7=Meta+7,Meta+7,Activate Task Manager Entry 7
activate task manager entry 8=Meta+8,Meta+8,Activate Task Manager Entry 8
activate task manager entry 9=Meta+9,Meta+9,Activate Task Manager Entry 9
activate widget 125=none,none,Activate Application Launcher Widget
activate widget 148=none,none,Activate Application Launcher Widget
activate widget 217=none,none,Activate Application Launcher Widget
activate widget 249=none,none,Activate Application Launcher Widget
activate widget 299=Alt+F1,none,Activate Application Launcher Widget
activate widget 3=none,none,Activate Application Launcher Widget
activate widget 324=none,none,Activate Application Launcher Widget
activate widget 346=none,none,Activate Application Launcher Widget
activate widget 369=none,none,Activate Application Launcher Widget
activate widget 392=none,none,Activate Application Launcher Widget
activate widget 50=none,none,Activate Simple Menu Widget
activate widget 65=none,none,Activate Application Launcher Widget
clear-history=none,none,Clear Clipboard History
clipboard_action=Meta+Ctrl+X,Meta+Ctrl+X,Automatic Action Popup Menu
cycle-panels=Meta+Alt+P,Meta+Alt+P,Move keyboard focus between panels
cycleNextAction=none,none,Next History Item
cyclePrevAction=none,none,Previous History Item
edit_clipboard=none,none,Edit Contents…
manage activities=Meta+Q,Meta+Q,Show Activity Switcher
next activity=Meta+Tab,Meta+Tab,Walk through activities
previous activity=Meta+Shift+Tab,Meta+Shift+Tab,Walk through activities (Reverse)
repeat_action=Meta+Ctrl+R,Meta+Ctrl+R,Manually Invoke Action on Current Clipboard
show dashboard=Ctrl+F12,Ctrl+F12,Show Desktop
show-barcode=none,none,Show Barcode…
show-on-mouse-pos=Meta+V,Meta+V,Show Items at Mouse Position
stop current activity=Meta+S,Meta+S,Stop Current Activity
switch to next activity=none,none,Switch to Next Activity
switch to previous activity=none,none,Switch to Previous Activity
toggle do not disturb=none,none,Toggle do not disturb
[systemsettings.desktop]
_k_friendly_name=System Settings
_launch=Tools,Tools,System Settings
kcm-kscreen=none,none,Display Configuration
kcm-lookandfeel=none,none,Global Theme
kcm-users=none,none,Users
powerdevilprofilesconfig=none,none,Energy Saving
screenlocker=none,none,Screen Locking
[yakuake]
_k_friendly_name=Yakuake
toggle-window-state=F12,F12,Open/Retract Yakuake
